Cannot flash my board nrf5340
Hi, I have changed Vdd from 1.8 V to 3.3 V but now I cannot flash anymore my board (nrf5340). This is the output error:
* Executing task: nRF Connect: Flash: AppCore_RHS_SD_UI_v1B/build (active)
Flashing build to 1050081286
-- west flash: rebuilding
ninja: no work to do.
-- west flash: using runner nrfjprog
-- runners.nrfjprog: reset after flashing requested
-- runners.nrfjprog: Flashing file: c:\nordic\myapps\AppCore_RHS_SD_UI_v1B\build\zephyr\zephyr.hex
[error] [ Worker] - An unknown error.
[error] [ Client] - Encountered error -102: Command select_coprocessor executed for 137 milliseconds with result -102
ERROR: Failed when selecting coprocessor APPLICATION
ERROR: JLinkARM DLL reported an error. Try again. If error condition
ERROR: persists, run the same command again with argument --log, contact Nordic
ERROR: Semiconductor and provide the generated log.log file to them.
NOTE: For additional output, try running again with logging enabled (--log).
NOTE: Any generated log error messages will be displayed.
FATAL ERROR: command exited with status 33: nrfjprog --program 'c:\nordic\myapps\AppCore_RHS_SD_UI_v1B\build\zephyr\zephyr.hex' --sectorerase --verify -f NRF53 --coprocessor CP_APPLICATION --snr 1050081286
* The terminal process terminated with exit code: 33.
* Terminal will be reused by tasks, press any key to close it.
I have tried to erase the board but I get this message: Error erasing device. See the Output tab for more details.
What can I do?
Thanks
  • Hi, I didn't change anything else, just the power supply. When I try to return to 1.8 V I get another error. I don't have any other board. This is the output when I use "nrfutil":
    PS C:\nordic\myapps\AppCore_RHS_SD_UI_v1B> .\nrfutil device recover --x-family nrf53
    x Failed to recover 1050081286, Device error: Failed to write DebugPort register 0x08: Unknown Error in J-Link DLL (error code =-1)
    Error: One or more recover tasks failed:
    * 1050081286: Device error: Failed to write DebugPort register 0x08: Unknown Error in J-Link DLL (error code =-1) (Generic)
    PS C:\nordic\myapps\AppCore_RHS_SD_UI_v1B> .\nrfutil device erase --all --x-family nrf53
    x Failed to erase 1050081286, Device error: Failed to write DebugPort register 0x08: Unknown Error in J-Link DLL (error code =-1)
    Error: One or more erase tasks failed:
    Can you show this error?
    Is this output from "nrfutil device" when you used 3.3 V or 1.8 V? Can you show the output also when using other voltage?
    Dejan
  • The output is for 3.3 V. I cannot return to 1.8 V because I get this error:
    PS C:\nordic\myapps\AppCore_RHS_SD_UI_v1B> nrfjprog -f nrf53 --memwr 0x00FF8010 --val 3
    [error] [ Client] - Encountered error -102: Command read_device_info executed for 141 milliseconds with result -102
    [error] [ Client] - Encountered error -102: Command read_memory_descriptors executed for 27 milliseconds with result -102
    Failed to read device memories.
    You sent logs where you used nrfutil for recoovering and erasing only in case of 3.3 V. Can you show the logs of "nrfutil device" when you use 1.8 V instead?
    Dejan
  • Hi, I cannot return to 1.8 V because I get some errors. Before setting 3.3 V (so when I was working with 1.8V), everything was working.
