Error when compiling application with NSC v3.0.1 and CONFIG_BT_LL_SOFTDEVICE=n
I recently updated Nordic connect SDK and toolchain from v2.7.0 to v3.0.1. When compiling my application with activated CONFIG_BT_LL_SOFTDEVICE flag, I get this error message:
c:/ncs/toolchains/0b393f9e1b/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd.exe: zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a(hci_core.c.obj):(.data.bt_dev+0x170): undefined reference to `__device_dts_ord_112'
collect2.exe: error: ld returned 1 exit status
When setting the CONFIG flag to "no" it compiles as expected. When using v2.7.0 I also had the flag set to "no" and it worked. Are there any related changes in the new version? I didn't find anything about it in the Migration guides.
Christian
    Could you attach the entire build log? There's most likely something more useful somewhere else in the log.
    Do you set 'CONFIG_BT_LL_SOFTDEVICE="no"' or "CONFIG_BT_LL_SOFTDEVICE=n"?
    Andreas
    thanks for your answer, here's the complete log:
     *  Executing task: nRF Connect: Build [pristine]: test_app/hw3_button_3_0_1 (active)
    Building test_app
    C:\WINDOWS\system32\cmd.exe /d /s /c "west build --build-dir d:/Projekte/nrf_connect_sdk/apps/test_app/hw3_button_3_0_1 d:/Projekte/nrf_connect_sdk/apps/test_app --pristine --board [email protected]/nrf52833 --sysbuild -- -DNCS_TOOLCHAIN_VERSION=NONE -DBOARD_ROOT=d:\Projekte\nrf_connect_sdk"
    Loading Zephyr module(s) (Zephyr base): sysbuild_default
    -- Found Python3: C:/ncs/toolchains/0b393f9e1b/opt/bin/python.exe (found suitable version "3.12.4", minimum required is "3.10") found components: Interpreter
    -- Cache files will be written to: C:/ncs/v3.0.1/zephyr/.cache
    -- Board: test_app, Revision: 2.0.0, qualifiers: nrf52833
    Parsing d:/Projekte/nrf_connect_sdk/apps/test_app/Kconfig.sysbuild
    Loaded configuration 'D:/Projekte/nrf_connect_sdk/apps/test_app/hw3_button_3_0_1/_sysbuild/empty.conf'
    Merged configuration 'D:/Projekte/nrf_connect_sdk/apps/test_app/hw3_button_3_0_1/_sysbuild/empty.conf'
    Merged configuration 'd:/Projekte/nrf_connect_sdk/apps/test_app/sysbuild.conf'
    Configuration saved to 'D:/Projekte/nrf_connect_sdk/apps/test_app/hw3_button_3_0_1/zephyr/.config'
    Kconfig header saved to 'D:/Projekte/nrf_connect_sdk/apps/test_app/hw3_button_3_0_1/_sysbuild/autoconf.h'
       * Running CMake for test_app *
    -- Application: D:/Projekte/nrf_connect_sdk/apps/test_app
    -- CMake version: 3.21.0
    -- Zephyr version: 4.0.99 (C:/ncs/v3.0.1/zephyr)
    -- Found host-tools: zephyr 0.17.0 (C:/ncs/toolchains/0b393f9e1b/opt/zephyr-sdk)
    -- Found toolchain: zephyr 0.17.0 (C:/ncs/toolchains/0b393f9e1b/opt/zephyr-sdk)
    -- Found Dtc: C:/ncs/toolchains/0b393f9e1b/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
    -- Found BOARD.dts: D:/Projekte/nrf_connect_sdk/boards/Haveltec/test_app/test_app.dts
    -- Found devicetree overlay: D:/Projekte/nrf_connect_sdk/boards/Haveltec/test_app/test_app_2_0_0.overlay
    unit address and first address in 'reg' (0x43000) don't match for /soc/flash-controller@4001e000/flash@0/partitions/partition@430000
    -- Generated zephyr.dts: D:/Projekte/nrf_connect_sdk/apps/test_app/hw3_button_3_0_1/test_app/zephyr/zephyr.dts
    -- Generated pickled edt: D:/Projekte/nrf_connect_sdk/apps/test_app/hw3_button_3_0_1/test_app/zephyr/edt.pickle
    -- Generated devicetree_generated.h: D:/Projekte/nrf_connect_sdk/apps/test_app/hw3_button_3_0_1/test_app/zephyr/include/generated/zephyr/devicetree_generated.h
    -- Including generated dts.cmake file: D:/Projekte/nrf_connect_sdk/apps/test_app/hw3_button_3_0_1/test_app/zephyr/dts.cmake
    warning: LOG_BUFFER_SIZE (defined at C:/ncs/v3.0.1/nrf\subsys/net/openthread/Kconfig.defconfig:51,
    subsys/logging\Kconfig.processing:122) was assigned the value '4096' but got the value ''. Check
    these unsatisfied dependencies: (NET_L2_OPENTHREAD || (LOG_MODE_DEFERRED && !LOG_FRONTEND_ONLY &&
    !LOG_MODE_MINIMAL && LOG)) (=n). See
    http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_LOG_BUFFER_SIZE and/or look up
    LOG_BUFFER_SIZE in the menuconfig/guiconfig interface. The Application Development Primer, Setting
    Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be helpful
    too.
