Enabling the TLS layer to get a HTTPS connection going.
7343.nrf7002dk_nrf5340_cpuapp_ns.conf3124.prj.confHello everyone.
WE're trying to make a https connection with google.com and execute a GET request.
Wifi connection is working; DHCP seems to be working (my personal assumption given the log message we get: "Resolved: [(1, 1, 6, '', ('142.250.201.206', 443))]" which indicates that getaddrinfo() works); but when trying to initiate the socket via TLS, something strange happens: we get the error "OSError: 109".
Inserting some debug prints inside subsys/net/lib/sockets/, we found the culprit to be the function "int zsock_setsockopt_ctx(struct net_context *ctx, int level, int optname, const void *optval, socklen_t optlen)".
The function call that triggers error 109 is:  res = setsockopt(socket->ctx, SOL_TLS, TLS_PEER_VERIFY, &verify, sizeof(verify));
No matter what other option we try to set via setsockopt(), it will fail with the 109 error since the implementation for setsockopt() is somehow set to sockets_inet.c (whose implementation does not recognise SOL_TLS as a valid in its switches) instead of sockets_tls.c (which has handling for SOL_TLS in its switches). My personal hunch is that the config options set in the project are somehow wrong. Can someone please take a look over our .conf files? Maybe we can find the culprit. :)
We can provide any extra code snippets that are necessary for debugging and/ or run any tests. Have a great day and hope to hear from you soon!
  • Current hypothesis is that the error comes from "MBEDTLS_SSL_ALERT_MSG_UNRECOGNIZED_NAME". This might come from the order I'm trying to do the request.
    My order: connect to WiFi network -> getaddrinfo() -> setup socket -> socket connect -> PEER_VERIFY, TAG_LIST, HOSTNAME socket options being set -> send socket request
    What I saw in the https_client sample: connect to WiFi network -> getaddrinfo() -> setup socket -> PEER_VERIFY, TAG_LIST, HOSTNAME socket options being set -> socket connect -> send socket request
    I assume the https_client sample's order is the right one, so trying to do it that way now. Sadly, that brings a new error when trying to socket connect:
    >>> print("Connecting to:", result[0][-1])
    Connecting to: ('142.251.39.14', 443)
    >>> s.connect(result[0][-1])
    DNS message size: 44
    DNS message content (hex):50 4e 81 80 00 01 00 01 00 00 00 00 06 67 6f 6f 67 6c 65 03 63 6f 6d 00 00 01 00 01 c0 0c 00 01 00 01 00 00 00 c0 00 04 8e fb 27 0e
      File "<stdin>", line 1, in <module>
    OSError: [Errno 2] ENOENT
    Adding even more debugging code, I reached the function "tls_mbedtls_set_credentials()" inside sockets_tls.c. In there, there's a loop:
    while ((cred = credential_next_get(tag, cred)) != NULL) {
    which doesn't even enter, so it goes to the next section where it throws the above error:
    if (!tag_found) {
        err = -ENOENT;
        goto exit;
    Tudor B. said:
    since I had a suspicion that allowing MBEDTLS to have its own stack would somehow use up more RAM than by not letting it.
    This seems to have COMPLETELY unlocked MBEDTLS!
    Disabling the dedicated mbedtls .heap can cause issues, as this will then fallback to using the system heap (CONFIG_HEAP_MEM_POOL_SIZE).
    If you do not use alot of heap, then you're fine, but this will require added runtime test and verification to ensure no heap overflow.
    So, we know that a https_client sample is able to respond to the SERVER_HELLO with a CLIENT_HELLO (which is the one that we're missing here).
    There can be several reasons for this, but the server tells us a fatal error with 112, which is a strange response, but might point to missing mbedtls features, if you read into this stack overflow thread:
    https://stackoverflow.com/questions/74678330/ssl-tls-handshake-failed-unrecognized-name
    Q1: Do you have SNI enabled in mbedtls?
    CONFIG_MBEDTLS_SSL_SERVER_NAME_INDICATION
    Q2: Could you share your full .config file? I want to see which mbedtls features are enabled, and which are not.
    Q3: Recreating this locally at my end will require micropy. Can you share which version of micropy (and zephyr) that you use and a brief of the socket commands that you use, so I can try this on my end?
    HĂĄkon
  • Hello Hakon.
    A1: "CONFIG_MBEDTLS_SSL_SERVER_NAME_INDICATION" explicitly enabled in the board.conf.
    A2:
    6036.nrf7002dk_nrf5340_cpuapp_ns.conf
    4174.prj.conf
    A3:
    The Zephyr when I do a --pristine build:
    -- Zephyr version: 4.0.99 (/opt/nordic/ncs/v3.0.0/zephyr)
    Or maybe it's best to give you the one that shows up when connecting over serial?:
    *** Booting nRF Connect SDK v3.0.0-3bfc46578e42 ***
    *** Using Zephyr OS v4.0.99-a0e545cb437a ***
    As for the micropython: MicroPython 9ea566c69-dirty on 2025-05-28; zephyr-nrf7002dk with nrf5340
    Socket commands depend a lot on the current implementation. We took over another implementation and started adapting it to get it to work. This is the modsocket.c file:
     * This file is part of the MicroPython project, http://micropython.org/
     * The MIT License (MIT)
     * Copyright (c) 2023 Mariano Goluboff
     * Copyright (c) 2017 Linaro Limited
     * Permission is hereby granted, free of charge, to any person obtaining a copy
     * of this software and associated documentation files (the "Software"), to deal
     * in the Software without restriction, including without limitation the rights
     * to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
     * copies of the Software, and to permit persons to whom the Software is
     * furnished to do so, subject to the following conditions:
     * The above copyright notice and this permission notice shall be included in
     * all copies or substantial portions of the Software.
     * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
     * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
     * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
     * AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
     * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
     * OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
     * THE SOFTWARE.
     #include "py/mpconfig.h"
     #if (CONFIG_NET_SOCKETS && !CONFIG_EXCLUDE_PY_SOCKETS)
     #include "py/runtime.h"
     #include "py/stream.h"
     #include "mpthreadport.c"
     #include <stdio.h>
     #include <errno.h>
     #include <zephyr/kernel.h>
     // Zephyr's generated version header
     #include <version.h>
     #include <zephyr/net/net_pkt.h>
     #include <zephyr/net/dns_resolve.h>
     #include <zephyr/net/socket.h>
     #include <zephyr/posix/fcntl.h>
     #include <zephyr/net/tls_credentials.h>
     #if (CONFIG_NET_SOCKETS_SOCKOPT_TLS || CONFIG_NET_SOCKETS_OFFLOAD)
     #define DEBUG_PRINT 1
     #if DEBUG_PRINT // print debugging info
     #define DEBUG_printf printf
     #else // don't print debugging info
     #define DEBUG_printf(...) (void)0
    #include <string.h>
    #include <stdlib.h>
    #include <zephyr/net/conn_mgr_monitor.h>
    #include <zephyr/net/conn_mgr_connectivity.h>
    #if defined(CONFIG_POSIX_API)
    #include <zephyr/posix/arpa/inet.h>
    #include <zephyr/posix/netdb.h>
    #include <zephyr/posix/unistd.h>
    #include <zephyr/posix/sys/socket.h>
    // Potentiallt necessary...?
    // #include "psa/storage_common.h"
    // #include "psa/protected_storage.h"
     #define GOOGLE_CA_SEC_TAG 16842753  // any unused sec_tag you pick
    /* Binary DER-encoded certificate data */
    #include "cert/r1.crt.inc"
    #define MBEDTLS_SSL_TLS_C 1
     typedef struct _socket_obj_t {
         mp_obj_base_t base;
         int ctx;
         #define STATE_NEW 0
         #define STATE_CONNECTING 1
         #define STATE_CONNECTED 2
         #define STATE_PEER_CLOSED 3
         int8_t state;
         sa_family_t family;
     } socket_obj_t;
    //  static struct dns_resolve_context my_ctx;
     STATIC const mp_obj_type_t socket_type;
     // Helper functions
     #define RAISE_ERRNO(x) { int _err = x; if (_err < 0) mp_raise_OSError(-_err); }
     #define RAISE_SOCK_ERRNO(x) { if ((int)(x) == -1) mp_raise_OSError(errno); }
     STATIC void socket_check_closed(socket_obj_t *socket) {
         if (socket->ctx == -1) {
             // already closed
             mp_raise_OSError(EBADF);
     STATIC void parse_inet_addr(socket_obj_t *socket, mp_obj_t addr_in, struct sockaddr *sockaddr) {
         // We employ the fact that port and address offsets are the same for IPv4 & IPv6
         struct sockaddr_in *sockaddr_in = (struct sockaddr_in *)sockaddr;
         mp_obj_t *addr_items;
         sockaddr_in->sin_family = socket->family;
         size_t address_array_size = (sockaddr_in->sin_family == AF_INET6) ? 4 : 2;
         mp_obj_get_array_fixed_n(addr_in, address_array_size, &addr_items);
         RAISE_ERRNO(net_addr_pton(sockaddr_in->sin_family, mp_obj_str_get_str(addr_items[0]), &sockaddr_in->sin_addr));
         sockaddr_in->sin_port = htons(mp_obj_get_int(addr_items[1]));
     STATIC mp_obj_t format_inet_addr(struct sockaddr *addr, mp_obj_t port) {
         struct sockaddr_in6 *sockaddr_in6 = (struct sockaddr_in6 *)addr;
         char buf[40];
         net_addr_ntop(addr->sa_family, &sockaddr_in6->sin6_addr, buf, sizeof(buf));
         mp_obj_tuple_t *tuple = mp_obj_new_tuple(addr->sa_family == AF_INET ? 2 : 4, NULL);
         tuple->items[0] = mp_obj_new_str(buf, strlen(buf));
         // We employ the fact that port offset is the same for IPv4 & IPv6
         // not filled in
         // tuple->items[1] = mp_obj_new_int(ntohs(((struct sockaddr_in*)addr)->sin_port));
         tuple->items[1] = port;
         if (addr->sa_family == AF_INET6) {
             tuple->items[2] = MP_OBJ_NEW_SMALL_INT(0); // flow_info
             tuple->items[3] = MP_OBJ_NEW_SMALL_INT(sockaddr_in6->sin6_scope_id);
         return MP_OBJ_FROM_PTR(tuple);
     socket_obj_t *socket_new(void) {
         socket_obj_t *socket = m_new_obj(socket_obj_t);
         socket->base.type = (mp_obj_t)&socket_type;
         socket->state = STATE_NEW;
         return socket;
     // Methods
     STATIC void socket_print(const mp_print_t *print, mp_obj_t self_in, mp_print_kind_t kind) {
         socket_obj_t *self = self_in;
         if (self->ctx == -1) {
             mp_printf(print, "<socket NULL>");
         } else {
             mp_printf(print, "<socket %p family=%d>", self->ctx, self->family);
     #include <time.h>
     #include <date_time.h>
     #include <stdio.h> // For printk
    void set_nordic_date_time(void) {
        struct tm dt;
        int ret;
        // Set the desired date and time
        // Example: May 21, 2024, 10:30:00 UTC
        dt.tm_year = 125;
        dt.tm_mon = 5;
        dt.tm_mday = 21;
        dt.tm_hour = 11; // Use UTC hours
        dt.tm_min = 25;
        dt.tm_sec = 0;
        dt.tm_wday = 2; // 0=Sunday, 1=Monday, ..., 6=Saturday (Tuesday)
        // dt.tz = 0; // Timezone offset in minutes from UTC (0 for UTC)
        printk("Attempting to set date and time (YYYY-MM-DD HH:MM:SS) to %04d-%02d-%02d %02d:%02d:%02d...\n",
               dt.tm_year, dt.tm_mon, dt.tm_mday, dt.tm_hour, dt.tm_min, dt.tm_sec);
        // Initialize the date_time library if not already done
        // Depending on your application's init, this might be needed.
        // Check date_time_init() API if required. For simplicity, we assume
        // it might be handled elsewhere or implicitly.
