Can't get WPA2 Enterprise (EAP-TLS) to connect to wifi AP using nrf5340/nrf7002/NCS2.9.0
I am trying to get the wifi stack to connect to a wifi AP using WAP2 Enterprise (initially just with identity and eap_password, later with full ca_certificate check and client certificate).
We have a custom PCB with nrf5340, nrf7002, and an application built with NCS2.9.0.
The code will connect ok when using WPA2-PSK and WPA3-SAE, but doesn't manage to connect using WPA2-EAP-TLS?
To try to determine why, I have enabled WPA2-Enterprise connection in the wifi-sta sample but this doesn't connect either.
wifi-sta prj.conf file:
4300.prj.conf
The connection setup code is like this:
static int __wifi_params_wpa2eap(struct wifi_connect_req_params *params)
    params->timeout =  CONFIG_STA_CONN_TIMEOUT_SEC * MSEC_PER_SEC;
    if (params->timeout == 0) {
        params->timeout = SYS_FOREVER_MS;
    /* Defaults */
    params->band = WIFI_FREQ_BAND_UNKNOWN;
    params->channel = WIFI_CHANNEL_ANY;
    params->security = WIFI_SECURITY_TYPE_NONE;
    params->mfp = WIFI_MFP_OPTIONAL;
    /* SSID */
    params->ssid =STA_SSID;
    params->ssid_length = strlen(params->ssid);
    params->security = WIFI_SECURITY_TYPE_EAP_TLS;
    params->eap_identity = STA_IDENTITY;        //"cc2-004a";
    params->eap_id_length = strlen(params->eap_identity);
    params->eap_password = STA_PASSWORD;
    params->eap_passwd_length = strlen(params->eap_password);
    return 0;
Is this correct to set up a WPA2 EAP-TLS connection?
btw my wifi AP is a HP 505H using an internal database for EAP user lookup.
The debug output from wpa_supplient during the connection attempt:
[00:00:00.470,855] <inf> sta: Starting cc2v1 with CPU frequency: 64 MHz
[00:00:00.471,038] <dbg> wpa_supp: wpa_printf_impl: wpa_supplicant v2.11-devel
[00:00:00.471,252] <inf> wifi_supplicant: wpa_supplicant initialized
[00:00:00.471,618] <dbg> wifi_supplicant: add_interface: Adding interface wlan0 [1] (0x200019b8)
[00:00:00.471,710] <dbg> wpa_supp: wpa_printf_impl: Calling wpa_cli: interface_add, argc: 5
[00:00:00.471,771] <dbg> wpa_supp: wpa_printf_impl: argv[0]: interface_add
[00:00:00.471,832] <dbg> wpa_supp: wpa_printf_impl: argv[1]: wlan0
[00:00:00.471,862] <dbg> wpa_supp: wpa_printf_impl: argv[2]: zephyr
[00:00:00.471,893] <dbg> wpa_supp: wpa_printf_impl: argv[3]: zephyr
[00:00:00.471,954] <dbg> wpa_supp: wpa_printf_impl: argv[4]: zephyr
[00:00:00.472,320] <dbg> wpa_supp: wpa_printf_impl: RX global ctrl_iface - hexdump_ascii(len=71):
[00:00:00.472,351] <dbg> wpa_supp: _wpa_hexdump_ascii:
49 4e 54 45 52 46 41 43 45 5f 41 44 44 20 77 6c |INTERFAC E_ADD wl
61 6e 30 09 7a 65 70 68 79 72 09 7a 65 70 68 79 |an0.zeph yr.zephy
72 09 7a 65 70 68 79 72 09 09 09 09 20 77 6c 61 |r.zephyr .... wla
6e 30 20 7a 65 70 68 79 72 20 7a 65 70 68 79 72 |n0 zephy r zephyr
20 7a 65 70 68 79 72 | zephyr
[00:00:00.472,412] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE GLOBAL INTERFACE_ADD 'wlan0 zephyr zephyr zephyr wlan0 zephyr zephyr zephyr'
[00:00:00.472,534] <dbg> wpa_supp: wpa_printf_impl: Initializing interface 'wlan0' conf 'zephyr' driver 'zephyr' ctrl_interface 'zephyr' bridge 'N/A'
[00:00:00.474,517] <dbg> wpa_supp: wpa_printf_impl: Add interface wlan0 to a new radio N/A
[00:00:00.477,966] <dbg> wpa_supp: wpa_printf_impl: wpa_supp: Added 802.11b mode based on 802.11g information
[00:00:00.478,179] <dbg> wpa_supp: wpa_printf_impl: l2_packet_init: iface wlan0 ifindex 1
[00:00:00.478,332] <dbg> wpa_supp: wpa_printf_impl: wlan0: Own MAC address: f0:ce:37:00:00:4a
[00:00:00.478,485] <dbg> wpa_supp: wpa_printf_impl: _wpa_drv_zep_set_key: priv:0x2000a450 alg 0 addr 0x0 key_idx 0 set_tx 0 seq 0x0 seq_len 0 key 0x0 key_len 0 key_flag 10
[00:00:00.482,025] <dbg> wpa_supp: wpa_printf_impl: _wpa_drv_zep_set_key: priv:0x2000a450 alg 0 addr 0x0 key_idx 1 set_tx 0 seq 0x0 seq_len 0 key 0x0 key_len 0 key_flag 10
[00:00:00.484,344] <dbg> wpa_supp: wpa_printf_impl: _wpa_drv_zep_set_key: priv:0x2000a450 alg 0 addr 0x0 key_idx 2 set_tx 0 seq 0x0 seq_len 0 key 0x0 key_len 0 key_flag 10
[00:00:00.486,663] <dbg> wpa_supp: wpa_printf_impl: _wpa_drv_zep_set_key: priv:0x2000a450 alg 0 addr 0x0 key_idx 3 set_tx 0 seq 0x0 seq_len 0 key 0x0 key_len 0 key_flag 10
[00:00:00.488,983] <dbg> wpa_supp: wpa_printf_impl: _wpa_drv_zep_set_key: priv:0x2000a450 alg 0 addr 0x0 key_idx 4 set_tx 0 seq 0x0 seq_len 0 key 0x0 key_len 0 key_flag 10
[00:00:00.492,675] <dbg> wpa_supp: wpa_printf_impl: _wpa_drv_zep_set_key: priv:0x2000a450 alg 0 addr 0x0 key_idx 5 set_tx 0 seq 0x0 seq_len 0 key 0x0 key_len 0 key_flag 10
[00:00:00.494,964] <dbg> wpa_supp: wpa_printf_impl: wlan0: RSN: flushing PMKID list in the driver
[00:00:00.495,086] <dbg> wpa_supp: wpa_printf_impl: wlan0: State: DISCONNECTED -> INACTIVE
[00:00:00.557,220] <dbg> wpa_supp: wpa_printf_impl: EAPOL: SUPP_PAE entering state DISCONNECTED
[00:00:00.557,281] <dbg> wpa_supp: wpa_printf_impl: EAPOL: Supplicant port status: Unauthorized
[00:00:00.567,687] <dbg> wpa_supp: wpa_printf_impl: EAPOL: KEY_RX entering state NO_KEY_RECEIVE
[00:00:00.567,749] <dbg> wpa_supp: wpa_printf_impl: EAPOL: SUPP_BE entering state INITIALIZE
[00:00:00.567,779] <dbg> wpa_supp: wpa_printf_impl: EAP: EAP entering state DISABLED
[00:00:00.568,145] <dbg> wpa_supp: wpa_printf_impl: wlan0: Added interface wlan0
[00:00:00.568,267] <dbg> wpa_supp: wpa_printf_impl: wlan0: State: INACTIVE -> DISCONNECTED
[00:00:01.471,008] <dbg> wpa_supp: wpa_printf_impl: Calling wpa_cli: remove_network, argc: 2
[00:00:01.471,069] <dbg> wpa_supp: wpa_printf_impl: argv[0]: remove_network
[00:00:01.471,099] <dbg> wpa_supp: wpa_printf_impl: argv[1]: all
[00:00:01.471,466] <dbg> wpa_supp: wpa_printf_impl: wlan0: Control interface command 'REMOVE_NETWORK all'
[00:00:01.471,557] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: REMOVE_NETWORK all
[00:00:01.472,076] <dbg> wpa_supp: wpa_printf_impl: wlan0: Control interface command 'ADD_NETWORK'
[00:00:01.472,167] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: ADD_NETWORK
[00:00:01.472,656] <dbg> wpa_supp: wpa_printf_impl: Received len: 26, msg_len:26 - CTRL-EVENT-NETWORK-ADDED 0->END
[00:00:01.473,022] <dbg> wpa_supp: wpa_printf_impl: NET added: 0
[00:00:01.473,114] <dbg> wpa_supp: wpa_printf_impl: Calling wpa_cli: set_network, argc: 4
[00:00:01.473,175] <dbg> wpa_supp: wpa_printf_impl: argv[0]: set_network
[00:00:01.473,205] <dbg> wpa_supp: wpa_printf_impl: argv[1]: 0
[00:00:01.473,266] <dbg> wpa_supp: wpa_printf_impl: argv[2]: ssid
[00:00:01.473,297] <dbg> wpa_supp: wpa_printf_impl: argv[3]: "kiosk_wpa2_ent"
[00:00:01.473,693] <dbg> wpa_supp: wpa_printf_impl: wlan0: Control interface command 'SET_NETWORK [REMOVED]'
[00:00:01.473,815] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: SET_NETWORK id=0 name='ssid'
[00:00:01.473,876] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: value - hexdump_ascii(len=16): [REMOVED]
[00:00:01.473,968] <dbg> wpa_supp: wpa_printf_impl: ssid - hexdump_ascii(len=14):
[00:00:01.473,999] <dbg> wpa_supp: _wpa_hexdump_ascii:
6b 69 6f 73 6b 5f 77 70 61 32 5f 65 6e 74 |kiosk_wp a2_ent
[00:00:01.474,273] <dbg> wpa_supp: wpa_printf_impl: Calling wpa_cli: set_network, argc: 4
[00:00:01.474,304] <dbg> wpa_supp: wpa_printf_impl: argv[0]: set_network
[00:00:01.474,365] <dbg> wpa_supp: wpa_printf_impl: argv[1]: 0
[00:00:01.474,395] <dbg> wpa_supp: wpa_printf_impl: argv[2]: scan_ssid
[00:00:01.474,456] <dbg> wpa_supp: wpa_printf_impl: argv[3]: 1
[00:00:01.474,822] <dbg> wpa_supp: wpa_printf_impl: wlan0: Control interface command 'SET_NETWORK [REMOVED]'
[00:00:01.474,975] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: SET_NETWORK id=0 name='scan_ssid'
[00:00:01.475,036] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: value - hexdump_ascii(len=1): [REMOVED]
[00:00:01.475,097] <dbg> wpa_supp: wpa_printf_impl: scan_ssid=1 (0x1)
[00:00:01.475,372] <dbg> wpa_supp: wpa_printf_impl: Calling wpa_cli: set_network, argc: 4
[00:00:01.475,402] <dbg> wpa_supp: wpa_printf_impl: argv[0]: set_network
[00:00:01.475,463] <dbg> wpa_supp: wpa_printf_impl: argv[1]: 0
[00:00:01.475,494] <dbg> wpa_supp: wpa_printf_impl: argv[2]: key_mgmt
[00:00:01.475,524] <dbg> wpa_supp: wpa_printf_impl: argv[3]: NONE
[00:00:01.475,921] <dbg> wpa_supp: wpa_printf_impl: wlan0: Control interface command 'SET_NETWORK [REMOVED]'
[00:00:01.476,043] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: SET_NETWORK id=0 name='key_mgmt'
[00:00:01.476,104] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: value - hexdump_ascii(len=4): [REMOVED]
[00:00:01.476,196] <dbg> wpa_supp: wpa_printf_impl: key_mgmt: 0x4
[00:00:01.476,501] <dbg> wpa_supp: wpa_printf_impl: Calling wpa_cli: set_network, argc: 4
[00:00:01.476,531] <dbg> wpa_supp: wpa_printf_impl: argv[0]: set_network
[00:00:01.476,593] <dbg> wpa_supp: wpa_printf_impl: argv[1]: 0
[00:00:01.476,623] <dbg> wpa_supp: wpa_printf_impl: argv[2]: ieee80211w
[00:00:01.476,654] <dbg> wpa_supp: wpa_printf_impl: argv[3]: 0
[00:00:01.477,050] <dbg> wpa_supp: wpa_printf_impl: wlan0: Control interface command 'SET_NETWORK [REMOVED]'
[00:00:01.477,172] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: SET_NETWORK id=0 name='ieee80211w'
[00:00:01.477,233] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: value - hexdump_ascii(len=1): [REMOVED]
[00:00:01.477,386] <dbg> wpa_supp: wpa_printf_impl: ieee80211w=0 (0x0)
[00:00:01.477,661] <dbg> wpa_supp: wpa_printf_impl: Calling wpa_cli: set_network, argc: 4
[00:00:01.477,722] <dbg> wpa_supp: wpa_printf_impl: argv[0]: set_network
[00:00:01.477,752] <dbg> wpa_supp: wpa_printf_impl: argv[1]: 0
[00:00:01.477,813] <dbg> wpa_supp: wpa_printf_impl: argv[2]: proto
[00:00:01.477,844] <dbg> wpa_supp: wpa_printf_impl: argv[3]: RSN
[00:00:01.478,210] <dbg> wpa_supp: wpa_printf_impl: wlan0: Control interface command 'SET_NETWORK [REMOVED]'
[00:00:01.478,363] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: SET_NETWORK id=0 name='proto'
