Cannot flash my board nrf5340
Hi, I have changed Vdd from 1.8 V to 3.3 V but now I cannot flash anymore my board (nrf5340). This is the output error:
* Executing task: nRF Connect: Flash: AppCore_RHS_SD_UI_v1B/build (active)
Flashing build to 1050081286
-- west flash: rebuilding
ninja: no work to do.
-- west flash: using runner nrfjprog
-- runners.nrfjprog: reset after flashing requested
-- runners.nrfjprog: Flashing file: c:\nordic\myapps\AppCore_RHS_SD_UI_v1B\build\zephyr\zephyr.hex
[error] [ Worker] - An unknown error.
[error] [ Client] - Encountered error -102: Command select_coprocessor executed for 137 milliseconds with result -102
ERROR: Failed when selecting coprocessor APPLICATION
ERROR: JLinkARM DLL reported an error. Try again. If error condition
ERROR: persists, run the same command again with argument --log, contact Nordic
ERROR: Semiconductor and provide the generated log.log file to them.
NOTE: For additional output, try running again with logging enabled (--log).
NOTE: Any generated log error messages will be displayed.
FATAL ERROR: command exited with status 33: nrfjprog --program 'c:\nordic\myapps\AppCore_RHS_SD_UI_v1B\build\zephyr\zephyr.hex' --sectorerase --verify -f NRF53 --coprocessor CP_APPLICATION --snr 1050081286
* The terminal process terminated with exit code: 33.
* Terminal will be reused by tasks, press any key to close it.
I have tried to erase the board but I get this message: Error erasing device. See the Output tab for more details.
What can I do?
Thanks
  • Try these things
    `nrfjprog --eraseall`
    `west flash --recover`
    Paste outputs
  • These are the outputs I got in both cases.
    PS C:\nordic\myapps\AppCore_RHS_SD_UI_v1B> nrfjprog --eraseall
    [error] [ Client] - Encountered error -102: Command connect_to_emu_with_snr executed for 557 milliseconds with result -102
    ERROR: Unable to connect to a debugger.
    PS C:\nordic\myapps\AppCore_RHS_SD_UI_v1B\build> west flash --recover
    Using board 1050081286
    -- runners.nrfjprog: Recovering and erasing flash memory for both the network and application cores.
    [error] [ Client] - Encountered error -102: Command enable_coprocessor executed for 168 milliseconds with result -102
    Failed to enable coprocessor with unknown error.
    FATAL ERROR: command exited with status 33: nrfjprog --recover -f NRF53 --coprocessor CP_NETWORK --snr 1050081286
  • Okay, can you collect the log and send the output?
    Or, can you install NRF Connect for Desktop Application --> Under this install Programmer, try to erase all and see the log output. It mentions low voltage or something, then its power supply issue.
    If not, try to change the debugger unit/check for loose connections.
  • [2025-May-20 21:04:26] [debug] --------------------------------------------------------------------------------
    [2025-May-20 21:04:26] [debug] C:\Program Files\Nordic Semiconductor\nrf-command-line-tools\bin\nrfjprog.exe --recover --coprocessor CP_APPLICATION -f NRF53 --snr 1050081286 --log
    [2025-May-20 21:04:26] [debug] nrfjprog version 10.24.2 external
    [2025-May-20 21:04:26] [ info] Load library at C:\Program Files\Nordic Semiconductor\nrf-command-line-tools\bin\nrfjprog.dll.
    [2025-May-20 21:04:26] [ info] Library loaded, loading member functions.
    [2025-May-20 21:04:26] [ info] Member functions succesfully loaded.
    [2025-May-20 21:04:26] [debug] [ Client] - open
    [2025-May-20 21:04:26] [debug] [ Client] - start
    [2025-May-20 21:04:26] [ info] [ Client] - stdout: Jlinkarm nRF Worker ready. Handling sequence 882d2a0f-feca-4e3b-ae70-79af41f2c605.
    [2025-May-20 21:04:26] [trace] [ Client] - Command open executed for 85 milliseconds with result 0
    [2025-May-20 21:04:26] [debug] [ Client] - config
    [2025-May-20 21:04:26] [debug] [SeggerBackend] - Logger sink registered in Segger backend logger
    [2025-May-20 21:04:26] [trace] [ Client] - Command config executed for 14 milliseconds with result 0
    [2025-May-20 21:04:26] [debug] [  JLink] - Logger sink registered in JLink logger
    [2025-May-20 21:04:26] [debug] [  nRF53] - open
    [2025-May-20 21:04:26] [debug] [  nRF53] - just_check_family
    [2025-May-20 21:04:26] [debug] [SeggerBackend] - open_dll
    [2025-May-20 21:04:26] [debug] [SeggerBackend] - No J-Link DLL path was provided. Attempting to auto detect.
