Enabling the TLS layer to get a HTTPS connection going.
7343.nrf7002dk_nrf5340_cpuapp_ns.conf3124.prj.confHello everyone.
WE're trying to make a https connection with google.com and execute a GET request.
Wifi connection is working; DHCP seems to be working (my personal assumption given the log message we get: "Resolved: [(1, 1, 6, '', ('142.250.201.206', 443))]" which indicates that getaddrinfo() works); but when trying to initiate the socket via TLS, something strange happens: we get the error "OSError: 109".
Inserting some debug prints inside subsys/net/lib/sockets/, we found the culprit to be the function "int zsock_setsockopt_ctx(struct net_context *ctx, int level, int optname, const void *optval, socklen_t optlen)".
The function call that triggers error 109 is:  res = setsockopt(socket->ctx, SOL_TLS, TLS_PEER_VERIFY, &verify, sizeof(verify));
No matter what other option we try to set via setsockopt(), it will fail with the 109 error since the implementation for setsockopt() is somehow set to sockets_inet.c (whose implementation does not recognise SOL_TLS as a valid in its switches) instead of sockets_tls.c (which has handling for SOL_TLS in its switches). My personal hunch is that the config options set in the project are somehow wrong. Can someone please take a look over our .conf files? Maybe we can find the culprit. :)
We can provide any extra code snippets that are necessary for debugging and/ or run any tests. Have a great day and hope to hear from you soon!
  • How can I disable SoftAP and leave just STA mode active?
  • Running the "west build -d ./build/zephyr -t ram_report" command produces the following output:
    ram_report.txt
    I've filtered through it and found only a few major RAM hoggers:
    │ ├── _k_mem_slab_buf_tcp_conns_slab 3000 0.49% 0x20063440 noinit
    │ ├── fw_patch 81572 13.36% 0x000b7d68 rodata
    │ ├── heap.lto_priv.0 32768 5.37% 0x2000f024 bss
    │ ├── iface_wq_stack 4400 0.72% 0x20030108 noinit
    │ ├── kheap__system_heap 65536 10.74% 0x2001b1e8 noinit
    │ ├── kheap_net_buf_mem_pool_rx_bufs 4096 0.67% 0x20031238 noinit
    │ ├── kheap_net_buf_mem_pool_tx_bufs 4096 0.67% 0x20032238 noinit
    │ ├── kheap_wifi_drv_ctrl_mem_pool 20000 3.28% 0x20056f60 noinit
    │ ├── kheap_wifi_drv_data_mem_pool 130000 21.30% 0x20037390 noinit
    │ ├── mbedtls_heap 16384 2.68% 0x200171c4 bss
    │ ├── mgmt_stack 4600 0.75% 0x20033638 noinit
    │ ├── mp_thread_stack_array 20480 3.36% 0x2005de80 noinit
    │ ├── supplicant_thread_stack 5600 0.92% 0x2002eb28 noinit
    │ ├── z_main_stack 12288 2.01% 0x2002b328 noinit
    Also worth noting: I suspect AP is disabled based on the most recent .conf files that I've uploaded. I even tried to tune some RX and TX buffs, but it only lowered RAM usage by ~1.65%:
    RAM:      374936 B       416 KB     88.02%
    Also, I've explicitly set: CONFIG_NRF70_AP_MODE=n
    and I found and took in virtually everything from: https://github.com/nrfconnect/sdk-nrf/blob/main/samples/wifi/throughput/overlay-memory-optimized.conf
    which was suggested in the "WiFi stack configuration and performance" documentation page: https://docs.nordicsemi.com/bundle/ncs-latest/page/nrf/protocols/wifi/stack_configuration.html
    I even tried disabling CONFIG_WIFI_NM_WPA_SUPPLICANT, but RAM usage didn't lower by much and anyway I suspect we need this one to enable STA mode to connect to a WiFi.