[00:00:01.478,424] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: value - hexdump_ascii(len=3): [REMOVED]
[00:00:01.478,485] <dbg> wpa_supp: wpa_printf_impl: proto: 0x2
[00:00:01.478,790] <dbg> wpa_supp: wpa_printf_impl: Calling wpa_cli: set_network, argc: 4
[00:00:01.478,820] <dbg> wpa_supp: wpa_printf_impl: argv[0]: set_network
[00:00:01.478,881] <dbg> wpa_supp: wpa_printf_impl: argv[1]: 0
[00:00:01.478,912] <dbg> wpa_supp: wpa_printf_impl: argv[2]: key_mgmt
[00:00:01.478,973] <dbg> wpa_supp: wpa_printf_impl: argv[3]: WPA-EAP
[00:00:01.479,339] <dbg> wpa_supp: wpa_printf_impl: wlan0: Control interface command 'SET_NETWORK [REMOVED]'
[00:00:01.479,492] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: SET_NETWORK id=0 name='key_mgmt'
[00:00:01.479,553] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: value - hexdump_ascii(len=7): [REMOVED]
[00:00:01.479,644] <dbg> wpa_supp: wpa_printf_impl: key_mgmt: 0x1
[00:00:01.479,919] <dbg> wpa_supp: wpa_printf_impl: Calling wpa_cli: set, argc: 3
[00:00:01.479,949] <dbg> wpa_supp: wpa_printf_impl: argv[0]: set
[00:00:01.480,010] <dbg> wpa_supp: wpa_printf_impl: argv[1]: openssl_ciphers
[00:00:01.480,041] <dbg> wpa_supp: wpa_printf_impl: argv[2]: "DEFAULT:!EXP:!LOW"
[00:00:01.480,438] <dbg> wpa_supp: wpa_printf_impl: wlan0: Control interface command 'SET openssl_ciphers "DEFAULT:!EXP:!LOW"'
[00:00:01.480,529] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE SET 'openssl_ciphers'='"DEFAULT:!EXP:!LOW"'
[00:00:01.480,651] <dbg> wpa_supp: wpa_printf_impl: openssl_ciphers='"DEFAULT:!EXP:!LOW"'
[00:00:01.480,926] <dbg> wpa_supp: wpa_printf_impl: Calling wpa_cli: set_network, argc: 4
[00:00:01.480,987] <dbg> wpa_supp: wpa_printf_impl: argv[0]: set_network
[00:00:01.481,018] <dbg> wpa_supp: wpa_printf_impl: argv[1]: 0
[00:00:01.481,048] <dbg> wpa_supp: wpa_printf_impl: argv[2]: group
[00:00:01.481,109] <dbg> wpa_supp: wpa_printf_impl: argv[3]: CCMP
[00:00:01.481,475] <dbg> wpa_supp: wpa_printf_impl: wlan0: Control interface command 'SET_NETWORK [REMOVED]'
[00:00:01.481,628] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: SET_NETWORK id=0 name='group'
[00:00:01.481,689] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: value - hexdump_ascii(len=4): [REMOVED]
[00:00:01.481,781] <dbg> wpa_supp: wpa_printf_impl: group: 0x10
[00:00:01.482,055] <dbg> wpa_supp: wpa_printf_impl: Calling wpa_cli: set_network, argc: 4
[00:00:01.482,116] <dbg> wpa_supp: wpa_printf_impl: argv[0]: set_network
[00:00:01.482,147] <dbg> wpa_supp: wpa_printf_impl: argv[1]: 0
[00:00:01.482,177] <dbg> wpa_supp: wpa_printf_impl: argv[2]: pairwise
[00:00:01.482,238] <dbg> wpa_supp: wpa_printf_impl: argv[3]: CCMP
[00:00:01.482,604] <dbg> wpa_supp: wpa_printf_impl: wlan0: Control interface command 'SET_NETWORK [REMOVED]'
[00:00:01.482,757] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: SET_NETWORK id=0 name='pairwise'
[00:00:01.482,818] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: value - hexdump_ascii(len=4): [REMOVED]
[00:00:01.482,910] <dbg> wpa_supp: wpa_printf_impl: pairwise: 0x10
[00:00:01.483,184] <dbg> wpa_supp: wpa_printf_impl: Calling wpa_cli: set_network, argc: 4
[00:00:01.483,245] <dbg> wpa_supp: wpa_printf_impl: argv[0]: set_network
[00:00:01.483,276] <dbg> wpa_supp: wpa_printf_impl: argv[1]: 0
[00:00:01.483,306] <dbg> wpa_supp: wpa_printf_impl: argv[2]: group_mgmt
[00:00:01.483,367] <dbg> wpa_supp: wpa_printf_impl: argv[3]: AES-128-CMAC
[00:00:01.483,734] <dbg> wpa_supp: wpa_printf_impl: wlan0: Control interface command 'SET_NETWORK [REMOVED]'
[00:00:01.483,917] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: SET_NETWORK id=0 name='group_mgmt'
[00:00:01.483,978] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: value - hexdump_ascii(len=12): [REMOVED]
[00:00:01.484,069] <dbg> wpa_supp: wpa_printf_impl: group_mgmt: 0x20
[00:00:01.484,375] <dbg> wpa_supp: wpa_printf_impl: Calling wpa_cli: set_network, argc: 4
[00:00:01.484,405] <dbg> wpa_supp: wpa_printf_impl: argv[0]: set_network
[00:00:01.484,466] <dbg> wpa_supp: wpa_printf_impl: argv[1]: 0
[00:00:01.484,497] <dbg> wpa_supp: wpa_printf_impl: argv[2]: proto
[00:00:01.484,527] <dbg> wpa_supp: wpa_printf_impl: argv[3]: RSN
[00:00:01.484,924] <dbg> wpa_supp: wpa_printf_impl: wlan0: Control interface command 'SET_NETWORK [REMOVED]'
[00:00:01.485,076] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: SET_NETWORK id=0 name='proto'
[00:00:01.485,137] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: value - hexdump_ascii(len=3): [REMOVED]
[00:00:01.485,443] <dbg> wpa_supp: wpa_printf_impl: Calling wpa_cli: set_network, argc: 4
[00:00:01.485,504] <dbg> wpa_supp: wpa_printf_impl: argv[0]: set_network
[00:00:01.485,534] <dbg> wpa_supp: wpa_printf_impl: argv[1]: 0
[00:00:01.485,565] <dbg> wpa_supp: wpa_printf_impl: argv[2]: eap
[00:00:01.485,626] <dbg> wpa_supp: wpa_printf_impl: argv[3]: TLS
[00:00:01.486,022] <dbg> wpa_supp: wpa_printf_impl: wlan0: Control interface command 'SET_NETWORK [REMOVED]'
[00:00:01.486,145] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: SET_NETWORK id=0 name='eap'
[00:00:01.486,206] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: value - hexdump_ascii(len=3): [REMOVED]
[00:00:01.486,511] <dbg> wpa_supp: wpa_printf_impl: eap methods - hexdump(len=16): 00 00 00 00 0d 00 00 00 00 00 00 00 00 00 00 00
[00:00:01.486,846] <dbg> wpa_supp: wpa_printf_impl: Calling wpa_cli: set_network, argc: 4
[00:00:01.486,877] <dbg> wpa_supp: wpa_printf_impl: argv[0]: set_network
[00:00:01.486,938] <dbg> wpa_supp: wpa_printf_impl: argv[1]: 0
[00:00:01.486,968] <dbg> wpa_supp: wpa_printf_impl: argv[2]: identity
[00:00:01.486,999] <dbg> wpa_supp: wpa_printf_impl: argv[3]: "cc2-004a"
[00:00:01.487,396] <dbg> wpa_supp: wpa_printf_impl: wlan0: Control interface command 'SET_NETWORK [REMOVED]'
[00:00:01.487,548] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: SET_NETWORK id=0 name='identity'
[00:00:01.487,609] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: value - hexdump_ascii(len=10): [REMOVED]
[00:00:01.487,701] <dbg> wpa_supp: wpa_printf_impl: identity - hexdump_ascii(len=8):
[00:00:01.487,731] <dbg> wpa_supp: _wpa_hexdump_ascii:
63 63 32 2d 30 30 34 61 |cc2-004a
[00:00:01.488,037] <dbg> wpa_supp: wpa_printf_impl: Calling wpa_cli: set_network, argc: 4
[00:00:01.488,067] <dbg> wpa_supp: wpa_printf_impl: argv[0]: set_network
[00:00:01.488,128] <dbg> wpa_supp: wpa_printf_impl: argv[1]: 0
[00:00:01.488,159] <dbg> wpa_supp: wpa_printf_impl: argv[2]: password
[00:00:01.488,220] <dbg> wpa_supp: wpa_printf_impl: argv[3]: "infrafon-2022"
[00:00:01.488,616] <dbg> wpa_supp: wpa_printf_impl: wlan0: Control interface command 'SET_NETWORK [REMOVED]'
[00:00:01.488,739] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: SET_NETWORK id=0 name='password'
[00:00:01.488,800] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: value - hexdump_ascii(len=15): [REMOVED]
[00:00:01.488,922] <dbg> wpa_supp: wpa_printf_impl: password - hexdump_ascii(len=13): [REMOVED]
[00:00:01.489,227] <dbg> wpa_supp: wpa_printf_impl: Calling wpa_cli: set_network, argc: 4
[00:00:01.489,257] <dbg> wpa_supp: wpa_printf_impl: argv[0]: set_network
[00:00:01.489,318] <dbg> wpa_supp: wpa_printf_impl: argv[1]: 0
[00:00:01.489,349] <dbg> wpa_supp: wpa_printf_impl: argv[2]: anonymous_identity
[00:00:01.489,410] <dbg> wpa_supp: wpa_printf_impl: argv[3]: "(null)"
[00:00:01.489,776] <dbg> wpa_supp: wpa_printf_impl: wlan0: Control interface command 'SET_NETWORK [REMOVED]'
[00:00:01.489,929] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: SET_NETWORK id=0 name='anonymous_identity'
[00:00:01.489,990] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: value - hexdump_ascii(len=8): [REMOVED]
[00:00:01.490,081] <dbg> wpa_supp: wpa_printf_impl: anonymous_identity - hexdump_ascii(len=6):
[00:00:01.490,112] <dbg> wpa_supp: _wpa_hexdump_ascii:
28 6e 75 6c 6c 29 |(null)
[00:00:01.490,356] <inf> sta: Connection requested
[00:00:01.490,417] <inf> sta: ==================
[00:00:01.490,447] <inf> sta: State: DISCONNECTED
[00:00:01.568,054] <dbg> wpa_supp: wpa_printf_impl: EAPOL: disable timer tick
[00:00:01.790,557] <inf> sta: ==================
What else should my code do to get this to work?
Thanks!
    BrianW said:
    Great thanks! Indeed thats quite a different set of fields in the params structure from the code I had. I'll give that a go...
    Let me know how it goes!
    BrianW said:
    The difference is just in where the data (in PEM format) for the different fields comes from - in this case its statically defined in the code, yes? This net_mgmt call to set the certificates is supported in 2.9 as well?
    thanks
    Correct. With run time, the certificates are provided using Wi-Fi shell, while with compile time, the certificates are, as the name states, included in the build at compile time.
    In both cases, the credentials are provided using the same method, i.e., the parameters you shared and calling the net_mgmt() command. The implementation is slightly different in v3.0.0 since the certificates can also be provided at run time, but the way they are provided is the same.
    Marte
  • Great thanks! Indeed thats quite a different set of fields in the params structure from the code I had. I'll give that a go...
     I looked at the shell param setting code in detail, and noted that the
    params->key2_passwd = KEY2_PASSWD;
    params->key2_passwd_length = strlen(params->key2_passwd);
    if only if specifing 2 key passwords - if just one -K <password> then its key_passwd that is set
    and that:
    params->mfp = WIFI_MFP_REQUIRED; // 2
    params->suiteb_type = WIFI_SUITEB_192; // 2
    from -w 2 and -S 2 are for WPA3 (I'm trying to get WPA2 working first!)
    Also, WIFI_SECURITY_TYPE_EAP_TLS == WIFI_SECURITY_TYPE_EAP in wifi.h to same as I had.
    So finally the main difference is putting an anonymous identity rather than eap_identity.
    Alas, still doesn't work...