    [2025-May-20 21:04:26] [ info] [SeggerBackend] - Load library at C:\Program Files\SEGGER\JLink_V816\JLink_x64.dll.
    [2025-May-20 21:04:26] [ info] [SeggerBackend] - Library loaded, loading member functions.
    [2025-May-20 21:04:26] [ info] [SeggerBackend] - Member functions succesfully loaded.
    [2025-May-20 21:04:26] [debug] [SeggerBackend] - Set batch mode
    [2025-May-20 21:04:26] [debug] [ Client] - enum_emu_snr
    [2025-May-20 21:04:26] [debug] [SeggerBackend] - dll_version
    [2025-May-20 21:04:26] [ info] [SeggerBackend] - Segger dll version 8.16.  loaded.
    [2025-May-20 21:04:26] [trace] [ Worker] - Command open executed for 10 milliseconds with result 0
    [2025-May-20 21:04:26] [debug] [  nRF53] - config
    [2025-May-20 21:04:26] [debug] [SeggerBackend] - enum_emu_snr
    [2025-May-20 21:04:26] [trace] [ Worker] - Command config executed for 7 milliseconds with result 0
    [2025-May-20 21:04:26] [trace] [ Client] - Command enum_emu_con_info executed for 14 milliseconds with result 0
    [2025-May-20 21:04:26] [debug] [ Client] - connect_to_emu_with_snr
    [2025-May-20 21:04:26] [debug] [  nRF53] - enum_emu_con_info
    [2025-May-20 21:04:26] [debug] [SeggerBackend] - is_connected_to_emu
    [2025-May-20 21:04:26] [debug] [SeggerBackend] - enum_emu_con_info
    [2025-May-20 21:04:26] [trace] [ Worker] - Command enum_emu_con_info executed for 5 milliseconds with result 0
    [2025-May-20 21:04:26] [debug] [  nRF53] - connect_to_emu_with_snr
    [2025-May-20 21:04:26] [debug] [SeggerBackend] - connect_to_emu_with_snr
    [2025-May-20 21:04:26] [debug] [SeggerBackend] - ---just_enum_emu_snr
    [2025-May-20 21:04:26] [debug] [SeggerBackend] - ---just_get_num_emus
    [2025-May-20 21:04:26] [debug] [SeggerBackend] - ---just_connect_to_emu_with_snr
    [2025-May-20 21:04:26] [debug] [SeggerBackend] - ---just_connect_to_emu_without_snr
    [2025-May-20 21:04:26] [debug] [SeggerBackend] - Segger logging enabled.
    [2025-May-20 21:04:27] [trace] [  JLink] - Firmware: J-Link OB-nRF5340-NordicSemi compiled Feb 11 2025 17:15:35
    [2025-May-20 21:04:27] [trace] [  JLink] - Hardware: V1.00
    [2025-May-20 21:04:27] [trace] [  JLink] - S/N: 1050081286
    [2025-May-20 21:04:27] [trace] [  JLink] - OEM: SEGGER
    [2025-May-20 21:04:27] [trace] [  JLink] - Feature(s): RDI, FlashBP, FlashDL, JFlash, GDB
    [2025-May-20 21:04:27] [trace] [  JLink] - Bootloader: 2021 May 18
    [2025-May-20 21:04:27] [trace] [  JLink] - USB speed mode: Full speed (12 MBit/s)
    [2025-May-20 21:04:27] [trace] [  JLink] - TELNET listener socket opened on port 19021
    [2025-May-20 21:04:27] [trace] [  JLink] - WEBSRV WEBSRV_Init(): Starting webserver thread(s)
    [2025-May-20 21:04:27] [trace] [  JLink] - WEBSRV Webserver running on local port 19080
    [2025-May-20 21:04:27] [trace] [  JLink] - Looking for J-Link GUI Server exe at: C:\Program Files\SEGGER\JLink_V816\JLinkGUIServer.exe
    [2025-May-20 21:04:27] [trace] [  JLink] - Forking J-Link GUI Server: C:\Program Files\SEGGER\JLink_V816\JLinkGUIServer.exe
    [2025-May-20 21:04:27] [trace] [ Client] - Command connect_to_emu_with_snr executed for 93 milliseconds with result 0
    [2025-May-20 21:04:27] [trace] [  JLink] - J-Link GUI Server info: "J-Link GUI server V8.16 "
    [2025-May-20 21:04:27] [debug] [ Client] - read_connected_emu_snr
    [2025-May-20 21:04:27] [trace] [  JLink] - - 55.235ms returns "O.K."