        ret = date_time_set(&dt);
        if (ret == 0) {
            printk("Date and time set successfully using date_time_set.\n");
        } else {
            printk("Failed to set date and time using date_time_set, error: %d\n", ret);
    #include <mbedtls/debug.h>
     STATIC mp_obj_t socket_make_new(const mp_obj_type_t *type, size_t n_args, size_t n_kw, const mp_obj_t *args) {
         mp_arg_check_num(n_args, n_kw, 0, 4, false);
        //  set_nordic_date_time();
         mbedtls_debug_set_threshold(4);
         socket_obj_t *socket = socket_new();
         int family = AF_INET;
         int socktype = SOCK_STREAM;
         int proto = -1;
         if (n_args >= 1) {
             family = mp_obj_get_int(args[0]);
             if (n_args >= 2) {
                 socktype = mp_obj_get_int(args[1]);
                 if (n_args >= 3) {
                     proto = mp_obj_get_int(args[2]);
         if (proto == -1) {
             proto = IPPROTO_TLS_1_2;
             if (socktype != SOCK_STREAM) {
                 proto = IPPROTO_UDP;
        gc_collect();
         int res = tls_credential_add(GOOGLE_CA_SEC_TAG, TLS_CREDENTIAL_CA_CERTIFICATE, r1_crt, r1_crt_len);
         RAISE_SOCK_ERRNO(res);
         printk("Trying to initialize socket...\n");
         printk("Family: %d, socktype: %d, proto: %d \n", family, socktype, proto);
         socket->ctx = zsock_socket(family, socktype, proto);
         printk("Returned value: %d \n", socket->ctx);
         RAISE_SOCK_ERRNO(socket->ctx);
         printk("Done initializing socket! \n");
         socket->family = family;
         return MP_OBJ_FROM_PTR(socket);
    //  #if CONFIG_NET_SOCKETS_OFFLOAD
     STATIC mp_obj_t socket_tlswrap(size_t n_args, const mp_obj_t *pos_args, mp_map_t *kwargs) {
         enum { ARG_sec_tag, ARG_verify, ARG_hostname };
         static const mp_arg_t allowed_args[] = {
             { MP_QSTR_sec_tag, MP_ARG_REQUIRED | MP_ARG_INT },
             { MP_QSTR_verify, MP_ARG_INT, {.u_int = TLS_PEER_VERIFY_REQUIRED} },
             { MP_QSTR_hostname, MP_ARG_KW_ONLY | MP_ARG_OBJ, {.u_obj = mp_const_none} },
         // parse args
         mp_arg_val_t args[MP_ARRAY_SIZE(allowed_args)];
         mp_arg_parse_all(n_args - 1, pos_args + 1, kwargs, MP_ARRAY_SIZE(allowed_args), allowed_args, args);
         socket_obj_t *socket = pos_args[0];
         sec_tag_t sec_tag = args[ARG_sec_tag].u_int;
         int res;
         printk("Trying 1...\n");
         int verify = args[ARG_verify].u_int;
        //  printk("Failed to setup TLS sec tag, err %d\n", errno);
         printk("1 is done\n");
         res = setsockopt(socket->ctx, SOL_TLS, TLS_SEC_TAG_LIST, &sec_tag, sizeof(sec_tag));
         printk("2 is done\n");
         if (args[ARG_hostname].u_obj != mp_const_none) {
             const char *hostname = mp_obj_str_get_str(args[ARG_hostname].u_obj);
             setsockopt(socket->ctx, SOL_TLS, TLS_HOSTNAME, hostname, strlen(hostname));
             printk("3 is done\n");
         return mp_const_none;
     MP_DEFINE_CONST_FUN_OBJ_KW(socket_tlswrap_obj, 1, socket_tlswrap);
    //  #endif
     STATIC mp_obj_t socket_bind(mp_obj_t self_in, mp_obj_t addr_in) {
         socket_obj_t *socket = self_in;
         socket_check_closed(socket);
         struct sockaddr sockaddr;
         parse_inet_addr(socket, addr_in, &sockaddr);
         int res = zsock_bind(socket->ctx, &sockaddr, sizeof(sockaddr));
     STATIC MP_DEFINE_CONST_FUN_OBJ_2(socket_bind_obj, socket_bind);
     STATIC mp_obj_t socket_connect(mp_obj_t self_in, mp_obj_t addr_in) {
         int res = zsock_connect(socket->ctx, &sockaddr, sizeof(sockaddr));
     STATIC MP_DEFINE_CONST_FUN_OBJ_2(socket_connect_obj, socket_connect);
     // method socket.listen([backlog])
     STATIC mp_obj_t socket_listen(size_t n_args, const mp_obj_t *args) {
         socket_obj_t *socket = args[0];
         mp_int_t backlog = MICROPY_PY_SOCKET_LISTEN_BACKLOG_DEFAULT;
         if (n_args > 1) {
             backlog = mp_obj_get_int(args[1]);
             backlog = (backlog < 0) ? 0 : backlog;
         int res = zsock_listen(socket->ctx, backlog);
     STATIC MP_DEFINE_CONST_FUN_OBJ_VAR_BETWEEN(socket_listen_obj, 1, 2, socket_listen);
     STATIC mp_obj_t socket_accept(mp_obj_t self_in) {
         socklen_t addrlen = sizeof(sockaddr);
         int ctx = zsock_accept(socket->ctx, &sockaddr, &addrlen);
         socket_obj_t *socket2 = socket_new();
         socket2->ctx = ctx;
         mp_obj_tuple_t *client = mp_obj_new_tuple(2, NULL);
         client->items[0] = MP_OBJ_FROM_PTR(socket2);
         // TODO
         client->items[1] = mp_const_none;
         return MP_OBJ_FROM_PTR(client);
     STATIC MP_DEFINE_CONST_FUN_OBJ_1(socket_accept_obj, socket_accept);
     STATIC mp_uint_t sock_write(mp_obj_t self_in, const void *buf, mp_uint_t size, int *errcode) {
             // already closed
             *errcode = EBADF;
             return MP_STREAM_ERROR;
         ssize_t len = zsock_send(socket->ctx, buf, size, 0);
         if (len == -1) {
             *errcode = errno;
         return len;
     STATIC mp_obj_t socket_send(mp_obj_t self_in, mp_obj_t buf_in) {
         mp_buffer_info_t bufinfo;
         mp_get_buffer_raise(buf_in, &bufinfo, MP_BUFFER_READ);
         int err = 0;
         mp_uint_t len = sock_write(self_in, bufinfo.buf, bufinfo.len, &err);
         if (len == MP_STREAM_ERROR) {
             mp_raise_OSError(err);
         return mp_obj_new_int_from_uint(len);
     STATIC MP_DEFINE_CONST_FUN_OBJ_2(socket_send_obj, socket_send);
     STATIC mp_uint_t sock_read(mp_obj_t self_in, void *buf, mp_uint_t max_len, int *errcode) {
             // already closed
             *errcode = EBADF;
         ssize_t recv_len = zsock_recv(socket->ctx, buf, max_len, 0);
         if (recv_len == -1) {
             *errcode = errno;
         return recv_len;
     STATIC mp_obj_t socket_recv(mp_obj_t self_in, mp_obj_t len_in) {
         mp_int_t max_len = mp_obj_get_int(len_in);
         vstr_t vstr;
         // +1 to accommodate for trailing \0
         vstr_init_len(&vstr, max_len + 1);
         int err;
         mp_uint_t len = sock_read(self_in, vstr.buf, max_len, &err);
             vstr_clear(&vstr);
         if (len == 0) {
             vstr_clear(&vstr);
             return mp_const_empty_bytes;
         vstr.len = len;
         return mp_obj_new_bytes_from_vstr(&vstr);
     STATIC MP_DEFINE_CONST_FUN_OBJ_2(socket_recv_obj, socket_recv);
     STATIC mp_obj_t socket_setsockopt(size_t n_args, const mp_obj_t *args) {
         (void)n_args; // always 4
         mp_warning(MP_WARN_CAT(RuntimeWarning), "setsockopt() not implemented");
     STATIC MP_DEFINE_CONST_FUN_OBJ_VAR_BETWEEN(socket_setsockopt_obj, 4, 4, socket_setsockopt);
     // method socket.settimeout(value)
    // timeout=0 means non-blocking
    // timeout=None means blocking
    // otherwise, timeout is in seconds
    // static mp_obj_t socket_settimeout(mp_obj_t self_in, mp_obj_t timeout_in) {
    //     mod_network_socket_obj_t *self = MP_OBJ_TO_PTR(self_in);
    //     mp_uint_t timeout;
    //     if (timeout_in == mp_const_none) {
    //         timeout = -1;
    //     } else {
    //         #if MICROPY_PY_BUILTINS_FLOAT
    //         timeout = (mp_uint_t)(MICROPY_FLOAT_CONST(1000.0) * mp_obj_get_float(timeout_in));
    //         #else
    //         timeout = 1000 * mp_obj_get_int(timeout_in);
    //         #endif
    //     if (self->nic == MP_OBJ_NULL) {
    //         #if MICROPY_PY_SOCKET_EXTENDED_STATE
    //         // store the timeout in the socket state until a NIC is bound
    //         self->timeout = timeout;
    //         #else
    //         // not connected
    //         mp_raise_OSError(MP_ENOTCONN);
    //         #endif
    //     } else {
    //         int _errno;
    //         if (self->nic_protocol->settimeout(self, timeout, &_errno) != 0) {
    //             mp_raise_OSError(_errno);
    //     return mp_const_none;
    // static MP_DEFINE_CONST_FUN_OBJ_2(socket_settimeout_obj, socket_settimeout);
     STATIC mp_obj_t socket_setblocking(mp_obj_t self_in, mp_obj_t blocking) {
         int ret = zsock_fcntl(socket->ctx, F_GETFL, 0);
         if (ret == -1) {
             mp_raise_OSError(-errno);
         if (mp_obj_is_true(blocking)) {
             ret = zsock_fcntl(socket->ctx, F_SETFL, ret & ~(O_NONBLOCK));
         } else {
             ret = zsock_fcntl(socket->ctx, F_SETFL, ret | O_NONBLOCK);
         if (ret == -1) {
     STATIC MP_DEFINE_CONST_FUN_OBJ_2(socket_setblocking_obj, socket_setblocking);
     STATIC mp_obj_t socket_makefile(size_t n_args, const mp_obj_t *args) {
         (void)n_args;
         return args[0];
     STATIC MP_DEFINE_CONST_FUN_OBJ_VAR_BETWEEN(socket_makefile_obj, 1, 3, socket_makefile);
     STATIC mp_uint_t sock_ioctl(mp_obj_t o_in, mp_uint_t request, uintptr_t arg, int *errcode) {
         socket_obj_t *socket = o_in;
         (void)arg;
         switch (request) {
             case MP_STREAM_CLOSE:
                 if (socket->ctx != -1) {
                     int res = zsock_close(socket->ctx);
                     if (res == -1) {
                         *errcode = errno;
                     socket->ctx = -1;
                 return 0;
                 *errcode = MP_EINVAL;
     #if CONFIG_PDN
     STATIC mp_obj_t socket_pdn(mp_obj_t self_in, mp_obj_t id) {
         if (!mp_obj_is_int(id)) {
             mp_raise_TypeError(MP_ERROR_TEXT("ID must be an integer"));
         int pdn_id = mp_obj_get_int(id);
         int ret = setsockopt(socket->ctx, SOL_SOCKET, SO_BINDTOPDN, &pdn_id, sizeof(pdn_id));
         if (ret) {
             mp_raise_OSError(ret);
     STATIC MP_DEFINE_CONST_FUN_OBJ_2(socket_pdn_obj, socket_pdn);
     STATIC const mp_rom_map_elem_t socket_locals_dict_table[] = {
         { MP_ROM_QSTR(MP_QSTR___del__), MP_ROM_PTR(&mp_stream_close_obj) },
         { MP_ROM_QSTR(MP_QSTR_close), MP_ROM_PTR(&mp_stream_close_obj) },
         { MP_ROM_QSTR(MP_QSTR_bind), MP_ROM_PTR(&socket_bind_obj) },
         { MP_ROM_QSTR(MP_QSTR_connect), MP_ROM_PTR(&socket_connect_obj) },
         { MP_ROM_QSTR(MP_QSTR_listen), MP_ROM_PTR(&socket_listen_obj) },
         { MP_ROM_QSTR(MP_QSTR_accept), MP_ROM_PTR(&socket_accept_obj) },
         { MP_ROM_QSTR(MP_QSTR_send), MP_ROM_PTR(&socket_send_obj) },
         { MP_ROM_QSTR(MP_QSTR_recv), MP_ROM_PTR(&socket_recv_obj) },
         { MP_ROM_QSTR(MP_QSTR_setsockopt), MP_ROM_PTR(&socket_setsockopt_obj) },
        //  { MP_ROM_QSTR(MP_QSTR_settimeout), MP_ROM_PTR(&socket_settimeout_obj) },
         { MP_ROM_QSTR(MP_QSTR_setblocking), MP_ROM_PTR(&socket_setblocking_obj) },
         { MP_ROM_QSTR(MP_QSTR_read), MP_ROM_PTR(&mp_stream_read_obj) },
         { MP_ROM_QSTR(MP_QSTR_readinto), MP_ROM_PTR(&mp_stream_readinto_obj) },
         { MP_ROM_QSTR(MP_QSTR_readline), MP_ROM_PTR(&mp_stream_unbuffered_readline_obj) },
         { MP_ROM_QSTR(MP_QSTR_write), MP_ROM_PTR(&mp_stream_write_obj) },
         { MP_ROM_QSTR(MP_QSTR_makefile), MP_ROM_PTR(&socket_makefile_obj) },
         { MP_ROM_QSTR(MP_QSTR_tlswrap), MP_ROM_PTR(&socket_tlswrap_obj) },
         #if CONFIG_PDN
         { MP_ROM_QSTR(MP_QSTR_pdn), MP_ROM_PTR(&socket_pdn_obj) },
        //  #endif
     STATIC MP_DEFINE_CONST_DICT(socket_locals_dict, socket_locals_dict_table);
     STATIC const mp_stream_p_t socket_stream_p = {
         .read = sock_read,
         .write = sock_write,
         .ioctl = sock_ioctl,
     STATIC MP_DEFINE_CONST_OBJ_TYPE(
         socket_type,
         MP_QSTR_socket,
         MP_TYPE_FLAG_NONE,
         make_new, socket_make_new,
         print, socket_print,
         protocol, &socket_stream_p,
         locals_dict, &socket_locals_dict
     // getaddrinfo() implementation
     typedef struct _getaddrinfo_state_t {
         mp_obj_t result;
         struct k_sem sem;
         mp_obj_t port;
         int status;
         mp_thread_t *calling_thread_state;
     } getaddrinfo_state_t;
     void dns_resolve_cb(enum dns_resolve_status status, struct dns_addrinfo *info, void *user_data) {
        if (!user_data) {
            printk("DNS CALLBACK: user_data is NULL!\n");
            return;
        getaddrinfo_state_t *state = user_data;
        // Set the MicroPython thread state for this callback
        mp_thread_set_state(state->calling_thread_state);
        printk("DNS CALLBACK: status=%d\n", status);
        // Process valid info
        if (info != NULL && info->ai_addr.sa_family != 0) {
            // Safety: make sure address is valid
            if (info->ai_addr.sa_family != AF_INET && info->ai_addr.sa_family != AF_INET6) {
                printk("DNS CALLBACK: invalid sa_family=%d\n", info->ai_addr.sa_family);
                // We could set an error here, but for now, just ignore this invalid entry.
                // state->status = -EINVAL; // Consider setting this if needed
                return;
            mp_obj_tuple_t *tuple = mp_obj_new_tuple(5, NULL);
            tuple->items[0] = MP_OBJ_NEW_SMALL_INT(info->ai_family);
            tuple->items[1] = MP_OBJ_NEW_SMALL_INT(SOCK_STREAM);
            tuple->items[2] = MP_OBJ_NEW_SMALL_INT(IPPROTO_TCP);
            tuple->items[3] = MP_OBJ_NEW_QSTR(MP_QSTR_);
            tuple->items[4] = format_inet_addr(&info->ai_addr, state->port);
            mp_obj_list_append(state->result, MP_OBJ_FROM_PTR(tuple));
            // Do NOT give semaphore here, wait for final info == NULL call
            return;
        // If info is NULL, it signals the end of results for this query type or an error
        if (info == NULL) {
             if (status != DNS_EAI_ALLDONE && state->status == 0) {
                // If it's an error status and we haven't recorded one yet
                state->status = status;
                printk("Setting final error status: %d\n", status);
            } else if (status == DNS_EAI_ALLDONE && state->status == 0 && mp_obj_len(state->result) == 0) {
                 // Handle the case where ALLDONE is received but no addresses were found, and no error was set yet.
                 // This might indicate a resolution failure even if status was 0 initially.
                 state->status = -ENOENT; // Or another appropriate error code for no address found
                 printk("Setting status to ENOENT: %d\n", state->status);
            // Always give the semaphore when info is NULL to signal completion for this query type
            printk("Giving semaphore on info == NULL\n");
            k_sem_give(&state->sem);
     STATIC mp_obj_t mod_getaddrinfo(size_t n_args, const mp_obj_t *args) {
        mp_obj_t host_in = args[0], port_in = args[1];
        const char *host = mp_obj_str_get_str(host_in);
        mp_int_t family = AF_INET;
        if (n_args > 2) {
            family = mp_obj_get_int(args[2]);
        printk("Using system DNS resolver...\n");
        getaddrinfo_state_t state;
        state.port = port_in;
        state.result = mp_obj_new_list(0, NULL);
        state.calling_thread_state = mp_thread_get_state();
        k_sem_init(&state.sem, 0, UINT_MAX);
        for (int i = 2; i--;) {
            int type = (family != AF_INET6 ? DNS_QUERY_TYPE_A : DNS_QUERY_TYPE_AAAA);
            printk("Querying DNS for %s (type %d)...\n", host, type);
            RAISE_ERRNO(dns_get_addr_info(host, type, NULL, dns_resolve_cb, &state, 5000));
            printk("semaphore wait...1\n");
            if (k_sem_take(&state.sem, K_SECONDS(10)) != 0) {
                printk("semaphore wait...2\n");
                mp_raise_OSError(ETIMEDOUT);
            if (family != 0) {
            family = AF_INET6;
        printk("something...1\n");
        mp_int_t len = MP_OBJ_SMALL_INT_VALUE(mp_obj_len(state.result));
        if (state.status != 0 && len == 0) {
            mp_raise_OSError(state.status);
        return state.result;
     STATIC MP_DEFINE_CONST_FUN_OBJ_VAR_BETWEEN(mod_getaddrinfo_obj, 2, 3, mod_getaddrinfo);
     #if !CONFIG_NET_SOCKETS_OFFLOAD
     STATIC mp_obj_t pkt_get_info(void) {
         struct k_mem_slab *rx, *tx;
         struct net_buf_pool *rx_data, *tx_data;
         net_pkt_get_info(&rx, &tx, &rx_data, &tx_data);
         mp_obj_tuple_t *t = MP_OBJ_TO_PTR(mp_obj_new_tuple(4, NULL));
         t->items[0] = MP_OBJ_NEW_SMALL_INT(k_mem_slab_num_free_get(rx));
         t->items[1] = MP_OBJ_NEW_SMALL_INT(k_mem_slab_num_free_get(tx));
         t->items[2] = MP_OBJ_NEW_SMALL_INT(rx_data->avail_count);
         t->items[3] = MP_OBJ_NEW_SMALL_INT(tx_data->avail_count);
         return MP_OBJ_FROM_PTR(t);
     STATIC MP_DEFINE_CONST_FUN_OBJ_0(pkt_get_info_obj, pkt_get_info);
     STATIC const mp_rom_map_elem_t mp_module_socket_globals_table[] = {
         { MP_ROM_QSTR(MP_QSTR___name__), MP_ROM_QSTR(MP_QSTR_socket) },
         // objects
         { MP_ROM_QSTR(MP_QSTR_socket), MP_ROM_PTR(&socket_type) },
         // class constants
         { MP_ROM_QSTR(MP_QSTR_AF_INET), MP_ROM_INT(AF_INET) },
         { MP_ROM_QSTR(MP_QSTR_AF_INET6), MP_ROM_INT(AF_INET6) },
         { MP_ROM_QSTR(MP_QSTR_AF_PACKET), MP_ROM_INT(AF_PACKET) },
         { MP_ROM_QSTR(MP_QSTR_SOCK_STREAM), MP_ROM_INT(SOCK_STREAM) },
         { MP_ROM_QSTR(MP_QSTR_SOCK_DGRAM), MP_ROM_INT(SOCK_DGRAM) },
         { MP_ROM_QSTR(MP_QSTR_SOCK_RAW), MP_ROM_INT(SOCK_RAW) },
         { MP_ROM_QSTR(MP_QSTR_IPPROTO_TLS_1_2), MP_ROM_INT(IPPROTO_TLS_1_2) },
         { MP_ROM_QSTR(MP_QSTR_TLS_PEER_VERIFY_NONE), MP_ROM_INT(TLS_PEER_VERIFY_NONE) },
         { MP_ROM_QSTR(MP_QSTR_TLS_PEER_VERIFY_OPTIONAL), MP_ROM_INT(TLS_PEER_VERIFY_OPTIONAL) },
         { MP_ROM_QSTR(MP_QSTR_TLS_PEER_VERIFY_REQUIRED), MP_ROM_INT(TLS_PEER_VERIFY_REQUIRED) },
         { MP_ROM_QSTR(MP_QSTR_SOL_SOCKET), MP_ROM_INT(1) },
         { MP_ROM_QSTR(MP_QSTR_SO_REUSEADDR), MP_ROM_INT(2) },
         { MP_ROM_QSTR(MP_QSTR_getaddrinfo), MP_ROM_PTR(&mod_getaddrinfo_obj) },
         { MP_ROM_QSTR(MP_QSTR_pkt_get_info), MP_ROM_PTR(&pkt_get_info_obj) },
     STATIC MP_DEFINE_CONST_DICT(mp_module_socket_globals, mp_module_socket_globals_table);
     const mp_obj_module_t mp_module_socket = {
         .base = { &mp_type_module },
         .globals = (mp_obj_dict_t *)&mp_module_socket_globals,
     MP_REGISTER_EXTENSIBLE_MODULE(MP_QSTR_socket, mp_module_socket);
     #endif // (CONFIG_NET_SOCKETS && !CONFIG_EXCLUDE_PY_SOCKETS)
    And the "Wifi file" (as I like to call it):
     * Development of the code in this file was sponsored by Microbric Pty Ltd
     * and Mnemote Pty Ltd
     * Copyright (c) 2016, 2017 Nick Moore @mnemote
     * Copyright (c) 2017 "Eric Poulsen" <[email protected]>
     * Based on esp8266/modnetwork.c which is Copyright (c) 2015 Paul Sokolovsky
     * And the ESP IDF example code which is Public Domain / CC0
     * THE SOFTWARE.