  • I tried playing with various stacks, including CONFIG_MAIN_STACK_SIZE. But lowering other stacks and squeezing in CONFIG_MBEDTLS_HEAP_SIZE=81920, I reach a RAM usage of:
    RAM:      407704 B       416 KB     95.71%
    The image flashes, but when I try the same scenario of connecting to WiFi, doing getaddrinfo(), then opening a socket, I get a Stack Overflow when trying to connect to the WiFi network:
    Network ID: DIGI-4TYa & Network MAC: AC:CC:36:55:68:E9
    Network ID: DIGI-4uE3 & Network MAC: AC:CC:36:4D:9A:51
    Network ID: DIGI-C7uG & Network MAC: 28:F8:D6:C7:E5:91
    Network ID: DIGI-kTWh & Network MAC: 1C:BF:CE:9E:E2:38
    Network ID: Tea2.4 & Network MAC: AE:CC:36:1D:9A:51
    Network ID: DIGI-9x4D & Network MAC: F0:A7:31:6F:2D:7A
    Network ID: DIGI-Wpk7 & Network MAC: 74:31:AF:15:E0:41
    Network ID: HomeA&A & Network MAC: 92:A2:F4:9E:B3:D8
    MAC: F4:CE:36:00:1C:F4
    [(b'', b'62:ED:00:CD:74:72\x00', 44, -47, 1, False), (b'TP-Link_7474', b'40:ED:00:CD:74:72\x00', 44, -47, 1, False), (b'', b'62:ED:00:CD:74:73\x00', 4, -47, 1, False), (b'TP-Link_7474', b'40:ED:00:CD:74:]
    >>> wlan.connect("TP-Link_7474", "55920322", network.SECURITY_PSK, 4)
    [00:00:27.243,804] <err> os: ***** USAGE FAULT *****
    [00:00:27.249,450] <err> os:   Stack overflow (context area not valid)
    [00:00:27.256,713] <err> os: r0/a1:  0x20033528  r1/a2:  0x00000001  r2/a3:  0x00078000
    [00:00:27.265,472] <err> os: r3/a4:  0x00000000 r12/ip:  0x00008000 r14/lr:  0x0002446d
    [00:00:27.274,200] <err> os:  xpsr:  0x41000200
    [00:00:27.279,479] <err> os: s[ 0]:  0xaaaaaaaa  s[ 1]:  0xaaaaaaaa  s[ 2]:  0xaaaaaaaa  s[ 3]:  0xaaaaaaaa
    [00:00:27.289,978] <err> os: s[ 4]:  0xaaaaaaaa  s[ 5]:  0xaaaaaaaa  s[ 6]:  0xaaaaaaaa  s[ 7]:  0xaaaaaaaa
    [00:00:27.300,445] <err> os: s[ 8]:  0xaaaaaaaa  s[ 9]:  0xaaaaaaaa  s[10]:  0xaaaaaaaa  s[11]:  0xaaaaaaaa
    [00:00:27.310,943] <err> os: s[12]:  0x00000000  s[13]:  0x000730db  s[14]:  0x2000a060  s[15]:  0x2000a060
    [00:00:27.321,411] <err> os: fpscr:  0x000f4240
    [00:00:27.326,690] <err> os: Faulting instruction address (r15/pc): 0x0002879a
    [00:00:27.334,655] <err> os: >>> ZEPHYR FATAL ERROR 2: Stack overflow on CPU 0
    [00:00:27.342,590] <err> os: Current thread: 0x20009e08 (mp_main)
    [00:00:27.349,426] <err> os: Halting system
  • Håkon! More progress was made!!! :D
    So, I disabled:
    # CONFIG_MBEDTLS_ENABLE_HEAP=y
    # CONFIG_MBEDTLS_HEAP_SIZE=16384
    since I had a suspicion that allowing MBEDTLS to have its own stack would somehow use up more RAM than by not letting it.
    This seems to have COMPLETELY unlocked MBEDTLS!
    Here's a log of it in action:
    >>> s = None
    >>> s = socket.socket()
    Trying to initialize socket...