    The logs:
    [00:00:00.390,472] <inf> wifi_nrf_bus: SPIM spi@a000: freq = 24 MHz
    [00:00:00.390,502] <inf> wifi_nrf_bus: SPIM spi@a000: latency = 1
    *** Booting nRF Connect SDK v2.9.0-7787b2649840 ***
    *** Using Zephyr OS v3.7.99-1f8f3dc29142 ***
    [00:00:00.604,431] <inf> sta: Starting cc2v1 with CPU frequency: 64 MHz
    [00:00:00.604,614] <dbg> wpa_supp: wpa_printf_impl: wpa_supplicant v2.11-devel
    [00:00:00.604,827] <inf> wifi_supplicant: wpa_supplicant initialized
    [00:00:00.605,224] <dbg> wifi_supplicant: add_interface: Adding interface wlan0 [1] (0x200029b8)
    [00:00:00.605,316] <dbg> wpa_supp: wpa_printf_impl: Calling wpa_cli: interface_add, argc: 5
    [00:00:00.605,346] <dbg> wpa_supp: wpa_printf_impl: argv[0]: interface_add
    [00:00:00.605,407] <dbg> wpa_supp: wpa_printf_impl: argv[1]: wlan0
    [00:00:00.605,438] <dbg> wpa_supp: wpa_printf_impl: argv[2]: zephyr
    [00:00:00.605,499] <dbg> wpa_supp: wpa_printf_impl: argv[3]: zephyr
    [00:00:00.605,529] <dbg> wpa_supp: wpa_printf_impl: argv[4]: zephyr
    [00:00:00.605,926] <dbg> wpa_supp: wpa_printf_impl: RX global ctrl_iface - hexdump_ascii(len=71):
    [00:00:00.605,926] <dbg> wpa_supp: _wpa_hexdump_ascii:
    [00:00:00.605,987] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE GLOBAL INTERFACE_ADD 'wlan0      zephyr  zephyr  zephyr                           wlan0 zephyr zephyr zephyr'
    [00:00:00.606,140] <dbg> wpa_supp: wpa_printf_impl: Initializing interface 'wlan0' conf 'zephyr' driver 'zephyr' ctrl_interface 'zephyr' bridge 'N/A'
    [00:00:00.608,093] <dbg> wpa_supp: wpa_printf_impl: Add interface wlan0 to a new radio N/A
    [00:00:00.611,541] <dbg> wpa_supp: wpa_printf_impl: wpa_supp: Added 802.11b mode based on 802.11g information
    [00:00:00.611,724] <dbg> wpa_supp: wpa_printf_impl: l2_packet_init: iface wlan0 ifindex 1
    [00:00:00.611,877] <dbg> wpa_supp: wpa_printf_impl: wlan0: Own MAC address: f0:ce:37:00:00:4a
    [00:00:00.612,030] <dbg> wpa_supp: wpa_printf_impl: _wpa_drv_zep_set_key: priv:0x2000b450 alg 0 addr 0x0 key_idx 0 set_tx 0 seq 0x0 seq_len 0 key 0x0 key_len 0 key_flag 10
    [00:00:00.615,539] <dbg> wpa_supp: wpa_printf_impl: _wpa_drv_zep_set_key: priv:0x2000b450 alg 0 addr 0x0 key_idx 1 set_tx 0 seq 0x0 seq_len 0 key 0x0 key_len 0 key_flag 10
    [00:00:00.617,828] <dbg> wpa_supp: wpa_printf_impl: _wpa_drv_zep_set_key: priv:0x2000b450 alg 0 addr 0x0 key_idx 2 set_tx 0 seq 0x0 seq_len 0 key 0x0 key_len 0 key_flag 10
    [00:00:00.620,117] <dbg> wpa_supp: wpa_printf_impl: _wpa_drv_zep_set_key: priv:0x2000b450 alg 0 addr 0x0 key_idx 3 set_tx 0 seq 0x0 seq_len 0 key 0x0 key_len 0 key_flag 10
    [00:00:00.622,406] <dbg> wpa_supp: wpa_printf_impl: _wpa_drv_zep_set_key: priv:0x2000b450 alg 0 addr 0x0 key_idx 4 set_tx 0 seq 0x0 seq_len 0 key 0x0 key_len 0 key_flag 10
    [00:00:00.626,037] <dbg> wpa_supp: wpa_printf_impl: _wpa_drv_zep_set_key: priv:0x2000b450 alg 0 addr 0x0 key_idx 5 set_tx 0 seq 0x0 seq_len 0 key 0x0 key_len 0 key_flag 10
    [00:00:00.628,295] <dbg> wpa_supp: wpa_printf_impl: wlan0: RSN: flushing PMKID list in the driver
    [00:00:00.628,417] <dbg> wpa_supp: wpa_printf_impl: wlan0: State: DISCONNECTED -> INACTIVE
    [00:00:00.690,612] <dbg> wpa_supp: wpa_printf_impl: EAPOL: SUPP_PAE entering state DISCONNECTED
    [00:00:00.690,673] <dbg> wpa_supp: wpa_printf_impl: EAPOL: Supplicant port status: Unauthorized
    [00:00:00.700,714] <dbg> wpa_supp: wpa_printf_impl: EAPOL: KEY_RX entering state NO_KEY_RECEIVE
    [00:00:00.700,744] <dbg> wpa_supp: wpa_printf_impl: EAPOL: SUPP_BE entering state INITIALIZE
    [00:00:00.700,805] <dbg> wpa_supp: wpa_printf_impl: EAP: EAP entering state DISABLED
    [00:00:00.701,202] <dbg> wpa_supp: wpa_printf_impl: wlan0: Added interface wlan0
    [00:00:00.701,324] <dbg> wpa_supp: wpa_printf_impl: wlan0: State: INACTIVE -> DISCONNECTED
    [00:00:01.604,522] <inf> sta: Wi-Fi enterprise credentials loaded and configured : ca_cert len 1242, client cert len 1138, key len 1715
    [00:00:01.604,614] <dbg> wpa_supp: wpa_printf_impl: Calling wpa_cli: remove_network, argc: 2
    [00:00:01.604,644] <dbg> wpa_supp: wpa_printf_impl: argv[0]: remove_network
    [00:00:01.604,705] <dbg> wpa_supp: wpa_printf_impl: argv[1]: all
    [00:00:01.605,072] <dbg> wpa_supp: wpa_printf_impl: wlan0: Control interface command 'REMOVE_NETWORK all'
    [00:00:01.605,163] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: REMOVE_NETWORK all
    [00:00:01.605,651] <dbg> wpa_supp: wpa_printf_impl: wlan0: Control interface command 'ADD_NETWORK'
    [00:00:01.605,773] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: ADD_NETWORK
    [00:00:01.606,262] <dbg> wpa_supp: wpa_printf_impl: Received len: 26, msg_len:26 - CTRL-EVENT-NETWORK-ADDED 0->END
    [00:00:01.606,628] <dbg> wpa_supp: wpa_printf_impl: NET added: 0
    [00:00:01.606,719] <dbg> wpa_supp: wpa_printf_impl: Calling wpa_cli: set_network, argc: 4
    [00:00:01.606,781] <dbg> wpa_supp: wpa_printf_impl: argv[0]: set_network
    [00:00:01.606,811] <dbg> wpa_supp: wpa_printf_impl: argv[1]: 0
    [00:00:01.606,872] <dbg> wpa_supp: wpa_printf_impl: argv[2]: ssid
    [00:00:01.606,903] <dbg> wpa_supp: wpa_printf_impl: argv[3]: "kiosk_wpa2_ent"
    [00:00:01.607,299] <dbg> wpa_supp: wpa_printf_impl: wlan0: Control interface command 'SET_NETWORK [REMOVED]'
    [00:00:01.607,421] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: SET_NETWORK id=0 name='ssid'
    [00:00:01.607,482] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: value - hexdump_ascii(len=16): [REMOVED]
    [00:00:01.607,574] <dbg> wpa_supp: wpa_printf_impl: ssid - hexdump_ascii(len=14):
    [00:00:01.607,604] <dbg> wpa_supp: _wpa_hexdump_ascii:
    [00:00:01.607,879] <dbg> wpa_supp: wpa_printf_impl: Calling wpa_cli: set_network, argc: 4
    [00:00:01.607,940] <dbg> wpa_supp: wpa_printf_impl: argv[0]: set_network
    [00:00:01.607,971] <dbg> wpa_supp: wpa_printf_impl: argv[1]: 0
    [00:00:01.608,032] <dbg> wpa_supp: wpa_printf_impl: argv[2]: scan_ssid
    [00:00:01.608,062] <dbg> wpa_supp: wpa_printf_impl: argv[3]: 1
    [00:00:01.608,459] <dbg> wpa_supp: wpa_printf_impl: wlan0: Control interface command 'SET_NETWORK [REMOVED]'
    [00:00:01.608,581] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: SET_NETWORK id=0 name='scan_ssid'
    [00:00:01.608,642] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: value - hexdump_ascii(len=1): [REMOVED]
    [00:00:01.608,703] <dbg> wpa_supp: wpa_printf_impl: scan_ssid=1 (0x1)
    [00:00:01.608,978] <dbg> wpa_supp: wpa_printf_impl: Calling wpa_cli: set_network, argc: 4
    [00:00:01.609,039] <dbg> wpa_supp: wpa_printf_impl: argv[0]: set_network
    [00:00:01.609,069] <dbg> wpa_supp: wpa_printf_impl: argv[1]: 0
    [00:00:01.609,130] <dbg> wpa_supp: wpa_printf_impl: argv[2]: key_mgmt
    [00:00:01.609,161] <dbg> wpa_supp: wpa_printf_impl: argv[3]: NONE
    [00:00:01.609,558] <dbg> wpa_supp: wpa_printf_impl: wlan0: Control interface command 'SET_NETWORK [REMOVED]'
    [00:00:01.609,680] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: SET_NETWORK id=0 name='key_mgmt'
    [00:00:01.609,741] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: value - hexdump_ascii(len=4): [REMOVED]
    [00:00:01.609,832] <dbg> wpa_supp: wpa_printf_impl: key_mgmt: 0x4
    [00:00:01.610,137] <dbg> wpa_supp: wpa_printf_impl: Calling wpa_cli: set_network, argc: 4
    [00:00:01.610,168] <dbg> wpa_supp: wpa_printf_impl: argv[0]: set_network
    [00:00:01.610,229] <dbg> wpa_supp: wpa_printf_impl: argv[1]: 0
    [00:00:01.610,260] <dbg> wpa_supp: wpa_printf_impl: argv[2]: ieee80211w
    [00:00:01.610,321] <dbg> wpa_supp: wpa_printf_impl: argv[3]: 0
    [00:00:01.610,687] <dbg> wpa_supp: wpa_printf_impl: wlan0: Control interface command 'SET_NETWORK [REMOVED]'
    [00:00:01.610,839] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: SET_NETWORK id=0 name='ieee80211w'
    [00:00:01.610,900] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: value - hexdump_ascii(len=1): [REMOVED]
    [00:00:01.611,022] <dbg> wpa_supp: wpa_printf_impl: ieee80211w=0 (0x0)
    [00:00:01.611,328] <dbg> wpa_supp: wpa_printf_impl: Calling wpa_cli: set_network, argc: 4
    [00:00:01.611,358] <dbg> wpa_supp: wpa_printf_impl: argv[0]: set_network
    [00:00:01.611,419] <dbg> wpa_supp: wpa_printf_impl: argv[1]: 0
    [00:00:01.611,450] <dbg> wpa_supp: wpa_printf_impl: argv[2]: proto
    [00:00:01.611,511] <dbg> wpa_supp: wpa_printf_impl: argv[3]: RSN
    [00:00:01.611,877] <dbg> wpa_supp: wpa_printf_impl: wlan0: Control interface command 'SET_NETWORK [REMOVED]'
    [00:00:01.612,030] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: SET_NETWORK id=0 name='proto'
    [00:00:01.612,091] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: value - hexdump_ascii(len=3): [REMOVED]
    [00:00:01.612,152] <dbg> wpa_supp: wpa_printf_impl: proto: 0x2
    [00:00:01.612,457] <dbg> wpa_supp: wpa_printf_impl: Calling wpa_cli: set_network, argc: 4
    [00:00:01.612,487] <dbg> wpa_supp: wpa_printf_impl: argv[0]: set_network
    [00:00:01.612,548] <dbg> wpa_supp: wpa_printf_impl: argv[1]: 0
    [00:00:01.612,579] <dbg> wpa_supp: wpa_printf_impl: argv[2]: key_mgmt
    [00:00:01.612,640] <dbg> wpa_supp: wpa_printf_impl: argv[3]: WPA-EAP
    [00:00:01.613,006] <dbg> wpa_supp: wpa_printf_impl: wlan0: Control interface command 'SET_NETWORK [REMOVED]'
    [00:00:01.613,159] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: SET_NETWORK id=0 name='key_mgmt'
    [00:00:01.613,220] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: value - hexdump_ascii(len=7): [REMOVED]
    [00:00:01.613,311] <dbg> wpa_supp: wpa_printf_impl: key_mgmt: 0x1
    [00:00:01.613,586] <dbg> wpa_supp: wpa_printf_impl: Calling wpa_cli: set, argc: 3
    [00:00:01.613,647] <dbg> wpa_supp: wpa_printf_impl: argv[0]: set
    [00:00:01.613,677] <dbg> wpa_supp: wpa_printf_impl: argv[1]: openssl_ciphers
    [00:00:01.613,739] <dbg> wpa_supp: wpa_printf_impl: argv[2]: "DEFAULT:!EXP:!LOW"
    [00:00:01.614,135] <dbg> wpa_supp: wpa_printf_impl: wlan0: Control interface command 'SET openssl_ciphers "DEFAULT:!EXP:!LOW"'
    [00:00:01.614,227] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE SET 'openssl_ciphers'='"DEFAULT:!EXP:!LOW"'
    [00:00:01.614,349] <dbg> wpa_supp: wpa_printf_impl: openssl_ciphers='"DEFAULT:!EXP:!LOW"'
    [00:00:01.614,624] <dbg> wpa_supp: wpa_printf_impl: Calling wpa_cli: set_network, argc: 4
    [00:00:01.614,654] <dbg> wpa_supp: wpa_printf_impl: argv[0]: set_network
    [00:00:01.614,715] <dbg> wpa_supp: wpa_printf_impl: argv[1]: 0
    [00:00:01.614,746] <dbg> wpa_supp: wpa_printf_impl: argv[2]: group
    [00:00:01.614,807] <dbg> wpa_supp: wpa_printf_impl: argv[3]: CCMP
    [00:00:01.615,173] <dbg> wpa_supp: wpa_printf_impl: wlan0: Control interface command 'SET_NETWORK [REMOVED]'
