I am trying to use the nrfx driver example to run an RGB led connected externally to the nrf5340 board.
I dont see the led/pwm cycle running successfully. Can anyone please have a look & suggest corrections?
Device Tree Overlay File:
&sw_pwm {
status = "okay";
channel-gpios = <&gpio1 13 PWM_POLARITY_NORMAL>,
<&gpio1 14 PWM_POLARITY_NORMAL>,
<&gpio1 15 PWM_POLARITY_NORMAL>;
pwmleds {
compatible = "pwm-leds";
status = "okay";
red_pwm_led: red_pwm_led {
pwms = <&sw_pwm 2 PWM_MSEC(100) PWM_POLARITY_INVERTED>;
label = "RED PWM LED";
green_pwm_led: green_pwm_led {
pwms = <&sw_pwm 0 PWM_MSEC(100) PWM_POLARITY_INVERTED>;
label = "GREEN PWM LED";
blue_pwm_led: blue_pwm_led {
pwms = <&sw_pwm 1 PWM_MSEC(100) PWM_POLARITY_INVERTED>;
label = "BLUE PWM LED";
aliases {
red-pwm-led = &red_pwm_led;
green-pwm-led = &green_pwm_led;
blue-pwm-led = &blue_pwm_led;
swpwm = &sw_pwm;
Code Snippet:
#include "nrfx_pwm.h"
#define GREEN_LED_PIN (NRF_GPIO_PIN_MAP(1, 13))
#define BLUE_LED_PIN (NRF_GPIO_PIN_MAP(1, 14))
#define RED_LED_PIN (NRF_GPIO_PIN_MAP(1, 15))
static nrfx_pwm_t m_pwm0 = NRFX_PWM_INSTANCE(0);
// Sequence: LED ON for 25 ms, OFF for 9975 ms (assuming 10s period, 1 Hz)
static nrf_pwm_values_common_t seq_values[] = {
25, // ON (duty cycle value for 25 ms)
0 // OFF (duty cycle value for 9975 ms)
static nrf_pwm_sequence_t const seq =
.values.p_common = seq_values,
.length = NRF_PWM_VALUES_LENGTH(seq_values),
.repeats = 0,
.end_delay = 0
void pwm_init(void)
nrfx_pwm_config_t const config0 =
.output_pins = { GREEN_LED_PIN, BLUE_LED_PIN, RED_LED_PIN },
.irq_priority = NRFX_PWM_DEFAULT_CONFIG_IRQ_PRIORITY,
.base_clock = NRF_PWM_CLK_1MHz,
.count_mode = NRF_PWM_MODE_UP,
.top_value = 10000, // 10,000 ticks at 1 MHz = 10 ms per period
.load_mode = NRF_PWM_LOAD_COMMON,
.step_mode = NRF_PWM_STEP_AUTO
nrfx_pwm_init(&m_pwm0, &config0, NULL, NULL);
void start_pwm(void)
nrfx_pwm_simple_playback(&m_pwm0, &seq, 1, NRFX_PWM_FLAG_LOOP);