    Family: 1, socktype: 1, proto: 258
    Dead here...15
    [00:01:27.568,298] <dbg> net_sock_tls: tls_alloc: (mp_main): Allocated TLS context, 0x2000a190
    Dead here...17
    Checking stupid errno...1.1: 0
    [00:01:27.582,305] <dbg> net_sock: zsock_socket_internal: (mp_main): socket: ctx=0x2000b0e8, fd=16
    Dead here...18
    Dead here...19
    Returned value: 15
    Done initializing socket!
    >>> print("Connecting to:", result[0][-1])
    Connecting to: ('142.251.39.78', 443)
    >>> s.connect(result[0][-1])
    Dead here...5. DNS message size: 44
    DNS message content (hex):9d ae 81 80 00 01 00 01 00 00 00 00 06 67 6f 6f 67 6c 65 03 63 6f 6d 00 00 01 00 01 c0 0c 00 01 00 01 00 00 00 48 00 04 8e fb 27 4e
    Dead here...6
    Dead here...7
    [00:01:27.715,545] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:1331: The SSL configuration is tls12 only.
    [00:01:27.735,412] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4663: => handshake
    [00:01:27.745,727] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2354: => flush output
    [00:01:27.756,317] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2363: <= flush output
    [00:01:27.766,937] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4582: client state: MBEDTLS_SSL_HELLO_REQUEST
    [00:01:27.779,571] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2354: => flush output
    [00:01:27.790,161] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2363: <= flush output
    [00:01:27.800,781] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4582: client state: MBEDTLS_SSL_CLIENT_HELLO
    [00:01:27.813,354] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0921: => write client hello
    [00:01:27.825,134] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0487: dumping 'client hello, random bytes' (32 bytes)
    [00:01:27.838,775] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0487: 0000:  d6 ff 0c 29 d8 e1 2c 45 37 c2 62 83 05 1a b5 30  ...)..,E7.b....0
    [00:01:27.854,553] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0487: 0010:  db 44 82 22 9a 48 98 8c 48 89 c6 dc 2f a7 74 2c  .D.".H..H.../.t,
    [00:01:27.870,117] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0512: dumping 'session id' (0 bytes)
    [00:01:27.882,049] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c024, TLS-ECDHE-ECDSA-WITH-AES-256-CBC-SHA384
    [00:01:27.898,010] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c028, TLS-ECDHE-RSA-WITH-AES-256-CBC-SHA384
    [00:01:27.913,757] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c00a, TLS-ECDHE-ECDSA-WITH-AES-256-CBC-SHA
    [00:01:27.929,412] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c014, TLS-ECDHE-RSA-WITH-AES-256-CBC-SHA
    [00:01:27.944,915] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c023, TLS-ECDHE-ECDSA-WITH-AES-128-CBC-SHA256
    [00:01:27.960,845] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c027, TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
    [00:01:27.976,623] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c009, TLS-ECDHE-ECDSA-WITH-AES-128-CBC-SHA
    [00:01:27.992,279] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c013, TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA
    [00:01:28.007,812] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: 003d, TLS-RSA-WITH-AES-256-CBC-SHA256
    [00:01:28.023,040] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: 0035, TLS-RSA-WITH-AES-256-CBC-SHA
    [00:01:28.038,024] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c02a, TLS-ECDH-RSA-WITH-AES-256-CBC-SHA384
    [00:01:28.053,680] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c00f, TLS-ECDH-RSA-WITH-AES-256-CBC-SHA
    [00:01:28.069,091] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c026, TLS-ECDH-ECDSA-WITH-AES-256-CBC-SHA384
    [00:01:28.084,960] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c005, TLS-ECDH-ECDSA-WITH-AES-256-CBC-SHA
    [00:01:28.100,524] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: 003c, TLS-RSA-WITH-AES-128-CBC-SHA256
    [00:01:28.115,783] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: 002f, TLS-RSA-WITH-AES-128-CBC-SHA
    [00:01:28.130,737] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c029, TLS-ECDH-RSA-WITH-AES-128-CBC-SHA256
    [00:01:28.146,423] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c00e, TLS-ECDH-RSA-WITH-AES-128-CBC-SHA
    [00:01:28.161,834] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c025, TLS-ECDH-ECDSA-WITH-AES-128-CBC-SHA256
    [00:01:28.177,673] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c004, TLS-ECDH-ECDSA-WITH-AES-128-CBC-SHA
    [00:01:28.193,267] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0388: adding EMPTY_RENEGOTIATION_INFO_SCSV
    [00:01:28.205,657] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0397: client hello, got zu cipher suites
    [00:01:28.217,895] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0041: client hello, adding server name extension:
    [00:01:28.231,018] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0231: client hello, adding supported_groups extension
    [00:01:28.244,415] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0250: got supported group(001d)
    [00:01:28.255,859] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0282: NamedGroup: x25519 ( 1d )
    [00:01:28.267,333] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0250: got supported group(0017)
    [00:01:28.278,778] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0282: NamedGroup: secp256r1 ( 17 )
    [00:01:28.290,527] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0302: dumping 'Supported groups extension' (6 bytes)
    [00:01:28.303,955] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0302: 0000:  00 04 00 1d 00 17                                ......