    [2025-May-20 21:04:27] [trace] [  JLink] - JLINK_HasError()
    [2025-May-20 21:04:27] [trace] [  JLink] - JLINK_Lock()
    [2025-May-20 21:04:27] [trace] [  JLink] - JLINK_ExecCommand("SetRestartOnClose = 0", ...).
    [2025-May-20 21:04:27] [trace] [  JLink] - - 0.002ms returns 0x01
    [2025-May-20 21:04:27] [trace] [  JLink] - JLINK_ExecCommand("DisableFlashDL", ...).
    [2025-May-20 21:04:27] [trace] [  JLink] - - 0.000ms returns 0x00
    [2025-May-20 21:04:27] [trace] [  JLink] - JLINK_ExecCommand("ExcludeFlashCacheRange 0x0-0xFFFFFFFF", ...).
    [2025-May-20 21:04:27] [trace] [  JLink] - - 0.005ms returns 0x00
    [2025-May-20 21:04:27] [trace] [  JLink] - JLINK_SetHookUnsecureDialog
    [2025-May-20 21:04:27] [trace] [  JLink] - JLINK_SetHookUnsecureDialog(...)
    [2025-May-20 21:04:27] [trace] [  JLink] - - 0.019ms returns 0
    [2025-May-20 21:04:27] [trace] [  JLink] - JLINK_TIF_Select(JLINKARM_TIF_SWD)
    [2025-May-20 21:04:27] [trace] [  JLink] - - 0.654ms returns 0x00
    [2025-May-20 21:04:27] [trace] [  JLink] - JLINK_GetSpeedInfo()
    [2025-May-20 21:04:27] [trace] [  JLink] - 128000000 Hz / n, n >= 64
    [2025-May-20 21:04:27] [trace] [  JLink] - - 0.011ms
    [2025-May-20 21:04:27] [debug] [SeggerBackend] - Connected emulator supports SWD speeds up to 2000kHz
    [2025-May-20 21:04:27] [trace] [  JLink] - JLINK_SetSpeed(2000)
    [2025-May-20 21:04:27] [trace] [  JLink] - - 0.095ms
    [2025-May-20 21:04:27] [trace] [  JLink] - JLINK_GetSpeed()
    [2025-May-20 21:04:27] [trace] [  JLink] - - 0.014ms returns 2000
    [2025-May-20 21:04:27] [debug] [SeggerBackend] - SWD clock set to 2000kHz
    [2025-May-20 21:04:27] [trace] [  JLink] - JLINK_GetSN()
    [2025-May-20 21:04:27] [trace] [  JLink] - - 0.006ms returns 1050081286
    [2025-May-20 21:04:27] [trace] [  JLink] - - 0.009ms
    [2025-May-20 21:04:27] [debug] [  nRF53] - read_device_family
    [2025-May-20 21:04:27] [trace] [ Worker] - Command connect_to_emu_with_snr executed for 86 milliseconds with result 0
    [2025-May-20 21:04:27] [trace] [ Client] - Command read_connected_emu_snr executed for 14 milliseconds with result 0
    [2025-May-20 21:04:27] [debug] [ Client] - enable_coprocessor
    [2025-May-20 21:04:27] [debug] [  nRF53] - read_connected_emu_snr
    [2025-May-20 21:04:27] [debug] [SeggerBackend] - is_connected_to_emu
    [2025-May-20 21:04:27] [trace] [  JLink] - JLINK_IsOpen()
    [2025-May-20 21:04:27] [trace] [  JLink] - - 0.010ms returns 0x01
    [2025-May-20 21:04:27] [debug] [SeggerBackend] - read_connected_emu_snr
    [2025-May-20 21:04:27] [trace] [  JLink] - - 0.004ms
    [2025-May-20 21:04:27] [trace] [ Worker] - Command read_connected_emu_snr executed for 0 milliseconds with result 0
    [2025-May-20 21:04:27] [debug] [  nRF53] - enable_coprocessor
    [2025-May-20 21:04:27] [trace] [ Client] - Command enable_coprocessor executed for 0 milliseconds with result 0
    [2025-May-20 21:04:27] [debug] [ Client] - select_coprocessor
    [2025-May-20 21:04:27] [error] [ Client] - Encountered error -5: Command select_coprocessor executed for 14 milliseconds with result -5
    [2025-May-20 21:04:27] [trace] [  JLink] - - 0.013ms returns 0x01
    [2025-May-20 21:04:27] [debug] [  nRF53] - Just_enable_coprocessor
    [2025-May-20 21:04:27] [trace] [ Worker] - Command enable_coprocessor executed for 0 milliseconds with result 0
    [2025-May-20 21:04:27] [debug] [  nRF53] - select_coprocessor
    [2025-May-20 21:04:27] [trace] [  JLink] - - 0.003ms returns 0x01
    [2025-May-20 21:04:27] [debug] [SeggerBackend] - is_connected_to_device
    [2025-May-20 21:04:27] [trace] [  JLink] - JLINK_IsConnected()
    [2025-May-20 21:04:27] [trace] [  JLink] - - 0.004ms returns FALSE
    [2025-May-20 21:04:27] [debug] [  nRF53] - Just_select_coprocessor
    [2025-May-20 21:04:27] [ info] [  nRF53] - Loading new coprocessor data.
