nRF9160 DK - A-GPS
I'm using nRF9160DK with SDKs v3.0.0
I am trying to use A-GPS with nRFCloud REST. I used the location example and it works correctly. The documentation states that A-GPS is used via the location.h library
docs.nordicsemi.com/.../location.html
The thing I don't understand about this example is whether the application actually uses A-GPS, or should I work in the LOCATION_EVT_GNSS_ASSISTANCE_REQUEST event.
In the example, I cannot understand where the assistance request is activated.
    I will look more into it and get back to you with more information.
    Michal
    thank u for your reply. Unfortunately, I'm still stuck. I tried reading the documentation to better understand A-GPS.
  • From digging into the location library, I think the following happens:
    As long as you have the following in your prj.conf
    # nRF Cloud (for A-GNSS and cell location)
    CONFIG_NRF_CLOUD=y
    CONFIG_NRF_CLOUD_REST=y
    CONFIG_NRF_CLOUD_AGNSS=y
    CONFIG_MODEM_INFO=y # required by CONFIG_NRF_CLOUD_AGNSS
    CONFIG_MODEM_INFO_ADD_NETWORK=y # required by CONFIG_NRF_CLOUD_AGNSS
    # Library that maintains the current date time UTC for A-GNSS and P-GPS purposes
    CONFIG_DATE_TIME=y
    And you initialize location_init() function with the event handler like in the sample, then the location library should take care of it in the background.
    Those two links may be useful as well:
    nRF Cloud A-GNSS
    Using GNSS and GNSS assistance
    If you want to dig more into it, you can for example look into
    ncs/v3.0.0/nrf/lib/location/method_gnss.c
    or
    ncs/v3.0.0/nrf/lib/location/method_cloud_location.c
    as well as location_core.c and other files in that directory, as well the header files like
    ncs/v3.0.0/nrf/include/modem/location.h
    I have asked internally as well, just to make sure my assumptions are correct.
    Michal