     #include <string.h>
     #include "py/objlist.h"
     #include "py/mphal.h"
     #include "extmod/modnetwork.h"
     #include "modnetwork.h"
     #if MICROPY_PY_NETWORK_WLAN
     LOG_MODULE_REGISTER(wifimod, CONFIG_LOG_DEFAULT_LEVEL);
     #include <stdio.h>
     #include <stdlib.h>
     #include <zephyr/shell/shell.h>
     #include <zephyr/init.h>
     #include <zephyr/net/net_if.h>
     #include <zephyr/net/wifi_mgmt.h>
     #include <zephyr/net/wifi_utils.h>
     #include <net/wifi_ready.h>
     #include <zephyr/net/dhcpv4_server.h>
     #include <zephyr/net/net_event.h>
     #include <zephyr/net/ethernet.h>
     #include <zephyr/net/ethernet_mgmt.h>
     #include "net_private.h"
     #define WIFI_SHELL_MODULE "wifi"
     #ifdef CONFIG_WIFI_MGMT_RAW_SCAN_RESULTS_ONLY
     #define WIFI_SHELL_MGMT_EVENTS (NET_EVENT_WIFI_RAW_SCAN_RESULT |                \
    				 NET_EVENT_WIFI_SCAN_DONE)
     #else
     #define WIFI_SHELL_MGMT_EVENTS (NET_EVENT_WIFI_SCAN_RESULT |		\
    				 NET_EVENT_WIFI_SCAN_DONE |		\
    				 NET_EVENT_WIFI_RAW_SCAN_RESULT)
     #define SCAN_TIMEOUT_MS 10000
     #define WIFI_MAC_MAX_LEN 17
     #define STATUS_POLLING_MS   300
    // WiFi security type definitions for MicroPython
    #define MP_WIFI_SECURITY_NONE (0)
    #define MP_WIFI_SECURITY_PSK (1)
    #define MP_WIFI_SECURITY_PSK_SHA256 (2)
    #define MP_WIFI_SECURITY_SAE (3)
    #define MP_WIFI_SECURITY_SAE_HNP (3)  // Same as SAE
    #define MP_WIFI_SECURITY_SAE_H2E (4)
    #define MP_WIFI_SECURITY_SAE_AUTO (5)
    #define MP_WIFI_SECURITY_WAPI (6)
    #define MP_WIFI_SECURITY_EAP (7)
    #define MP_WIFI_SECURITY_EAP_TLS (7)  // Same as EAP
    #define MP_WIFI_SECURITY_WEP (8)
    #define MP_WIFI_SECURITY_WPA_PSK (9)
    #define MP_WIFI_SECURITY_WPA_AUTO_PERSONAL (10)
    #define MP_WIFI_SECURITY_DPP (11)
    #define MP_WIFI_SECURITY_EAP_PEAP_MSCHAPV2 (12)
    #define MP_WIFI_SECURITY_EAP_PEAP_GTC (13)
    #define MP_WIFI_SECURITY_EAP_TTLS_MSCHAPV2 (14)
    #define MP_WIFI_SECURITY_EAP_PEAP_TLS (15)
    #define MP_WIFI_SECURITY_EAP_TLS_SHA256 (16)
    /* AP Mode Configuration */
    #define WIFI_AP_SSID       "Pulsar-mPy"
    #define WIFI_AP_PSK        ""
    #define WIFI_AP_IP_ADDRESS "192.168.1.1"
    #define WIFI_AP_NETMASK    "255.255.255.0"
    static struct net_mgmt_event_callback wifi_shell_mgmt_cb;
    static struct net_mgmt_event_callback net_shell_mgmt_cb;
    static struct net_if *ap_iface;
    static struct wifi_connect_req_params ap_config;
    static uint32_t scan_result;
     /* The devicetree node identifier for the "led0" alias. */
    //  #define LED0_NODE DT_ALIAS(led0)
    //  #define LED_SLEEP_TIME_MS   100
    //  static const struct gpio_dt_spec led = GPIO_DT_SPEC_GET(LED0_NODE, gpios);
     static K_SEM_DEFINE(wifi_ready_state_changed_sem, 0, 1);
     static bool wifi_ready_status;
     K_SEM_DEFINE(scan_sem, 0, 1);
     // struct wifi_scan_result wifi_entries[100] = {0};
     struct wifi_scan_result *wifi_entries;
     uint8_t wifi_entries_idx=0;
     static struct {
    	 const struct shell *sh;
    	 union {
    		 struct {
    			 uint8_t connected	: 1;
    			 uint8_t connect_result	: 1;
    			 uint8_t disconnect_requested	: 1;
    			 uint8_t _unused		: 5;
    		 uint8_t all;
     } context;
     typedef struct _wlan_obj_t {
    	mp_obj_base_t base;
    	int mode;  // network.STA_IF or network.AP_IF
    	bool is_active;
    } wlan_obj_t;
    // TODO: Do we need to blink the led when connecting/ connected to the WiFi?
    //  void toggle_led(void)
    // 	 int ret;
    // 	 if (!device_is_ready(led.port)) {
    // 		 LOG_ERR("LED device is not ready");
    // 		 return;
    // 	 ret = gpio_pin_configure_dt(&led, GPIO_OUTPUT_ACTIVE);
    // 	 if (ret < 0) {
    // 		 LOG_ERR("Error %d: failed to configure LED pin", ret);
    // 		 return;
    // 	 while (1) {
    // 		 if (context.connected) {
    // 			 gpio_pin_toggle_dt(&led);
    // 			 k_msleep(LED_SLEEP_TIME_MS);
    // 		 } else {
    // 			 gpio_pin_set_dt(&led, 0);
    //  K_THREAD_DEFINE(led_thread_id, 1024, toggle_led, NULL, NULL, NULL,
    // 		 7, 0, 0);
    static void clear_ipv4_addresses(struct net_if *iface)
        struct net_if_ipv4 *ipv4 = iface->config.ip.ipv4;
        if (ipv4) {
            ARRAY_FOR_EACH(ipv4->unicast, i) {
                if (ipv4->unicast[i].ipv4.is_used) {
                    net_if_ipv4_addr_rm(iface, &ipv4->unicast[i].ipv4.address.in_addr);
    static int cmd_wifi_status(void)
    	 struct net_if *iface = net_if_get_default();
    	 struct wifi_iface_status status = { 0 };
    	 if (net_mgmt(NET_REQUEST_WIFI_IFACE_STATUS, iface, &status,
    				 sizeof(struct wifi_iface_status))) {
    		 LOG_INF("Status request failed");
    		 return -ENOEXEC;
    	 LOG_INF("==================");
    	 LOG_INF("State: %s", wifi_state_txt(status.state));
    	 if (status.state >= WIFI_STATE_ASSOCIATED) {
    		 uint8_t mac_string_buf[sizeof("xx:xx:xx:xx:xx:xx")];
    		 LOG_INF("Interface Mode: %s",
    				wifi_mode_txt(status.iface_mode));
    		 LOG_INF("Link Mode: %s",
    				wifi_link_mode_txt(status.link_mode));
    		 LOG_INF("SSID: %.32s", status.ssid);
    		 LOG_INF("BSSID: %s",
    				net_sprint_ll_addr_buf(
    				 status.bssid, WIFI_MAC_ADDR_LEN,
    				 mac_string_buf, sizeof(mac_string_buf)));
    		 LOG_INF("Band: %s", wifi_band_txt(status.band));
    		 LOG_INF("Channel: %d", status.channel);
    		 LOG_INF("Security: %s", wifi_security_txt(status.security));
    		 LOG_INF("MFP: %s", wifi_mfp_txt(status.mfp));
    		 LOG_INF("RSSI: %d", status.rssi);
    	 return 0;
     #if defined CONFIG_WIFI_NRF70_SKIP_LOCAL_ADMIN_MAC
     static bool local_mac_check(const uint8_t *const mac)
     return ((mac[0] & 0x02) ||
     ((mac[0] == 0x00) && (mac[1] == 0x00) && (mac[2] == 0x5E)));
     #endif /* CONFIG_WIFI_NRF70_SKIP_LOCAL_ADMIN_MAC */
     static void handle_wifi_scan_result(struct net_mgmt_event_callback *cb)
    	 const struct wifi_scan_result *entry =
    		 (const struct wifi_scan_result *)cb->info;
    	 uint8_t ssid_print[WIFI_SSID_MAX_LEN + 1];
    	 wifi_entries[wifi_entries_idx] = *entry;
    	 wifi_entries_idx++;
    	 scan_result++;
    	 if (scan_result == 1U) {
    		 printk("%-4s | %-32s %-5s | %-4s | %-4s | %-5s | %s\n",
    				"Num", "SSID", "(len)", "Chan", "RSSI", "Security", "BSSID");
    	 strncpy(ssid_print, entry->ssid, sizeof(ssid_print) - 1);
    	 ssid_print[sizeof(ssid_print) - 1] = '\0';
    	 __ASSERT(!local_mac_check(entry->mac), "Locally administered MAC found: %s\n", ssid_print);
    	 printk("%-4d | %-32s %-5u | %-4u | %-4d | %-5s | %s\n",
    			 scan_result, ssid_print, entry->ssid_length,
    			 entry->channel, entry->rssi,
    			 wifi_security_txt(entry->security),
    			 ((entry->mac_length) ?
    			 net_sprint_ll_addr_buf(entry->mac, WIFI_MAC_ADDR_LEN, mac_string_buf,
    						 sizeof(mac_string_buf)) : ""));
     static void handle_wifi_scan_done(struct net_mgmt_event_callback *cb)
    	 const struct wifi_status *status =
    		 (const struct wifi_status *)cb->info;
    	 if (status->status) {
    		 LOG_ERR("Scan request failed (%d)", status->status);
    	 } else {
    		 printk("Scan request done\n");
    	 scan_result = 0U;
    	 k_sem_give(&scan_sem);
     static void handle_wifi_connect_result(struct net_mgmt_event_callback *cb)
    		 (const struct wifi_status *) cb->info;
    		 return;
    		 LOG_ERR("Connection failed (%d)", status->status);
    	 } else {
    		 LOG_INF("Connected");
    		 context.connected = true;
    	 context.connect_result = true;
     static void handle_wifi_disconnect_result(struct net_mgmt_event_callback *cb)
    	 if (!context.connected) {
    		 return;
    	 if (context.disconnect_requested) {
    		 LOG_INF("Disconnection request %s (%d)",
    			  status->status ? "failed" : "done",
    					 status->status);
    		 context.disconnect_requested = false;
    	 } else {
    		 LOG_INF("Received Disconnected");
    		 context.connected = false;
    	 // cmd_wifi_status();
     static void wifi_mgmt_event_handler(struct net_mgmt_event_callback *cb,
    					  uint32_t mgmt_event, struct net_if *iface)
    	 switch (mgmt_event) {
    	 case NET_EVENT_WIFI_SCAN_RESULT:
    		 handle_wifi_scan_result(cb);
    	 case NET_EVENT_WIFI_RAW_SCAN_RESULT:
    		 handle_raw_scan_result(cb);
    	 case NET_EVENT_WIFI_SCAN_DONE:
    		 handle_wifi_scan_done(cb);
    	 case NET_EVENT_IPV4_DHCP_BOUND:
    		 LOG_INF("Wifi: Got IP via DHCP");
    	 case NET_EVENT_WIFI_CONNECT_RESULT:
    		 LOG_INF("Wi-Fi connect result: status...");
    		const struct wifi_status *status = (const struct wifi_status *)cb->info;
    			LOG_ERR("Connection failed (reason: %d)", status->status);
    			context.connect_result = true; // Ensure we don't hang
    		 handle_wifi_connect_result(cb);
    	 case NET_EVENT_WIFI_DISCONNECT_RESULT:
    		 LOG_INF("Wi-Fi disconnect result: status...");
    		 handle_wifi_disconnect_result(cb);
     static void print_dhcp_ip(struct net_mgmt_event_callback *cb)
    	 /* Get DHCP info from struct net_if_dhcpv4 and print */
    	 const struct net_if_dhcpv4 *dhcpv4 = cb->info;
    	 const struct in_addr *addr = &dhcpv4->requested_ip;
    	 char dhcp_info[128];
    	 net_addr_ntop(AF_INET, addr, dhcp_info, sizeof(dhcp_info));
    	 printk("DHCP IP address: %s\r\n", dhcp_info);
     static void net_mgmt_event_handler(struct net_mgmt_event_callback *cb,
    		 LOG_INF("Net MGMT: Got IP via DHCP");
    		 print_dhcp_ip(cb);
     void net_mgmt_callback_init(void)
    	 memset(&context, 0, sizeof(context));
    	 net_mgmt_init_event_callback(&wifi_shell_mgmt_cb,
    					  wifi_mgmt_event_handler,
    					  WIFI_SHELL_MGMT_EVENTS);
    	 net_mgmt_add_event_callback(&wifi_shell_mgmt_cb);
    	 net_mgmt_init_event_callback(&net_shell_mgmt_cb,
    					  net_mgmt_event_handler,
    					  NET_EVENT_IPV4_DHCP_BOUND);
    	 net_mgmt_add_event_callback(&net_shell_mgmt_cb);
    	 printk("Starting %s with CPU frequency: %d MHz\r\n", CONFIG_BOARD, SystemCoreClock/MHZ(1));
    	 k_sleep(K_SECONDS(1));
     #ifdef CONFIG_WIFI_READY_LIB
     void wifi_ready_cb(bool wifi_ready)
    	 LOG_DBG("Is Wi-Fi ready?: %s", wifi_ready ? "yes" : "no");
    	 wifi_ready_status = wifi_ready;
    	 k_sem_give(&wifi_ready_state_changed_sem);
     static int register_wifi_ready(void)
    	 int ret = 0;
    	 wifi_ready_callback_t cb;
    	 struct net_if *iface = net_if_get_first_wifi();
    	 if (!iface) {
    		 LOG_ERR("Failed to get Wi-Fi interface");
    		 return -1;
    	 cb.wifi_ready_cb = wifi_ready_cb;
    	 LOG_DBG("Registering Wi-Fi ready callbacks");
    	 ret = register_wifi_ready_callback(cb, iface);
    	 if (ret) {
    		 LOG_ERR("Failed to register Wi-Fi ready callbacks %s", strerror(ret));
    		 return ret;
    	 return ret;
     #endif /* CONFIG_WIFI_READY_LIB */
     static mp_obj_t wlan_isconnected(mp_obj_t self_in) {
    	 struct net_if *iface = net_if_get_wifi_sta();
    	 if (!iface) {
    		 return mp_const_false;
    	 struct wifi_iface_status status = {0};
    	 int ret = net_mgmt(NET_REQUEST_WIFI_IFACE_STATUS, iface,
    						&status, sizeof(struct wifi_iface_status));
    	 if (ret == 0 && status.state == WIFI_STATE_COMPLETED) {
    		 return mp_const_true;
     static MP_DEFINE_CONST_FUN_OBJ_1(wlan_isconnected_obj, wlan_isconnected);
     static bool is_mac_addr_set(struct net_if *iface)
    	 struct net_linkaddr *linkaddr = net_if_get_link_addr(iface);
    	 struct net_eth_addr wifi_addr;
    	 if (!linkaddr || linkaddr->len != WIFI_MAC_ADDR_LEN) {
    		 return false;
    	 memcpy(wifi_addr.addr, linkaddr->addr, WIFI_MAC_ADDR_LEN);
    	 return net_eth_is_addr_valid(&wifi_addr);
     static mp_obj_t wlan_make_new(const mp_obj_type_t *type, size_t n_args, size_t n_kw, const mp_obj_t *args) {
    	 mp_arg_check_num(n_args, n_kw, 1, 1, false);
    	 int mode = mp_obj_get_int(args[0]);
    	 int ret = 0;
    	 if (mode != 0 && mode != 1) {
    		 mp_raise_ValueError(MP_ERROR_TEXT("invalid mode"));
    	 wlan_obj_t *self = m_new_obj(wlan_obj_t);
    	 self->base.type = &zephyr_network_wlan_type;
    	 self->mode = mode;
    	 self->is_active = false;
    	 net_mgmt_callback_init();
    	 ret = register_wifi_ready();
    	 if (ret) {
    		 return ret;
    	 if (!is_mac_addr_set(net_if_get_default())) {
    		 int ret;
    		 struct ethernet_req_params params;
    		 /* Set a local MAC address with Nordic OUI */
    		 if (net_if_is_admin_up(iface)) {
    			 ret = net_if_down(iface);
    			 if (ret < 0 && ret != -EALREADY) {
    				 printk("Cannot bring down iface (%d)\r\n", ret);
    				 goto _end;
    		 ret = net_bytes_from_str(params.mac_address.addr, sizeof(CONFIG_WIFI_MAC_ADDRESS),
    					  CONFIG_WIFI_MAC_ADDRESS);
    		 if (ret) {
    			 printk("Failed to parse MAC address: %s (%d)\r\n", CONFIG_WIFI_MAC_ADDRESS, ret);
    			 goto _end;
    		 net_mgmt (NET_REQUEST_ETHERNET_SET_MAC_ADDRESS, iface, &params, sizeof(params));
    		 ret = net_if_up(iface);
    			 printk("Cannot bring up iface (%d)\r\n", ret);
    			 goto _end;
    		 printk("OTP not programmed, proceeding with local MAC: %s\r\n", net_sprint_ll_addr(net_if_get_link_addr(iface)->addr, net_if_get_link_addr(iface)->len));
    	 if (mode == 1) { // AP mode
    		// clear assigned IPs when starting
    		clear_ipv4_addresses(iface);
    	 self->is_active = true;
     _end:
    	 return MP_OBJ_FROM_PTR(self);
     static mp_obj_t wlan_active(size_t n_args, const mp_obj_t *args) {
    	 wlan_obj_t *self = MP_OBJ_TO_PTR(args[0]);
    	 if (n_args == 1) {
    		 return mp_obj_new_bool(self->is_active);
    	 } else {
     static MP_DEFINE_CONST_FUN_OBJ_VAR_BETWEEN(wlan_active_obj, 1, 2, wlan_active);
     static mp_obj_t network_wlan_scan(mp_obj_t self_in) {
    	 struct wifi_scan_params params = {.scan_type = WIFI_SCAN_TYPE_ACTIVE, .bands = 0 };
    	 mp_obj_t wifi_networks_list = mp_obj_new_list(0, NULL);
    	 // CLear buffers
    	 wifi_entries = calloc(100, sizeof(struct wifi_scan_result));
    	 wifi_entries_idx=0;
    	 if (net_mgmt(NET_REQUEST_WIFI_SCAN, iface, &params,
    			 sizeof(struct wifi_scan_params))) {
    				 printk("Scan request failed\r\n");
    		 goto _end;
    	 printk("Scan requested\n\r");
    	 k_sem_take(&scan_sem, K_MSEC(SCAN_TIMEOUT_MS));
    	 printk("Found %d networks. \n\r", wifi_entries_idx);
    	 for (int i=0; i< wifi_entries_idx; i++)
    		 strncpy(mac_string_buf, net_sprint_ll_addr_buf(wifi_entries[i].mac, WIFI_MAC_ADDR_LEN, mac_string_buf, sizeof(mac_string_buf)), strlen(mac_string_buf));
    		 printk("Network ID: %s & Network MAC: %s \n\r", wifi_entries[i].ssid, mac_string_buf);
    		 // Debug code
    		 // printk("Network ID: %s & Network MAC: %s \n\r", wifi_entries[i].ssid, net_sprint_ll_addr_buf(wifi_entries[i].mac, WIFI_MAC_ADDR_LEN, mac_string_buf, sizeof(mac_string_buf)));
    		 mp_obj_tuple_t *t = mp_obj_new_tuple(6, NULL);
    		 t->items[0] = mp_obj_new_bytes(wifi_entries[i].ssid, wifi_entries[i].ssid_length);
    		 t->items[1] = mp_obj_new_bytes(mac_string_buf, sizeof(mac_string_buf));
    		 t->items[2] = MP_OBJ_NEW_SMALL_INT(wifi_entries[i].channel);
    		 t->items[3] = MP_OBJ_NEW_SMALL_INT(wifi_entries[i].rssi);
    		 t->items[4] = MP_OBJ_NEW_SMALL_INT(wifi_entries[i].security);
    		 t->items[5] = mp_const_false; // XXX hidden?
