Help with CoAP Client Sample on nRF9160 DK Using Jio NB-IoT SIM
Hi Nordic team,
I'm using the nRF9160 DK with nRF Connect SDK v2.9.1, and trying to run the coap_client sample to send a GET request to the public CoAP test server at coap.me (IP: 134.102.218.18), targeting the resource path /hello.
I'm using a Jio NB-IoT SIM for LTE connectivity.
I’ve configured the sample as follows:
Enabled CONFIG_COAP_CLIENT=y
Set CONFIG_COAP_SERVER_HOSTNAME="coap.me"
Set CONFIG_COAP_SERVER_PORT=5683
Enabled CONFIG_LTE_LINK_CONTROL=y and CONFIG_LTE_AUTO_INIT_AND_CONNECT=n
Using conn_mgr to establish the LTE connection before sending the CoAP request
I would like to ask:
Is there anything specific I need to change to get communication working with a CoAP server like coap.me?
Has anyone successfully used NB-IoT (especially with Jio SIM) to send CoAP requests over UDP?
Are there any known limitations or additional requirements for using NB-IoT for CoAP communication?
Thanks and regards,
Arun
  • Yes, I’m using NCS 2.9.1 with the sample located at:
    nrf/samples/net/coap_client
    I only modified these two Kconfig values:
    CONFIG_COAP_SAMPLE_SERVER_HOSTNAME="coap.me"
    CONFIG_COAP_SAMPLE_RESOURCE="hello"
  • west build -d build_nrf9160dk_nrf9160_ns -b nrf9160dk/nrf9160/ns --pristine -- -DCONFIG_COAP_SAMPLE_SERVER_HOSTNAME='"coap.me"' -DCONFIG_COAP_SAMPLE_RESOURCE='"hello"' -DSNIPPET="nrf91-modem-trace-uart"
    will enable the modem trace.
    coap.pcapng.gz
    (My modem uses currently LTE-M, in my experience in Europe, there is no difference according UDP, except that LTE-M has a lower latency.)
  • still facing
    *** Booting nRF Connect SDK v2.9.1-60d0d6c8d42d ***
    *** Using Zephyr OS v3.7.99-ca954a6216c9 ***
    [00:00:00.389,739] <inf> coap_client_sample: The CoAP client sample started
    [00:00:00.389,770] <inf> coap_client_sample: Bringing network interface up and connecting to the network
    [00:00:00.723,083] <inf> coap_client_sample: Waiting for network connectivity
    [00:01:16.345,245] <wrn> nrf_modem_lib_netif: No IPv4 address given by the network
    [00:01:16.411,895] <inf> coap_client_sample: Network connectivity established
    [00:01:16.616,424] <inf> coap_client_sample: IPv4 Address found 134.102.218.18
    [00:01:16.616,729] <inf> coap_client_sample: Initializing CoAP client
    [00:01:16.618,347] <err> coap_client_sample: Failed to send request: -114
    [00:01:16.618,347] <err> coap_client_sample: periodic_coap_request_loop, error: -114
    [00:01:16.618,347] <err> coap_client_sample: Fatal error! Rebooting the device*** Booting nRF Connect SDK v2.9.1-60d0d6c8d42d ***
    [00:00:00.253,295] <inf> coap_client_sample: The CoAP client sample started
    [00:00:00.253,326] <inf> coap_client_sample: Bringing network interface up and connecting to the network
    [00:00:00.584,411] <inf> coap_client_sample: Waiting for network connectivity
    [00:01:21.317,138] <wrn> nrf_modem_lib_netif: No IPv4 address given by the network
    [00:01:21.388,763] <inf> coap_client_sample: Network connectivity established
    [00:01:21.738,281] <inf> coap_client_sample: IPv4 Address found 134.102.218.18
    [00:01:21.738,555] <inf> coap_client_sample: Initializing CoAP client
    [00:01:21.740,173] <err> coap_client_sample: Failed to send request: -114
    [00:01:21.740,203] <err> coap_client_sample: periodic_coap_request_loop, error: -114
    [00:01:21.740,203] <err> coap_client_sample: Fatal error! Rebooting the device
  • I forgot to mention — I'm actually using the nRF9151 DK, not the nRF9160.
    From what I understand, the nRF9151 is fully compatible with the nrf9160dk_nrf9160_ns build target, and no changes to the configuration are required for this sample. Please correct me if I'm wrong.
  • west build -b nrf9151dk/nrf9151/ns --pristine -- -DCONFIG_COAP_SAMPLE_SERVER_HOSTNAME='"coap.me"' -DCONFIG_COAP_SAMPLE_RESOURCE='"hello"' -DSNIPPET="nrf91-modem-trace-uart" -DCONFIG_LTE_NETWORK_MODE_NBIOT=y
    (you may skip the -DCONFIG_LTE_NETWORK_MODE_NBIOT=y, I just add this to force my modem in NB-IoT mode.)
    coap-nbiot.pcapng.gz
    Edited: just in the case you're not common with using the modem trace and export capture in wireshark.
    Modem Trace, see DevAcademy - Modem Trace
    Export Captures, see Logs and IP Capturing ‐ How To Provide The Right Information - Wireshark.