    [00:00:01.615,295] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: SET_NETWORK id=0 name='group'
    [00:00:01.615,386] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: value - hexdump_ascii(len=4): [REMOVED]
    [00:00:01.615,478] <dbg> wpa_supp: wpa_printf_impl: group: 0x10
    [00:00:01.615,753] <dbg> wpa_supp: wpa_printf_impl: Calling wpa_cli: set_network, argc: 4
    [00:00:01.615,814] <dbg> wpa_supp: wpa_printf_impl: argv[0]: set_network
    [00:00:01.615,844] <dbg> wpa_supp: wpa_printf_impl: argv[1]: 0
    [00:00:01.615,875] <dbg> wpa_supp: wpa_printf_impl: argv[2]: pairwise
    [00:00:01.615,936] <dbg> wpa_supp: wpa_printf_impl: argv[3]: CCMP
    [00:00:01.616,302] <dbg> wpa_supp: wpa_printf_impl: wlan0: Control interface command 'SET_NETWORK [REMOVED]'
    [00:00:01.616,455] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: SET_NETWORK id=0 name='pairwise'
    [00:00:01.616,516] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: value - hexdump_ascii(len=4): [REMOVED]
    [00:00:01.616,607] <dbg> wpa_supp: wpa_printf_impl: pairwise: 0x10
    [00:00:01.616,912] <dbg> wpa_supp: wpa_printf_impl: Calling wpa_cli: set_network, argc: 4
    [00:00:01.616,943] <dbg> wpa_supp: wpa_printf_impl: argv[0]: set_network
    [00:00:01.616,973] <dbg> wpa_supp: wpa_printf_impl: argv[1]: 0
    [00:00:01.617,034] <dbg> wpa_supp: wpa_printf_impl: argv[2]: group_mgmt
    [00:00:01.617,065] <dbg> wpa_supp: wpa_printf_impl: argv[3]: AES-128-CMAC
    [00:00:01.617,492] <dbg> wpa_supp: wpa_printf_impl: wlan0: Control interface command 'SET_NETWORK [REMOVED]'
    [00:00:01.617,614] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: SET_NETWORK id=0 name='group_mgmt'
    [00:00:01.617,706] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: value - hexdump_ascii(len=12): [REMOVED]
    [00:00:01.617,797] <dbg> wpa_supp: wpa_printf_impl: group_mgmt: 0x20
    [00:00:01.618,103] <dbg> wpa_supp: wpa_printf_impl: Calling wpa_cli: set_network, argc: 4
    [00:00:01.618,133] <dbg> wpa_supp: wpa_printf_impl: argv[0]: set_network
    [00:00:01.618,194] <dbg> wpa_supp: wpa_printf_impl: argv[1]: 0
    [00:00:01.618,225] <dbg> wpa_supp: wpa_printf_impl: argv[2]: proto
    [00:00:01.618,255] <dbg> wpa_supp: wpa_printf_impl: argv[3]: RSN
    [00:00:01.618,652] <dbg> wpa_supp: wpa_printf_impl: wlan0: Control interface command 'SET_NETWORK [REMOVED]'
    [00:00:01.618,804] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: SET_NETWORK id=0 name='proto'
    [00:00:01.618,865] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: value - hexdump_ascii(len=3): [REMOVED]
    [00:00:01.619,171] <dbg> wpa_supp: wpa_printf_impl: Calling wpa_cli: set_network, argc: 4
    [00:00:01.619,232] <dbg> wpa_supp: wpa_printf_impl: argv[0]: set_network
    [00:00:01.619,262] <dbg> wpa_supp: wpa_printf_impl: argv[1]: 0
    [00:00:01.619,323] <dbg> wpa_supp: wpa_printf_impl: argv[2]: eap
    [00:00:01.619,354] <dbg> wpa_supp: wpa_printf_impl: argv[3]: TLS
    [00:00:01.619,750] <dbg> wpa_supp: wpa_printf_impl: wlan0: Control interface command 'SET_NETWORK [REMOVED]'
    [00:00:01.619,903] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: SET_NETWORK id=0 name='eap'
    [00:00:01.619,964] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: value - hexdump_ascii(len=3): [REMOVED]
    [00:00:01.620,269] <dbg> wpa_supp: wpa_printf_impl: eap methods - hexdump(len=16): 00 00 00 00 0d 00 00 00 00 00 00 00 00 00 00 00
    [00:00:01.620,605] <dbg> wpa_supp: wpa_printf_impl: Calling wpa_cli: set_network, argc: 4
    [00:00:01.620,635] <dbg> wpa_supp: wpa_printf_impl: argv[0]: set_network
    [00:00:01.620,697] <dbg> wpa_supp: wpa_printf_impl: argv[1]: 0
    [00:00:01.620,727] <dbg> wpa_supp: wpa_printf_impl: argv[2]: anonymous_identity
    [00:00:01.620,758] <dbg> wpa_supp: wpa_printf_impl: argv[3]: "anon"
    [00:00:01.621,154] <dbg> wpa_supp: wpa_printf_impl: wlan0: Control interface command 'SET_NETWORK [REMOVED]'
    [00:00:01.621,307] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: SET_NETWORK id=0 name='anonymous_identity'
    [00:00:01.621,368] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: value - hexdump_ascii(len=6): [REMOVED]
    [00:00:01.621,490] <dbg> wpa_supp: wpa_printf_impl: anonymous_identity - hexdump_ascii(len=4):
    [00:00:01.621,490] <dbg> wpa_supp: _wpa_hexdump_ascii:
                                       61 6e 6f 6e                                      |anon
    [00:00:01.621,887] <dbg> wpa_supp: wpa_printf_impl: Calling wpa_cli: set_network, argc: 4
    [00:00:01.621,917] <dbg> wpa_supp: wpa_printf_impl: argv[0]: set_network
    [00:00:01.621,978] <dbg> wpa_supp: wpa_printf_impl: argv[1]: 0
    [00:00:01.622,009] <dbg> wpa_supp: wpa_printf_impl: argv[2]: ca_cert
    [00:00:01.622,070] <dbg> wpa_supp: wpa_printf_impl: argv[3]: "blob://ca_cert"
    [00:00:01.622,467] <dbg> wpa_supp: wpa_printf_impl: wlan0: Control interface command 'SET_NETWORK [REMOVED]'
    [00:00:01.622,589] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: SET_NETWORK id=0 name='ca_cert'
    [00:00:01.622,650] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: value - hexdump_ascii(len=16): [REMOVED]
    [00:00:01.622,772] <dbg> wpa_supp: wpa_printf_impl: ca_cert - hexdump_ascii(len=14):
    [00:00:01.622,802] <dbg> wpa_supp: _wpa_hexdump_ascii:
                                       62 6c 6f 62 3a 2f 2f 63  61 5f 63 65 72 74       |blob://c a_cert
    [00:00:01.623,168] <dbg> wpa_supp: wpa_printf_impl: Calling wpa_cli: set_network, argc: 4
    [00:00:01.623,229] <dbg> wpa_supp: wpa_printf_impl: argv[0]: set_network
    [00:00:01.623,260] <dbg> wpa_supp: wpa_printf_impl: argv[1]: 0
    [00:00:01.623,321] <dbg> wpa_supp: wpa_printf_impl: argv[2]: client_cert
    [00:00:01.623,352] <dbg> wpa_supp: wpa_printf_impl: argv[3]: "blob://client_cert"
    [00:00:01.623,748] <dbg> wpa_supp: wpa_printf_impl: wlan0: Control interface command 'SET_NETWORK [REMOVED]'
    [00:00:01.623,901] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: SET_NETWORK id=0 name='client_cert'
    [00:00:01.623,962] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: value - hexdump_ascii(len=20): [REMOVED]
    [00:00:01.624,084] <dbg> wpa_supp: wpa_printf_impl: client_cert - hexdump_ascii(len=18):
    [00:00:01.624,084] <dbg> wpa_supp: _wpa_hexdump_ascii:
                                       62 6c 6f 62 3a 2f 2f 63  6c 69 65 6e 74 5f 63 65 |blob://c lient_ce
                                       72 74                                            |rt
    [00:00:01.624,511] <dbg> wpa_supp: wpa_printf_impl: Calling wpa_cli: set_network, argc: 4
    [00:00:01.624,542] <dbg> wpa_supp: wpa_printf_impl: argv[0]: set_network
    [00:00:01.624,603] <dbg> wpa_supp: wpa_printf_impl: argv[1]: 0
    [00:00:01.624,633] <dbg> wpa_supp: wpa_printf_impl: argv[2]: private_key
    [00:00:01.624,694] <dbg> wpa_supp: wpa_printf_impl: argv[3]: "blob://private_key"
    [00:00:01.625,091] <dbg> wpa_supp: wpa_printf_impl: wlan0: Control interface command 'SET_NETWORK [REMOVED]'
    [00:00:01.625,213] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: SET_NETWORK id=0 name='private_key'
    [00:00:01.625,274] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: value - hexdump_ascii(len=20): [REMOVED]
    [00:00:01.625,396] <dbg> wpa_supp: wpa_printf_impl: private_key - hexdump_ascii(len=18):
    [00:00:01.625,427] <dbg> wpa_supp: _wpa_hexdump_ascii:
                                       62 6c 6f 62 3a 2f 2f 70  72 69 76 61 74 65 5f 6b |blob://p rivate_k
                                       65 79                                            |ey
    [00:00:01.625,732] <dbg> wpa_supp: wpa_printf_impl: Calling wpa_cli: set_network, argc: 4
    [00:00:01.625,762] <dbg> wpa_supp: wpa_printf_impl: argv[0]: set_network
    [00:00:01.625,823] <dbg> wpa_supp: wpa_printf_impl: argv[1]: 0
    [00:00:01.625,854] <dbg> wpa_supp: wpa_printf_impl: argv[2]: private_key_passwd
    [00:00:01.625,915] <dbg> wpa_supp: wpa_printf_impl: argv[3]: "key_004a-2025"
    [00:00:01.626,312] <dbg> wpa_supp: wpa_printf_impl: wlan0: Control interface command 'SET_NETWORK [REMOVED]'
    [00:00:01.626,434] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: SET_NETWORK id=0 name='private_key_passwd'
    [00:00:01.626,525] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: value - hexdump_ascii(len=15): [REMOVED]
    [00:00:01.626,647] <dbg> wpa_supp: wpa_printf_impl: private_key_passwd - hexdump_ascii(len=13): [REMOVED]
    [00:00:01.626,892] <inf> sta: Connection requested
    [00:00:01.626,953] <inf> sta: ==================
    [00:00:01.626,983] <inf> sta: State: DISCONNECTED
    [00:00:01.701,080] <dbg> wpa_supp: wpa_printf_impl: EAPOL: disable timer tick
    [00:00:06.627,105] <inf> sta: ==================
    [00:00:06.627,136] <inf> sta: State: DISCONNECTED
    [00:00:11.627,258] <inf> sta: ==================
    What seems strange is that there are no errors, its as though it doesn't start the connection process after doing all the param config?
    I am also trying to build the wifi shell with WPA2 Enterprise on NCS 3.0.0 as per the link you suggested, but currently it won't build due to some issue with the DTS for my custom board when it gets to the link:
    c:/ncs/toolchains/0b393f9e1b/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd.exe: modules/nrf_wifi/bus/libnrf70-buslib.a(rpu_hw_if.c.obj): in function `rpu_init':
    C:/ncs/v3.0.0/zephyr/modules/nrf_wifi/bus/rpu_hw_if.c:452: undefined reference to `__device_dts_ord_14'
    c:/ncs/toolchains/0b393f9e1b/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd.exe: modules/nrf_wifi/bus/libnrf70-buslib.a(rpu_hw_if.c.obj):(.rodata.iovdd_ctrl_spec+0x0): undefined reference to `__device_dts_ord_14'
    collect2.exe: error: ld returned 1 exit status
    Its all a bit of a struggle...
    I will discuss the logs internally and get back to you.
    Regarding the build errors you see, we have a guide on debugging devicetree errors in our nRF Connect SDK Intermediate course on DevAcademy that is very useful. You can find it here: Troubleshooting the devicetree.
    Marte
  • Managed to build the wifi shellsample (my iovdd gpio was on a i2c ioexpander, so I needed to enable I2C in the prj.conf - got to love those easy to debug DTS issues...).
    Put my ca.pem, client.pem, client_key.pem into zephyr/samples/net/wifi/test_certs as indicated.
    Then, doing a WPA2-EAP-TLS connect:
    wifi connect -s kiosk_wpa2_ent -k 7 -a anon -K key_004a-2025
    gave me pretty much the same logs as my app for the wpa_supp configuration (although it also configured ca_cert2/client_cert2/private_key2/private_key2_passwd).
    However, then it actually went on to try to connect unlike my app code - WHY?