    		 mp_obj_list_append(wifi_networks_list, MP_OBJ_FROM_PTR(t));
    	 free(wifi_entries);
    	 // print our board's own MAC address:
    	 const struct net_linkaddr *link_addr = net_if_get_link_addr(iface);
    	 printk("MAC: %02X:%02X:%02X:%02X:%02X:%02X\n",
    		 link_addr->addr[0], link_addr->addr[1], link_addr->addr[2],
    		 link_addr->addr[3], link_addr->addr[4], link_addr->addr[5]);
     _end:
    	 return wifi_networks_list;
     static MP_DEFINE_CONST_FUN_OBJ_1(network_wlan_scan_obj, network_wlan_scan);
     static mp_obj_t network_wlan_connect(size_t n_args, const mp_obj_t *pos_args, mp_map_t *kw_args) {
    	 enum { ARG_ssid, ARG_key, ARG_security, ARG_channel };
    		 { MP_QSTR_, MP_ARG_OBJ, {.u_obj = mp_const_none} },
    		 { MP_QSTR_, MP_ARG_INT, {.u_int = mp_const_none} },
    	 // parse args
    	 mp_arg_parse_all(n_args - 1, pos_args + 1, kw_args, MP_ARRAY_SIZE(allowed_args), allowed_args, args);
    	struct wifi_connect_req_params cnx_params = {0};
    	size_t len;
    	const char *p;
    	p = mp_obj_str_get_data(args[ARG_ssid].u_obj, &len);
    	cnx_params.ssid = p;
    	cnx_params.ssid_length = MIN(len, WIFI_SSID_MAX_LEN);
    	if (args[ARG_key].u_obj != mp_const_none) {
    		p = mp_obj_str_get_data(args[ARG_key].u_obj, &len);
    		cnx_params.psk = (uint8_t *)p;
    		cnx_params.psk_length = MIN(len, WIFI_PSK_MAX_LEN);
    	if (args[ARG_security].u_int > WIFI_SECURITY_TYPE_MAX) {
            mp_raise_ValueError(MP_ERROR_TEXT("Auth value not valid"));
    	if (args[ARG_channel].u_int != WIFI_CHANNEL_ANY &&
            args[ARG_channel].u_int > WIFI_CHANNEL_MAX) {
            mp_raise_ValueError(MP_ERROR_TEXT("invalid channel number"));
    	 cnx_params.security = WIFI_SECURITY_TYPE_PSK;
    	//  cnx_params.channel = 11;
    	cnx_params.security = args[ARG_security].u_int;
        cnx_params.channel = args[ARG_channel].u_int;
    	cnx_params.mfp = WIFI_MFP_DISABLE;
    	cnx_params.timeout = 10000;
    	// Make sure the interface is up
    	if (!net_if_is_up(iface)) {
    		int ret = net_if_up(iface);
    			mp_raise_msg(&mp_type_OSError, MP_ERROR_TEXT("Failed to bring interface up"));
    	 // Ensure WPA supplicant thread is fully initialized
    	 k_sleep(K_MSEC(3000));
    	 if (net_mgmt(NET_REQUEST_WIFI_CONNECT, iface, &cnx_params, sizeof(struct wifi_connect_req_params))) {
    			mp_raise_msg(&mp_type_OSError, MP_ERROR_TEXT("Connection failed"));
    		return mp_obj_new_bool(false);
    	LOG_INF("Connection requested");
    	while (!context.connect_result) {
    		cmd_wifi_status();
    		struct wifi_iface_status iface_status;
    		if (net_mgmt(NET_REQUEST_WIFI_IFACE_STATUS, iface, &iface_status, sizeof(struct wifi_iface_status))) {
    			mp_raise_msg(&mp_type_RuntimeError, MP_ERROR_TEXT("Error getting status"));
    		// return the RFC 2863 operational status (see enum net_if_oper_state):
    		// 0 - NET_IF_OPER_UNKNOWN,        /**< Initial (unknown) value */
    		// 1 - NET_IF_OPER_NOTPRESENT,     /**< Hardware missing */
    		// 2 - NET_IF_OPER_DOWN,           /**< Interface is down */
    		// 3 - NET_IF_OPER_LOWERLAYERDOWN, /**< Lower layer interface is down */
    		// 4 - NET_IF_OPER_TESTING,        /**< Training mode */
    		// 5 - NET_IF_OPER_DORMANT,        /**< Waiting external action */
    		// 6 - NET_IF_OPER_UP,             /**< Interface is up */
    		LOG_INF("Net If state: %d ", iface->if_dev->oper_state);
    		k_sleep(K_MSEC(STATUS_POLLING_MS));
     static MP_DEFINE_CONST_FUN_OBJ_KW(network_wlan_connect_obj, 1, network_wlan_connect);
     STATIC mp_obj_t network_wlan_status(size_t n_args, const mp_obj_t *args) {
    	wlan_if_obj_t *self = MP_OBJ_TO_PTR(args[0]);
    	if (self->if_id == MOD_NETWORK_AP_IF) {
    		mp_raise_NotImplementedError(MP_ERROR_TEXT("Status only on Station interface"));
    	if (n_args == 1) {
    		if (self->if_id != MOD_NETWORK_STA_IF) {
    		uint8_t retval = WIFI_STATE_DISCONNECTED;
    		// TODO: it makes more sense to completely remove this. TBD if that's the case or not
    		// switch (iface_status.state) {
    		// 	case WIFI_STATE_DISCONNECTED:
    		// 	case WIFI_STATE_INTERFACE_DISABLED:
    		// 	case WIFI_STATE_INACTIVE:
    		// 		retval = WIFI_STATE_DISCONNECTED;
    		// 		break;
    		// 	case WIFI_STATE_SCANNING:
    		// 	case WIFI_STATE_ASSOCIATING:
    		// 	case WIFI_STATE_ASSOCIATED:
    		// 	case WIFI_STATE_4WAY_HANDSHAKE:
    		// 		// Return negative status code if authentication failed
    		// 		// if (iface_status.status != 0) {
    		// 		// 	return MP_OBJ_NEW_SMALL_INT(-iface_status.status);
    		// 		// return the RFC 2863 operational status (see enum net_if_oper_state)
    		// 		return MP_OBJ_NEW_SMALL_INT(-iface->if_dev->oper_state);
    		// 		break;
    		// 	case WIFI_STATE_GROUP_HANDSHAKE:
    		// 		retval = WIFI_STATE_AUTHENTICATING;
    		// 		break;
    		// 	case WIFI_STATE_COMPLETED:
    		// 		retval = WIFI_STATE_COMPLETED;
    		// 		break;
    		retval = iface_status.state;
    		return mp_obj_new_int_from_uint(retval);
    	// There's one more argument
    	if (iface_status.state != WIFI_STATE_COMPLETED) {
    		mp_raise_msg(&mp_type_RuntimeError, MP_ERROR_TEXT("Device not connected"));
    	switch ((uintptr_t)args[1]) {
    		case (uintptr_t)MP_OBJ_NEW_QSTR(MP_QSTR_rssi): {
    			return MP_OBJ_NEW_SMALL_INT(iface_status.rssi);
    		case (uintptr_t)MP_OBJ_NEW_QSTR(MP_QSTR_ssid): {
    			return mp_obj_new_str(iface_status.ssid, iface_status.ssid_len);
    		case (uintptr_t)MP_OBJ_NEW_QSTR(MP_QSTR_band): {
    			return mp_obj_new_int_from_uint(iface_status.band);
    		case (uintptr_t)MP_OBJ_NEW_QSTR(MP_QSTR_channel): {
    			return mp_obj_new_int(iface_status.channel);
    		case (uintptr_t)MP_OBJ_NEW_QSTR(MP_QSTR_link_mode): {
    			return mp_obj_new_int_from_uint(iface_status.link_mode);
    		case (uintptr_t)MP_OBJ_NEW_QSTR(MP_QSTR_security): {
    			return mp_obj_new_int_from_uint(iface_status.security);
    		case (uintptr_t)MP_OBJ_NEW_QSTR(MP_QSTR_mfp): {
    			return mp_obj_new_int_from_uint(iface_status.mfp);
    		case (uintptr_t)MP_OBJ_NEW_QSTR(MP_QSTR_bssid): {
    			return mp_obj_new_bytes(iface_status.bssid, WIFI_MAC_ADDR_LEN);
    		case (uintptr_t)MP_OBJ_NEW_QSTR(MP_QSTR_dtim): {
    			return mp_obj_new_int_from_uint(iface_status.dtim_period);
    		case (uintptr_t)MP_OBJ_NEW_QSTR(MP_QSTR_beacon_interval): {
    			return mp_obj_new_int_from_uint(iface_status.beacon_interval);
    		case (uintptr_t)MP_OBJ_NEW_QSTR(MP_QSTR_twt_capable): {
    			return mp_obj_new_bool(iface_status.twt_capable);
    			mp_raise_ValueError(MP_ERROR_TEXT("unknown status param"));
    STATIC MP_DEFINE_CONST_FUN_OBJ_VAR_BETWEEN(network_wlan_status_obj, 1, 2, network_wlan_status);
    STATIC mp_obj_t network_wlan_disconnect(mp_obj_t self_in) {
        wlan_if_obj_t *self = MP_OBJ_TO_PTR(self_in);
            mp_raise_NotImplementedError(MP_ERROR_TEXT("Disconnect only on Station interface"));
        if (net_mgmt(NET_REQUEST_WIFI_DISCONNECT, iface, NULL, 0)) {
            LOG_ERR("Disconnect request failed");
    STATIC MP_DEFINE_CONST_FUN_OBJ_1(network_wlan_disconnect_obj, network_wlan_disconnect);
    static void enable_dhcpv4_server(void)
    	static struct in_addr addr;
    	static struct in_addr netmaskAddr;
    	if (net_addr_pton(AF_INET, WIFI_AP_IP_ADDRESS, &addr)) {
    		LOG_ERR("Invalid address: %s", WIFI_AP_IP_ADDRESS);
    		return;
    	if (net_addr_pton(AF_INET, WIFI_AP_NETMASK, &netmaskAddr)) {
    		LOG_ERR("Invalid netmask: %s", WIFI_AP_NETMASK);
    		return;
    	net_if_ipv4_set_gw(ap_iface, &addr);
    	if (net_if_ipv4_addr_add(ap_iface, &addr, NET_ADDR_MANUAL, 0) == NULL) {
    		LOG_ERR("unable to set IP address for AP interface");
    	if (!net_if_ipv4_set_netmask_by_addr(ap_iface, &addr, &netmaskAddr)) {
    		LOG_ERR("Unable to set netmask for AP interface: %s", WIFI_AP_NETMASK);
    	addr.s4_addr[3] += 10; /* Starting IPv4 address for DHCPv4 address pool. */
    	if (net_dhcpv4_server_start(ap_iface, &addr) != 0) {
    		LOG_ERR("DHCP server is not started for desired IP");
    		return;
    	LOG_INF("DHCPv4 server started...\n");
    STATIC mp_obj_t network_wlan_config(size_t n_args, const mp_obj_t *args, mp_map_t *kwargs) {
    	/* Get AP interface in AP-STA mode. */
    	ap_iface = net_if_get_wifi_sap();
    	if (!ap_iface) {
    		LOG_INF("AP: is not initialized");
    		return mp_obj_new_int(-EIO);
    	LOG_INF("Turning on AP Mode");
    	ap_config.ssid = (const uint8_t *)WIFI_AP_SSID;
    	ap_config.ssid_length = strlen(WIFI_AP_SSID);
    	ap_config.psk = (const uint8_t *)WIFI_AP_PSK;
    	ap_config.psk_length = strlen(WIFI_AP_PSK);
    	ap_config.channel = 11;
    	ap_config.band = WIFI_FREQ_BAND_2_4_GHZ;
    	if (strlen(WIFI_AP_PSK) == 0) {
    		ap_config.security = WIFI_SECURITY_TYPE_NONE;
    	} else {
    		ap_config.security = WIFI_SECURITY_TYPE_PSK;
    	if (!wifi_utils_validate_chan(ap_config.band, ap_config.channel)) {
    		LOG_ERR("Invalid channel %d in %d band", ap_config.channel, ap_config.band);
    	enable_dhcpv4_server();
    	int ret = net_mgmt(NET_REQUEST_WIFI_AP_ENABLE, ap_iface, &ap_config, sizeof(struct wifi_connect_req_params));
    	if (ret) {
    		LOG_ERR("NET_REQUEST_WIFI_AP_ENABLE failed, err: %d", ret);
    	return mp_obj_new_int(ret);
    STATIC MP_DEFINE_CONST_FUN_OBJ_KW(network_wlan_config_obj, 1, network_wlan_config);
    static const mp_rom_map_elem_t wlan_locals_dict_table[] = {
    	{ MP_ROM_QSTR(MP_QSTR_active), MP_ROM_PTR(&wlan_active_obj) },
    	{ MP_ROM_QSTR(MP_QSTR_scan), MP_ROM_PTR(&network_wlan_scan_obj) },
    	{ MP_ROM_QSTR(MP_QSTR_connect), MP_ROM_PTR(&network_wlan_connect_obj) },
    	{ MP_ROM_QSTR(MP_QSTR_disconnect), MP_ROM_PTR(&network_wlan_disconnect_obj) },
    	{ MP_ROM_QSTR(MP_QSTR_config), MP_ROM_PTR(&network_wlan_config_obj) },
    	// { MP_ROM_QSTR(MP_QSTR_ifconfig), MP_ROM_PTR(&wlan_ifconfig_obj) },
    	{ MP_ROM_QSTR(MP_QSTR_isconnected), MP_ROM_PTR(&wlan_isconnected_obj) },
    	{ MP_ROM_QSTR(MP_QSTR_status), MP_ROM_PTR(&network_wlan_status_obj) },
    static MP_DEFINE_CONST_DICT(wlan_locals_dict, wlan_locals_dict_table);
    	zephyr_network_wlan_type,
    	MP_QSTR_WLAN,
    	MP_TYPE_FLAG_NONE,
    	make_new, wlan_make_new,
    	locals_dict, &wlan_locals_dict
    #endif // MICROPY_PY_NETWORK_WLAN
    The steps that I take over serial to get these errors:
    import network
    import usocket as socket
    import time
    wlan = network.WLAN(network.STA_IF)  # Wi-Fi client
    wlan.scan()
    wlan.connect("TP-Link_7474", "55920322", network.SECURITY_PSK, 4)
    def getaddrinfo_to_host(host, port):
        try:
            print("Resolving " + host + "...")
