NRF54L10: I2C configuration error
Hello Team,
I'm using nrf54l15 dk and ncs version 2.9.0 for the development. I am getting an error while configuring I2C. I selected i2c20 from the device tree and assigned P1.00 for SCL and P1.01 for SDA. It generated the following code in the nrf54l15dk_nrf54l10_cpuapp.overlay file
&i2c20 {
	pinctrl-0 = <&i2c20_default>;
	pinctrl-names = "default";
&pinctrl {
	i2c20_default: i2c20_default {
		group1 {
			psels = <NRF_PSEL(TWIM_SDA, 1, 1)>, <NRF_PSEL(TWIM_SCL, 1, 0)>;
Added the following configuration in the prj.conf file
CONFIG_I2C=y
CONFIG_PINCTRL=y
And wrote the following code to initialize I2C
#define I2C_NODE        DT_NODELABEL(i2c20)
const struct device *const i2c_dev = DEVICE_DT_GET(I2C_NODE);
const uint16_t i2c_addr = 0x68;
const struct i2c_dt_spec *i2c_spec;
i2c_spec = I2C_DT_SPEC_GET(I2C_NODE);
I'm getting the following error
devicetree error: 'pinctrl-0' is marked as required in 'properties:' in C:/ncs/v2.9.0/zephyr/dts/bindings\i2c\nordic,nrf-twim.yaml, but does not appear in <Node /soc/peripheral@50000000/i2c@c6000 in 'C:/ncs/v2.9.0/zephyr/misc/empty_file.c'>
Kindly help me resolve the error.
Payal
    Could you share the full blinky project that fails, including which board you configure towards?
    Håkon
  •  *  Executing task: nRF Connect: Build: Code/Code (active)
    Building Code
    C:\Windows\system32\cmd.exe /d /s /c "west build --build-dir c:/Payal/Project/Gas_meter/gas_meter_base_fw/Code_1/Code/build --domain Code"
    -- west build: building domain(s): Code
    [0/1] Re-running CMake...
    Loading Zephyr default modules (Zephyr base (cached)).
    -- Application: C:/Payal/Project/Gas_meter/gas_meter_base_fw/Code_1/Code
    -- CMake version: 3.21.0
    -- Cache files will be written to: C:/ncs/v2.9.0/zephyr/.cache
    -- Zephyr version: 3.7.99 (C:/ncs/v2.9.0/zephyr)
    -- Board: nrf54l15dk, qualifiers: nrf54l10/cpuapp
    -- Found host-tools: zephyr 0.17.0 (C:/ncs/toolchains/b620d30767/opt/zephyr-sdk)
    -- Found toolchain: zephyr 0.17.0 (C:/ncs/toolchains/b620d30767/opt/zephyr-sdk)
    -- Found BOARD.dts: C:/ncs/v2.9.0/zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l10_cpuapp.dts
    -- Found devicetree overlay: C:/Payal/Project/Gas_meter/gas_meter_base_fw/Code_1/Code/nrf54l15dk_nrf54l10_cpuapp.overlay
    unit address and first address in 'reg' (0x5004c000) don't match for /soc/peripheral@50000000/vpr@4c000/mailbox@1
    -- Generated zephyr.dts: C:/Payal/Project/Gas_meter/gas_meter_base_fw/Code_1/Code/build/Code/zephyr/zephyr.dts
    -- Generated devicetree_generated.h: C:/Payal/Project/Gas_meter/gas_meter_base_fw/Code_1/Code/build/Code/zephyr/include/generated/zephyr/devicetree_generated.h
    -- Including generated dts.cmake file: C:/Payal/Project/Gas_meter/gas_meter_base_fw/Code_1/Code/build/Code/zephyr/dts.cmake
    Parsing C:/ncs/v2.9.0/zephyr/Kconfig