    [00:01:10.267,303] <dbg> wpa_supp: wpa_printf_impl: wlan0: Setting scan request: 0.000000 sec
    [00:01:10.276,367] <dbg> wpa_supp: wpa_printf_impl: wlan0: State: DISCONNECTED -> SCANNING
    [00:01:10.285,003] <dbg> wpa_supp: wpa_printf_impl: Scan SSID - hexdump_ascii(len=14):
    [00:01:10.293,273] <dbg> wpa_supp: _wpa_hexdump_ascii:
    [00:01:10.307,952] <dbg> wpa_supp: wpa_printf_impl: wlan0: Include wildcard SSID in the scan request
    [00:01:10.317,626] <dbg> wpa_supp: wpa_printf_impl: wlan0: Add radio work 'scan'@0x2005cd60
    [00:01:10.326,416] <dbg> wpa_supp: wpa_printf_impl: wlan0: First radio work item in the queue - schedule start immediately
    [00:01:10.338,012] <dbg> wpa_supp: wpa_printf_impl: wlan0: Starting radio work 'scan'@0x2005cd60 after 0.011566 second wait
    [00:01:10.350,067] <dbg> wpa_supp: wpa_printf_impl: Calling wpa_cli: select_network, argc: 2
    [00:01:10.358,245] <dbg> wpa_supp: wpa_printf_impl: wpa_drv_zep_scan2: Scan requested - scan timeout 35 seconds
    [00:01:10.372,558] <dbg> wifi_supplicant: event_socket_handler: Passing message 47 to wpa_supplicant
    [00:01:10.382,080] <dbg> wpa_supp: wpa_printf_impl: wlan0: Event SCAN_STARTED (47) received
    [00:01:10.390,899] <dbg> wpa_supp: wpa_printf_impl: wlan0: Own scan request started a scan in 0.018341 seconds
    [00:01:10.401,458] <dbg> wpa_supp: wpa_printf_impl: Received len: 24, msg_len:24 - CTRL-EVENT-SCAN-STARTED ->END
    [00:01:10.412,109] <dbg> wpa_supp: wpa_printf_impl: argv[0]: select_network
    [00:01:10.419,433] <dbg> wpa_supp: wpa_printf_impl: argv[1]: 0
    [00:01:10.425,994] <dbg> wpa_supp: wpa_printf_impl: wlan0: Control interface command 'SELECT_NETWORK 0'
    [00:01:10.435,760] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: SELECT_NETWORK id=0
    Connect fails after a while, seems to be an mbedtls issue in the pk_parse_key part.. .
    [00:01:17.554,260] <dbg> wpa_supp: wpa_printf_impl: EAP: Status notification: accept proposed method (param=TLS)
    [00:01:17.567,077] <dbg> wpa_supp: wpa_printf_impl: EAP: Initialize selected EAP method: vendor 0 method 13 (TLS)
    [00:01:17.579,864] <dbg> wpa_supp: wpa_printf_impl: TLS: using phase1 config options
    [00:01:17.590,972] <err> wpa_supp: MTLS: invalid tls_disable_tlsv* params; ignoring
    [00:01:17.609,710] <err> wpa_supp: MTLS: mbedtls_pk_parse_key: (-0x3d00)
    [00:01:17.619,232] <inf> wpa_supp: TLS: Failed to set TLS connection parameters
    [00:01:17.629,425] <inf> wpa_supp: EAP-TLS: Failed to initialize SSL.
    [00:01:17.638,458] <inf> wpa_supp: wlan0: EAP: Failed to initialize EAP method: vendor 0 method 13 (TLS)
    [00:01:17.650,543] <dbg> wpa_supp: wpa_printf_impl: EAP: Building EAP-Nak (requested type 13 vendor=0 method=0 not allowed)
    Error code 0x3d00 is apparently:
    0x3D00 PK - Invalid key tag or value
    What could this be objecting to?
    Full logs:
    wifi scan
    Scan requested
    Num  | SSID                             (len) | Chan (Band)   | RSSI | Security        | BSSID             | MFP
    1    | kiosk                            5     | 104  (5GHz  ) | -52  | WPA2-PSK        | 8C:FD:DE:9E:68:76 | Disable
    2    | Livebox-6870                     12    | 104  (5GHz  ) | -52  | WPA2-PSK        | 8C:FD:DE:9E:68:75 | Disable
    3    | kiosk_wpa2_ent                   14    | 36   (5GHz  ) | -58  | EAP-TLS         | B8:37:B2:09:1C:11 | Disable
    4    | kiosk_wpa3_ent                   14    | 36   (5GHz  ) | -59  | EAP-TLS         | B8:37:B2:09:1C:12 | Optional
    5    | kiosk_wpa3_per                   14    | 36   (5GHz  ) | -59  | WPA3-SAE-HNP    | B8:37:B2:09:1C:10 | Optional
    6    | kiosk                            5     | 6    (2.4GHz) | -63  | WPA2-PSK        | 8C:FD:DE:9E:68:71 | Disable
    7    | Livebox-6870                     12    | 6    (2.4GHz) | -63  | WPA2-PSK        | 8C:FD:DE:9E:68:70 | Disable
    8    | Livebox-0490                     12    | 11   (2.4GHz) | -68  | WPA2-PSK        | 58:2F:F7:C7:9B:B8 | Optional
    9    | kiosk_wpa3_per                   14    | 1    (2.4GHz) | -69  | WPA3-SAE-HNP    | B8:37:B2:09:1C:00 | Optional
    10   | Livebox-0490                     12    | 100  (5GHz  ) | -70  | WPA2-PSK        | 58:2F:F7:C7:9B:B0 | Optional
    11   | kiosk_wpa2_ent                   14    | 1    (2.4GHz) | -71  | EAP-TLS         | B8:37:B2:09:1C:01 | Disable
    12   | Livebox-6E70                     12    | 112  (5GHz  ) | -73  | WPA2-PSK        | D4:F8:29:54:6E:75 | Disable
    13   | kiosk_wpa3_ent                   14    | 1    (2.4GHz) | -73  | EAP-TLS         | B8:37:B2:09:1C:02 | Optional
    14   | Livebox-7551                     12    | 52   (5GHz  ) | -74  | WPA-PSK         | 08:87:C6:04:75:52 | Disable
    15   | Livebox-7551                     12    | 6    (2.4GHz) | -76  | WPA-PSK         | 08:87:C6:04:75:51 | Disable
    16   | Livebox-96be                     12    | 132  (5GHz  ) | -79  | WPA-PSK         | 68:3F:7D:12:96:C3 | Disable
    17   | WIFIBRG001241c95e3fIPC117        25    | 11   (2.4GHz) | -86  | WPA2-PSK        | DE:29:19:DC:F9:72 | Disable
    18   | Livebox-96be                     12    | 11   (2.4GHz) | -89  | WPA-PSK         | 68:3F:7D:12:96:C2 | Disable
    Scan request done
    uart:~$ wifi connect -s kiosk_wpa2_ent -k 7 -a anon -K key_004a-2025
    [00:01:08.400,115] <dbg> wpa_supp: wpa_printf_impl: Calling wpa_cli: remove_network, argc: 2
    [00:01:08.408,935] <dbg> wpa_supp: wpa_printf_impl: argv[0]: remove_network
    [00:01:08.416,290] <dbg> wpa_supp: wpa_printf_impl: argv[1]: all
    [00:01:08.423,034] <dbg> wpa_supp: wpa_printf_impl: wlan0: Control interface command 'REMOVE_NETWORK all'
    [00:01:08.432,983] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: REMOVE_NETWORK all
    [00:01:08.441,284] <dbg> wpa_supp: wpa_printf_impl: wlan0: Control interface command 'ADD_NETWORK'
    [00:01:08.450,622] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: ADD_NETWORK
    [00:01:08.458,251] <dbg> wpa_supp: wpa_printf_impl: Received len: 26, msg_len:26 - CTRL-EVENT-NETWORK-ADDED 0->END
    [00:01:08.469,116] <dbg> wpa_supp: wpa_printf_impl: NET added: 0
    [00:01:08.475,524] <dbg> wpa_supp: wpa_printf_impl: Calling wpa_cli: set_network, argc: 4
    [00:01:08.484,069] <dbg> wpa_supp: wpa_printf_impl: argv[0]: set_network
    [00:01:08.491,149] <dbg> wpa_supp: wpa_printf_impl: argv[1]: 0
    [00:01:08.497,406] <dbg> wpa_supp: wpa_printf_impl: argv[2]: ssid
    [00:01:08.503,906] <dbg> wpa_supp: wpa_printf_impl: argv[3]: "kiosk_wpa2_ent"
    [00:01:08.511,779] <dbg> wpa_supp: wpa_printf_impl: wlan0: Control interface command 'SET_NETWORK [REMOVED]'
    [00:01:08.522,003] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: SET_NETWORK id=0 name='ssid'
    [00:01:08.530,792] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: value - hexdump_ascii(len=16): [REMOVED]
    [00:01:08.540,679] <dbg> wpa_supp: wpa_printf_impl: ssid - hexdump_ascii(len=14):
    [00:01:08.548,522] <dbg> wpa_supp: _wpa_hexdump_ascii:
    [00:01:08.563,293] <dbg> wpa_supp: wpa_printf_impl: Calling wpa_cli: set_network, argc: 4
    [00:01:08.571,838] <dbg> wpa_supp: wpa_printf_impl: argv[0]: set_network
    [00:01:08.578,948] <dbg> wpa_supp: wpa_printf_impl: argv[1]: 0
    [00:01:08.585,174] <dbg> wpa_supp: wpa_printf_impl: argv[2]: scan_ssid
    [00:01:08.592,102] <dbg> wpa_supp: wpa_printf_impl: argv[3]: 1
    [00:01:08.598,663] <dbg> wpa_supp: wpa_printf_impl: wlan0: Control interface command 'SET_NETWORK [REMOVED]'
    [00:01:08.608,886] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: SET_NETWORK id=0 name='scan_ssid'
    [00:01:08.618,133] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: value - hexdump_ascii(len=1): [REMOVED]
    [00:01:08.627,899] <dbg> wpa_supp: wpa_printf_impl: scan_ssid=1 (0x1)
    [00:01:08.634,887] <dbg> wpa_supp: wpa_printf_impl: Calling wpa_cli: set_network, argc: 4
    [00:01:08.643,432] <dbg> wpa_supp: wpa_printf_impl: argv[0]: set_network
    [00:01:08.650,512] <dbg> wpa_supp: wpa_printf_impl: argv[1]: 0
    [00:01:08.656,738] <dbg> wpa_supp: wpa_printf_impl: argv[2]: key_mgmt
    [00:01:08.663,574] <dbg> wpa_supp: wpa_printf_impl: argv[3]: NONE
    [00:01:08.670,410] <dbg> wpa_supp: wpa_printf_impl: wlan0: Control interface command 'SET_NETWORK [REMOVED]'
    [00:01:08.680,633] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: SET_NETWORK id=0 name='key_mgmt'
    [00:01:08.689,788] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: value - hexdump_ascii(len=4): [REMOVED]
    [00:01:08.699,584] <dbg> wpa_supp: wpa_printf_impl: key_mgmt: 0x4
    [00:01:08.706,176] <dbg> wpa_supp: wpa_printf_impl: Calling wpa_cli: set_network, argc: 4
    [00:01:08.714,721] <dbg> wpa_supp: wpa_printf_impl: argv[0]: set_network
    [00:01:08.721,801] <dbg> wpa_supp: wpa_printf_impl: argv[1]: 0
    [00:01:08.728,057] <dbg> wpa_supp: wpa_printf_impl: argv[2]: ieee80211w
    [00:01:08.735,046] <dbg> wpa_supp: wpa_printf_impl: argv[3]: 0
    [00:01:08.741,638] <dbg> wpa_supp: wpa_printf_impl: wlan0: Control interface command 'SET_NETWORK [REMOVED]'
    [00:01:08.751,861] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: SET_NETWORK id=0 name='ieee80211w'
    [00:01:08.761,169] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: value - hexdump_ascii(len=1): [REMOVED]
    [00:01:08.770,965] <dbg> wpa_supp: wpa_printf_impl: ieee80211w=0 (0x0)
    [00:01:08.778,015] <dbg> wpa_supp: wpa_printf_impl: Calling wpa_cli: set_network, argc: 4
    [00:01:08.786,529] <dbg> wpa_supp: wpa_printf_impl: argv[0]: set_network
    [00:01:08.793,640] <dbg> wpa_supp: wpa_printf_impl: argv[1]: 0
    [00:01:08.799,865] <dbg> wpa_supp: wpa_printf_impl: argv[2]: proto
    [00:01:08.806,427] <dbg> wpa_supp: wpa_printf_impl: argv[3]: RSN
    [00:01:08.813,171] <dbg> wpa_supp: wpa_printf_impl: wlan0: Control interface command 'SET_NETWORK [REMOVED]'
    [00:01:08.823,394] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: SET_NETWORK id=0 name='proto'
    [00:01:08.832,305] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: value - hexdump_ascii(len=3): [REMOVED]
    [00:01:08.842,071] <dbg> wpa_supp: wpa_printf_impl: proto: 0x2
