How does the device receive messages from the parent node when it goes into low power?
Hi, the nordic team
I am working on thread protocol using SDK version 2.9.1.
I use the SED device,My poll is 1000 ms. How can I receive messages from my parent node when my SED device goes into low power?
Here is my code to get into low power:
        if (IS_ENABLED(CONFIG_RAM_POWER_DOWN_LIBRARY)) {
		power_down_unused_ram();
        int err;
        k_timer_init(&led_timer, on_led_timer_expiry, on_led_timer_stop);
	k_timer_init(&provisioning_timer, on_provisioning_timer_expiry, NULL);
	k_work_queue_init(&coap_server_workq);
	k_work_queue_start(&coap_server_workq, coap_server_workq_stack_area,
					K_THREAD_STACK_SIZEOF(coap_server_workq_stack_area),
					COAP_SERVER_WORKQ_PRIORITY, NULL);
	k_work_init(&provisioning_work, activate_provisioning);
        if (IS_ENABLED(CONFIG_OPENTHREAD_MTD_SED)) {
		k_work_init(&poll_change_work,
                        into_low_power_sleeply);
        err = ot_coap_init(&deactivate_provisionig, &on_light_request);
        if (err) {
		LOG_ERR("Could not initialize OpenThread CoAP");
		goto end;
        err = dk_leds_init();
        if (err) {
                LOG_ERR("Cannot init LEDs (err: %d)", err);
                goto end;
        err = dk_buttons_init(button_pressed_callback);
        if (err)
                LOG_ERR("Cannot init buttons (err: %d)", err);
                goto end;
            // 点亮 LED1
        dk_set_led_on(OT_CONNECTION_LED);
        err = restore_network_data();
end:
        return 0;
 //改变poll时间,进入低功耗
static void into_low_power_sleeply(struct k_work *item)
        ARG_UNUSED(item);
        otError error;
	otLinkModeConfig mode;
	struct openthread_context *context = openthread_get_default_context();
	__ASSERT_NO_MSG(context != NULL);
	openthread_api_mutex_lock(context);
	mode = otThreadGetLinkMode(context->instance);
	mode.mRxOnWhenIdle = false;
	error = otThreadSetLinkMode(context->instance, mode);
        otLinkSetPollPeriod(context->instance, OT_POLL_PERIOD);
	openthread_api_mutex_unlock(context);
	if (error != OT_ERROR_NONE) {
		LOG_ERR("Failed to set MLE link mode configuration");
#if IS_ENABLED(CONFIG_PM_DEVICE)
	const struct device *cons = DEVICE_DT_GET(DT_CHOSEN(zephyr_console));
	if (!device_is_ready(cons)) {
		return;
        pm_device_action_run(cons, PM_DEVICE_ACTION_SUSPEND);
        dk_set_led_off(OT_CONNECTION_LED);
        dk_set_led_off(PROVISIONING_LED);
        dk_set_led_off(LIGHT_LED);
    Not sure if I understand the question. When you configure OpenThread as a Sleepy End Device (SED), the stack automatically wakes up every Polling Interval, and sends a 802.15.4 “Data Poll” to its parent, and retrieves any buffered frames. Your application doesn’t need to do anything special
    I would need to know more details about what you want to help.
    Amanda H.
    I'm using the cli example as the leader. When my SED device goes into low power, my leader send commands to SED, but I don't see any processing from the SED device.
    liisa.
  • We would need more details about what you mean by "send commands", and what you expect to "process" from the SED side.
  • Hi,Amanda H
    "send commands" is the leader send "coap get   + ipv6 address  + /lock/state".the "process" is the SED receive the "send commands" to return the lock's state.I mean, it doesn't feel like the SED device is going to automatically fetch the parent  {"Data Poll" to its parent, and retrieves any buffered frames}.
    liisa
  • Hi!
    Amanda is out of office, so I'm replying instead.
    It is automatic process - the SED device needs to be configured with given Polling Interval (e.g. 2 seconds). Internally OpenThread stack will wake up every e.g. 2 seconds and fetch the data from the parent. There is no need for application to do specific things. Of course, application needs to register proper application callbacks for CoAP or UDP Sockets to get notification about reception of IPv6 application packet.
    You may try to increase log's verbosity and maybe sniff frames.
    CONFIG_OPENTHREAD_SOURCES=y
    CONFIG_OPENTHREAD_DEBUG=y
    CONFIG_OPENTHREAD_LOG_LEVEL_INFO=y
    CONFIG_OPENTHREAD_SHELL=y