    [00:01:28.318,603] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9505: adding signature_algorithms extension
    [00:01:28.330,902] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9525: got signature scheme [603] ecdsa_secp521r1_sha512
    [00:01:28.344,177] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9534: sent signature scheme [603] ecdsa_secp521r1_sha512
    [00:01:28.357,543] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9525: got signature scheme [601] rsa_pkcs1_sha512
    [00:01:28.370,330] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9534: sent signature scheme [601] rsa_pkcs1_sha512
    [00:01:28.383,178] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9525: got signature scheme [503] ecdsa_secp384r1_sha384
    [00:01:28.396,484] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9534: sent signature scheme [503] ecdsa_secp384r1_sha384
    [00:01:28.409,851] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9525: got signature scheme [501] rsa_pkcs1_sha384
    [00:01:28.422,607] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9534: sent signature scheme [501] rsa_pkcs1_sha384
    [00:01:28.435,485] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9525: got signature scheme [403] ecdsa_secp256r1_sha256
    [00:01:28.448,760] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9534: sent signature scheme [403] ecdsa_secp256r1_sha256
    [00:01:28.462,127] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9525: got signature scheme [401] rsa_pkcs1_sha256
    [00:01:28.474,914] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9534: sent signature scheme [401] rsa_pkcs1_sha256
    [00:01:28.487,731] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:0105: client hello, adding supported_point_formats extension
    [00:01:28.502,258] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:0150: client hello, adding ecjpake_kkpp extension
    [00:01:28.515,808] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:0165: generating new ecjpake parameters
    [00:01:28.624,450] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:0338: client hello, adding extended_master_secret extension
    [00:01:28.638,854] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:0372: client hello, adding session ticket extension
    [00:01:28.652,587] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0689: client hello, total extension length: zu
    [00:01:28.665,374] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: dumping 'client hello extensions' (385 bytes)
    [00:01:28.678,833] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0000:  01 81 00 00 00 05 00 03 00 00 00 00 0a 00 06 00  ................
    [00:01:28.694,641] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0010:  04 00 1d 00 17 00 0d 00 0e 00 0c 06 03 06 01 05  ................
    [00:01:28.710,479] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0020:  03 05 01 04 03 04 01 00 0b 00 02 01 00 01 00 01  ................
    [00:01:28.726,257] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0030:  4a 41 04 44 45 b2 d9 27 08 d6 36 21 e8 f1 2c 89  JA.DE..'..6!..,.
    [00:01:28.742,065] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0040:  0d bd 5d fe db 7b c0 9b a7 c8 b1 bd d8 a3 50 ec  ..]..{........P.
    [00:01:28.757,873] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0050:  06 14 0b d2 e0 b0 05 87 2f 3d 5d 26 2d 20 ba 45  ......../=]&- .E
    [00:01:28.773,681] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0060:  92 c3 59 26 a2 e5 52 42 f5 3b 7f dd 74 ae ed ce  ..Y&..RB.;..t...