    [00:01:08.848,449] <dbg> wpa_supp: wpa_printf_impl: Calling wpa_cli: set_network, argc: 4
    [00:01:08.856,964] <dbg> wpa_supp: wpa_printf_impl: argv[0]: set_network
    [00:01:08.864,074] <dbg> wpa_supp: wpa_printf_impl: argv[1]: 0
    [00:01:08.870,300] <dbg> wpa_supp: wpa_printf_impl: argv[2]: key_mgmt
    [00:01:08.877,136] <dbg> wpa_supp: wpa_printf_impl: argv[3]: WPA-EAP
    [00:01:08.884,246] <dbg> wpa_supp: wpa_printf_impl: wlan0: Control interface command 'SET_NETWORK [REMOVED]'
    [00:01:08.894,470] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: SET_NETWORK id=0 name='key_mgmt'
    [00:01:08.903,625] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: value - hexdump_ascii(len=7): [REMOVED]
    [00:01:08.913,421] <dbg> wpa_supp: wpa_printf_impl: key_mgmt: 0x1
    [00:01:08.920,043] <dbg> wpa_supp: wpa_printf_impl: Calling wpa_cli: set, argc: 3
    [00:01:08.927,856] <dbg> wpa_supp: wpa_printf_impl: argv[0]: set
    [00:01:08.934,295] <dbg> wpa_supp: wpa_printf_impl: argv[1]: openssl_ciphers
    [00:01:08.941,741] <dbg> wpa_supp: wpa_printf_impl: argv[2]: "DEFAULT:!EXP:!LOW"
    [00:01:08.949,890] <dbg> wpa_supp: wpa_printf_impl: wlan0: Control interface command 'SET openssl_ciphers "DEFAULT:!EXP:!LOW"'
    [00:01:08.961,639] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE SET 'openssl_ciphers'='"DEFAULT:!EXP:!LOW"'
    [00:01:08.971,710] <dbg> wpa_supp: wpa_printf_impl: openssl_ciphers='"DEFAULT:!EXP:!LOW"'
    [00:01:08.980,377] <dbg> wpa_supp: wpa_printf_impl: Calling wpa_cli: set_network, argc: 4
    [00:01:08.988,891] <dbg> wpa_supp: wpa_printf_impl: argv[0]: set_network
    [00:01:08.996,002] <dbg> wpa_supp: wpa_printf_impl: argv[1]: 0
    [00:01:09.002,227] <dbg> wpa_supp: wpa_printf_impl: argv[2]: group
    [00:01:09.008,819] <dbg> wpa_supp: wpa_printf_impl: argv[3]: CCMP
    [00:01:09.015,625] <dbg> wpa_supp: wpa_printf_impl: wlan0: Control interface command 'SET_NETWORK [REMOVED]'
    [00:01:09.025,848] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: SET_NETWORK id=0 name='group'
    [00:01:09.034,729] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: value - hexdump_ascii(len=4): [REMOVED]
    [00:01:09.044,525] <dbg> wpa_supp: wpa_printf_impl: group: 0x10
    [00:01:09.050,994] <dbg> wpa_supp: wpa_printf_impl: Calling wpa_cli: set_network, argc: 4
    [00:01:09.059,509] <dbg> wpa_supp: wpa_printf_impl: argv[0]: set_network
    [00:01:09.066,619] <dbg> wpa_supp: wpa_printf_impl: argv[1]: 0
    [00:01:09.072,845] <dbg> wpa_supp: wpa_printf_impl: argv[2]: pairwise
    [00:01:09.079,681] <dbg> wpa_supp: wpa_printf_impl: argv[3]: CCMP
    [00:01:09.086,517] <dbg> wpa_supp: wpa_printf_impl: wlan0: Control interface command 'SET_NETWORK [REMOVED]'
    [00:01:09.096,740] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: SET_NETWORK id=0 name='pairwise'
    [00:01:09.105,895] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: value - hexdump_ascii(len=4): [REMOVED]
    [00:01:09.115,692] <dbg> wpa_supp: wpa_printf_impl: pairwise: 0x10
    [00:01:09.122,406] <dbg> wpa_supp: wpa_printf_impl: Calling wpa_cli: set_network, argc: 4
    [00:01:09.130,920] <dbg> wpa_supp: wpa_printf_impl: argv[0]: set_network
    [00:01:09.138,031] <dbg> wpa_supp: wpa_printf_impl: argv[1]: 0
    [00:01:09.144,256] <dbg> wpa_supp: wpa_printf_impl: argv[2]: group_mgmt
    [00:01:09.151,275] <dbg> wpa_supp: wpa_printf_impl: argv[3]: AES-128-CMAC
    [00:01:09.158,813] <dbg> wpa_supp: wpa_printf_impl: wlan0: Control interface command 'SET_NETWORK [REMOVED]'
    [00:01:09.169,036] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: SET_NETWORK id=0 name='group_mgmt'
    [00:01:09.178,344] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: value - hexdump_ascii(len=12): [REMOVED]
    [00:01:09.188,232] <dbg> wpa_supp: wpa_printf_impl: group_mgmt: 0x20
    [00:01:09.195,098] <dbg> wpa_supp: wpa_printf_impl: Calling wpa_cli: set_network, argc: 4
    [00:01:09.203,643] <dbg> wpa_supp: wpa_printf_impl: argv[0]: set_network
    [00:01:09.210,754] <dbg> wpa_supp: wpa_printf_impl: argv[1]: 0
    [00:01:09.216,979] <dbg> wpa_supp: wpa_printf_impl: argv[2]: proto
    [00:01:09.223,571] <dbg> wpa_supp: wpa_printf_impl: argv[3]: RSN
    [00:01:09.230,316] <dbg> wpa_supp: wpa_printf_impl: wlan0: Control interface command 'SET_NETWORK [REMOVED]'
    [00:01:09.240,539] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: SET_NETWORK id=0 name='proto'
    [00:01:09.249,420] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: value - hexdump_ascii(len=3): [REMOVED]
    [00:01:09.259,368] <dbg> wpa_supp: wpa_printf_impl: Calling wpa_cli: set_network, argc: 4
    [00:01:09.267,883] <dbg> wpa_supp: wpa_printf_impl: argv[0]: set_network
    [00:01:09.274,993] <dbg> wpa_supp: wpa_printf_impl: argv[1]: 0
    [00:01:09.281,219] <dbg> wpa_supp: wpa_printf_impl: argv[2]: eap
    [00:01:09.287,628] <dbg> wpa_supp: wpa_printf_impl: argv[3]: TLS
    [00:01:09.294,372] <dbg> wpa_supp: wpa_printf_impl: wlan0: Control interface command 'SET_NETWORK [REMOVED]'
    [00:01:09.304,595] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: SET_NETWORK id=0 name='eap'
    [00:01:09.313,323] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: value - hexdump_ascii(len=3): [REMOVED]
    [00:01:09.323,272] <dbg> wpa_supp: wpa_printf_impl: eap methods - hexdump(len=16): 00 00 00 00 0d 00 00 00 00 00 00 00 00 00 00 00
    [00:01:09.335,510] <dbg> wpa_supp: wpa_printf_impl: Calling wpa_cli: set_network, argc: 4
    [00:01:09.344,055] <dbg> wpa_supp: wpa_printf_impl: argv[0]: set_network
    [00:01:09.351,135] <dbg> wpa_supp: wpa_printf_impl: argv[1]: 0
    [00:01:09.357,391] <dbg> wpa_supp: wpa_printf_impl: argv[2]: anonymous_identity
    [00:01:09.365,081] <dbg> wpa_supp: wpa_printf_impl: argv[3]: "anon"
    [00:01:09.372,100] <dbg> wpa_supp: wpa_printf_impl: wlan0: Control interface command 'SET_NETWORK [REMOVED]'
    [00:01:09.382,324] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: SET_NETWORK id=0 name='anonymous_identity'
    [00:01:09.392,364] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: value - hexdump_ascii(len=6): [REMOVED]
    [00:01:09.402,160] <dbg> wpa_supp: wpa_printf_impl: anonymous_identity - hexdump_ascii(len=4):
    [00:01:09.411,132] <dbg> wpa_supp: _wpa_hexdump_ascii:
                                       61 6e 6f 6e                                      |anon
    [00:01:09.426,086] <dbg> wpa_supp: wpa_printf_impl: Calling wpa_cli: set_network, argc: 4
    [00:01:09.434,631] <dbg> wpa_supp: wpa_printf_impl: argv[0]: set_network
    [00:01:09.441,741] <dbg> wpa_supp: wpa_printf_impl: argv[1]: 0
    [00:01:09.447,967] <dbg> wpa_supp: wpa_printf_impl: argv[2]: ca_cert
    [00:01:09.454,742] <dbg> wpa_supp: wpa_printf_impl: argv[3]: "blob://ca_cert"
    [00:01:09.462,585] <dbg> wpa_supp: wpa_printf_impl: wlan0: Control interface command 'SET_NETWORK [REMOVED]'
    [00:01:09.472,839] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: SET_NETWORK id=0 name='ca_cert'
    [00:01:09.481,903] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: value - hexdump_ascii(len=16): [REMOVED]
    [00:01:09.491,790] <dbg> wpa_supp: wpa_printf_impl: ca_cert - hexdump_ascii(len=14):
    [00:01:09.499,877] <dbg> wpa_supp: _wpa_hexdump_ascii:
    [00:01:09.514,831] <dbg> wpa_supp: wpa_printf_impl: Calling wpa_cli: set_network, argc: 4
    [00:01:09.523,376] <dbg> wpa_supp: wpa_printf_impl: argv[0]: set_network
    [00:01:09.530,487] <dbg> wpa_supp: wpa_printf_impl: argv[1]: 0
    [00:01:09.536,712] <dbg> wpa_supp: wpa_printf_impl: argv[2]: client_cert
    [00:01:09.543,823] <dbg> wpa_supp: wpa_printf_impl: argv[3]: "blob://client_cert"
    [00:01:09.552,062] <dbg> wpa_supp: wpa_printf_impl: wlan0: Control interface command 'SET_NETWORK [REMOVED]'
    [00:01:09.562,286] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: SET_NETWORK id=0 name='client_cert'
    [00:01:09.571,716] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: value - hexdump_ascii(len=20): [REMOVED]
    [00:01:09.581,604] <dbg> wpa_supp: wpa_printf_impl: client_cert - hexdump_ascii(len=18):
    [00:01:09.590,057] <dbg> wpa_supp: _wpa_hexdump_ascii:
                                       72 74                                            |rt
    [00:01:09.613,861] <dbg> wpa_supp: wpa_printf_impl: Calling wpa_cli: set_network, argc: 4
    [00:01:09.622,375] <dbg> wpa_supp: wpa_printf_impl: argv[0]: set_network
    [00:01:09.629,486] <dbg> wpa_supp: wpa_printf_impl: argv[1]: 0
    [00:01:09.635,711] <dbg> wpa_supp: wpa_printf_impl: argv[2]: private_key
    [00:01:09.642,822] <dbg> wpa_supp: wpa_printf_impl: argv[3]: "blob://private_key"
    [00:01:09.651,031] <dbg> wpa_supp: wpa_printf_impl: wlan0: Control interface command 'SET_NETWORK [REMOVED]'
    [00:01:09.661,254] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: SET_NETWORK id=0 name='private_key'
    [00:01:09.670,684] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: value - hexdump_ascii(len=20): [REMOVED]
    [00:01:09.680,572] <dbg> wpa_supp: wpa_printf_impl: private_key - hexdump_ascii(len=18):
    [00:01:09.688,995] <dbg> wpa_supp: _wpa_hexdump_ascii:
                                       65 79                                            |ey
    [00:01:09.712,799] <dbg> wpa_supp: wpa_printf_impl: Calling wpa_cli: set_network, argc: 4
    [00:01:09.721,313] <dbg> wpa_supp: wpa_printf_impl: argv[0]: set_network
    [00:01:09.728,424] <dbg> wpa_supp: wpa_printf_impl: argv[1]: 0
    [00:01:09.734,649] <dbg> wpa_supp: wpa_printf_impl: argv[2]: private_key_passwd
    [00:01:09.742,370] <dbg> wpa_supp: wpa_printf_impl: argv[3]: "key_004a-2025"
    [00:01:09.750,152] <dbg> wpa_supp: wpa_printf_impl: wlan0: Control interface command 'SET_NETWORK [REMOVED]'
    [00:01:09.760,375] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: SET_NETWORK id=0 name='private_key_passwd'
    [00:01:09.770,416] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: value - hexdump_ascii(len=15): [REMOVED]
    [00:01:09.780,303] <dbg> wpa_supp: wpa_printf_impl: private_key_passwd - hexdump_ascii(len=13): [REMOVED]
    [00:01:09.790,374] <dbg> wpa_supp: wpa_printf_impl: Calling wpa_cli: set_network, argc: 4
    [00:01:09.798,919] <dbg> wpa_supp: wpa_printf_impl: argv[0]: set_network
    [00:01:09.806,030] <dbg> wpa_supp: wpa_printf_impl: argv[1]: 0
    [00:01:09.812,255] <dbg> wpa_supp: wpa_printf_impl: argv[2]: ca_cert2
    [00:01:09.819,091] <dbg> wpa_supp: wpa_printf_impl: argv[3]: "blob://ca_cert2"
    [00:01:09.827,056] <dbg> wpa_supp: wpa_printf_impl: wlan0: Control interface command 'SET_NETWORK [REMOVED]'
    [00:01:09.837,280] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: SET_NETWORK id=0 name='ca_cert2'
    [00:01:09.846,435] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: value - hexdump_ascii(len=17): [REMOVED]
    [00:01:09.856,323] <dbg> wpa_supp: wpa_printf_impl: ca_cert2 - hexdump_ascii(len=15):
    [00:01:09.864,501] <dbg> wpa_supp: _wpa_hexdump_ascii:
                                       62 6c 6f 62 3a 2f 2f 63  61 5f 63 65 72 74 32    |blob://c a_cert2
    [00:01:09.879,302] <dbg> wpa_supp: wpa_printf_impl: Calling wpa_cli: set_network, argc: 4
    [00:01:09.887,847] <dbg> wpa_supp: wpa_printf_impl: argv[0]: set_network
    [00:01:09.894,927] <dbg> wpa_supp: wpa_printf_impl: argv[1]: 0
    [00:01:09.901,153] <dbg> wpa_supp: wpa_printf_impl: argv[2]: client_cert2
    [00:01:09.908,355] <dbg> wpa_supp: wpa_printf_impl: argv[3]: "blob://client_cert2"
    [00:01:09.916,656] <dbg> wpa_supp: wpa_printf_impl: wlan0: Control interface command 'SET_NETWORK [REMOVED]'
    [00:01:09.926,879] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: SET_NETWORK id=0 name='client_cert2'
    [00:01:09.936,401] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: value - hexdump_ascii(len=21): [REMOVED]
    [00:01:09.946,289] <dbg> wpa_supp: wpa_printf_impl: client_cert2 - hexdump_ascii(len=19):
    [00:01:09.954,803] <dbg> wpa_supp: _wpa_hexdump_ascii:
                                       72 74 32                                         |rt2
    [00:01:09.978,607] <dbg> wpa_supp: wpa_printf_impl: Calling wpa_cli: set_network, argc: 4
    [00:01:09.987,152] <dbg> wpa_supp: wpa_printf_impl: argv[0]: set_network
    [00:01:09.994,232] <dbg> wpa_supp: wpa_printf_impl: argv[1]: 0
    [00:01:10.000,488] <dbg> wpa_supp: wpa_printf_impl: argv[2]: private_key2
    [00:01:10.007,659] <dbg> wpa_supp: wpa_printf_impl: argv[3]: "blob://private_key2"
    [00:01:10.015,960] <dbg> wpa_supp: wpa_printf_impl: wlan0: Control interface command 'SET_NETWORK [REMOVED]'
    [00:01:10.026,184] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: SET_NETWORK id=0 name='private_key2'
    [00:01:10.035,705] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: value - hexdump_ascii(len=21): [REMOVED]
    [00:01:10.045,593] <dbg> wpa_supp: wpa_printf_impl: private_key2 - hexdump_ascii(len=19):
    [00:01:10.054,107] <dbg> wpa_supp: _wpa_hexdump_ascii:
                                       65 79 32                                         |ey2
    [00:01:10.077,880] <dbg> wpa_supp: wpa_printf_impl: Calling wpa_cli: set_network, argc: 4
    [00:01:10.086,425] <dbg> wpa_supp: wpa_printf_impl: argv[0]: set_network
    [00:01:10.093,505] <dbg> wpa_supp: wpa_printf_impl: argv[1]: 0
    [00:01:10.099,761] <dbg> wpa_supp: wpa_printf_impl: argv[2]: private_key2_passwd
    [00:01:10.107,543] <dbg> wpa_supp: wpa_printf_impl: argv[3]: "(null)"
    [00:01:10.114,715] <dbg> wpa_supp: wpa_printf_impl: wlan0: Control interface command 'SET_NETWORK [REMOVED]'
    [00:01:10.124,938] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: SET_NETWORK id=0 name='private_key2_passwd'
    [00:01:10.135,040] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: value - hexdump_ascii(len=8): [REMOVED]
    [00:01:10.144,866] <dbg> wpa_supp: wpa_printf_impl: private_key2_passwd - hexdump_ascii(len=6): [REMOVED]
    [00:01:10.154,937] <dbg> wpa_supp: wpa_printf_impl: Calling wpa_cli: set_network, argc: 4
    [00:01:10.163,452] <dbg> wpa_supp: wpa_printf_impl: argv[0]: set_network
    [00:01:10.170,562] <dbg> wpa_supp: wpa_printf_impl: argv[1]: 0
    [00:01:10.176,788] <dbg> wpa_supp: wpa_printf_impl: argv[2]: ieee80211w
    [00:01:10.183,807] <dbg> wpa_supp: wpa_printf_impl: argv[3]: 1
    [00:01:10.190,368] <dbg> wpa_supp: wpa_printf_impl: wlan0: Control interface command 'SET_NETWORK [REMOVED]'
    [00:01:10.200,592] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: SET_NETWORK id=0 name='ieee80211w'
    [00:01:10.209,899] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: value - hexdump_ascii(len=1): [REMOVED]
    [00:01:10.219,726] <dbg> wpa_supp: wpa_printf_impl: ieee80211w=1 (0x1)
    [00:01:10.226,745] <dbg> wpa_supp: wpa_printf_impl: Calling wpa_cli: enable_network, argc: 2
    [00:01:10.235,534] <dbg> wpa_supp: wpa_printf_impl: argv[0]: enable_network
    [00:01:10.242,889] <dbg> wpa_supp: wpa_printf_impl: argv[1]: 0
    [00:01:10.249,450] <dbg> wpa_supp: wpa_printf_impl: wlan0: Control interface command 'ENABLE_NETWORK 0'
    [00:01:10.259,246] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: ENABLE_NETWORK id=0
    [00:01:10.443,847] <dbg> wpa_supp: wpa_printf_impl: wlan0: Setting scan request: 0.000000 sec
    [00:01:10.452,911] <dbg> wpa_supp: wpa_printf_impl: wlan0: Already scanning - Reschedule the incoming scan req
    [00:01:10.463,348] <dbg> wpa_supp: wpa_printf_impl: wlan0: Setting scan request: 1.000000 sec
    [00:01:11.472,412] <dbg> wpa_supp: wpa_printf_impl: wlan0: Already scanning - Reschedule the incoming scan req
    [00:01:11.485,015] <dbg> wpa_supp: wpa_printf_impl: wlan0: Setting scan request: 1.000000 sec
    [00:01:12.496,276] <dbg> wpa_supp: wpa_printf_impl: wlan0: Already scanning - Reschedule the incoming scan req
    [00:01:12.508,880] <dbg> wpa_supp: wpa_printf_impl: wlan0: Setting scan request: 1.000000 sec
    [00:01:13.520,141] <dbg> wpa_supp: wpa_printf_impl: wlan0: Already scanning - Reschedule the incoming scan req
    [00:01:13.532,745] <dbg> wpa_supp: wpa_printf_impl: wlan0: Setting scan request: 1.000000 sec
    [00:01:14.544,006] <dbg> wpa_supp: wpa_printf_impl: wlan0: Already scanning - Reschedule the incoming scan req
    [00:01:14.556,610] <dbg> wpa_supp: wpa_printf_impl: wlan0: Setting scan request: 1.000000 sec
    [00:01:14.813,446] <dbg> wifi_supplicant: event_socket_handler: Passing message 3 to wpa_supplicant
    [00:01:14.825,042] <dbg> wpa_supp: wpa_printf_impl: wlan0: Event SCAN_RESULTS (3) received
    [00:01:14.835,906] <dbg> wpa_supp: wpa_printf_impl: wlan0: Scan completed in 4.445007 seconds
    [00:01:14.850,830] <dbg> wpa_supp: wpa_printf_impl: Sorted scan results
    [00:01:14.860,076] <dbg> wpa_supp: wpa_printf_impl: b8:37:b2:09:1c:11 ssid=kiosk_wpa2_ent freq=5180 qual=0 noise=-92~ level=-58 snr=34* flags=0xb age=3613 est=336376
    [00:01:14.879,119] <dbg> wpa_supp: wpa_printf_impl: IEs - hexdump(len=251): 00 0e 6b 69 6f 73 6b 5f 77 70 61 32 5f 65 6e 74 01 08 8c 12 98 24 b0 48 60 6c 03 01 24 07 0c 46 52 20 24 08 17 64 0b 1e 95 05 0e 20 01 00 23 02 12 00 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00 00 0f ac 01 28 00 0b 05 00 00 0a
    [00:01:14.908,843] <dbg> wpa_supp: wpa_printf_impl: b8:37:b2:09:1c:01 ssid=kiosk_wpa2_ent freq=2412 qual=0 noise=-89~ level=-72 snr=17 flags=0xb age=4480 est=47666
    [00:01:14.927,551] <dbg> wpa_supp: wpa_printf_impl: IEs - hexdump(len=228): 00 0e 6b 69 6f 73 6b 5f 77 70 61 32 5f 65 6e 74 01 08 82 84 0b 16 24 30 48 6c 03 01 01 2a 01 00 32 04 0c 12 18 60 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00 00 0f ac 01 28 00 0b 05 00 00 26 6c 6b 2d 1a ad 09 17 ff ff 00 00 00
    [00:01:14.957,244] <dbg> wpa_supp: wpa_printf_impl: wlan0: BSS: Start scan result update 1
    [00:01:14.968,261] <dbg> wpa_supp: wpa_printf_impl: wlan0: BSS: Add new id 0 BSSID b8:37:b2:09:1c:11 SSID 'kiosk_wpa2_ent' freq 5180
    [00:01:14.983,062] <dbg> wpa_supp: wpa_printf_impl: wlan0: BSS: Add new id 1 BSSID b8:37:b2:09:1c:01 SSID 'kiosk_wpa2_ent' freq 2412
    [00:01:14.997,619] <dbg> wpa_supp: wpa_printf_impl: BSS: last_scan_res_used=2/32
    [00:01:15.007,598] <dbg> wpa_supp: wpa_printf_impl: wlan0: New scan results available (own=1 ext=0)
    [00:01:15.019,378] <dbg> wpa_supp: wpa_printf_impl: wlan0: Radio work 'scan'@0x2005cd60 done in 4.681366 seconds
    [00:01:15.032,165] <dbg> wpa_supp: wpa_printf_impl: wlan0: radio_work_free('scan'@0x2005cd60): num_active_works --> 0
    [00:01:15.045,379] <dbg> wpa_supp: wpa_printf_impl: wlan0: Scan results matching the currently selected network
    [00:01:15.058,135] <dbg> wpa_supp: wpa_printf_impl: IEEE 802.11 element parse ignored unknown element (id=7 elen=12)
    [00:01:15.071,197] <dbg> wpa_supp: wpa_printf_impl: IEEE 802.11 element parse ignored unknown element (id=32 elen=1)
    [00:01:15.084,289] <dbg> wpa_supp: wpa_printf_impl: IEEE 802.11 element parse ignored unknown element (id=35 elen=2)
    [00:01:15.097,381] <dbg> wpa_supp: wpa_printf_impl: IEEE 802.11 element parse ignored unknown element (id=11 elen=5)
    [00:01:15.110,443] <dbg> wpa_supp: wpa_printf_impl: IEEE 802.11 element parse ignored unknown element (id=195 elen=4)
    [00:01:15.123,626] <dbg> wpa_supp: wpa_printf_impl: IEEE 802.11 element parsing ignored unknown element extension (ext_id=38 elen=13)
    [00:01:15.138,153] <dbg> wpa_supp: wpa_printf_impl: wlan0: MLD: No Multi-Link element
    [00:01:15.148,681] <dbg> wpa_supp: wpa_printf_impl: wlan0: 0: b8:37:b2:09:1c:11 freq=5180 level=-58 snr=34 est_throughput=336376
    [00:01:15.162,902] <dbg> wpa_supp: wpa_printf_impl: IEEE 802.11 element parse ignored unknown element (id=11 elen=5)
    [00:01:15.175,994] <dbg> wpa_supp: wpa_printf_impl: IEEE 802.11 element parse ignored unknown element (id=74 elen=14)
    [00:01:15.189,147] <dbg> wpa_supp: wpa_printf_impl: IEEE 802.11 element parsing ignored unknown element extension (ext_id=38 elen=13)
    [00:01:15.203,704] <dbg> wpa_supp: wpa_printf_impl: wlan0: MLD: No Multi-Link element
    [00:01:15.214,233] <dbg> wpa_supp: wpa_printf_impl: wlan0: 1: b8:37:b2:09:1c:01 freq=2412 level=-72 snr=17 est_throughput=47666
    [00:01:15.228,302] <dbg> wpa_supp: wpa_printf_impl: wlan0: Selecting BSS from priority group 0
    [00:01:15.239,654] <dbg> wpa_supp: wpa_printf_impl: wlan0: 0: b8:37:b2:09:1c:11 ssid='kiosk_wpa2_ent' wpa_ie_len=0 rsn_ie_len=20 caps=0x111 level=-58 freq=5180