    Loaded configuration 'C:/Payal/Project/Gas_meter/gas_meter_base_fw/Code_1/Code/build/Code/zephyr/.config'
    Merged configuration 'C:/Payal/Project/Gas_meter/gas_meter_base_fw/Code_1/Code/build/Code/zephyr/.config.sysbuild'
    No change to configuration in 'C:/Payal/Project/Gas_meter/gas_meter_base_fw/Code_1/Code/build/Code/zephyr/.config'
    No change to Kconfig header in 'C:/Payal/Project/Gas_meter/gas_meter_base_fw/Code_1/Code/build/Code/zephyr/include/generated/zephyr/autoconf.h'
    =========== Generating psa_crypto_config ===============
    Backup: CONFIG_MBEDTLS_PSA_CRYPTO_SPM: False
    Backup: CONFIG_MBEDTLS_PSA_CRYPTO_C: True
    Backup: CONFIG_MBEDTLS_PSA_CRYPTO_KEY_ID_ENCODES_OWNER: False
    Backup: CONFIG_MBEDTLS_PLATFORM_SETUP_TEARDOWN_ALT: False
    Backup: CONFIG_MBEDTLS_THREADING: False
    Backup: CONFIG_MBEDTLS_THREADING_ALT: True
    =========== Checkpoint: backup ===============
    Restore: CONFIG_MBEDTLS_PSA_CRYPTO_SPM: False
    Restore: CONFIG_MBEDTLS_PSA_CRYPTO_C: True
    Restore: CONFIG_MBEDTLS_PSA_CRYPTO_KEY_ID_ENCODES_OWNER: False
    Restore: CONFIG_MBEDTLS_PLATFORM_SETUP_TEARDOWN_ALT: False
    Restore: CONFIG_MBEDTLS_THREADING: False
    Restore: CONFIG_MBEDTLS_THREADING_ALT: True
    =========== End psa_crypto_config ===============
    =========== Generating psa_crypto_library_config ===============
    Backup: CONFIG_MBEDTLS_USE_PSA_CRYPTO: True
    Backup: CONFIG_MBEDTLS_PLATFORM_PRINTF_ALT: False
    Restore: CONFIG_MBEDTLS_USE_PSA_CRYPTO: True
    Restore: CONFIG_MBEDTLS_PLATFORM_PRINTF_ALT: False
    =========== End psa_crypto_library_config ===============
    -- Including signing script: C:/ncs/v2.9.0/nrf/cmake/sysbuild/image_signing.cmake
    -- Configuring done
    -- Generating done
    -- Build files have been written to: C:/Payal/Project/Gas_meter/gas_meter_base_fw/Code_1/Code/build/Code
    [51/191] Building C object zephyr/drivers/i2c/CMakeFiles/drivers__i2c.dir/i2c_nrfx_twim.c.obj
    FAILED: zephyr/drivers/i2c/CMakeFiles/drivers__i2c.dir/i2c_nrfx_twim.c.obj
    C:\ncs\toolchains\b620d30767\opt\zephyr-sdk\arm-zephyr-eabi\bin\arm-zephyr-eabi-gcc.exe -DDEVELOP_IN_NRF54L15 -DKERNEL -DK_HEAP_MEM_POOL_SIZE=0 -DMBEDTLS_CONFIG_FILE=\"nrf-config.h\" -DMBEDTLS_PSA_CRYPTO_CONFIG_FILE=\"nrf-psa-crypto-config.h\" -DMBEDTLS_PSA_CRYPTO_USER_CONFIG_FILE=\"nrf-psa-crypto-user-config.h\" -DNRF54L10_XXAA -DNRF_APPLICATION -DNRF_CONFIG_CPU_FREQ_MHZ=128 -DPICOLIBC_DOUBLE_PRINTF_SCANF -DUSE_PARTITION_MANAGER=1 -D__LINUX_ERRNO_EXTENSIONS__ -D__PROGRAM_START -D__ZEPHYR_SUPERVISOR__ -D__ZEPHYR__=1 -IC:/ncs/v2.9.0/nrf/drivers/mpsl/clock_control -IC:/Payal/Project/Gas_meter/gas_meter_base_fw/Code_1/Code/build/Code/zephyr/include/generated/zephyr -IC:/ncs/v2.9.0/zephyr/include -IC:/Payal/Project/Gas_meter/gas_meter_base_fw/Code_1/Code/build/Code/zephyr/include/generated -IC:/ncs/v2.9.0/zephyr/soc/nordic -IC:/ncs/v2.9.0/zephyr/soc/nordic/nrf54l/. -IC:/ncs/v2.9.0/zephyr/soc/nordic/common/. -IC:/ncs/v2.9.0/zephyr/subsys/mgmt/mcumgr/util/include -IC:/ncs/v2.9.0/bootloader/mcuboot/boot/bootutil/include -IC:/ncs/v2.9.0/zephyr/subsys/mgmt/mcumgr/transport/include -IC:/ncs/v2.9.0/zephyr/subsys/bluetooth -IC:/ncs/v2.9.0/zephyr/subsys/settings/include -IC:/ncs/v2.9.0/nrf/include -IC:/ncs/v2.9.0/nrf/lib/multithreading_lock/. -IC:/ncs/v2.9.0/nrf/subsys/bluetooth/controller/. -IC:/ncs/v2.9.0/zephyr/drivers/flash -IC:/ncs/v2.9.0/nrf/tests/include -IC:/ncs/v2.9.0/modules/hal/cmsis/CMSIS/Core/Include -IC:/ncs/v2.9.0/zephyr/modules/cmsis/. -IC:/ncs/v2.9.0/modules/hal/nordic/nrfx -IC:/ncs/v2.9.0/modules/hal/nordic/nrfx/drivers/include -IC:/ncs/v2.9.0/modules/hal/nordic/nrfx/mdk -IC:/ncs/v2.9.0/zephyr/modules/hal_nordic/nrfx/. -IC:/ncs/v2.9.0/modules/crypto/tinycrypt/lib/include -IC:/ncs/v2.9.0/modules/lib/zcbor/include -IC:/ncs/v2.9.0/nrfxlib/softdevice_controller/include -IC:/ncs/v2.9.0/nrfxlib/mpsl/fem/common/include -IC:/ncs/v2.9.0/nrfxlib/mpsl/fem/nrf21540_gpio/include -IC:/ncs/v2.9.0/nrfxlib/mpsl/fem/nrf21540_gpio_spi/include -IC:/ncs/v2.9.0/nrfxlib/mpsl/fem/nrf2220/include -IC:/ncs/v2.9.0/nrfxlib/mpsl/fem/nrf2240/include -IC:/ncs/v2.9.0/nrfxlib/mpsl/fem/nrf22xx/include -IC:/ncs/v2.9.0/nrfxlib/mpsl/fem/simple_gpio/include -IC:/ncs/v2.9.0/nrfxlib/mpsl/fem/include -IC:/ncs/v2.9.0/nrfxlib/mpsl/fem/include/protocol -IC:/ncs/v2.9.0/nrfxlib/mpsl/include -IC:/ncs/v2.9.0/nrfxlib/mpsl/include/protocol -IC:/Payal/Project/Gas_meter/gas_meter_base_fw/Code_1/Code/build/Code/generated/library_nrf_security_psa -IC:/ncs/v2.9.0/nrf/subsys/nrf_security/include -IC:/ncs/v2.9.0/nrf/subsys/nrf_security/src/threading/include -IC:/ncs/v2.9.0/nrf/subsys/nrf_security/src/utils -IC:/ncs/v2.9.0/nrf/subsys/nrf_security/src/drivers/cracen/common/include -IC:/ncs/v2.9.0/nrf/subsys/nrf_security/src/drivers/cracen/sxsymcrypt/include -IC:/ncs/v2.9.0/nrf/subsys/nrf_security/src/drivers/cracen/silexpk/target/baremetal_ba414e_with_ik -IC:/ncs/v2.9.0/nrf/subsys/nrf_security/src/drivers/cracen/silexpk/include -IC:/ncs/v2.9.0/nrf/subsys/nrf_security/src/drivers/cracen/sicrypto/include -IC:/ncs/v2.9.0/nrf/subsys/nrf_security/src/drivers/cracen/cracenpsa/include -IC:/ncs/v2.9.0/modules/crypto/oberon-psa-crypto/include -IC:/ncs/v2.9.0/modules/crypto/oberon-psa-crypto/library -IC:/ncs/v2.9.0/modules/crypto/mbedtls/library -IC:/ncs/v2.9.0/modules/crypto/mbedtls/include -IC:/ncs/v2.9.0/modules/crypto/mbedtls/include/library -IC:/ncs/v2.9.0/nrfxlib/crypto/nrf_oberon/include -isystem C:/ncs/v2.9.0/zephyr/lib/libc/common/include -Os -DNDEBUG -Wshadow -fno-strict-aliasing -Os -imacros C:/Payal/Project/Gas_meter/gas_meter_base_fw/Code_1/Code/build/Code/zephyr/include/generated/zephyr/autoconf.h -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m33 -mthumb -mabi=aapcs -mfpu=fpv5-sp-d16 -mfloat-abi=hard -mfp16-format=ieee -mtp=soft --sysroot=C:/ncs/toolchains/b620d30767/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi -imacros C:/ncs/v2.9.0/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wdouble-promotion -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-pic -fno-pie -fno-asynchronous-unwind-tables -ftls-model=local-exec -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=C:/Payal/Project/Gas_meter/gas_meter_base_fw/Code_1/Code=CMAKE_SOURCE_DIR -fmacro-prefix-map=C:/ncs/v2.9.0/zephyr=ZEPHYR_BASE -fmacro-prefix-map=C:/ncs/v2.9.0=WEST_TOPDIR -ffunction-sections -fdata-sections -specs=picolibc.specs -std=c99 -MD -MT zephyr/drivers/i2c/CMakeFiles/drivers__i2c.dir/i2c_nrfx_twim.c.obj -MF zephyr\drivers\i2c\CMakeFiles\drivers__i2c.dir\i2c_nrfx_twim.c.obj.d -o zephyr/drivers/i2c/CMakeFiles/drivers__i2c.dir/i2c_nrfx_twim.c.obj -c C:/ncs/v2.9.0/zephyr/drivers/i2c/i2c_nrfx_twim.c
    In file included from C:/ncs/v2.9.0/zephyr/include/zephyr/toolchain.h:50,
                     from C:/ncs/v2.9.0/zephyr/include/zephyr/sys/__assert.h:11,
                     from C:/ncs/v2.9.0/zephyr/include/zephyr/irq_multilevel.h:15,
                     from C:/ncs/v2.9.0/zephyr/include/zephyr/devicetree.h:20,
                     from C:/ncs/v2.9.0/zephyr/include/zephyr/device.h:12,
                     from C:/ncs/v2.9.0/zephyr/include/zephyr/drivers/i2c.h:27,
                     from C:/ncs/v2.9.0/zephyr/drivers/i2c/i2c_nrfx_twim.c:7:
    C:/ncs/v2.9.0/zephyr/include/zephyr/toolchain/gcc.h:87:36: error: static assertion failed: "/soc/peripheral@50000000/i2c@c7000 defined without sleep state"
       87 | #define BUILD_ASSERT(EXPR, MSG...) _Static_assert((EXPR), "" MSG)
    c:\ncs\v2.9.0\zephyr\soc\nordic\common\soc_nrf_common.h:235:9: note: in expansion of macro 'BUILD_ASSERT'
      235 |         BUILD_ASSERT(!IS_ENABLED(CONFIG_PM_DEVICE) ||                          \
    C:/ncs/v2.9.0/zephyr/drivers/i2c/i2c_nrfx_twim.c:230:9: note: in expansion of macro 'NRF_DT_CHECK_NODE_HAS_PINCTRL_SLEEP'
      230 |         NRF_DT_CHECK_NODE_HAS_PINCTRL_SLEEP(I2C(idx));                         \
    C:/ncs/v2.9.0/zephyr/drivers/i2c/i2c_nrfx_twim.c:298:1: note: in expansion of macro 'I2C_NRFX_TWIM_DEVICE'
      298 | I2C_NRFX_TWIM_DEVICE(21);
    [56/191] Building C object zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/uart_nrfx_uarte.c.obj
    FATAL ERROR: command exited with status 1: 'C:\ncs\toolchains\b620d30767\opt\bin\cmake.EXE' --build C:/Payal/Project/Gas_meter/gas_meter_base_fw/Code_1/Code/build/Code
     *  The terminal process terminated with exit code: 1.
    I tried reinstalling the NCS version 2.9.0, and now I can compile the samples for nrf54l10 without any errors.
    Now I want to configure I2C in my code, as you said, P1.00 and P1.01 are used for the external LFXO.
