Hi there,
I have tested out the BLE-NUS SDK firmware on the NRF51422 SDK Board, and it responded well. When I ported the exact same code over to my custom board, I received auto disconnection and error code 10 upon connection to the board from the nRF UART App.
When the baud rate is >4800, the peripheral is unrecoverable. When i changed the baud rate to 2400, the BLE-NUS is discoverable but the above mentioned disconnection happens.
This is the segment of the main function:
static void ble_evt_dispatch(ble_evt_t * p_ble_evt) { ble_conn_params_on_ble_evt(p_ble_evt); ble_nus_on_ble_evt(&m_nus, p_ble_evt); on_ble_evt(p_ble_evt); ble_advertising_on_ble_evt(p_ble_evt); }
static void sys_evt_dispatch(uint32_t sys_evt) { ble_advertising_on_sys_evt(sys_evt); pstorage_sys_event_handler(sys_evt); -- for pstorage use; not shown }
static void gap_params_init(void) { uint32_t err_code; ble_gap_conn_params_t gap_conn_params; ble_gap_conn_sec_mode_t sec_mode;
strlen(DEVICE_NAME));
gap_conn_params.slave_latency = SLAVE_LATENCY;
gap_conn_params.conn_sup_timeout = CONN_SUP_TIMEOUT;
static void scheduler_init(void) { APP_SCHED_INIT(SCHED_MAX_EVENT_DATA_SIZE, SCHED_QUEUE_SIZE); }
static void services_init(void) { uint32_t err_code; ble_nus_init_t nus_init;
static void conn_params_init(void) { uint32_t err_code; ble_conn_params_init_t cp_init;
cp_init.p_conn_params = NULL;
cp_init.next_conn_params_update_delay = NEXT_CONN_PARAMS_UPDATE_DELAY;
cp_init.max_conn_params_update_count = MAX_CONN_PARAMS_UPDATE_COUNT;
cp_init.start_on_notify_cccd_handle = BLE_GATT_HANDLE_INVALID;
cp_init.disconnect_on_fail = false;
cp_init.evt_handler = on_conn_params_evt;
cp_init.error_handler = conn_params_error_handler;
static void uart_init(void) { uint32_t err_code; const app_uart_comm_params_t comm_params = { RX_PIN_NUMBER, // RX Pin TX_PIN_NUMBER, // TX Pin RTS_PIN_NUMBER, // RTS Pin CTS_PIN_NUMBER, // CTS Pin APP_UART_FLOW_CONTROL_DISABLED, false, UART_BAUDRATE_BAUDRATE_Baud2400 };
UART_RX_BUF_SIZE,
UART_TX_BUF_SIZE,
uart_event_handle,
APP_IRQ_PRIORITY_LOW,
err_code);
static void advertising_init(void) { uint32_t err_code; ble_advdata_t advdata; ble_advdata_t scanrsp;
memset(&advdata, 0, sizeof(advdata));
advdata.name_type = BLE_ADVDATA_FULL_NAME;
advdata.include_appearance = false;
advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
memset(&scanrsp, 0, sizeof(scanrsp));
scanrsp.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
scanrsp.uuids_complete.p_uuids = m_adv_uuids;
ble_adv_modes_config_t options = {0};
options.ble_adv_fast_enabled = BLE_ADV_FAST_ENABLED;
options.ble_adv_fast_interval = APP_ADV_INTERVAL;
options.ble_adv_fast_timeout = APP_ADV_TIMEOUT_IN_SECONDS;
err_code = ble_advertising_init(&advdata, &scanrsp, &options, on_adv_evt, NULL);
int main(void) {
ble_stack_init(); // Initializes the S110 Soft Device -- LFCLK; and BLE event interrupt
APP_TIMER_INIT(APP_TIMER_PRESCALER, APP_TIMER_MAX_TIMERS, APP_TIMER_OP_QUEUE_SIZE, false);
scheduler_init();
gap_params_init();
services_init();
advertising_init();
conn_params_init();
uart_init();
ble_advertising_start(BLE_ADV_MODE_FAST);
// Enter main loop.
for (;;)
app_sched_execute();
power_manage();
Wireshark logs:
