nrf52840 ble mesh: Toggle function for generic ONOFF SERVER
Is there the possibility for a node with a Generic OnOff Client (BUTTON) to send a unique toggle command to a Generic OnOff Server (LED), instead to use 'bt_mesh_onoff_cli_set_unack' function and build a toggle logic changing the set value every time I push the button?
It could be an important feature in a system where there are for example two clients (BUTTON1 and BUTTON2) that command a single server (LED0).
When I press a button (it does not matter which) I want that LED0 goes ON, the when I press a button again (it does not matter which) I want that LED0 goes OFF and so on.
But if I use 'bt_mesh_onoff_cli_set_unack' function for BUTTON1 and BUTTON2 here is what happens:
Press BUTTON1 --> LED0 ON
Press BUTTON2 --> LED0 ON!! (I wanted LED0 OFF)
Press BUTTON1 --> LED0 OFF
Press BUTTON2--> LED0 OFF!! (I wanted LED0 ON)
and so on
Best regards