    P1.00 / P1.01 is by default used for the external LFXO. If testing on a DK, you should choose other pins.
    I configured P1.12 as SCL and P1.14 as SDA. Now I am getting the following error.
    The full error log file is attached.
    Can you help me resolve the error? Or how to configure I2C in NCS version 2.9.0?
    Payal
    Glad to hear that you got that sorted!
    Based on that build error message, it seems that there's defined a default and sleep pinctrl state, but not declared a sleep pinctrl entry.
    Here's a suggestion (feel free to change the pinout):
    &i2c20 {
    	status = "okay";
    	pinctrl-1 = <&i2c20_sleep>;
    &uart20 {
    	status = "disabled";
    &pinctrl {
    		group1 {
    			psels = <NRF_PSEL(TWIM_SDA, 1, 11)>,
    				<NRF_PSEL(TWIM_SCL, 1, 12)>;
    	i2c20_sleep: i2c20_sleep {
    		group1 {
    			low-power-enable;
    Håkon
    Tried your suggestion. I got the following error.
    devicetree error: pinctrl-names property in /soc/peripheral@50000000/i2c@c7000 in C:/ncs/v2.9.0/zephyr/misc/empty_file.c has 2 strings, expected 1 strings
    CMake Error at C:/ncs/v2.9.0/zephyr/cmake/modules/dts.cmake:295 (execute_process):
    execute_process failed command indexes:
    1: "Child return code: 1"
    Executing task: nRF Connect: Build [pristine]: Code/build
    Building Code
    C:\Windows\system32\cmd.exe /d /s /c "west build --build-dir c:/Payal/Project/Gas_meter/gas_meter_base_fw/Code_1/Code/build c:/Payal/Project/Gas_meter/gas_meter_base_fw/Code_1/Code --pristine --board nrf54l15dk/nrf54l10/cpuapp --sysbuild -- -DNCS_TOOLCHAIN_VERSION=NONE -DBOARD_ROOT=c:/payal/project/gas_meter/gas_meter_base_fw/code_1/code"
    Loading Zephyr module(s) (Zephyr base): sysbuild_default
    -- Found Python3: C:/ncs/toolchains/b620d30767/opt/bin/python.exe (found suitable version "3.12.4", minimum required is "3.8") found components: Interpreter
    Parsing C:/ncs/v2.9.0/zephyr/share/sysbuild/Kconfig
    Loaded configuration 'C:/Payal/Project/Gas_meter/gas_meter_base_fw/Code_1/Code/build/_sysbuild/empty.conf'
    Merged configuration 'c:/Payal/Project/Gas_meter/gas_meter_base_fw/Code_1/Code/sysbuild.conf'
    Configuration saved to 'C:/Payal/Project/Gas_meter/gas_meter_base_fw/Code_1/Code/build/zephyr/.config'
    Kconfig header saved to 'C:/Payal/Project/Gas_meter/gas_meter_base_fw/Code_1/Code/build/_sysbuild/autoconf.h'
       * Running CMake for mcuboot *
    -- Application: C:/ncs/v2.9.0/bootloader/mcuboot/boot/zephyr
    -- Found Dtc: C:/ncs/toolchains/b620d30767/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
    -- Found devicetree overlay: C:/ncs/v2.9.0/bootloader/mcuboot/boot/zephyr/app.overlay
    -- Generated zephyr.dts: C:/Payal/Project/Gas_meter/gas_meter_base_fw/Code_1/Code/build/mcuboot/zephyr/zephyr.dts
    -- Generated devicetree_generated.h: C:/Payal/Project/Gas_meter/gas_meter_base_fw/Code_1/Code/build/mcuboot/zephyr/include/generated/zephyr/devicetree_generated.h
    -- Including generated dts.cmake file: C:/Payal/Project/Gas_meter/gas_meter_base_fw/Code_1/Code/build/mcuboot/zephyr/dts.cmake
    warning: NRF_RTC_TIMER_USER_CHAN_COUNT (defined at
    C:/ncs/v2.9.0/zephyr/soc/nordic\nrf53\Kconfig.sync_rtc:23, drivers/timer/Kconfig.nrf_rtc:20) was
    assigned the value '0' but got the value ''. Check these unsatisfied dependencies: ((NRF53_SYNC_RTC
    && SOC_SERIES_NRF53X && SOC_FAMILY_NORDIC_NRF) || (NRF_RTC_TIMER && SYS_CLOCK_EXISTS)) (=n). See
    http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_NRF_RTC_TIMER_USER_CHAN_COUNT and/or look
    up NRF_RTC_TIMER_USER_CHAN_COUNT in the menuconfig/guiconfig interface. The Application Development
    Primer, Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual
    might be helpful too.