    warning: BT_CTLR_SDC_PERIPHERAL_COUNT (defined at
    C:/ncs/v3.0.1/nrf\subsys\bluetooth\controller/Kconfig:138) was assigned the value '3' but got the
    value ''. Check these unsatisfied dependencies: BT_LL_SOFTDEVICE (=n). See
    http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_BT_CTLR_SDC_PERIPHERAL_COUNT and/or look up
    BT_CTLR_SDC_PERIPHERAL_COUNT in the menuconfig/guiconfig interface. The Application Development
    Primer, Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual
    might be helpful too.
    warning: BT_LL_SW_SPLIT (defined at subsys/bluetooth\controller/Kconfig:145) was assigned the value
    'y' but got the value 'n'. Check these unsatisfied dependencies:
    DT_HAS_ZEPHYR_BT_HCI_LL_SW_SPLIT_ENABLED (=n). See
    http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_BT_LL_SW_SPLIT and/or look up
    BT_LL_SW_SPLIT in the menuconfig/guiconfig interface. The Application Development Primer, Setting
    too.
    warning: LOG_BACKEND_FORMAT_TIMESTAMP (defined at subsys/logging\Kconfig.formatting:172) was
    assigned the value 'y' but got the value 'n'. Check these unsatisfied dependencies:
    LOG_BACKEND_SUPPORTS_FORMAT_TIMESTAMP (=n), (!LOG_MODE_MINIMAL) (=n). See
    http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_LOG_BACKEND_FORMAT_TIMESTAMP and/or look up
    LOG_BACKEND_FORMAT_TIMESTAMP in the menuconfig/guiconfig interface. The Application Development
    warning: Deprecated symbol NFCT_PINS_AS_GPIOS is enabled.
    warning: Deprecated symbol BT_CTLR is enabled.
    Parsing D:/Projekte/nrf_connect_sdk/apps/test_app/Kconfig
    Loaded configuration 'D:/Projekte/nrf_connect_sdk/boards/Haveltec/test_app/test_app_defconfig'
    Merged configuration 'D:/Projekte/nrf_connect_sdk/boards/Haveltec/test_app/test_app_2_0_0_defconfig'
    Merged configuration 'D:/Projekte/nrf_connect_sdk/apps/test_app/prj.conf'
    Merged configuration 'D:/Projekte/nrf_connect_sdk/apps/test_app/hw3_button_3_0_1/test_app/zephyr/.config.sysbuild'
    Configuration saved to 'D:/Projekte/nrf_connect_sdk/apps/test_app/hw3_button_3_0_1/test_app/zephyr/.config'
    Kconfig header saved to 'D:/Projekte/nrf_connect_sdk/apps/test_app/hw3_button_3_0_1/test_app/zephyr/include/generated/zephyr/autoconf.h'
    -- Found GnuLd: c:/ncs/toolchains/0b393f9e1b/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi/bin/ld.bfd.exe (found version "2.38")
    -- Found assembler: C:/ncs/toolchains/0b393f9e1b/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc.exe
    CMake Warning at C:/ncs/v3.0.1/zephyr/subsys/usb/device/CMakeLists.txt:22 (message):
      CONFIG_USB_DEVICE_VID has default value 0x2FE3.
      This value is only for testing and MUST be configured for USB products.