    [2025-May-20 21:04:27] [debug] [  nRF53] - Just_load_coprocessor_data
    [2025-May-20 21:04:27] [debug] [SeggerBackend] - set_core_data
    [2025-May-20 21:04:27] [debug] [SeggerBackend] - Set core data:
    [2025-May-20 21:04:27] [debug] [SeggerBackend] -   Device ID: Cortex-M33
    [2025-May-20 21:04:27] [debug] [SeggerBackend] -   Expected core: 235012351
    [2025-May-20 21:04:27] [debug] [SeggerBackend] -   Existing Expected core: 235012351
    [2025-May-20 21:04:27] [debug] [SeggerBackend] -   Coprocessor: APPLICATION
    [2025-May-20 21:04:27] [debug] [SeggerBackend] -   AHB AP index: 0
    [2025-May-20 21:04:27] [debug] [SeggerBackend] -   Core base address: 4294967295
    [2025-May-20 21:04:27] [debug] [  nRF53] - Just_readback_status
    [2025-May-20 21:04:27] [debug] [SeggerBackend] - read_access_port_register
    [2025-May-20 21:04:27] [debug] [SeggerBackend] - ---just_read_access_port_register
    [2025-May-20 21:04:27] [debug] [SeggerBackend] - coresight_configure
    [2025-May-20 21:04:27] [trace] [  JLink] - JLINK_GetHWStatus(...)
    [2025-May-20 21:04:27] [trace] [  JLink] - - 0.146ms returns 0
    [2025-May-20 21:04:27] [trace] [  JLink] - JLINK_CORESIGHT_Configure()
    [2025-May-20 21:04:27] [trace] [  JLink] - - 0.571ms returns 0
    [2025-May-20 21:04:27] [debug] [SeggerBackend] - read_debug_port_idr
    [2025-May-20 21:04:27] [debug] [SeggerBackend] - read_debug_port_register
    [2025-May-20 21:04:27] [debug] [SeggerBackend] - ---just_read_debug_port_register
    [2025-May-20 21:04:27] [debug] [SeggerBackend] - ---just_select_debug_port_register
    [2025-May-20 21:04:27] [debug] [SeggerBackend] - Select AP 255, DP Bank 0, AP Bank 255
    [2025-May-20 21:04:27] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    [2025-May-20 21:04:27] [trace] [  JLink] - - 0.355ms returns 0
    [2025-May-20 21:04:27] [trace] [  JLink] - JLINK_CORESIGHT_ReadAPDPReg(DP reg 0x00)
    [2025-May-20 21:04:27] [trace] [  JLink] - Value=0x00000000
    [2025-May-20 21:04:27] [trace] [  JLink] - - 0.389ms returns 0
    [2025-May-20 21:04:27] [trace] [  JLink] - - 0.052ms
    [2025-May-20 21:04:27] [error] [ Worker] - Encountered unexpected debug port ID 0, expected 6
    [2025-May-20 21:04:27] [trace] [ Worker] - Command select_coprocessor executed for 1 milliseconds with result -5
    [2025-May-20 21:04:27] [debug] [  nRF53] - close
    [2025-May-20 21:04:27] [debug] [SeggerBackend] - close
    [2025-May-20 21:04:27] [debug] [SeggerBackend] - disconnect_from_emu
    [2025-May-20 21:04:27] [debug] [SeggerBackend] - ---just_disconnect_from_emu
    [2025-May-20 21:04:27] [trace] [  JLink] - - 0.007ms returns FALSE
    [2025-May-20 21:04:27] [debug] [SeggerBackend] - ---just_is_debug_region_powered
    [2025-May-20 21:04:27] [trace] [  JLink] - - 0.370ms returns 0
    [2025-May-20 21:04:27] [trace] [  JLink] - JLINK_CORESIGHT_ReadAPDPReg(DP reg 0x01)
    [2025-May-20 21:04:27] [trace] [  JLink] - - 0.418ms returns 0
    [2025-May-20 21:04:27] [trace] [  JLink] - JLINK_Close()
    [2025-May-20 21:04:27] [debug] [SeggerBackend] - Segger Backend closed.