    [00:01:28.789,489] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0070:  da 6c 71 41 04 00 15 b1 87 5e 56 af a4 b7 ee a8  .lqA.....^V.....
    [00:01:28.805,297] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0080:  78 4b c6 3f 86 60 7f 82 2b 04 91 48 11 47 cc ce  xK.?.`..+..H.G..
    [00:01:28.821,105] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0090:  65 8a ad 6b 95 f3 f3 b2 0a c9 0a 72 f8 de 8e 85  e..k.......r....
    [00:01:28.836,914] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 00a0:  6d e6 45 6e 47 e1 74 ab c2 fd 19 15 3c 70 15 9d  m.EnG.t.....<p..
    [00:01:28.852,691] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 00b0:  ba ba 66 51 bc 20 03 fc fe aa 97 1a bf 98 20 fe  ..fQ. ........ .
    [00:01:28.868,499] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 00c0:  5d c2 29 ff bb 71 15 a6 36 7c f9 f4 1a eb 90 67  ].)..q..6|.....g
    [00:01:28.884,307] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 00d0:  dc 2e 4f 9a 55 7d 41 04 1f 6c ad 32 3d 6f c2 f4  ..O.U}A..l.2=o..
    [00:01:28.900,115] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 00e0:  b3 95 c2 85 ce 38 e7 c1 9c 51 37 8a 25 b9 fc 82  .....8...Q7.%...
    [00:01:28.915,893] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 00f0:  b9 5f 88 f7 a7 8a 3d b7 1a 13 5c ec f3 c4 df 33  ._....=...\....3
    [00:01:28.931,701] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0100:  4a d8 d4 1a 62 23 8d f6 01 a3 e4 28 3f 2f 22 4b  J...b#.....(?/"K
    [00:01:28.947,509] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0110:  b1 56 28 09 31 ed bb bf 41 04 30 64 0e 22 dc a6  .V(.1...A.0d."..
    [00:01:28.963,317] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0120:  b1 ec 0f 5e 6f 04 cc 31 11 d7 17 69 6c 55 63 5c  ...^o..1...ilUc\
    [00:01:28.979,125] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0130:  c8 13 a5 38 a7 74 2f 37 84 4b b8 a7 b3 34 83 10  ...8.t/7.K...4..
    [00:01:28.994,934] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0140:  02 af 7e 70 c7 28 92 6b 33 6d 2f b2 f2 14 17 1b  ..~p.(.k3m/.....
    [00:01:29.010,742] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0150:  ef d8 c8 0d 93 83 01 17 87 5a 20 51 29 8a b8 4e  .........Z Q)..N
    [00:01:29.026,519] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0160:  7d 52 bf 92 ad 1e 82 f7 3a c2 e7 77 10 2d a6 e3  }R......:..w.-..
    [00:01:29.042,327] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0170:  f9 95 de f5 fa fa ca 67 49 32 5b 00 17 00 00 00  .......gI2[.....
    [00:01:29.057,983] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0180:  23                                               #
    [00:01:29.073,425] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2784: => write handshake message
    [00:01:29.084,930] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2944: => write record
    [00:01:29.095,581] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3028: output record: msgtype = 22, version = [3:3], msglen = zu
    [00:01:29.109,588] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: dumping 'output record sent to network' (477 bytes)
    [00:01:29.125,213] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0000:  16 03 03 01 d8 01 00 01 d4 03 03 d6 ff 0c 29 d8  ..............).
    [00:01:29.142,700] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0010:  e1 2c 45 37 c2 62 83 05 1a b5 30 db 44 82 22 9a  .,E7.b....0.D.".
    [00:01:29.160,156] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0020:  48 98 8c 48 89 c6 dc 2f a7 74 2c 00 00 2a c0 24  H..H.../.t,..*.$
    [00:01:29.177,612] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0030:  c0 28 c0 0a c0 14 c0 23 c0 27 c0 09 c0 13 00 3d  .(.....#.'.....=
    [00:01:29.195,068] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0040:  00 35 c0 2a c0 0f c0 26 c0 05 00 3c 00 2f c0 29  .5.*...&...<./.)