    =========== Generating psa_crypto_config ===============
    Backup: CONFIG_MBEDTLS_PSA_CRYPTO_SPM: False
    Backup: CONFIG_MBEDTLS_PSA_CRYPTO_C: True
    Backup: CONFIG_MBEDTLS_PSA_CRYPTO_KEY_ID_ENCODES_OWNER: False
    Backup: CONFIG_MBEDTLS_PLATFORM_SETUP_TEARDOWN_ALT: False
    Backup: CONFIG_MBEDTLS_THREADING: False
    Backup: CONFIG_MBEDTLS_THREADING_ALT: True
    =========== Checkpoint: backup ===============
    Restore: CONFIG_MBEDTLS_PSA_CRYPTO_SPM: False
    Restore: CONFIG_MBEDTLS_PSA_CRYPTO_C: True
    Restore: CONFIG_MBEDTLS_PSA_CRYPTO_KEY_ID_ENCODES_OWNER: False
    Restore: CONFIG_MBEDTLS_PLATFORM_SETUP_TEARDOWN_ALT: False
    Restore: CONFIG_MBEDTLS_THREADING: False
    Restore: CONFIG_MBEDTLS_THREADING_ALT: True
    =========== End psa_crypto_config ===============
    =========== Generating psa_crypto_library_config ===============
    Backup: CONFIG_MBEDTLS_USE_PSA_CRYPTO: True
    Backup: CONFIG_MBEDTLS_PLATFORM_PRINTF_ALT: False
    Restore: CONFIG_MBEDTLS_USE_PSA_CRYPTO: True
    Restore: CONFIG_MBEDTLS_PLATFORM_PRINTF_ALT: False
    =========== End psa_crypto_library_config ===============
    CMake Warning at C:/ncs/v3.0.1/zephyr/CMakeLists.txt:2180 (message):
    -- Configuring done
    -- Generating done
    -- Build files have been written to: D:/Projekte/nrf_connect_sdk/apps/test_app/hw3_button_3_0_1/test_app
    -- Configuring done
    -- Generating done
    [6/314] Generating include/generated/zephyr/version.h
    -- Zephyr version: 4.0.99 (C:/ncs/v3.0.1/zephyr), build: v4.0.99-ncs1-1
    [115/314] Building C object CMakeFiles/app.dir/D_/Projekte/nrf_connect_sdk/libs/uicr/ili_uicr.c.obj
    D:/Projekte/nrf_connect_sdk/libs/uicr/ili_uicr.c: In function 'ili_read_uicr':
    [199/314] Building C object CMakeFiles/app.dir/src/main.c.obj
    D:/Projekte/nrf_connect_sdk/apps/test_app/src/main.c:321:5: warning: 'BT_LE_ADV_OPT_CONNECTABLE' is deprecated [-Wdeprecated-declarations]
      321 |     .options = BT_LE_ADV_OPT_CONNECTABLE | BT_LE_ADV_OPT_USE_NAME
    In file included from D:/Projekte/nrf_connect_sdk/apps/test_app/src/main.c:19:
    C:/ncs/v3.0.1/zephyr/include/zephyr/bluetooth/bluetooth.h:638:9: note: declared here
      638 |         BT_LE_ADV_OPT_CONNECTABLE __deprecated = BIT(0),
    [309/314] Linking C executable zephyr\zephyr_pre0.elf
    FAILED: zephyr/zephyr_pre0.elf zephyr/zephyr_pre0.map D:/Projekte/nrf_connect_sdk/apps/test_app/hw3_button_3_0_1/test_app/zephyr/zephyr_pre0.map
    cmd.exe /C "cd . && C:\ncs\toolchains\0b393f9e1b\opt\zephyr-sdk\arm-zephyr-eabi\bin\arm-zephyr-eabi-gcc.exe  -gdwarf-4 @CMakeFiles\zephyr_pre0.rsp -o zephyr\zephyr_pre0.elf -L"c:/ncs/toolchains/0b393f9e1b/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/thumb/v7e-m/nofp" -lc -lgcc && cmd.exe /C "cd /D D:\Projekte\nrf_connect_sdk\apps\test_app\hw3_button_3_0_1\test_app\zephyr && C:\ncs\toolchains\0b393f9e1b\opt\bin\cmake.exe -E true""
    FAILED: _sysbuild/sysbuild/images/test_app-prefix/src/test_app-stamp/test_app-build D:/Projekte/nrf_connect_sdk/apps/test_app/hw3_button_3_0_1/_sysbuild/sysbuild/images/test_app-prefix/src/test_app-stamp/test_app-build
    cmd.exe /C "cd /D D:\Projekte\nrf_connect_sdk\apps\test_app\hw3_button_3_0_1\test_app && C:\ncs\toolchains\0b393f9e1b\opt\bin\cmake.exe --build ."
    FATAL ERROR: command exited with status 1: 'C:\ncs\toolchains\0b393f9e1b\opt\bin\cmake.EXE' --build D:/Projekte/nrf_connect_sdk/apps/test_app/hw3_button_3_0_1
     *  The terminal process terminated with exit code: 1.
    I set the CONFIG variable to n.
    Christian
  • Hi Christian,
    Thank you for sharing
    As you stated, I see there are some artifacts here w.r.t your application from 2.7.0 that are using deprecated functionality. Could you go through the release notes and migration guides and clear up any remaining warnings?
    Here's some resources that should get your through this:
    I know this is quite a bit of work to do, but unfortunately it's not as easy as "just upgrade" w.r.t upgrading to a newer release of NCS when you're going over 4 major releases of the SDK
    Andreas
    thanks for the support. I overlooked the bt-ll-sw-split snippet. After adding this, everything worked as expected.
    Christian