    [2025-May-20 21:04:27] [debug] [  nRF53] - nRF family DLL closed
    [2025-May-20 21:04:27] [trace] [ Client] - Command close executed for 62 milliseconds with result 0
    [2025-May-20 21:04:27] [debug] [ Client] - terminate
    [2025-May-20 21:04:27] [trace] [ Client] - Command terminate executed for 0 milliseconds with result 0
    [2025-May-20 21:04:27] [trace] [ Worker] - Command close executed for 45 milliseconds with result 0
    [2025-May-20 21:04:27] [trace] [ Worker] - Command terminate executed for 0 milliseconds with result 0
    [2025-May-20 21:04:27] [trace] [ Worker] - Executed 9 commands for 154 milliseconds
    [2025-May-20 21:04:27] [debug] [ Client] - Worker process exited with code: 0
    [2025-May-20 21:04:27] [debug] [ Client] - Child process terminated with result 0
    [2025-May-20 21:04:27] [trace] [ Client] - Executed 9 commands for 296 milliseconds
    [2025-May-20 21:22:37] [debug] --------------------------------------------------------------------------------
    [2025-May-20 21:22:37] [debug] C:\Program Files\Nordic Semiconductor\nrf-command-line-tools\bin\nrfjprog.exe --recover --coprocessor CP_APPLICATION -f NRF53 --snr 1050081286 --log
    [2025-May-20 21:22:37] [debug] nrfjprog version 10.24.2 external
    [2025-May-20 21:22:37] [ info] Load library at C:\Program Files\Nordic Semiconductor\nrf-command-line-tools\bin\nrfjprog.dll.
    [2025-May-20 21:22:37] [ info] Library loaded, loading member functions.
    [2025-May-20 21:22:37] [ info] Member functions succesfully loaded.
    [2025-May-20 21:22:37] [debug] [ Client] - open
    [2025-May-20 21:22:37] [debug] [ Client] - start
    [2025-May-20 21:22:37] [ info] [ Client] - stdout: Jlinkarm nRF Worker ready. Handling sequence 736a9d68-6317-4d88-af19-3f3ced7bef0c.
    [2025-May-20 21:22:37] [debug] [SeggerBackend] - Logger sink registered in Segger backend logger
    [2025-May-20 21:22:37] [debug] [  JLink] - Logger sink registered in JLink logger
    [2025-May-20 21:22:37] [debug] [  nRF53] - open
    [2025-May-20 21:22:37] [debug] [  nRF53] - just_check_family
    [2025-May-20 21:22:37] [debug] [SeggerBackend] - open_dll
    [2025-May-20 21:22:37] [debug] [SeggerBackend] - No J-Link DLL path was provided. Attempting to auto detect.
    [2025-May-20 21:22:37] [ info] [SeggerBackend] - Load library at C:\Program Files\SEGGER\JLink_V816\JLink_x64.dll.
    [2025-May-20 21:22:37] [ info] [SeggerBackend] - Library loaded, loading member functions.
    [2025-May-20 21:22:37] [ info] [SeggerBackend] - Member functions succesfully loaded.
    [2025-May-20 21:22:37] [debug] [SeggerBackend] - Set batch mode
    [2025-May-20 21:22:37] [debug] [SeggerBackend] - dll_version
    [2025-May-20 21:22:37] [ info] [SeggerBackend] - Segger dll version 8.16.  loaded.
    [2025-May-20 21:22:37] [trace] [ Worker] - Command open executed for 7 milliseconds with result 0
    [2025-May-20 21:22:37] [trace] [ Client] - Command open executed for 76 milliseconds with result 0
    [2025-May-20 21:22:37] [debug] [ Client] - config
    [2025-May-20 21:22:37] [trace] [ Client] - Command config executed for 15 milliseconds with result 0
    [2025-May-20 21:22:37] [debug] [  nRF53] - config
    [2025-May-20 21:22:37] [debug] [SeggerBackend] - enum_emu_snr
    [2025-May-20 21:22:37] [trace] [ Worker] - Command config executed for 4 milliseconds with result 0
    [2025-May-20 21:22:37] [debug] [ Client] - enum_emu_snr
    [2025-May-20 21:22:37] [trace] [ Client] - Command enum_emu_con_info executed for 15 milliseconds with result 0
    [2025-May-20 21:22:37] [debug] [ Client] - connect_to_emu_with_snr
    [2025-May-20 21:22:37] [debug] [  nRF53] - enum_emu_con_info
    [2025-May-20 21:22:37] [debug] [SeggerBackend] - is_connected_to_emu
    [2025-May-20 21:22:37] [debug] [SeggerBackend] - enum_emu_con_info
    [2025-May-20 21:22:37] [trace] [ Worker] - Command enum_emu_con_info executed for 4 milliseconds with result 0
    [2025-May-20 21:22:37] [debug] [  nRF53] - connect_to_emu_with_snr
    [2025-May-20 21:22:37] [debug] [SeggerBackend] - connect_to_emu_with_snr
    [2025-May-20 21:22:37] [debug] [SeggerBackend] - ---just_enum_emu_snr
    [2025-May-20 21:22:37] [debug] [SeggerBackend] - ---just_get_num_emus
    [2025-May-20 21:22:37] [debug] [SeggerBackend] - ---just_connect_to_emu_with_snr
    [2025-May-20 21:22:37] [debug] [SeggerBackend] - ---just_connect_to_emu_without_snr
    [2025-May-20 21:22:37] [debug] [SeggerBackend] - Segger logging enabled.