    Parsing C:/ncs/v2.9.0/bootloader/mcuboot/boot/zephyr/Kconfig
    Loaded configuration 'C:/ncs/v2.9.0/zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l10_cpuapp_defconfig'
    Merged configuration 'C:/ncs/v2.9.0/bootloader/mcuboot/boot/zephyr/prj.conf'
    Merged configuration 'C:/ncs/v2.9.0/bootloader/mcuboot/boot/zephyr/boards/nrf54l15dk_nrf54l10_cpuapp.conf'
    Merged configuration 'C:/Payal/Project/Gas_meter/gas_meter_base_fw/Code_1/Code/build/mcuboot/zephyr/.config.sysbuild'
    Configuration saved to 'C:/Payal/Project/Gas_meter/gas_meter_base_fw/Code_1/Code/build/mcuboot/zephyr/.config'
    Kconfig header saved to 'C:/Payal/Project/Gas_meter/gas_meter_base_fw/Code_1/Code/build/mcuboot/zephyr/include/generated/zephyr/autoconf.h'
    -- Found GnuLd: c:/ncs/toolchains/b620d30767/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi/bin/ld.bfd.exe (found version "2.38")
    -- Found assembler: C:/ncs/toolchains/b620d30767/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc.exe
    -- Setting build type to 'MinSizeRel' as none was specified.
    MCUBoot bootloader key file: C:/ncs/v2.9.0/bootloader/mcuboot/root-rsa-2048.pem
    -- Configuring done
    -- Generating done
    -- Build files have been written to: C:/Payal/Project/Gas_meter/gas_meter_base_fw/Code_1/Code/build/mcuboot
       * Running CMake for Code *
      C:/ncs/v2.9.0/zephyr/cmake/modules/zephyr_default.cmake:133 (include)
      C:/ncs/v2.9.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:66 (include)
      C:/ncs/v2.9.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate)
      CMakeLists.txt:4 (find_package)
    CMake Error at cmake/modules/sysbuild_extensions.cmake:514 (message):
      CMake configure failed for Zephyr project: Code
      Location: C:/Payal/Project/Gas_meter/gas_meter_base_fw/Code_1/Code
      cmake/modules/sysbuild_images.cmake:20 (ExternalZephyrProject_Cmake)
      cmake/modules/sysbuild_default.cmake:20 (include)
      C:/ncs/v2.9.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:75 (include)
      C:/ncs/v2.9.0/zephyr/share/sysbuild-package/cmake/SysbuildConfig.cmake:8 (include)
      template/CMakeLists.txt:10 (find_package)
    See also "C:/Payal/Project/Gas_meter/gas_meter_base_fw/Code_1/Code/build/CMakeFiles/CMakeOutput.log".
    FATAL ERROR: command exited with status 1: 'C:\ncs\toolchains\b620d30767\opt\bin\cmake.EXE' -DWEST_PYTHON=C:/ncs/toolchains/b620d30767/opt/bin/python.exe '-Bc:\Payal\Project\Gas_meter\gas_meter_base_fw\Code_1\Code\build' -GNinja -DBOARD=nrf54l15dk/nrf54l10/cpuapp -DNCS_TOOLCHAIN_VERSION=NONE -DBOARD_ROOT=c:/payal/project/gas_meter/gas_meter_base_fw/code_1/code '-SC:\ncs\v2.9.0\zephyr\share\sysbuild' '-DAPP_DIR:PATH=c:\Payal\Project\Gas_meter\gas_meter_base_fw\Code_1\Code'
    And how does your .overlay file look now?
    It seems that you're lacking the pinctrl-1 entry, based on the error message.
    Håkon