    [00:01:29.212,554] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0050:  c0 0e c0 25 c0 04 00 ff 01 00 01 81 00 00 00 05  ...%............
    [00:01:29.230,041] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0060:  00 03 00 00 00 00 0a 00 06 00 04 00 1d 00 17 00  ................
    [00:01:29.247,497] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0070:  0d 00 0e 00 0c 06 03 06 01 05 03 05 01 04 03 04  ................
    [00:01:29.264,984] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0080:  01 00 0b 00 02 01 00 01 00 01 4a 41 04 44 45 b2  ..........JA.DE.
    [00:01:29.282,440] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0090:  d9 27 08 d6 36 21 e8 f1 2c 89 0d bd 5d fe db 7b  .'..6!..,...]..{
    [00:01:29.299,896] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 00a0:  c0 9b a7 c8 b1 bd d8 a3 50 ec 06 14 0b d2 e0 b0  ........P.......
    [00:01:29.317,382] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 00b0:  05 87 2f 3d 5d 26 2d 20 ba 45 92 c3 59 26 a2 e5  ../=]&- .E..Y&..
    [00:01:29.334,838] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 00c0:  52 42 f5 3b 7f dd 74 ae ed ce da 6c 71 41 04 00  RB.;..t....lqA..
    [00:01:29.352,294] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 00d0:  15 b1 87 5e 56 af a4 b7 ee a8 78 4b c6 3f 86 60  ...^V.....xK.?.`
    [00:01:29.369,750] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 00e0:  7f 82 2b 04 91 48 11 47 cc ce 65 8a ad 6b 95 f3  ..+..H.G..e..k..
    [00:01:29.387,207] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 00f0:  f3 b2 0a c9 0a 72 f8 de 8e 85 6d e6 45 6e 47 e1  .....r....m.EnG.
    [00:01:29.404,693] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0100:  74 ab c2 fd 19 15 3c 70 15 9d ba ba 66 51 bc 20  t.....<p....fQ.
    [00:01:29.422,149] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0110:  03 fc fe aa 97 1a bf 98 20 fe 5d c2 29 ff bb 71  ........ .].)..q
    [00:01:29.439,605] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0120:  15 a6 36 7c f9 f4 1a eb 90 67 dc 2e 4f 9a 55 7d  ..6|.....g..O.U}
    [00:01:29.457,061] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0130:  41 04 1f 6c ad 32 3d 6f c2 f4 b3 95 c2 85 ce 38  A..l.2=o.......8
    [00:01:29.474,548] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0140:  e7 c1 9c 51 37 8a 25 b9 fc 82 b9 5f 88 f7 a7 8a  ...Q7.%...._....
    [00:01:29.492,004] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0150:  3d b7 1a 13 5c ec f3 c4 df 33 4a d8 d4 1a 62 23  =...\....3J...b#
    [00:01:29.509,460] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0160:  8d f6 01 a3 e4 28 3f 2f 22 4b b1 56 28 09 31 ed  .....(?/"K.V(.1.
    [00:01:29.526,916] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0170:  bb bf 41 04 30 64 0e 22 dc a6 b1 ec 0f 5e 6f 04  ..A.0d.".....^o.
    [00:01:29.544,372] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0180:  cc 31 11 d7 17 69 6c 55 63 5c c8 13 a5 38 a7 74  .1...ilUc\...8.t
    [00:01:29.561,859] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0190:  2f 37 84 4b b8 a7 b3 34 83 10 02 af 7e 70 c7 28  /7.K...4....~p.(
    [00:01:29.579,315] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 01a0:  92 6b 33 6d 2f b2 f2 14 17 1b ef d8 c8 0d 93 83  .k3m/...........
    [00:01:29.596,771] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 01b0:  01 17 87 5a 20 51 29 8a b8 4e 7d 52 bf 92 ad 1e  ...Z Q)..N}R....