    [2025-May-20 21:22:37] [trace] [  JLink] - Firmware: J-Link OB-nRF5340-NordicSemi compiled Feb 11 2025 17:15:35
    [2025-May-20 21:22:37] [trace] [  JLink] - Hardware: V1.00
    [2025-May-20 21:22:37] [trace] [  JLink] - S/N: 1050081286
    [2025-May-20 21:22:37] [trace] [  JLink] - OEM: SEGGER
    [2025-May-20 21:22:37] [trace] [  JLink] - Feature(s): RDI, FlashBP, FlashDL, JFlash, GDB
    [2025-May-20 21:22:37] [trace] [  JLink] - Bootloader: 2021 May 18
    [2025-May-20 21:22:37] [trace] [  JLink] - USB speed mode: Full speed (12 MBit/s)
    [2025-May-20 21:22:37] [trace] [  JLink] - TELNET listener socket opened on port 19021
    [2025-May-20 21:22:37] [trace] [  JLink] - WEBSRV WEBSRV_Init(): Starting webserver thread(s)
    [2025-May-20 21:22:37] [trace] [  JLink] - WEBSRV Webserver running on local port 19080
    [2025-May-20 21:22:37] [trace] [  JLink] - Looking for J-Link GUI Server exe at: C:\Program Files\SEGGER\JLink_V816\JLinkGUIServer.exe
    [2025-May-20 21:22:37] [trace] [  JLink] - Forking J-Link GUI Server: C:\Program Files\SEGGER\JLink_V816\JLinkGUIServer.exe
    [2025-May-20 21:22:37] [trace] [ Client] - Command connect_to_emu_with_snr executed for 107 milliseconds with result 0
    [2025-May-20 21:22:37] [debug] [ Client] - read_connected_emu_snr
    [2025-May-20 21:22:38] [trace] [  JLink] - J-Link GUI Server info: "J-Link GUI server V8.16 "
    [2025-May-20 21:22:38] [trace] [  JLink] - - 79.704ms returns "O.K."
    [2025-May-20 21:22:38] [trace] [  JLink] - JLINK_HasError()
    [2025-May-20 21:22:38] [trace] [  JLink] - JLINK_Lock()
    [2025-May-20 21:22:38] [trace] [  JLink] - JLINK_ExecCommand("SetRestartOnClose = 0", ...).
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.001ms returns 0x01
    [2025-May-20 21:22:38] [trace] [  JLink] - JLINK_ExecCommand("DisableFlashDL", ...).
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.000ms returns 0x00
    [2025-May-20 21:22:38] [trace] [  JLink] - JLINK_ExecCommand("ExcludeFlashCacheRange 0x0-0xFFFFFFFF", ...).
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.003ms returns 0x00
    [2025-May-20 21:22:38] [trace] [ Client] - Command read_connected_emu_snr executed for 0 milliseconds with result 0
    [2025-May-20 21:22:38] [trace] [  JLink] - JLINK_SetHookUnsecureDialog
    [2025-May-20 21:22:38] [trace] [  JLink] - JLINK_SetHookUnsecureDialog(...)
