TC-CNET-4.2 Failing Matter over Thread door Lock
CHIPTOOL | 2025-05-27 15:16:32.517076 | CHIP:DMG SuppressResponse = true,
CHIPTOOL | 2025-05-27 15:16:32.520788 | CHIP:DMG InteractionModelRevision = 11
CHIPTOOL | 2025-05-27 15:16:32.521850 | CHIP:DMG }
CHIPTOOL | 2025-05-27 15:16:32.522991 | CHIP:TOO Endpoint: 0 Cluster: 0x0000_0031 Attribute 0x0000_0001 DataVersion: 2560674587
CHIPTOOL | 2025-05-27 15:16:32.523970 | CHIP:TOO Networks: 1 entries
CHIPTOOL | 2025-05-27 15:16:32.526492 | CHIP:TOO [1]: {
CHIPTOOL | 2025-05-27 15:16:32.527595 | CHIP:TOO NetworkID: 6EF21B4719BD75EC
CHIPTOOL | 2025-05-27 15:16:32.528533 | CHIP:TOO Connected: TRUE
CHIPTOOL | 2025-05-27 15:16:32.529423 | CHIP:TOO }
CHIPTOOL | 2025-05-27 15:16:32.532036 | CHIP:DMG >> to UDP:[fd11:22::517c:f86f:bd69:8325%wpan0]:5540 | 24502156 | [Secure Channel (0) / Standalone Ack (0x10) / Session = 13397 / Exchange = 5722]
CHIPTOOL | 2025-05-27 15:16:32.533111 | CHIP:DMG Header Flags =
CHIPTOOL | 2025-05-27 15:16:32.534052 | CHIP:DMG {
CHIPTOOL | 2025-05-27 15:16:32.535879 | CHIP:DMG Exchange (0x03) =
CHIPTOOL | 2025-05-27 15:16:32.538170 | CHIP:DMG {
CHIPTOOL | 2025-05-27 15:16:32.539313 | CHIP:DMG Initiator = true
CHIPTOOL | 2025-05-27 15:16:32.540256 | CHIP:DMG AckMsg = 93836004
CHIPTOOL | 2025-05-27 15:16:32.541154 | CHIP:DMG }
CHIPTOOL | 2025-05-27 15:16:32.543909 | CHIP:DMG }
CHIPTOOL | 2025-05-27 15:16:32.544961 | CHIP:DMG
CHIPTOOL | 2025-05-27 15:16:32.545892 | CHIP:DMG Additional Fields =
CHIPTOOL | 2025-05-27 15:16:32.546865 | CHIP:DMG {
CHIPTOOL | 2025-05-27 15:16:32.549825 | CHIP:DMG peer_address = UDP:[fd11:22::517c:f86f:bd69:8325%wpan0]:5540
CHIPTOOL | 2025-05-27 15:16:32.551002 | CHIP:DMG }
CHIPTOOL | 2025-05-27 15:16:32.551952 | CHIP:DMG
CHIPTOOL | 2025-05-27 15:16:32.552866 | CHIP:EM <<< [E:5722i S:20017 M:24502156 (Ack:93836004)] (S) Msg TX to 1:2A4C4AC7DF607E64 [0C00] [UDP:[fd11:22::517c:f86f:bd69:8325%wpan0]:5540] --- Type 0000:10 (SecureChannel:StandaloneAck)
CHIPTOOL | 2025-05-27 15:16:32.555969 | CHIP:EM Flushed pending ack for MessageCounter:93836004 on exchange 5722i
WARNING | 2025-05-27 15:16:32.557784 | Test Failure: The response ([{'NetworkID': b'n\xf2\x1bG\x19\xbdu\xec', 'Connected': True}]) is missing [{'NetworkID': b'\x11\x11\x11\x11""""', 'Connected': True}].
INFO | 2025-05-27 15:16:32.560239 | Test Step Completed [FAILED]: Step 7: TH reads the Networks attribute list from the DUT
INFO | 2025-05-27 15:16:32.565208 | Executing Test Step: Step 8: TH reads ScanMaxTimeSeconds attribute from the DUT
CHIPTOOL | 2025-05-27 15:16:33.712405 | CHIP:TOO Command: networkcommissioning read scan-max-time-seconds 0x2a4c4ac7df607e64 0
CHIPTOOL | 2025-05-27 15:16:33.713800 | CHIP:TOO Sending command to node 0x2a4c4ac7df607e64
Parents Reply
  • CHIPTOOL | 2025-05-27 15:16:32.527595 | CHIP:TOO NetworkID: 6EF21B4719BD75EC
    I believe there are two ways to solve this.
    1: Do not change anything in the Test Harness. Just create a Thread Network with ID: 1111111122222222
    2: Use the NetworkID from the created Thread network (different from 1111111122222222) => Then PIXIT has to be modified accordingly.
    Edvin