            addr = socket.getaddrinfo(host, port)
            print("Resolved:", addr)
            return addr
        except Exception as e:
            print("DNS Error:", e)
            return None
        return None
    result = getaddrinfo_to_host("google.com", 443)
    if result:
        print("Success!")
    else:
        print("Failed to resolve host")
    s = None
    s = socket.socket()
    ## point 1
    trusted_ca_tag = 16842753
    print("Performing TLS handshake...")
    s.tlswrap(sec_tag=trusted_ca_tag, hostname="google.com")
    print("TLS Handshake complete.")
    ## point 2
    print("TCP Connected.")
    Note: depending on what error you want to pop up, you can reverse point 1 and 2. Currently I'm debugging with them not reversed and slowly inching forward. For now, I discovered that the correct value is "trusted_ca_tag = 16842753".
    Tudor B. said:
    Yes, these are the project files, ie. my_app/prj.conf and my_app/boards/$(board).conf, but it would be good to see the full compiled config file.
    This is to verify what is set as the default configurations, and to ensure that no changes was applied after initial configuration/building.
    This seems to be a local build of micropy:
    /opt/repos/micropython [master|✚ 3…2] $ git show 9ea566c69
    fatal: ambiguous argument '9ea566c69': unknown revision or path not in the working tree.
    Use '--' to separate paths from revisions, like this:
    'git <command> [<revision>...] -- [<file>...]'
    You seem to have local changes, as I am unable to build properly with your suggested changes. The first issue is the missing header mpconfigport_full.h, but I found that in one of your other on-going cases.
    Then this was emitted:
    ----- Installing platform NS -----
    [116/679] cd /opt/repos/micropython/build/zephyr && /usr/bin/cmake -E make_directory...yr/../../py/makeversionhdr.py /opt/repos/micropython/build/zephyr/genhdr/mpversion.h
    GEN /opt/repos/micropython/build/zephyr/genhdr/mpversion.h
    [439/679] Generating genhdr/qstr.i.last
    FAILED: genhdr/qstr.i.last /opt/repos/micropython/build/zephyr/genhdr/qstr.i.last
    cd /opt/repos/micropython/build/zephyr && /home/hkn/zephyrproject/.venv/bin/python /opt/repos/micropython/ports/zephyr/../../py/makeqstrdefs.py pp /opt/zephyr-sdk/zephyr-sdk-0.16.5/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc -E output /opt/repos/micropython/build/zephyr/genhdr/qstr.i.last cflags -I/opt/repos/micropython/ports/zephyr/../.. -I/opt/repos/micropython/ports/zephyr -I/opt/repos/micropython/build/zephyr -DNDEBUG "-DMP_CONFIGFILE=<mpconfigport_full.h>" -DMICROPY_HEAP_SIZE=32768 -DFFCONF_H=\"/opt/repos/micropython/ports/zephyr/../../lib/oofatfs/ffconf.h\" -DMICROPY_VFS_FAT=1 -DMICROPY_VFS_LFS1=0 -DMICROPY_VFS_LFS2=1 -I/opt/repos/micropython/build/zephyr/zephyr/include/generated/zephyr -I/opt/ncs/zephyr/include -I/opt/repos/micropython/build/zephyr/zephyr/include/generated -I/opt/ncs/zephyr/soc/nordic -I/opt/ncs/zephyr/lib/libc/newlib/include -I/opt/ncs/zephyr/lib/libc/common/include -I/opt/ncs/zephyr/include/zephyr/posix -I/opt/ncs/zephyr/soc/nordic/nrf53/. -I/opt/ncs/zephyr/soc/nordic/common/. -I/opt/ncs/zephyr/subsys/net/l2 -I/opt/ncs/zephyr/subsys/net/lib/dns/. -I/opt/ncs/zephyr/subsys/net/conn_mgr/. -I/opt/ncs/nrf/include -I/opt/ncs/zephyr/modules/mbedtls/include -I/opt/repos/micropython/build/zephyr/tfm/api_ns/interface/include -I/opt/ncs/modules/lib/hostap/port/mbedtls -I/opt/ncs/nrf/modules/trusted-firmware-m/. -I/opt/ncs/nrf/include/tfm -I/opt/ncs/nrf/tests/include -I/opt/ncs/zephyr/modules/hostap/src/ -I/opt/ncs/modules/lib/hostap/ -I/opt/ncs/modules/lib/hostap/wpa_supplicant/ -I/opt/ncs/modules/lib/hostap/src/ -I/opt/ncs/modules/lib/hostap/src/common/ -I/opt/ncs/modules/lib/hostap/src/eap_common -I/opt/ncs/modules/lib/hostap/src/eap_server -I/opt/ncs/modules/lib/hostap/src/radius -I/opt/ncs/modules/lib/hostap/src/crypto/ -I/opt/ncs/modules/lib/hostap/src/ap/ -I/opt/ncs/modules/lib/hostap/src/drivers/ -I/opt/ncs/modules/lib/hostap/src/rsn_supp -I/opt/ncs/modules/hal/cmsis/CMSIS/Core/Include -I/opt/ncs/zephyr/modules/cmsis/. -I/opt/ncs/nrf/modules/hal_nordic/. -I/opt/ncs/modules/hal/nordic/nrfx -I/opt/ncs/modules/hal/nordic/nrfx/drivers/include -I/opt/ncs/modules/hal/nordic/nrfx/mdk -I/opt/ncs/zephyr/modules/hal_nordic/nrfx/. -isystem/opt/ncs/zephyr/lib/libc/common/include -DKERNEL -D__ZEPHYR__=1 -D_ANSI_SOURCE -D__LINUX_ERRNO_EXTENSIONS__ -DUSE_PARTITION_MANAGER=1 -D__PROGRAM_START -DNRF5340_XXAA_APPLICATION -DNRF5340_XXAA_APPLICATION -DNRF_SKIP_FICR_NS_COPY_TO_RAM -DNRF_TRUSTZONE_NONSECURE -DK_HEAP_MEM_POOL_SIZE=65536 -fno-strict-aliasing -Os -flto=auto -imacros /opt/repos/micropython/build/zephyr/zephyr/include/generated/zephyr/autoconf.h -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m33 -mthumb -mabi=aapcs -mfpu=fpv5-sp-d16 -mfloat-abi=hard -mfp16-format=ieee --sysroot=/opt/zephyr-sdk/zephyr-sdk-0.16.5/arm-zephyr-eabi/arm-zephyr-eabi -imacros /opt/ncs/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wformat -Wno-format-zero-length -Wdouble-promotion -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-pic -fno-pie -fno-asynchronous-unwind-tables -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=/opt/repos/micropython/ports/zephyr=CMAKE_SOURCE_DIR -fmacro-prefix-map=/opt/ncs/zephyr=ZEPHYR_BASE -fmacro-prefix-map=/opt/ncs=WEST_TOPDIR -ffunction-sections -fdata-sections -specs=nano.specs -D_POSIX_THREADS -std=c99 -DNO_QSTR cxxflags -I/opt/repos/micropython/ports/zephyr/../.. -I/opt/repos/micropython/ports/zephyr -I/opt/repos/micropython/build/zephyr -DNDEBUG "-DMP_CONFIGFILE=<mpconfigport_full.h>" -DMICROPY_HEAP_SIZE=32768 -DFFCONF_H=\"/opt/repos/micropython/ports/zephyr/../../lib/oofatfs/ffconf.h\" -DMICROPY_VFS_FAT=1 -DMICROPY_VFS_LFS1=0 -DMICROPY_VFS_LFS2=1 -I/opt/repos/micropython/build/zephyr/zephyr/include/generated/zephyr -I/opt/ncs/zephyr/include -I/opt/repos/micropython/build/zephyr/zephyr/include/generated -I/opt/ncs/zephyr/soc/nordic -I/opt/ncs/zephyr/lib/libc/newlib/include -I/opt/ncs/zephyr/lib/libc/common/include -I/opt/ncs/zephyr/include/zephyr/posix -I/opt/ncs/zephyr/soc/nordic/nrf53/. -I/opt/ncs/zephyr/soc/nordic/common/. -I/opt/ncs/zephyr/subsys/net/l2 -I/opt/ncs/zephyr/subsys/net/lib/dns/. -I/opt/ncs/zephyr/subsys/net/conn_mgr/. -I/opt/ncs/nrf/include -I/opt/ncs/zephyr/modules/mbedtls/include -I/opt/repos/micropython/build/zephyr/tfm/api_ns/interface/include -I/opt/ncs/modules/lib/hostap/port/mbedtls -I/opt/ncs/nrf/modules/trusted-firmware-m/. -I/opt/ncs/nrf/include/tfm -I/opt/ncs/nrf/tests/include -I/opt/ncs/zephyr/modules/hostap/src/ -I/opt/ncs/modules/lib/hostap/ -I/opt/ncs/modules/lib/hostap/wpa_supplicant/ -I/opt/ncs/modules/lib/hostap/src/ -I/opt/ncs/modules/lib/hostap/src/common/ -I/opt/ncs/modules/lib/hostap/src/eap_common -I/opt/ncs/modules/lib/hostap/src/eap_server -I/opt/ncs/modules/lib/hostap/src/radius -I/opt/ncs/modules/lib/hostap/src/crypto/ -I/opt/ncs/modules/lib/hostap/src/ap/ -I/opt/ncs/modules/lib/hostap/src/drivers/ -I/opt/ncs/modules/lib/hostap/src/rsn_supp -I/opt/ncs/modules/hal/cmsis/CMSIS/Core/Include -I/opt/ncs/zephyr/modules/cmsis/. -I/opt/ncs/nrf/modules/hal_nordic/. -I/opt/ncs/modules/hal/nordic/nrfx -I/opt/ncs/modules/hal/nordic/nrfx/drivers/include -I/opt/ncs/modules/hal/nordic/nrfx/mdk -I/opt/ncs/zephyr/modules/hal_nordic/nrfx/. -isystem/opt/ncs/zephyr/lib/libc/common/include -DKERNEL -D__ZEPHYR__=1 -D_ANSI_SOURCE -D__LINUX_ERRNO_EXTENSIONS__ -DUSE_PARTITION_MANAGER=1 -D__PROGRAM_START -DNRF5340_XXAA_APPLICATION -DNRF5340_XXAA_APPLICATION -DNRF_SKIP_FICR_NS_COPY_TO_RAM -DNRF_TRUSTZONE_NONSECURE -DK_HEAP_MEM_POOL_SIZE=65536 -fno-strict-aliasing -Os -flto=auto -imacros /opt/repos/micropython/build/zephyr/zephyr/include/generated/zephyr/autoconf.h -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m33 -mthumb -mabi=aapcs -mfpu=fpv5-sp-d16 -mfloat-abi=hard -mfp16-format=ieee --sysroot=/opt/zephyr-sdk/zephyr-sdk-0.16.5/arm-zephyr-eabi/arm-zephyr-eabi -imacros /opt/ncs/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wformat -Wno-format-zero-length -Wdouble-promotion -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-pic -fno-pie -fno-asynchronous-unwind-tables -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=/opt/repos/micropython/ports/zephyr=CMAKE_SOURCE_DIR -fmacro-prefix-map=/opt/ncs/zephyr=ZEPHYR_BASE -fmacro-prefix-map=/opt/ncs=WEST_TOPDIR -ffunction-sections -fdata-sections -specs=nano.specs -D_POSIX_THREADS -std=c99 -DNO_QSTR sources /opt/repos/micropython/ports/zephyr/../../py/argcheck.c /opt/repos/micropython/ports/zephyr/../../py/asmarm.c /opt/repos/micropython/ports/zephyr/../../py/asmbase.c /opt/repos/micropython/ports/zephyr/../../py/asmrv32.c /opt/repos/micropython/ports/zephyr/../../py/asmthumb.c /opt/repos/micropython/ports/zephyr/../../py/asmx64.c /opt/repos/micropython/ports/zephyr/../../py/asmx86.c /opt/repos/micropython/ports/zephyr/../../py/asmxtensa.c /opt/repos/micropython/ports/zephyr/../../py/bc.c /opt/repos/micropython/ports/zephyr/../../py/binary.c /opt/repos/micropython/ports/zephyr/../../py/builtinevex.c /opt/repos/micropython/ports/zephyr/../../py/builtinhelp.c /opt/repos/micropython/ports/zephyr/../../py/builtinimport.c /opt/repos/micropython/ports/zephyr/../../py/compile.c /opt/repos/micropython/ports/zephyr/../../py/cstack.c /opt/repos/micropython/ports/zephyr/../../py/emitbc.c /opt/repos/micropython/ports/zephyr/../../py/emitcommon.c /opt/repos/micropython/ports/zephyr/../../py/emitglue.c /opt/repos/micropython/ports/zephyr/../../py/emitinlinerv32.c /opt/repos/micropython/ports/zephyr/../../py/emitinlinethumb.c /opt/repos/micropython/ports/zephyr/../../py/emitinlinextensa.c /opt/repos/micropython/ports/zephyr/../../py/emitnarm.c /opt/repos/micropython/ports/zephyr/../../py/emitndebug.c /opt/repos/micropython/ports/zephyr/../../py/emitnrv32.c /opt/repos/micropython/ports/zephyr/../../py/emitnthumb.c /opt/repos/micropython/ports/zephyr/../../py/emitnx64.c /opt/repos/micropython/ports/zephyr/../../py/emitnx86.c /opt/repos/micropython/ports/zephyr/../../py/emitnxtensa.c /opt/repos/micropython/ports/zephyr/../../py/emitnxtensawin.c /opt/repos/micropython/ports/zephyr/../../py/formatfloat.c /opt/repos/micropython/ports/zephyr/../../py/frozenmod.c /opt/repos/micropython/ports/zephyr/../../py/gc.c /opt/repos/micropython/ports/zephyr/../../py/lexer.c /opt/repos/micropython/ports/zephyr/../../py/malloc.c /opt/repos/micropython/ports/zephyr/../../py/map.c /opt/repos/micropython/ports/zephyr/../../py/modarray.c /opt/repos/micropython/ports/zephyr/../../py/modbuiltins.c /opt/repos/micropython/ports/zephyr/../../py/modcmath.c /opt/repos/micropython/ports/zephyr/../../py/modcollections.c /opt/repos/micropython/ports/zephyr/../../py/modgc.c /opt/repos/micropython/ports/zephyr/../../py/modio.c /opt/repos/micropython/ports/zephyr/../../py/modmath.c /opt/repos/micropython/ports/zephyr/../../py/modmicropython.c /opt/repos/micropython/ports/zephyr/../../py/modstruct.c /opt/repos/micropython/ports/zephyr/../../py/modsys.c /opt/repos/micropython/ports/zephyr/../../py/modthread.c /opt/repos/micropython/ports/zephyr/../../py/moderrno.c /opt/repos/micropython/ports/zephyr/../../py/mpprint.c /opt/repos/micropython/ports/zephyr/../../py/mpstate.c /opt/repos/micropython/ports/zephyr/../../py/mpz.c /opt/repos/micropython/ports/zephyr/../../py/nativeglue.c /opt/repos/micropython/ports/zephyr/../../py/nlr.c /opt/repos/micropython/ports/zephyr/../../py/nlrmips.c /opt/repos/micropython/ports/zephyr/../../py/nlrpowerpc.c /opt/repos/micropython/ports/zephyr/../../py/nlrrv32.c /opt/repos/micropython/ports/zephyr/../../py/nlrrv64.c /opt/repos/micropython/ports/zephyr/../../py/nlrsetjmp.c /opt/repos/micropython/ports/zephyr/../../py/nlrthumb.c /opt/repos/micropython/ports/zephyr/../../py/nlrx64.c /opt/repos/micropython/ports/zephyr/../../py/nlrx86.c /opt/repos/micropython/ports/zephyr/../../py/nlrxtensa.c /opt/repos/micropython/ports/zephyr/../../py/obj.c /opt/repos/micropython/ports/zephyr/../../py/objarray.c /opt/repos/micropython/ports/zephyr/../../py/objattrtuple.c /opt/repos/micropython/ports/zephyr/../../py/objbool.c /opt/repos/micropython/ports/zephyr/../../py/objboundmeth.c /opt/repos/micropython/ports/zephyr/../../py/objcode.c /opt/repos/micropython/ports/zephyr/../../py/objcell.c /opt/repos/micropython/ports/zephyr/../../py/objclosure.c /opt/repos/micropython/ports/zephyr/../../py/objcomplex.c /opt/repos/micropython/ports/zephyr/../../py/objdeque.c /opt/repos/micropython/ports/zephyr/../../py/objdict.c /opt/repos/micropython/ports/zephyr/../../py/objenumerate.c /opt/repos/micropython/ports/zephyr/../../py/objexcept.c /opt/repos/micropython/ports/zephyr/../../py/objfilter.c /opt/repos/micropython/ports/zephyr/../../py/objfloat.c /opt/repos/micropython/ports/zephyr/../../py/objfun.c /opt/repos/micropython/ports/zephyr/../../py/objgenerator.c /opt/repos/micropython/ports/zephyr/../../py/objgetitemiter.c /opt/repos/micropython/ports/zephyr/../../py/objint.c /opt/repos/micropython/ports/zephyr/../../py/objint_longlong.c /opt/repos/micropython/ports/zephyr/../../py/objint_mpz.c /opt/repos/micropython/ports/zephyr/../../py/objlist.c /opt/repos/micropython/ports/zephyr/../../py/objmap.c /opt/repos/micropython/ports/zephyr/../../py/objmodule.c /opt/repos/micropython/ports/zephyr/../../py/objnamedtuple.c /opt/repos/micropython/ports/zephyr/../../py/objnone.c /opt/repos/micropython/ports/zephyr/../../py/objobject.c /opt/repos/micropython/ports/zephyr/../../py/objpolyiter.c /opt/repos/micropython/ports/zephyr/../../py/objproperty.c /opt/repos/micropython/ports/zephyr/../../py/objrange.c /opt/repos/micropython/ports/zephyr/../../py/objreversed.c /opt/repos/micropython/ports/zephyr/../../py/objringio.c /opt/repos/micropython/ports/zephyr/../../py/objset.c /opt/repos/micropython/ports/zephyr/../../py/objsingleton.c /opt/repos/micropython/ports/zephyr/../../py/objslice.c /opt/repos/micropython/ports/zephyr/../../py/objstr.c /opt/repos/micropython/ports/zephyr/../../py/objstringio.c /opt/repos/micropython/ports/zephyr/../../py/objstrunicode.c /opt/repos/micropython/ports/zephyr/../../py/objtuple.c /opt/repos/micropython/ports/zephyr/../../py/objtype.c /opt/repos/micropython/ports/zephyr/../../py/objzip.c /opt/repos/micropython/ports/zephyr/../../py/opmethods.c /opt/repos/micropython/ports/zephyr/../../py/pairheap.c /opt/repos/micropython/ports/zephyr/../../py/parse.c /opt/repos/micropython/ports/zephyr/../../py/parsenum.c /opt/repos/micropython/ports/zephyr/../../py/parsenumbase.c /opt/repos/micropython/ports/zephyr/../../py/persistentcode.c /opt/repos/micropython/ports/zephyr/../../py/profile.c /opt/repos/micropython/ports/zephyr/../../py/pystack.c /opt/repos/micropython/ports/zephyr/../../py/qstr.c /opt/repos/micropython/ports/zephyr/../../py/reader.c /opt/repos/micropython/ports/zephyr/../../py/repl.c /opt/repos/micropython/ports/zephyr/../../py/ringbuf.c /opt/repos/micropython/ports/zephyr/../../py/runtime.c /opt/repos/micropython/ports/zephyr/../../py/runtime_utils.c /opt/repos/micropython/ports/zephyr/../../py/scheduler.c /opt/repos/micropython/ports/zephyr/../../py/scope.c /opt/repos/micropython/ports/zephyr/../../py/sequence.c /opt/repos/micropython/ports/zephyr/../../py/showbc.c /opt/repos/micropython/ports/zephyr/../../py/smallint.c /opt/repos/micropython/ports/zephyr/../../py/stackctrl.c /opt/repos/micropython/ports/zephyr/../../py/stream.c /opt/repos/micropython/ports/zephyr/../../py/unicode.c /opt/repos/micropython/ports/zephyr/../../py/vm.c /opt/repos/micropython/ports/zephyr/../../py/vstr.c /opt/repos/micropython/ports/zephyr/../../py/warning.c /opt/repos/micropython/ports/zephyr/../../shared/libc/abort_.c /opt/repos/micropython/ports/zephyr/../../shared/libc/printf.c /opt/repos/micropython/ports/zephyr/../../extmod/btstack/modbluetooth_btstack.c /opt/repos/micropython/ports/zephyr/../../extmod/machine_adc.c /opt/repos/micropython/ports/zephyr/../../extmod/machine_adc_block.c /opt/repos/micropython/ports/zephyr/../../extmod/machine_bitstream.c /opt/repos/micropython/ports/zephyr/../../extmod/machine_i2c.c /opt/repos/micropython/ports/zephyr/../../extmod/machine_i2s.c /opt/repos/micropython/ports/zephyr/../../extmod/machine_mem.c /opt/repos/micropython/ports/zephyr/../../extmod/machine_pulse.c /opt/repos/micropython/ports/zephyr/../../extmod/machine_pwm.c /opt/repos/micropython/ports/zephyr/../../extmod/machine_signal.c /opt/repos/micropython/ports/zephyr/../../extmod/machine_spi.c /opt/repos/micropython/ports/zephyr/../../extmod/machine_uart.c /opt/repos/micropython/ports/zephyr/../../extmod/machine_usb_device.c /opt/repos/micropython/ports/zephyr/../../extmod/machine_wdt.c /opt/repos/micropython/ports/zephyr/../../extmod/modbluetooth.c /opt/repos/micropython/ports/zephyr/../../extmod/modframebuf.c /opt/repos/micropython/ports/zephyr/../../extmod/modlwip.c /opt/repos/micropython/ports/zephyr/../../extmod/modmachine.c /opt/repos/micropython/ports/zephyr/../../extmod/modmarshal.c /opt/repos/micropython/ports/zephyr/../../extmod/modnetwork.c /opt/repos/micropython/ports/zephyr/../../extmod/modonewire.c /opt/repos/micropython/ports/zephyr/../../extmod/modasyncio.c /opt/repos/micropython/ports/zephyr/../../extmod/modbinascii.c /opt/repos/micropython/ports/zephyr/../../extmod/modcryptolib.c /opt/repos/micropython/ports/zephyr/../../extmod/moductypes.c /opt/repos/micropython/ports/zephyr/../../extmod/moddeflate.c /opt/repos/micropython/ports/zephyr/../../extmod/modhashlib.c /opt/repos/micropython/ports/zephyr/../../extmod/modheapq.c /opt/repos/micropython/ports/zephyr/../../extmod/modjson.c /opt/repos/micropython/ports/zephyr/../../extmod/modos.c /opt/repos/micropython/ports/zephyr/../../extmod/modplatform.c /opt/repos/micropython/ports/zephyr/../../extmod/modrandom.c /opt/repos/micropython/ports/zephyr/../../extmod/modre.c /opt/repos/micropython/ports/zephyr/../../extmod/modselect.c /opt/repos/micropython/ports/zephyr/../../extmod/modsocket.c /opt/repos/micropython/ports/zephyr/../../extmod/modtls_axtls.c /opt/repos/micropython/ports/zephyr/../../extmod/modtls_mbedtls.c /opt/repos/micropython/ports/zephyr/../../extmod/modtime.c /opt/repos/micropython/ports/zephyr/../../extmod/modvfs.c /opt/repos/micropython/ports/zephyr/../../extmod/modwebsocket.c /opt/repos/micropython/ports/zephyr/../../extmod/modwebrepl.c /opt/repos/micropython/ports/zephyr/../../extmod/network_cyw43.c /opt/repos/micropython/ports/zephyr/../../extmod/network_lwip.c /opt/repos/micropython/ports/zephyr/../../extmod/network_ninaw10.c /opt/repos/micropython/ports/zephyr/../../extmod/network_ppp_lwip.c /opt/repos/micropython/ports/zephyr/../../extmod/network_wiznet5k.c /opt/repos/micropython/ports/zephyr/../../extmod/os_dupterm.c /opt/repos/micropython/ports/zephyr/../../extmod/vfs.c /opt/repos/micropython/ports/zephyr/../../extmod/vfs_blockdev.c /opt/repos/micropython/ports/zephyr/../../extmod/vfs_fat.c /opt/repos/micropython/ports/zephyr/../../extmod/vfs_fat_diskio.c /opt/repos/micropython/ports/zephyr/../../extmod/vfs_fat_file.c /opt/repos/micropython/ports/zephyr/../../extmod/vfs_lfs.c /opt/repos/micropython/ports/zephyr/../../extmod/vfs_rom.c /opt/repos/micropython/ports/zephyr/../../extmod/vfs_rom_file.c /opt/repos/micropython/ports/zephyr/../../extmod/vfs_posix.c /opt/repos/micropython/ports/zephyr/../../extmod/vfs_posix_file.c /opt/repos/micropython/ports/zephyr/../../extmod/vfs_reader.c /opt/repos/micropython/ports/zephyr/../../extmod/virtpin.c /opt/repos/micropython/ports/zephyr/../../extmod/nimble/modbluetooth_nimble.c /opt/repos/micropython/ports/zephyr/../../shared/libc/printf.c /opt/repos/micropython/ports/zephyr/../../shared/readline/readline.c /opt/repos/micropython/ports/zephyr/../../shared/runtime/gchelper_generic.c /opt/repos/micropython/ports/zephyr/../../shared/runtime/interrupt_char.c /opt/repos/micropython/ports/zephyr/../../shared/runtime/mpirq.c /opt/repos/micropython/ports/zephyr/../../shared/runtime/pyexec.c /opt/repos/micropython/ports/zephyr/../../shared/runtime/stdout_helpers.c /opt/repos/micropython/ports/zephyr/../../shared/timeutils/timeutils.c /opt/repos/micropython/ports/zephyr/../../lib/oofatfs/ff.c /opt/repos/micropython/ports/zephyr/../../lib/oofatfs/ffunicode.c /opt/repos/micropython/ports/zephyr/../../lib/littlefs/lfs1.c /opt/repos/micropython/ports/zephyr/../../lib/littlefs/lfs1_util.c /opt/repos/micropython/ports/zephyr/../../lib/littlefs/lfs2.c /opt/repos/micropython/ports/zephyr/../../lib/littlefs/lfs2_util.c /opt/repos/micropython/ports/zephyr/main.c /opt/repos/micropython/ports/zephyr/help.c /opt/repos/micropython/ports/zephyr/machine_i2c.c /opt/repos/micropython/ports/zephyr/machine_spi.c /opt/repos/micropython/ports/zephyr/machine_pin.c /opt/repos/micropython/ports/zephyr/machine_timer.c /opt/repos/micropython/ports/zephyr/modbluetooth_zephyr.c /opt/repos/micropython/ports/zephyr/modsocket.c /opt/repos/micropython/ports/zephyr/modzephyr.c /opt/repos/micropython/ports/zephyr/modzsensor.c /opt/repos/micropython/ports/zephyr/mphalport.c /opt/repos/micropython/ports/zephyr/uart_core.c /opt/repos/micropython/ports/zephyr/zephyr_device.c /opt/repos/micropython/ports/zephyr/zephyr_storage.c /opt/repos/micropython/ports/zephyr/mpthreadport.c
    /opt/repos/micropython/ports/zephyr/modsocket.c:51: warning: "DEBUG_printf" redefined
       51 |  #define DEBUG_printf printf
    In file included from /opt/repos/micropython/ports/zephyr/modsocket.c:33:
    /opt/repos/micropython/ports/zephyr/mpthreadport.c:38: note: this is the location of the previous definition
       38 | #define DEBUG_printf(...) // printk("_thread: " __VA_ARGS__)
    /opt/repos/micropython/ports/zephyr/modsocket.c:82:10: fatal error: cert/r1.crt.inc: No such file or directory
       82 | #include "cert/r1.crt.inc"
    compilation terminated.