    [2025-May-20 21:22:38] [debug] [ Client] - enable_coprocessor
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.010ms returns 0
    [2025-May-20 21:22:38] [trace] [  JLink] - JLINK_TIF_Select(JLINKARM_TIF_SWD)
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.561ms returns 0x00
    [2025-May-20 21:22:38] [trace] [  JLink] - JLINK_GetSpeedInfo()
    [2025-May-20 21:22:38] [trace] [  JLink] - 128000000 Hz / n, n >= 64
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.011ms
    [2025-May-20 21:22:38] [debug] [SeggerBackend] - Connected emulator supports SWD speeds up to 2000kHz
    [2025-May-20 21:22:38] [trace] [  JLink] - JLINK_SetSpeed(2000)
    [2025-May-20 21:22:38] [trace] [ Client] - Command enable_coprocessor executed for 0 milliseconds with result 0
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.072ms
    [2025-May-20 21:22:38] [debug] [ Client] - select_coprocessor
    [2025-May-20 21:22:38] [trace] [  JLink] - JLINK_GetSpeed()
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.026ms returns 2000
    [2025-May-20 21:22:38] [debug] [SeggerBackend] - SWD clock set to 2000kHz
    [2025-May-20 21:22:38] [trace] [  JLink] - JLINK_GetSN()
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.010ms returns 1050081286
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.015ms
    [2025-May-20 21:22:38] [debug] [  nRF53] - read_device_family
    [2025-May-20 21:22:38] [trace] [ Worker] - Command connect_to_emu_with_snr executed for 105 milliseconds with result 0
    [2025-May-20 21:22:38] [debug] [  nRF53] - read_connected_emu_snr
    [2025-May-20 21:22:38] [debug] [SeggerBackend] - is_connected_to_emu
    [2025-May-20 21:22:38] [trace] [  JLink] - JLINK_IsOpen()
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.009ms returns 0x01
    [2025-May-20 21:22:38] [debug] [SeggerBackend] - read_connected_emu_snr
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.007ms
    [2025-May-20 21:22:38] [trace] [ Worker] - Command read_connected_emu_snr executed for 0 milliseconds with result 0
    [2025-May-20 21:22:38] [debug] [  nRF53] - enable_coprocessor
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.006ms returns 0x01
    [2025-May-20 21:22:38] [debug] [  nRF53] - Just_enable_coprocessor
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.005ms
    [2025-May-20 21:22:38] [trace] [ Worker] - Command enable_coprocessor executed for 0 milliseconds with result 0
    [2025-May-20 21:22:38] [debug] [  nRF53] - select_coprocessor
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.003ms returns 0x01
    [2025-May-20 21:22:38] [debug] [SeggerBackend] - is_connected_to_device
    [2025-May-20 21:22:38] [trace] [  JLink] - JLINK_IsConnected()
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.004ms returns FALSE
    [2025-May-20 21:22:38] [debug] [  nRF53] - Just_select_coprocessor
    [2025-May-20 21:22:38] [ info] [  nRF53] - Loading new coprocessor data.
    [2025-May-20 21:22:38] [debug] [  nRF53] - Just_load_coprocessor_data
    [2025-May-20 21:22:38] [debug] [SeggerBackend] - set_core_data
    [2025-May-20 21:22:38] [debug] [SeggerBackend] - Set core data:
    [2025-May-20 21:22:38] [debug] [SeggerBackend] -   Device ID: Cortex-M33
    [2025-May-20 21:22:38] [debug] [SeggerBackend] -   Expected core: 235012351
    [2025-May-20 21:22:38] [debug] [SeggerBackend] -   Existing Expected core: 235012351
    [2025-May-20 21:22:38] [debug] [SeggerBackend] -   Coprocessor: APPLICATION
    [2025-May-20 21:22:38] [debug] [SeggerBackend] -   AHB AP index: 0
    [2025-May-20 21:22:38] [debug] [SeggerBackend] -   Core base address: 4294967295
    [2025-May-20 21:22:38] [debug] [  nRF53] - Just_readback_status
    [2025-May-20 21:22:38] [debug] [SeggerBackend] - read_access_port_register
    [2025-May-20 21:22:38] [debug] [SeggerBackend] - ---just_read_access_port_register
    [2025-May-20 21:22:38] [debug] [SeggerBackend] - coresight_configure
    [2025-May-20 21:22:38] [trace] [  JLink] - JLINK_GetHWStatus(...)
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.263ms returns 0
    [2025-May-20 21:22:38] [trace] [  JLink] - JLINK_CORESIGHT_Configure()
    [2025-May-20 21:22:38] [trace] [  JLink] - - 102.112ms returns 0
    [2025-May-20 21:22:38] [debug] [SeggerBackend] - read_debug_port_idr
    [2025-May-20 21:22:38] [debug] [SeggerBackend] - read_debug_port_register
    [2025-May-20 21:22:38] [debug] [SeggerBackend] - ---just_read_debug_port_register
    [2025-May-20 21:22:38] [debug] [SeggerBackend] - ---just_select_debug_port_register
    [2025-May-20 21:22:38] [debug] [SeggerBackend] - Select AP 255, DP Bank 0, AP Bank 255
    [2025-May-20 21:22:38] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.933ms returns -1
    [2025-May-20 21:22:38] [debug] [SeggerBackend] - ---just_abort_debug_action
    [2025-May-20 21:22:38] [debug] [SeggerBackend] - Attempting to clear any configuration errors in debug port before closing connection.
