NRF54L10: I2C configuration error
Hello Team,
I'm using nrf54l15 dk and ncs version 2.9.0 for the development. I am getting an error while configuring I2C. I selected i2c20 from the device tree and assigned P1.00 for SCL and P1.01 for SDA. It generated the following code in the nrf54l15dk_nrf54l10_cpuapp.overlay file
&i2c20 {
	pinctrl-0 = <&i2c20_default>;
	pinctrl-names = "default";
&pinctrl {
	i2c20_default: i2c20_default {
		group1 {
			psels = <NRF_PSEL(TWIM_SDA, 1, 1)>, <NRF_PSEL(TWIM_SCL, 1, 0)>;
Added the following configuration in the prj.conf file
CONFIG_I2C=y
CONFIG_PINCTRL=y
And wrote the following code to initialize I2C
#define I2C_NODE        DT_NODELABEL(i2c20)
const struct device *const i2c_dev = DEVICE_DT_GET(I2C_NODE);
const uint16_t i2c_addr = 0x68;
const struct i2c_dt_spec *i2c_spec;
i2c_spec = I2C_DT_SPEC_GET(I2C_NODE);
I'm getting the following error
devicetree error: 'pinctrl-0' is marked as required in 'properties:' in C:/ncs/v2.9.0/zephyr/dts/bindings\i2c\nordic,nrf-twim.yaml, but does not appear in <Node /soc/peripheral@50000000/i2c@c6000 in 'C:/ncs/v2.9.0/zephyr/misc/empty_file.c'>
Kindly help me resolve the error.
Payal
    It seems that you're lacking the pinctrl-1 entry, based on the error message.
    Yes, the pinctrl-1 entry was missing; adding it successfully compiled my code.
    Thanks for the help.
    I have one doubt when I configured P1.12 and P1.14 for SDA and SCL, in devicetree.
    Only the code below is generated in my .overlayfile
    &pinctrl {
        i2c21_default: i2c21_default {
            group1 {
                psels = <NRF_PSEL(TWIM_SCL, 1, 12)>, <NRF_PSEL(TWIM_SDA, 1, 14)>;
    &i2c21 {
        status = "okay";
        pinctrl-0 = <&i2c21_default>;
        zephyr,deferred-init;
    Can you help me understand why pincntrl-1 entry code and
    i2c20_sleep: i2c20_sleep {
    group1 {
    psels = <NRF_PSEL(TWIM_SDA, 1, 11)>,
    <NRF_PSEL(TWIM_SCL, 1, 12)>;
    low-power-enable;
    is not generated?
    Are there any additional settings for this?
    Payal
    You are currently using i2c21 and not i2c20, so this entry will not be used:
    group1 {
    low-power-enable;
    Håkon
    Understood. But for i2c21 below entry should be generated
    i2c21_sleep: i2c21_sleep {
    group1 {
    psels = <NRF_PSEL(TWIM_SDA, 1, 12)>,
    <NRF_PSEL(TWIM_SCL, 1, 14)>;
    low-power-enable;
    Right?
    Why is it not generated when I configure i2c21 in the devicetree?
    What is the significance of this entry?
    payalD said:
    Right?
    I am not sure I understand what you mean here.
    You setup i2c21 to only hold a default pin setup:
    &i2c21 {
        status = "okay";
    Which will not refer to any other instances than the "i2c21_default" in this case.
    Håkon