    In file included from /opt/repos/micropython/ports/zephyr/../../extmod/modnetwork.c:46:
    /opt/repos/micropython/ports/zephyr/../../ports/zephyr/network_wlan.c:40:11: fatal error: modnetwork.h: No such file or directory
       40 |  #include "modnetwork.h"
    In file included from /opt/repos/micropython/ports/zephyr/../../py/mpconfig.h:89,
                     from /opt/repos/micropython/ports/zephyr/../../py/mphal.h:30,
                     from /opt/repos/micropython/ports/zephyr/../../extmod/modos.c:27:
    /opt/repos/micropython/ports/zephyr/mpconfigport_full.h:89:37: fatal error: ports/zephyr/modos.c: No such file or directory
       89 | #define MICROPY_PY_OS_INCLUDEFILE   "ports/zephyr/modos.c"
    Command '['/opt/zephyr-sdk/zephyr-sdk-0.16.5/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc', '-E', '-I/opt/repos/micropython/ports/zephyr/../..', '-I/opt/repos/micropython/ports/zephyr', '-I/opt/repos/micropython/build/zephyr', '-DNDEBUG', '-DMP_CONFIGFILE=<mpconfigport_full.h>', '-DMICROPY_HEAP_SIZE=32768', '-DFFCONF_H="/opt/repos/micropython/ports/zephyr/../../lib/oofatfs/ffconf.h"', '-DMICROPY_VFS_FAT=1', '-DMICROPY_VFS_LFS1=0', '-DMICROPY_VFS_LFS2=1', '-I/opt/repos/micropython/build/zephyr/zephyr/include/generated/zephyr', '-I/opt/ncs/zephyr/include', '-I/opt/repos/micropython/build/zephyr/zephyr/include/generated', '-I/opt/ncs/zephyr/soc/nordic', '-I/opt/ncs/zephyr/lib/libc/newlib/include', '-I/opt/ncs/zephyr/lib/libc/common/include', '-I/opt/ncs/zephyr/include/zephyr/posix', '-I/opt/ncs/zephyr/soc/nordic/nrf53/.', '-I/opt/ncs/zephyr/soc/nordic/common/.', '-I/opt/ncs/zephyr/subsys/net/l2', '-I/opt/ncs/zephyr/subsys/net/lib/dns/.', '-I/opt/ncs/zephyr/subsys/net/conn_mgr/.', '-I/opt/ncs/nrf/include', '-I/opt/ncs/zephyr/modules/mbedtls/include', '-I/opt/repos/micropython/build/zephyr/tfm/api_ns/interface/include', '-I/opt/ncs/modules/lib/hostap/port/mbedtls', '-I/opt/ncs/nrf/modules/trusted-firmware-m/.', '-I/opt/ncs/nrf/include/tfm', '-I/opt/ncs/nrf/tests/include', '-I/opt/ncs/zephyr/modules/hostap/src/', '-I/opt/ncs/modules/lib/hostap/', '-I/opt/ncs/modules/lib/hostap/wpa_supplicant/', '-I/opt/ncs/modules/lib/hostap/src/', '-I/opt/ncs/modules/lib/hostap/src/common/', '-I/opt/ncs/modules/lib/hostap/src/eap_common', '-I/opt/ncs/modules/lib/hostap/src/eap_server', '-I/opt/ncs/modules/lib/hostap/src/radius', '-I/opt/ncs/modules/lib/hostap/src/crypto/', '-I/opt/ncs/modules/lib/hostap/src/ap/', '-I/opt/ncs/modules/lib/hostap/src/drivers/', '-I/opt/ncs/modules/lib/hostap/src/rsn_supp', '-I/opt/ncs/modules/hal/cmsis/CMSIS/Core/Include', '-I/opt/ncs/zephyr/modules/cmsis/.', '-I/opt/ncs/nrf/modules/hal_nordic/.', '-I/opt/ncs/modules/hal/nordic/nrfx', '-I/opt/ncs/modules/hal/nordic/nrfx/drivers/include', '-I/opt/ncs/modules/hal/nordic/nrfx/mdk', '-I/opt/ncs/zephyr/modules/hal_nordic/nrfx/.', '-isystem/opt/ncs/zephyr/lib/libc/common/include', '-DKERNEL', '-D__ZEPHYR__=1', '-D_ANSI_SOURCE', '-D__LINUX_ERRNO_EXTENSIONS__', '-DUSE_PARTITION_MANAGER=1', '-D__PROGRAM_START', '-DNRF5340_XXAA_APPLICATION', '-DNRF5340_XXAA_APPLICATION', '-DNRF_SKIP_FICR_NS_COPY_TO_RAM', '-DNRF_TRUSTZONE_NONSECURE', '-DK_HEAP_MEM_POOL_SIZE=65536', '-fno-strict-aliasing', '-Os', '-flto=auto', '-imacros', '/opt/repos/micropython/build/zephyr/zephyr/include/generated/zephyr/autoconf.h', '-fno-common', '-g', '-gdwarf-4', '-fdiagnostics-color=always', '-mcpu=cortex-m33', '-mthumb', '-mabi=aapcs', '-mfpu=fpv5-sp-d16', '-mfloat-abi=hard', '-mfp16-format=ieee', '--sysroot=/opt/zephyr-sdk/zephyr-sdk-0.16.5/arm-zephyr-eabi/arm-zephyr-eabi', '-imacros', '/opt/ncs/zephyr/include/zephyr/toolchain/zephyr_stdint.h', '-Wall', '-Wformat', '-Wformat-security', '-Wformat', '-Wno-format-zero-length', '-Wdouble-promotion', '-Wno-pointer-sign', '-Wpointer-arith', '-Wexpansion-to-defined', '-Wno-unused-but-set-variable', '-Werror=implicit-int', '-fno-pic', '-fno-pie', '-fno-asynchronous-unwind-tables', '-fno-reorder-functions', '--param=min-pagesize=0', '-fno-defer-pop', '-fmacro-prefix-map=/opt/repos/micropython/ports/zephyr=CMAKE_SOURCE_DIR', '-fmacro-prefix-map=/opt/ncs/zephyr=ZEPHYR_BASE', '-fmacro-prefix-map=/opt/ncs=WEST_TOPDIR', '-ffunction-sections', '-fdata-sections', '-specs=nano.specs', '-D_POSIX_THREADS', '-std=c99', '-DNO_QSTR', '/opt/repos/micropython/ports/zephyr/../../extmod/machine_uart.c', '/opt/repos/micropython/ports/zephyr/../../extmod/machine_usb_device.c', '/opt/repos/micropython/ports/zephyr/../../extmod/machine_wdt.c', '/opt/repos/micropython/ports/zephyr/../../extmod/modbluetooth.c', '/opt/repos/micropython/ports/zephyr/../../extmod/modframebuf.c', '/opt/repos/micropython/ports/zephyr/../../extmod/modlwip.c', '/opt/repos/micropython/ports/zephyr/../../extmod/modmachine.c', '/opt/repos/micropython/ports/zephyr/../../extmod/modmarshal.c', '/opt/repos/micropython/ports/zephyr/../../extmod/modnetwork.c', '/opt/repos/micropython/ports/zephyr/../../extmod/modonewire.c']' returned non-zero exit status 1.
    FAILED: _sysbuild/sysbuild/images/zephyr-prefix/src/zephyr-stamp/zephyr-build /opt/repos/micropython/build/_sysbuild/sysbuild/images/zephyr-prefix/src/zephyr-stamp/zephyr-build
    cd /opt/repos/micropython/build/zephyr && /usr/bin/cmake --build .
    FATAL ERROR: command exited with status 1: /usr/bin/cmake --build /opt/repos/micropython/build
    Could you please share the missing files and changes?
    Note: you can use "git diff origin/HEAD" to see your changes in the micropython repo.
    And git status to see untracked files.
    HĂĄkon
  • The cert file is generated based on the modifications you described above.
    modnetwork.h
     * This file is part of the MicroPython project, http://micropython.org/
     * The MIT License (MIT)
     * Copyright (c) 2015 Josef Gajdusek
     * Copyright (c) 2016 Damien P. George
     * Copyright (c) 2025 Daniel Campora on behalf of REMOTE TECH LTD
     * Permission is hereby granted, free of charge, to any person obtaining a copy
     * of this software and associated documentation files (the "Software"), to deal
     * in the Software without restriction, including without limitation the rights
     * to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
     * copies of the Software, and to permit persons to whom the Software is
     * furnished to do so, subject to the following conditions:
     * The above copyright notice and this permission notice shall be included in
     * all copies or substantial portions of the Software.
     * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
     * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
     * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
     * AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
     * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
     * OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
     * THE SOFTWARE.
    // This file is never compiled standalone, it's included directly from
    // extmod/modos.c via MICROPY_PY_OS_INCLUDEFILE.
    #include <zephyr/kernel.h>
    #include <stdio.h>
    #include <stdlib.h>
    #include <psa/crypto.h>
    #include <psa/crypto_extra.h>
    #include "py/mperrno.h"
    uint32_t zephyr_random(void) {
        uint8_t _rng_data[4];
        psa_status_t status = psa_generate_random(_rng_data, sizeof(_rng_data));
        if (status != PSA_SUCCESS) {
            mp_raise_OSError(MP_ENODEV);
        return (_rng_data[3] << 24) + (_rng_data[2] << 16) + (_rng_data[1] << 8) + _rng_data[0];
    static mp_obj_t mp_os_urandom(mp_obj_t num) {
        mp_int_t n = mp_obj_get_int(num);
        vstr_t vstr;
        vstr_init_len(&vstr, n);
        uint32_t r = 0;
        for (int i = 0; i < n; i++) {
            if ((i & 3) == 0) {
                r = zephyr_random(); // returns 32-bit hardware random number
            vstr.buf[i] = r;
            r >>= 8;
        return mp_obj_new_bytes_from_vstr(&vstr);
    static MP_DEFINE_CONST_FUN_OBJ_1(mp_os_urandom_obj, mp_os_urandom);
    I've attached the files that you're missing to this message.
    Also, by unknown and unexplained magic, as I kept adding debug code (simply adding printk() in various points), that made me leapfrog even further:
    >>> import time
    ...     try:
    ...         print("Resolving " + host + "...")
    ...         addr = socket.getaddrinfo(host, port)
    ...         print("Resolved:", addr)
    ...         return addr
    ...     except Exception as e:
    ...         print("DNS Error:", e)
    ...         return None
    ...     return None
    Resolving google.com...
    Querying DNS for google.com (type 1)...
    [00:00:43.961,944] <dbg> net_dns_reso~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~lve: dns_write: (mp_main): [0] submitting work to server idx 0 for id 378079
    semaphore wait...1
    [00:00:43.951,721] <dbg> net_sock_svc: socket_service_thread: (net_socket_service): Received restart event.
    [00:00:44.007,415] <dbg> net_sock: zsock_received_cb: (rx_q[0]): ctx=0x2000aed8, pkt=0x2005f060, st=0, user_data=(nil)
    Dead here...1
    DNS CALLBACK: status=-100
    Dead here...2
    DNS CALLBACK: status=-103
    something...1
    Resolved: [(1, 1, 6, '', ('142.251.208.110', 443))]
    >>> if result:
    ...     print("Success!")
    ... else:
    ...     print("Failed to resolve host")
    Success!
    >>> s = None
    >>> s = socket.socket()
    Trying to initialize socket...
    Family: 1, socktype: 1, proto: 258
    Dead here...15
    [00:00:44.058,319] <dbg> net_sock_tls: tls_alloc: (mp_main): Allocated TLS context, 0x2000a190
    Dead here...17
    Checking stupid errno...1.1: 0
    [00:00:44.072,296] <dbg> net_sock: zsock_socket_internal: (mp_main): socket: ctx=0x2000b0e8, fd=16
    Dead here...18
    Dead here...19
    Returned value: 15
    Done initializing socket!
    Dead herTrying 1...
    Dead here...8 (fucking christ...)
    Dead here...10 (fucking christ...)
    1 is done
    Dead here...9 (fucking christ...)
    2 is done
    3 is done
      File "<stdin>", line 1
    SyntaxError: invalid syntax
    >>> print("Connecting to:", result[0][-1])
    Connecting to: ('142.251.208.110', 443)
    >>> s.connect(result[0][-1])
    e...5. DNS message size: 44
    DNS message content (hex):93 af 81 80 00 01 00 01 00 00 00 00 06 67 6f 6f 67 6c 65 03 63 6f 6d 00 00 01 00 01 c0 0c 00 01 00 01 00 00 00 bb 00 04 8e fb d0 6e
    Dead here...6
    Dead here...7
    Dead here...60. tls->options.sec_tag_list.sec_tag_count: 1
    Dead here...61. tag: 16842753
    Dead here...63. Nr of credentials: 4
    counting... 0; cred type: 1; cred tag: 16842753
    Dead here...64. Found cred: 0
    Dead here...62. Counting: 0
    Dead here...65. Adding CA certificate
    Dead here...66. Parsing CA certificate
    Dead here...69
    Dead here...66.5. Parsing CA certificate done. err: 0
    Credentials set: 0
    counting... 1; cred type: 0; cred tag: 0
    counting... 2; cred type: 0; cred tag: 0
    counting... 3; cred type: 0; cred tag: 0
    [00:01:06.232,818] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:1331: The SSL configuration is tls12 only.
    [00:01:06.251,647] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4663: => handshake
    [00:01:06.261,932] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2354: => flush output
    [00:01:06.272,521] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2363: <= flush output
    [00:01:06.283,142] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4582: client state: MBEDTLS_SSL_HELLO_REQUEST
    [00:01:06.295,776] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2354: => flush output
    [00:01:06.306,365] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2363: <= flush output
    [00:01:06.316,986] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4582: client state: MBEDTLS_SSL_CLIENT_HELLO
    [00:01:06.329,559] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0921: => write client hello
    [00:01:06.341,369] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0487: dumping 'client hello, random bytes' (32 bytes)
    [00:01:06.354,980] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0487: 0000:  83 27 b4 b0 f6 cc fb 1f 7e 51 66 88 21 18 61 64  .'......~Qf.!.ad
    [00:01:06.370,788] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0487: 0010:  39 19 2e 4e b4 93 c5 4f f8 d9 54 c4 0b 07 6a a5  9..N...O..T...j.
    [00:01:06.386,352] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0512: dumping 'session id' (0 bytes)
    [00:01:06.398,284] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c024, TLS-ECDHE-ECDSA-WITH-AES-256-CBC-SHA384
    [00:01:06.414,245] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c028, TLS-ECDHE-RSA-WITH-AES-256-CBC-SHA384
    [00:01:06.429,992] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c00a, TLS-ECDHE-ECDSA-WITH-AES-256-CBC-SHA
    [00:01:06.445,678] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c014, TLS-ECDHE-RSA-WITH-AES-256-CBC-SHA
    [00:01:06.461,181] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c023, TLS-ECDHE-ECDSA-WITH-AES-128-CBC-SHA256
    [00:01:06.477,111] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c027, TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
    [00:01:06.492,889] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c009, TLS-ECDHE-ECDSA-WITH-AES-128-CBC-SHA
    [00:01:06.508,544] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c013, TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA
    [00:01:06.524,078] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: 003d, TLS-RSA-WITH-AES-256-CBC-SHA256
    [00:01:06.539,306] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: 0035, TLS-RSA-WITH-AES-256-CBC-SHA
    [00:01:06.554,290] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c02a, TLS-ECDH-RSA-WITH-AES-256-CBC-SHA384
    [00:01:06.569,976] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c00f, TLS-ECDH-RSA-WITH-AES-256-CBC-SHA
    [00:01:06.585,388] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c026, TLS-ECDH-ECDSA-WITH-AES-256-CBC-SHA384
    [00:01:06.601,257] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c005, TLS-ECDH-ECDSA-WITH-AES-256-CBC-SHA
    [00:01:06.616,821] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: 003c, TLS-RSA-WITH-AES-128-CBC-SHA256
    [00:01:06.632,080] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: 002f, TLS-RSA-WITH-AES-128-CBC-SHA
    [00:01:06.647,064] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c029, TLS-ECDH-RSA-WITH-AES-128-CBC-SHA256
    [00:01:06.662,719] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c00e, TLS-ECDH-RSA-WITH-AES-128-CBC-SHA
    [00:01:06.678,161] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c025, TLS-ECDH-ECDSA-WITH-AES-128-CBC-SHA256
    [00:01:06.694,000] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c004, TLS-ECDH-ECDSA-WITH-AES-128-CBC-SHA
    [00:01:06.709,594] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0388: adding EMPTY_RENEGOTIATION_INFO_SCSV
    [00:01:06.721,984] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0397: client hello, got 21 cipher suites
    [00:01:06.734,252] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0041: client hello, adding server name extension: google.com
    [00:01:06.748,229] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0231: client hello, adding supported_groups extension
    [00:01:06.761,627] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0250: got supported group(001d)
    [00:01:06.773,071] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0282: NamedGroup: x25519 ( 1d )
    [00:01:06.784,545] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0250: got supported group(0017)
    [00:01:06.796,020] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0282: NamedGroup: secp256r1 ( 17 )
    [00:01:06.807,739] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0302: dumping 'Supported groups extension' (6 bytes)
    [00:01:06.821,166] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0302: 0000:  00 04 00 1d 00 17                                ......
    [00:01:06.835,845] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9505: adding signature_algorithms extension
    [00:01:06.848,114] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9525: got signature scheme [603] ecdsa_secp521r1_sha512
    [00:01:06.861,419] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9534: sent signature scheme [603] ecdsa_secp521r1_sha512
    [00:01:06.874,786] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9525: got signature scheme [601] rsa_pkcs1_sha512
    [00:01:06.887,573] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9534: sent signature scheme [601] rsa_pkcs1_sha512
    [00:01:06.900,421] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9525: got signature scheme [503] ecdsa_secp384r1_sha384
    [00:01:06.913,726] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9534: sent signature scheme [503] ecdsa_secp384r1_sha384
    [00:01:06.927,124] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9525: got signature scheme [501] rsa_pkcs1_sha384
    [00:01:06.939,880] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9534: sent signature scheme [501] rsa_pkcs1_sha384
    [00:01:06.952,728] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9525: got signature scheme [403] ecdsa_secp256r1_sha256
    [00:01:06.966,033] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9534: sent signature scheme [403] ecdsa_secp256r1_sha256
    [00:01:06.979,431] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9525: got signature scheme [401] rsa_pkcs1_sha256
    [00:01:06.992,218] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9534: sent signature scheme [401] rsa_pkcs1_sha256
    [00:01:07.005,065] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:0105: client hello, adding supported_point_formats extension
    [00:01:07.019,561] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:0150: client hello, adding ecjpake_kkpp extension
    [00:01:07.033,142] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:0165: generating new ecjpake parameters
    [00:01:07.141,845] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:0338: client hello, adding extended_master_secret extension
    [00:01:07.156,250] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:0372: client hello, adding session ticket extension
    [00:01:07.170,013] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0689: client hello, total extension length: 395
    [00:01:07.182,891] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: dumping 'client hello extensions' (395 bytes)
    [00:01:07.196,319] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0000:  01 8b 00 00 00 0f 00 0d 00 00 0a 67 6f 6f 67 6c  ...........googl
    [00:01:07.212,127] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0010:  65 2e 63 6f 6d 00 0a 00 06 00 04 00 1d 00 17 00  e.com...........
    [00:01:07.227,935] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0020:  0d 00 0e 00 0c 06 03 06 01 05 03 05 01 04 03 04  ................