    [2025-May-20 21:22:38] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.928ms returns -1
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.840ms returns -1
    [2025-May-20 21:22:38] [error] [ Client] - Encountered error -102: Command select_coprocessor executed for 139 milliseconds with result -102
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.799ms returns -1
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.930ms returns -1
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.667ms returns -1
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.867ms returns -1
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.661ms returns -1
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.598ms returns -1
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.646ms returns -1
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.645ms returns -1
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.632ms returns -1
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.618ms returns -1
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.640ms returns -1
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.623ms returns -1
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.653ms returns -1
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.647ms returns -1
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.627ms returns -1
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.617ms returns -1
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.671ms returns -1
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.616ms returns -1
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.652ms returns -1
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.635ms returns -1
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.594ms returns -1
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.610ms returns -1
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.634ms returns -1
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.607ms returns -1
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.608ms returns -1
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.639ms returns -1
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.703ms returns -1
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.620ms returns -1
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.621ms returns -1
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.619ms returns -1
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.654ms returns -1
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.580ms returns -1
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.547ms returns -1
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.575ms returns -1
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.573ms returns -1
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.057ms
    [2025-May-20 21:22:38] [error] [ Worker] - An unknown error.
    [2025-May-20 21:22:38] [trace] [ Worker] - Command select_coprocessor executed for 133 milliseconds with result -102
    [2025-May-20 21:22:38] [debug] [  nRF53] - close
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.016ms returns 0x01
    [2025-May-20 21:22:38] [debug] [SeggerBackend] - close
    [2025-May-20 21:22:38] [debug] [SeggerBackend] - disconnect_from_emu
    [2025-May-20 21:22:38] [debug] [SeggerBackend] - ---just_disconnect_from_emu
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.024ms returns FALSE
    [2025-May-20 21:22:38] [debug] [SeggerBackend] - ---just_is_debug_region_powered
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.529ms returns -1
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.495ms returns -1
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.584ms returns -1
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.586ms returns -1
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.585ms returns -1
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.590ms returns -1
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.597ms returns -1
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.631ms returns -1
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.567ms returns -1
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.542ms returns -1
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.535ms returns -1
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.504ms returns -1
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.562ms returns -1
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.553ms returns -1
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.546ms returns -1
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.524ms returns -1
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.545ms returns -1
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.520ms returns -1
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.519ms returns -1
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.513ms returns -1
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.518ms returns -1
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.557ms returns -1
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.532ms returns -1
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.527ms returns -1
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.528ms returns -1
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.537ms returns -1
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.576ms returns -1
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.612ms returns -1
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.604ms returns -1
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.637ms returns -1
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.558ms returns -1
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.638ms returns -1
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.480ms returns -1
    [2025-May-20 21:22:38] [debug] [SeggerBackend] - Ignore exception An unknown error.
    [2025-May-20 21:22:38] [trace] [  JLink] - - 0.066ms
    [2025-May-20 21:22:38] [trace] [  JLink] - JLINK_Close()
    [2025-May-20 21:22:38] [debug] [SeggerBackend] - Segger Backend closed.
    [2025-May-20 21:22:38] [debug] [  nRF53] - nRF family DLL closed
    [2025-May-20 21:22:38] [trace] [ Client] - Command close executed for 77 milliseconds with result 0
    [2025-May-20 21:22:38] [debug] [ Client] - terminate
    [2025-May-20 21:22:38] [trace] [ Worker] - Command close executed for 61 milliseconds with result 0
    [2025-May-20 21:22:38] [trace] [ Client] - Command terminate executed for 0 milliseconds with result 0
    [2025-May-20 21:22:38] [trace] [ Worker] - Command terminate executed for 0 milliseconds with result 0
    [2025-May-20 21:22:38] [trace] [ Worker] - Executed 9 commands for 314 milliseconds
    [2025-May-20 21:22:38] [debug] [ Client] - Worker process exited with code: 0
    [2025-May-20 21:22:38] [debug] [ Client] - Child process terminated with result 0
    [2025-May-20 21:22:38] [trace] [ Client] - Executed 9 commands for 429 milliseconds
    This is the log output. Yes, I also think the problem is related to the power supply because I got this problem about flashing after that I changed the Vdd form 1.8 V to 3.3 V.
    Can you provide some details about your setup?
    Can you provide more information about your power supply?
    Do you see the same problem if you return to 1.8 V?
    Do you have any other board to test with?
    Can you try to use "nrfutil device" for erasing and recovering as shown in this documentation page?
    Dejan