    [00:01:29.614,227] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 01c0:  82 f7 3a c2 e7 77 10 2d a6 e3 f9 95 de f5 fa fa  ..:..w.-........
    [00:01:29.631,652] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 01d0:  ca 67 49 32 5b 00 17 00 00 00 23 00 00           .gI2[.....#..
    [00:01:29.648,590] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3081: <= write record
    [00:01:29.659,179] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2905: <= write handshake message
    [00:01:29.670,715] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:1014: <= write client hello
    [00:01:29.682,067] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2354: => flush output
    [00:01:29.692,687] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2368: message length: zu, out_left: zu
    [00:01:29.705,444] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2375: ssl->f_send() returned 477 (-0xfffffe23)
    [00:01:29.718,170] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2402: <= flush output
    [00:01:29.728,790] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4582: client state: MBEDTLS_SSL_SERVER_HELLO
    [00:01:29.741,333] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1196: => parse server hello
    [00:01:29.753,234] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4298: => read record
    [00:01:29.763,732] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2156: => fetch input
    [00:01:29.774,230] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2296: in_left: zu, nb_want: zu
    [00:01:29.785,644] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2316: in_left: zu, nb_want: zu
    [00:01:29.796,966] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4674: <= handshake
    [00:01:29.995,971] <dbg> net_sock: zsock_received_cb: (rx_q[0]): ctx=0x2000b0e8, pkt=0x2005f0a0, st=0, user_data=(nil)
    [00:01:30.007,873] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4663: => handshake
    [00:01:30.018,371] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2354: => flush output
    [00:01:30.028,991] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2363: <= flush output
    [00:01:30.042,114] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4582: client state: MBEDTLS_SSL_SERVER_HELLO
    [00:01:30.054,779] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1196: => parse server hello
    [00:01:30.066,650] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4298: => read record
    [00:01:30.077,148] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2156: => fetch input
    [00:01:30.087,677] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2296: in_left: zu, nb_want: zu
    [00:01:30.099,090] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2316: in_left: zu, nb_want: zu
    [00:01:30.110,473] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2319: ssl->f_recv(_timeout)() returned 5 (-0xfffffffb)
    [00:01:30.123,901] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2341: <= fetch input
    [00:01:30.134,460] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3964: dumping 'input record header' (5 bytes)
    [00:01:30.148,925] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3964: 0000:  15 03 01 00 02                                   .....
    [00:01:30.165,191] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3966: input record: msgtype = 21, version = [0x301], msglen = zu
    [00:01:30.179,229] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2156: => fetch input
    [00:01:30.189,758] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2296: in_left: zu, nb_want: zu
    [00:01:30.201,202] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2316: in_left: zu, nb_want: zu
    [00:01:30.212,585] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2319: ssl->f_recv(_timeout)() returned 2 (-0xfffffffe)
    [00:01:30.226,013] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2341: <= fetch input
    [00:01:30.236,541] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: dumping 'input record from network' (7 bytes)
    [00:01:30.251,556] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0000:  15 03 01 00 02 02 70                             ......p
    [00:01:30.268,005] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:5218: got an alert message, type: [2:112]
    [00:01:30.280,303] <err> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:5225: is a fatal alert message (msg 112)
    [00:01:30.292,602] <err> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4353: mbedtls_ssl_handle_message_type() returned -30592 (-0x7780)
    [00:01:30.307,037] <err> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1200: mbedtls_ssl_read_record() returned -30592 (-0x7780)
    [00:01:30.321,533] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4674: <= handshake
    [00:01:30.332,153] <err> net_sock_tls: TLS handshake error: -0x7780
    Will continue to investigate the new error:
    "TLS handshake error: -0x7780"
    Edit: Also, a quick question: Currently I'm using "IPPROTO_TLS_1_2", but I saw that "IPPROTO_TLS_1_3" also exists. Is the 1.3 version smaller/ more optimised (less RAM and ROM)?