    [00:01:07.243,743] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0030:  01 00 0b 00 02 01 00 01 00 01 4a 41 04 03 a5 0e  ..........JA....
    [00:01:07.259,552] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0040:  19 18 6e 04 ef 6d df 55 16 d1 d3 9d f2 fe 39 6c  ..n..m.U......9l
    [00:01:07.275,360] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0050:  e3 79 52 9a f6 b8 1c 2c 25 60 ae 36 67 c4 f4 a9  .yR....,%`.6g...
    [00:01:07.291,168] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0060:  74 92 0f e1 77 1b 2c ed 90 14 e8 b3 80 9e b1 34  t...w.,........4
    [00:01:07.306,945] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0070:  2f ae f1 dc 2e f1 8c 03 41 6a eb 87 fa 41 04 dd  /.......Aj...A..
    [00:01:07.322,753] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0080:  e1 7b 17 cc ac 4a 81 bb 4d 57 a1 6e bb dc a8 0f  .{...J..MW.n....
    [00:01:07.338,562] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0090:  49 96 db 9b bd 83 ff c3 5f 1c ce 39 51 36 b0 7d  I......._..9Q6.}
    [00:01:07.354,370] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 00a0:  97 44 5d b8 c2 54 af 66 77 99 8c ce 7c 5e c2 b5  .D]..T.fw...|^..
    [00:01:07.370,178] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 00b0:  72 53 4e 26 a6 74 96 79 ec a2 a1 ea 9a f3 02 20  rSN&.t.y.......
    [00:01:07.385,955] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 00c0:  3d ed 0b fc 27 96 1a bb cb 4e df 68 9a 1f 62 8e  =...'....N.h..b.
    [00:01:07.401,763] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 00d0:  e8 6c b2 a2 fb 6e 3f 17 92 1c aa 8e 94 2a e1 44  .l...n?......*.D
    [00:01:07.417,572] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 00e0:  41 04 14 50 cb bc d8 84 d8 35 7a ff 54 27 58 5f  A..P.....5z.T'X_
    [00:01:07.433,349] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 00f0:  92 79 99 0d 89 f7 18 78 a1 9a dc 97 61 a6 6b 03  .y.....x....a.k.
    [00:01:07.449,157] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0100:  91 9b f4 97 15 74 66 8e 6a ff 88 e5 4e 1d 1d 3d  .....tf.j...N..=
    [00:01:07.464,965] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0110:  36 3e 99 5f 47 60 2b 60 28 77 48 fb 66 c4 3d 06  6>._G`+`(wH.f.=.
    [00:01:07.480,773] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0120:  8a 69 41 04 de 97 67 49 f4 21 e9 23 09 9b 44 d2  .iA...gI.!.#..D.
    [00:01:07.496,551] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0130:  a1 66 56 5f f1 6e f9 4b ac 79 ae 83 01 9f 92 95  .fV_.n.K.y......
    [00:01:07.512,359] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0140:  ee 2a 52 9a 54 8d 01 2a 4c d2 e3 0e a9 6d 7b 28  .*R.T..*L....m{(
    [00:01:07.528,167] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0150:  e8 7b b2 d9 f3 df 7e 07 13 d5 d7 95 a0 25 e4 30  .{....~......%.0
    [00:01:07.543,945] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0160:  a7 7b ce 75 20 0b ce be 56 ad e7 df 97 bd 05 51  .{.u ...V......Q
    [00:01:07.559,753] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0170:  4f b6 09 ee b1 51 29 f1 71 ed 95 cb ea 96 d2 f5  O....Q).q.......
    [00:01:07.575,500] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0180:  5a 1f fa 17 07 00 17 00 00 00 23                 Z.........#
    [00:01:07.591,827] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2784: => write handshake message
    [00:01:07.603,332] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2944: => write record
    [00:01:07.613,983] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3028: output record: msgtype = 22, version = [3:3], msglen = 482
    [00:01:07.628,082] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: dumping 'output record sent to network' (487 bytes)
    [00:01:07.643,707] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0000:  16 03 03 01 e2 01 00 01 de 03 03 83 27 b4 b0 f6  ............'...
    [00:01:07.661,193] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0010:  cc fb 1f 7e 51 66 88 21 18 61 64 39 19 2e 4e b4  ...~Qf.!.ad9..N.
    [00:01:07.678,680] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0020:  93 c5 4f f8 d9 54 c4 0b 07 6a a5 00 00 2a c0 24  ..O..T...j...*.$
    [00:01:07.696,136] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0030:  c0 28 c0 0a c0 14 c0 23 c0 27 c0 09 c0 13 00 3d  .(.....#.'.....=
    [00:01:07.713,592] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0040:  00 35 c0 2a c0 0f c0 26 c0 05 00 3c 00 2f c0 29  .5.*...&...<./.)
    [00:01:07.731,079] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0050:  c0 0e c0 25 c0 04 00 ff 01 00 01 8b 00 00 00 0f  ...%............
    [00:01:07.748,565] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0060:  00 0d 00 00 0a 67 6f 6f 67 6c 65 2e 63 6f 6d 00  .....google.com.
    [00:01:07.766,052] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0070:  0a 00 06 00 04 00 1d 00 17 00 0d 00 0e 00 0c 06  ................
    [00:01:07.783,538] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0080:  03 06 01 05 03 05 01 04 03 04 01 00 0b 00 02 01  ................
    [00:01:07.800,994] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0090:  00 01 00 01 4a 41 04 03 a5 0e 19 18 6e 04 ef 6d  ....JA......n..m
    [00:01:07.818,481] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 00a0:  df 55 16 d1 d3 9d f2 fe 39 6c e3 79 52 9a f6 b8  .U......9l.yR...
    [00:01:07.835,937] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 00b0:  1c 2c 25 60 ae 36 67 c4 f4 a9 74 92 0f e1 77 1b  .,%`.6g...t...w.
    [00:01:07.853,424] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 00c0:  2c ed 90 14 e8 b3 80 9e b1 34 2f ae f1 dc 2e f1  ,........4/.....
    [00:01:07.870,880] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 00d0:  8c 03 41 6a eb 87 fa 41 04 dd e1 7b 17 cc ac 4a  ..Aj...A...{...J
    [00:01:07.888,366] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 00e0:  81 bb 4d 57 a1 6e bb dc a8 0f 49 96 db 9b bd 83  ..MW.n....I.....
    [00:01:07.905,822] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 00f0:  ff c3 5f 1c ce 39 51 36 b0 7d 97 44 5d b8 c2 54  .._..9Q6.}.D]..T
    [00:01:07.923,309] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0100:  af 66 77 99 8c ce 7c 5e c2 b5 72 53 4e 26 a6 74  .fw...|^..rSN&.t
    [00:01:07.940,765] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0110:  96 79 ec a2 a1 ea 9a f3 02 20 3d ed 0b fc 27 96  .y....... =...'.
    [00:01:07.958,251] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0120:  1a bb cb 4e df 68 9a 1f 62 8e e8 6c b2 a2 fb 6e  ...N.h..b..l...n
    [00:01:07.975,708] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0130:  3f 17 92 1c aa 8e 94 2a e1 44 41 04 14 50 cb bc  ?......*.DA..P..
    [00:01:07.993,194] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0140:  d8 84 d8 35 7a ff 54 27 58 5f 92 79 99 0d 89 f7  ...5z.T'X_.y....
    [00:01:08.010,650] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0150:  18 78 a1 9a dc 97 61 a6 6b 03 91 9b f4 97 15 74  .x....a.k......t
    [00:01:08.028,137] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0160:  66 8e 6a ff 88 e5 4e 1d 1d 3d 36 3e 99 5f 47 60  f.j...N..=6>._G`
    [00:01:08.045,593] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0170:  2b 60 28 77 48 fb 66 c4 3d 06 8a 69 41 04 de 97  +`(wH.f.=..iA...
    [00:01:08.063,079] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0180:  67 49 f4 21 e9 23 09 9b 44 d2 a1 66 56 5f f1 6e  gI.!.#..D..fV_.n
    [00:01:08.080,535] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0190:  f9 4b ac 79 ae 83 01 9f 92 95 ee 2a 52 9a 54 8d  .K.y.......*R.T.
    [00:01:08.098,022] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 01a0:  01 2a 4c d2 e3 0e a9 6d 7b 28 e8 7b b2 d9 f3 df  .*L....m{(.{....
    [00:01:08.115,478] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 01b0:  7e 07 13 d5 d7 95 a0 25 e4 30 a7 7b ce 75 20 0b  ~......%.0.{.u .
    [00:01:08.132,965] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 01c0:  ce be 56 ad e7 df 97 bd 05 51 4f b6 09 ee b1 51  ..V......QO....Q
    [00:01:08.150,421] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 01d0:  29 f1 71 ed 95 cb ea 96 d2 f5 5a 1f fa 17 07 00  ).q.......Z.....
    [00:01:08.167,785] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 01e0:  17 00 00 00 23 00 00                             ....#..
    [00:01:08.184,204] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3081: <= write record
    [00:01:08.194,793] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2905: <= write handshake message
    [00:01:08.206,329] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:1014: <= write client hello
    [00:01:08.217,681] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2354: => flush output
    [00:01:08.228,302] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2368: message length: 487, out_left: 487
    [00:01:08.241,241] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2375: ssl->f_send() returned 487 (-0xfffffe19)
    [00:01:08.253,967] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2402: <= flush output
    [00:01:08.264,587] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4582: client state: MBEDTLS_SSL_SERVER_HELLO
    [00:01:08.277,160] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1196: => parse server hello
    [00:01:08.289,062] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4298: => read record
    [00:01:08.299,560] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2156: => fetch input
    [00:01:08.310,089] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2296: in_left: 0, nb_want: 5
    [00:01:08.321,289] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2316: in_left: 0, nb_want: 5
    [00:01:08.332,458] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4674: <= handshake
    [00:01:08.389,709] <dbg> net_sock: zsock_received_cb: (rx_q[0]): ctx=0x2000b0e8, pkt=0x2005f0a0, st=0, user_data=(nil)
    [00:01:08.401,275] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4663: => handshake
    [00:01:08.411,560] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2354: => flush output
    [00:01:08.422,149] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2363: <= flush output
    [00:01:08.432,739] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4582: client state: MBEDTLS_SSL_SERVER_HELLO
    [00:01:08.445,312] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1196: => parse server hello
    [00:01:08.457,214] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4298: => read record
    [00:01:08.467,712] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2156: => fetch input
    [00:01:08.478,210] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2296: in_left: 0, nb_want: 5
    [00:01:08.489,471] 00:01:08.493,194] <dbg> net_sock: zsock_received_cb: (rx_q[0]): ctx=0x2000b0e8, pkt=0x2005f0e0, st=0, user_data=(nil)
    1;33m<wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2316: in_left: 0, nb_want: 5
    [00:01:08.514,160] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2319: ssl->f_recv(_timeout)() returned 5 (-0xfffffffb)
    [00:01:08.527,587] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2341: <= fetch input
    [00:01:08.538,116] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3964: dumping 'input record header' (5 bytes)
    [00:01:08.552,581] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3964: 0000:  16 03 03 00 3f                                   ....?
    [00:01:08.568,878] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3966: input record: msgtype = 22, version = [0x303], msglen = 63
    [00:01:08.582,946] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2156: => fetch input
    [00:01:08.593,841] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2296: in_left: 5, nb_want: 68
    [00:01:08.605,163] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2316: in_left: 5, nb_want: 68
    [00:01:08.616,455] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2319: ssl->f_recv(_timeout)() returned 63 (-0xffffffc1)
    [00:01:08.629,974] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2341: <= fetch input
    [00:01:08.640,533] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: dumping 'input record from network' (68 bytes)
    [00:01:08.655,731] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0000:  16 03 03 00 3f 02 00 00 3b 03 03 68 37 87 ec 1c  ....?...;..h7...
    [00:01:08.673,187] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0010:  ac 8d 74 6b 07 45 6d 8a b8 ce 61 d0 31 85 0c 06  ..tk.Em...a.1...
    [00:01:08.690,673] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0020:  70 f6 f7 44 4f 57 4e 47 52 44 01 00 c0 09 00 00  p..DOWNGRD......
    [00:01:08.708,129] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0030:  13 00 17 00 00 ff 01 00 01 00 00 0b 00 02 01 00  ................
    [00:01:08.725,494] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0040:  00 23 00 00                                      .#..
    [00:01:08.741,668] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3239: handshake message: msglen = 63, type = 2, hslen = 63
    [00:01:08.755,249] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3328: sole handshake fragment: 63, 0..63 of 63
    [00:01:08.767,761] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: dumping 'reassembled record' (68 bytes)
    [00:01:08.782,348] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0000:  16 03 03 00 3f 02 00 00 3b 03 03 68 37 87 ec 1c  ....?...;..h7...
    [00:01:08.799,835] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0010:  ac 8d 74 6b 07 45 6d 8a b8 ce 61 d0 31 85 0c 06  ..tk.Em...a.1...
    [00:01:08.817,291] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0020:  70 f6 f7 44 4f 57 4e 47 52 44 01 00 c0 09 00 00  p..DOWNGRD......
    [00:01:08.834,777] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0030:  13 00 17 00 00 ff 01 00 01 00 00 0b 00 02 01 00  ................
    [00:01:08.852,813] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0040:  00 23 00 00                                      .#..
    [00:01:08.869,293] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4370: <= read record
    [00:01:08.879,791] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1270: dumping 'server hello, version' (2 bytes)
    [00:01:08.893,280] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1270: 0000:  03 03                                            ..
    [00:01:08.908,142] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1291: server hello, current time: 1748469740
    [00:01:08.921,264] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1301: dumping 'server hello, random bytes' (32 bytes)
    [00:01:08.935,394] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1301: 0000:  68 37 87 ec 1c ac 8d 74 6b 07 45 6d 8a b8 ce 61  h7.....tk.Em...a
    [00:01:08.951,751] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1301: 0010:  d0 31 85 0c 06 70 f6 f7 44 4f 57 4e 47 52 44 01  .1...p..DOWNGRD.
    [00:01:08.967,834] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1363: server hello, session id len.: 0
    [00:01:08.980,438] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1364: dumping 'server hello, session id' (0 bytes)
    [00:01:08.994,079] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1388: no session has been resumed
    [00:01:09.006,225] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1391: server hello, chosen ciphersuite: c009
    [00:01:09.019,348] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1392: server hello, compress alg.: 0
    [00:01:09.031,799] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1427: server hello, chosen ciphersuite: TLS-ECDHE-ECDSA-WITH-AES-128-CBC-SHA
    [00:01:09.047,698] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1448: server hello, total extension length: 19
    [00:01:09.061,248] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1518: found extended_master_secret extension
    [00:01:09.074,371] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1466: found renegotiation extension
    [00:01:09.086,730] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1545: found supported_point_formats extension
    [00:01:09.099,945] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:0844: point format selected: 0
    [00:01:09.113,739] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1531: found session_ticket extension
    [00:01:09.126,159] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1662: <= parse server hello
    [00:01:09.138,061] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2354: => flush output
    [00:01:09.148,651] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2363: <= flush output
    [00:01:09.159,271] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4582: client state: MBEDTLS_SSL_SERVER_CERTIFICATE
    [00:01:09.172,363] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:8095: => parse certificate
    [00:01:09.183,380] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4298: => read record
    [00:01:09.193,878] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2156: => fetch input
    [00:01:09.204,406] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2296: in_left: 0, nb_want: 5
    [00:01:09.215,637] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2316: in_left: 0, nb_want: 5
    [00:01:09.226,837] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2319: ssl->f_recv(_timeout)() returned 5 (-0xfffffffb)
    [00:01:09.240,264] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2341: <= fetch input
    [00:01:09.250,823] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3964: dumping 'input record header' (5 bytes)
    [00:01:09.265,930] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3964: 0000:  16 03 03 18 b5                                   .....
    [00:01:09.282,257] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3966: input record: msgtype = 22, version = [0x303], msglen = 6325
    [00:01:09.296,478] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2156: => fetch input
    [00:01:09.307,006] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2296: in_left: 5, nb_want: 6330
    [00:01:09.319,030] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2316: in_left: 5, nb_want: 6330
    [00:01:09.330,505] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2319: ssl->f_recv(_timeout)() returned 1291 (-0xfffffaf5)
    [00:01:09.344,268] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2316: in_left: 1296, nb_want: 6330
    [00:01:09.355,957] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4674: <= handshake
      File "<stdin>", line 1, in <module>
    OSError: [Errno 116] ETIMEDOUT
    As far as I understand the logs, there are a few exchanges between the server and the client, but when an exchange that requires 6.3kb of data is expected by TLS, it receives 1.3kb of data but then times out before receiving the rest. I've repeated the test numerous times and the result is the same. Any ideas what this might be?
    Edit: wouldn't a call be faster? Given that I have everything set up and am 80% there?
