Enabling the TLS layer to get a HTTPS connection going.
7343.nrf7002dk_nrf5340_cpuapp_ns.conf3124.prj.confHello everyone.
WE're trying to make a https connection with google.com and execute a GET request.
Wifi connection is working; DHCP seems to be working (my personal assumption given the log message we get: "Resolved: [(1, 1, 6, '', ('142.250.201.206', 443))]" which indicates that getaddrinfo() works); but when trying to initiate the socket via TLS, something strange happens: we get the error "OSError: 109".
Inserting some debug prints inside subsys/net/lib/sockets/, we found the culprit to be the function "int zsock_setsockopt_ctx(struct net_context *ctx, int level, int optname, const void *optval, socklen_t optlen)".
The function call that triggers error 109 is:  res = setsockopt(socket->ctx, SOL_TLS, TLS_PEER_VERIFY, &verify, sizeof(verify));
No matter what other option we try to set via setsockopt(), it will fail with the 109 error since the implementation for setsockopt() is somehow set to sockets_inet.c (whose implementation does not recognise SOL_TLS as a valid in its switches) instead of sockets_tls.c (which has handling for SOL_TLS in its switches). My personal hunch is that the config options set in the project are somehow wrong. Can someone please take a look over our .conf files? Maybe we can find the culprit. :)
We can provide any extra code snippets that are necessary for debugging and/ or run any tests. Have a great day and hope to hear from you soon!
    Could you try with https_client first, to see if this works there?
    Add the cmd's (assuming WPA2) to store your SSID like this:
    wifi_cred add -s SSID -k 1 -p PASSWORD
    wifi_cred auto_connect
    Håkon
  • Hey there Håkon,
    I tried those commands, but I had to alter them a bit to get them to work on SDK v3.0.0. More specifically:
    wifi cred add -s SSID -k 1 -p PASSWORD
    wifi cred auto_connect
    Also, this is my log from running them:
    uart:~$ wifi cred auto_connect
    uart:~$
    uart:~$
    uart:~$
    uart:~$
    uart:~$
    --- 50 messages dropped ---
    00 00 --- 67 messages dropped ---
    01 17 00 04 17 d7 00 8a c0 0c 00 01 00 01 00 00 00 f7 00 10 26 00 14 06 3a 00 00 21 00 00 00 00 17 3e 2e 65 c0 0c 00 1c 00 01 00
    uart:~$
    Sent 61 bytes
    Received 318 bytes
    > HTTP/1.1 200 OK
    Finished, closing socket.
    Disconnected
    Network connectivity lost
    Disconnected from the network
    uart:~$
    uart:~$
    uart:~$
  • Also worth noting: by taking the https_client sample's config as a 1-to-1 reference, we overflow by ~130kb (region `FLASH' overflowed by 138084 bytes). I assume this is to the more "generous" sizes in the example. Are they truly necessary?
    I am not sure what you enable in your build, but it should not overflow if using one of the supported boards, ie. nrf7002dk/nrf5340/cpuapp/ns for instance.
    Additional mbedtls debug logs can safely be disabled, but is useful if debugging why you cannot connect to a given domain.
    Your log shows a successful connection to google:
    Sent 61 bytes
    Received 318 bytes
    > HTTP/1.1 200 OK
    Håkon
  • Your log shows a successful connection to google:
    Yes, it worked; what I wanted to point out was that the commands you provided don't work, but need to be edited like I mentioned. Trying your commands without any alterations produces:
    uart:~$ wifi_cred add -s TP-Link_7474 -k 1 -p 55920322
    wifi_cred: command not found
    uart:~$ wifi_cred auto_connect
    uart:~$
    We're using that configuration specifically. But we're also trying to integrate micropython. To have a full stack WiFi (STA, AP mode, HTTPS socket connection) and micropython itself required that we use "CONFIG_TFM_PROFILE_TYPE_MINIMAL=y", which reduces it's ROM and RAM footprint to 32kb each.
    Regarding what exactly is configured in the project: I've attached the prj.conf and the board.conf files to this post. I can attach any other necessary file that you deem useful.
    Is it possible to have a call via Teams/ Google Meet/ etc.? I'm sure the problem would be solved way faster. ;)
    Edit: while building I luckily saw this interesting warning:
    Restore: CONFIG_MBEDTLS_THREADING_ALT: False
    =========== End psa_crypto_library_config ===============
    -- Using ccache: /opt/homebrew/bin/ccache
    CMake Warning at /opt/nordic/ncs/v3.0.0/zephyr/CMakeLists.txt:1002 (message):
      No SOURCES given to Zephyr library:
      ..__nrf__subsys__net__lib__tls_credentials
      Excluding target from build.
    -- Found Python3: /opt/homebrew/bin/python3 (found version "3.13.3") found components: Interpreter
    -- Configuring done (8.1s)
    -- Generating done (0.7s)
    -- Build files have been written to: /Users/tudor/Documents/GitHub/micropython_nRF/ports/zephyr/build/zephyr
    -- Configuring done (13.0s)
    -- Generating done (0.0s)
    Could this contribute to what we're suspecting as being the main issue?: the fact that sockets_inet.c is selected when building instead of sockets_tls.c.