    [00:01:15.256,622] <dbg> wpa_supp: wpa_printf_impl: wlan0:    selected based on RSN IE
    [00:01:15.267,150] <dbg> wpa_supp: wpa_printf_impl: IEEE 802.11 element parse ignored unknown element (id=7 elen=12)
    [00:01:15.280,212] <dbg> wpa_supp: wpa_printf_impl: IEEE 802.11 element parse ignored unknown element (id=32 elen=1)
    [00:01:15.293,304] <dbg> wpa_supp: wpa_printf_impl: IEEE 802.11 element parse ignored unknown element (id=35 elen=2)
    [00:01:15.306,365] <dbg> wpa_supp: wpa_printf_impl: IEEE 802.11 element parse ignored unknown element (id=11 elen=5)
    [00:01:15.319,427] <dbg> wpa_supp: wpa_printf_impl: IEEE 802.11 element parse ignored unknown element (id=195 elen=4)
    [00:01:15.332,611] <dbg> wpa_supp: wpa_printf_impl: IEEE 802.11 element parsing ignored unknown element extension (ext_id=38 elen=13)
    [00:01:15.347,167] <dbg> wpa_supp: wpa_printf_impl: wlan0: MLD: No Multi-Link element
    [00:01:15.357,635] <dbg> wpa_supp: wpa_printf_impl: wlan0:    selected BSS b8:37:b2:09:1c:11 ssid='kiosk_wpa2_ent'
    [00:01:15.370,849] <dbg> wpa_supp: wpa_printf_impl: wlan0: Considering connect request: reassociate: 1  selected: b8:37:b2:09:1c:11  bssid: 00:00:00:00:00:00  pending: 00:00:00:00:00:00  wpa_state: SCANNING  ssid=0x2005bdf0  current_ssid=0x2005bdf0
    [00:01:15.395,416] <dbg> wpa_supp: wpa_printf_impl: wlan0: Request association with b8:37:b2:09:1c:11
    [00:01:15.407,257] <dbg> wpa_supp: wpa_printf_impl: wlan0: No ongoing scan/p2p-scan found to abort
    [00:01:15.418,823] <dbg> wpa_supp: wpa_printf_impl: wlan0: Add radio work 'sme-connect'@0x2005cd00
    [00:01:15.430,389] <dbg> wpa_supp: wpa_printf_impl: wlan0: First radio work item in the queue - schedule start immediately
    [00:01:15.444,030] <dbg> wpa_supp: wpa_printf_impl: RSN: Ignored PMKID candidate without preauth flag
    [00:01:15.455,780] <dbg> wpa_supp: wpa_printf_impl: RSN: Ignored PMKID candidate without preauth flag
    [00:01:15.467,742] <dbg> wpa_supp: wpa_printf_impl: wlan0: Starting radio work 'sme-connect'@0x2005cd00 after 0.037323 second wait
    [00:01:15.482,086] <dbg> wpa_supp: wpa_printf_impl: wlan0: WPA: clearing own WPA/RSN IE
    [00:01:15.492,645] <dbg> wpa_supp: wpa_printf_impl: wlan0: RSN: clearing own RSNXE
    [00:01:15.502,807] <dbg> wpa_supp: wpa_printf_impl: wlan0: Automatic auth_alg selection: 0x1
    [00:01:15.513,854] <dbg> wpa_supp: wpa_printf_impl: RSN: PMKSA cache search - network_ctx=0x2005bdf0 try_opportunistic=0 akmp=0x0
    [00:01:15.528,045] <dbg> wpa_supp: wpa_printf_impl: RSN: Search for BSSID b8:37:b2:09:1c:11
    [00:01:15.538,909] <dbg> wpa_supp: wpa_printf_impl: RSN: No PMKSA cache entry found
    [00:01:15.549,194] <dbg> wpa_supp: wpa_printf_impl: wlan0: RSN: using IEEE 802.11i/D9.0
    [00:01:15.559,844] <dbg> wpa_supp: wpa_printf_impl: wlan0: WPA: Selected cipher suites: group 16 pairwise 16 key_mgmt 1 proto 2
    [00:01:15.573,913] <dbg> wpa_supp: wpa_printf_impl: wlan0: WPA: Selected mgmt group cipher 32
    [00:01:15.585,052] <dbg> wpa_supp: wpa_printf_impl: wlan0: WPA: clearing AP WPA IE
    [00:01:15.595,336] <dbg> wpa_supp: wpa_printf_impl: WPA: set AP RSN IE - hexdump(len=22): 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00 00 0f ac 01 28 00
    [00:01:15.611,816] <dbg> wpa_supp: wpa_printf_impl: wlan0: WPA: clearing AP RSNXE
    [00:01:15.621,887] <dbg> wpa_supp: wpa_printf_impl: wlan0: RSN: Clearing AP RSNE Override element
    [00:01:15.633,331] <dbg> wpa_supp: wpa_printf_impl: wlan0: RSN: Clearing AP RSNE Override 2 element
    [00:01:15.644,989] <dbg> wpa_supp: wpa_printf_impl: wlan0: RSN: Clearing AP RSNXE Override element
    [00:01:15.656,585] <dbg> wpa_supp: wpa_printf_impl: wlan0: WPA: AP group 0x10 network profile group 0x10; available group 0x10
    [00:01:15.670,532] <dbg> wpa_supp: wpa_printf_impl: wlan0: WPA: using GTK CCMP
    [00:01:15.680,389] <dbg> wpa_supp: wpa_printf_impl: wlan0: WPA: AP pairwise 0x10 network profile pairwise 0x10; available pairwise 0x10
    [00:01:15.695,129] <dbg> wpa_supp: wpa_printf_impl: wlan0: WPA: using PTK CCMP
    [00:01:15.704,986] <dbg> wpa_supp: wpa_printf_impl: wlan0: WPA: AP key_mgmt 0x1 network profile key_mgmt 0x1; available key_mgmt 0x1
    [00:01:15.719,482] <dbg> wpa_supp: wpa_printf_impl: wlan0: WPA: using KEY_MGMT 802.1X
    [00:01:15.729,980] <dbg> wpa_supp: wpa_printf_impl: wlan0: WPA: AP mgmt_group_cipher 0x20 network profile mgmt_group_cipher 0x20; available mgmt_group_cipher 0x0
    [00:01:15.746,978] <dbg> wpa_supp: wpa_printf_impl: wlan0: WPA: not using MGMT group cipher
    [00:01:15.758,056] <dbg> wpa_supp: wpa_printf_impl: WPA: Set own WPA IE default - hexdump(len=22): 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00 00 0f ac 01 8c 00
    [00:01:15.775,299] <dbg> wpa_supp: wpa_printf_impl: RSN: Set own RSNXE default - hexdump(len=0):0â–’PuTTY â–’â–’PuTTY
    [00:01:15.787,414] <dbg> wpa_supp: wpa_printf_impl: WPA: No current PMKSA - clear PMK
    [00:01:15.797,821] <dbg> wpa_supp: wpa_printf_impl: RRM: Determining whether RRM can be used - device support: 0x50
    [00:01:15.810,791] <dbg> wpa_supp: wpa_printf_impl: RRM: No RRM in network
    [00:01:15.820,281] <dbg> wpa_supp: wpa_printf_impl: EAPOL: External notification - EAP success=0
    [00:01:15.831,604] <dbg> wpa_supp: wpa_printf_impl: EAPOL: External notification - EAP fail=0
    [00:01:15.842,681] <dbg> wpa_supp: wpa_printf_impl: EAPOL: External notification - portControl=Auto
    [00:01:15.854,339] <dbg> wpa_supp: wpa_printf_impl: wlan0: Cancelling scan request
    [00:01:15.864,593] <inf> wpa_supp: wlan0: SME: Trying to authenticate with b8:37:b2:09:1c:11 (SSID='kiosk_wpa2_ent' freq=5180 MHz)
    [00:01:15.878,906] <dbg> wpa_supp: wpa_printf_impl: EAPOL: External notification - portValid=0
    [00:01:15.890,106] <dbg> wpa_supp: wpa_printf_impl: wlan0: State: SCANNING -> AUTHENTICATING
    [00:01:15.911,804] <dbg> wpa_supp: wpa_printf_impl: Received len: 40, msg_len:40 - CTRL-EVENT-BSS-ADDED 0 b8:37:b2:09:1c:11->END
    [00:01:15.926,025] <dbg> wpa_supp: wpa_printf_impl: Received len: 40, msg_len:40 - CTRL-EVENT-BSS-ADDED 1 b8:37:b2:09:1c:01->END
    [00:01:15.940,216] <dbg> wpa_supp: wpa_printf_impl: Received len: 24, msg_len:24 - CTRL-EVENT-SCAN-RESULTS ->END
    [00:01:15.953,063] <dbg> wpa_supp: wpa_printf_impl: Received len: 88, msg_len:88 - SME: Trying to authenticate with b8:37:b2:09:1c:11 (SSID='kiosk_wpa2_ent' freq=5180 MHz)->END
    [00:01:16.266,174] <dbg> wifi_supplicant: event_socket_handler: Passing message 10 to wpa_supplicant
    [00:01:16.277,862] <dbg> wpa_supp: wpa_printf_impl: wlan0: Event AUTH (10) received
    [00:01:16.288,208] <dbg> wpa_supp: wpa_printf_impl: wlan0: SME: Authentication response: peer=b8:37:b2:09:1c:11 auth_type=0 auth_transaction=2 status_code=0
    [00:01:16.304,748] <dbg> wpa_supp: wpa_printf_impl: SME: Authentication response IEs - hexdump(len=0): [NULL]
    [00:01:16.317,413] <dbg> wpa_supp: wpa_printf_impl: SME: Association Request IEs - hexdump(len=22): 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00 00 0f ac 01 8c 00
    [00:01:16.334,869] <inf> wpa_supp: wlan0: Trying to associate with b8:37:b2:09:1c:11 (SSID='kiosk_wpa2_ent' freq=5180 MHz)
    [00:01:16.348,510] <dbg> wpa_supp: wpa_printf_impl: wlan0: State: AUTHENTICATING -> ASSOCIATING
    [00:01:16.359,954] <dbg> wpa_supp: wpa_printf_impl: WPA: set own WPA/RSN IE - hexdump(len=22): 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00 00 0f ac 01 8c 00
    [00:01:16.376,861] <dbg> wpa_supp: wpa_printf_impl: wlan0: RSN: clearing own RSNXE
    [00:01:16.392,242] <dbg> wpa_supp: wpa_printf_impl: Received len: 80, msg_len:80 - Trying to associate with b8:37:b2:09:1c:11 (SSID='kiosk_wpa2_ent' freq=5180 MHz)->END
    [00:01:16.412,109] <dbg> wifi_supplicant: event_socket_handler: Passing message 0 to wpa_supplicant
    [00:01:16.426,300] <dbg> wpa_supp: wpa_printf_impl: wlan0: Event ASSOC (0) received
    [00:01:16.436,553] <dbg> wpa_supp: wpa_printf_impl: wlan0: Association info event
    [00:01:16.448,089] <dbg> wpa_supp: wpa_printf_impl: req_ies - hexdump(len=215): 00 0e 6b 69 6f 73 6b 5f 77 70 61 32 5f 65 6e 74 01 08 0c 12 18 24 30 48 60 6c 21 02 00 17 5a 03 24 01 00 24 38 24 01 28 01 2c 01 30 01 34 01 38 01 3c 01 40 01 64 01 68 01 6c 01 70 01 74 01 78 01 7c 01 80 01 84 01 88 01 8c 01 90
    [00:01:16.478,942] <dbg> wpa_supp: wpa_printf_impl: resp_ies - hexdump(len=176): 01 08 8c 12 98 24 b0 48 60 6c 2d 1a ef 09 17 ff 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 3d 16 24 05 16 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 7f 0a 04 00 08 00 00 00 00 40 00 40 bf 0
    [00:01:16.508,636] <dbg> wpa_supp: wpa_printf_impl: IEEE 802.11 element parsing ignored unknown element extension (ext_id=38 elen=13)
    [00:01:16.523,223] <dbg> wpa_supp: wpa_printf_impl: IEEE 802.11 element parsing ignored unknown element extension (ext_id=38 elen=13)
    [00:01:16.537,780] <dbg> wpa_supp: wpa_printf_impl: wlan0: freq=5180 MHz
    [00:01:16.547,302] <dbg> wpa_supp: wpa_printf_impl: WPA: set own WPA/RSN IE - hexdump(len=22): 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00 00 0f ac 01 8c 00
    [00:01:16.564,208] <dbg> wpa_supp: wpa_printf_impl: wlan0: RSN: clearing own RSNXE
    [00:01:16.574,371] <dbg> wpa_supp: wpa_printf_impl: wlan0: State: ASSOCIATING -> ASSOCIATED
    [00:01:16.585,357] <dbg> wpa_supp: wpa_printf_impl: wlan0: Associated to a new BSS: BSSID=b8:37:b2:09:1c:11
    [00:01:16.597,656] <dbg> wpa_supp: wpa_printf_impl: wpa_drv_zep_get_ssid: SSID size: 14
    [00:01:16.608,215] <dbg> wpa_supp: wpa_printf_impl: wpa_drv_zep_get_ssid: SSID size: 14
    [00:01:16.618,835] <inf> wpa_supp: wlan0: Associated with b8:37:b2:09:1c:11
    [00:01:16.628,417] <dbg> wpa_supp: wpa_printf_impl: wlan0: WPA: Association event - clear replay counter
    [00:01:16.640,472] <dbg> wpa_supp: wpa_printf_impl: wlan0: WPA: Clear old PTK
    [00:01:16.650,726] <dbg> wpa_supp: wpa_printf_impl: EAPOL: External notification - portEnabled=0
    [00:01:16.662,048] <dbg> wpa_supp: wpa_printf_impl: EAPOL: External notification - portValid=0
    [00:01:16.673,217] <dbg> wpa_supp: wpa_printf_impl: EAPOL: External notification - portEnabled=1
    [00:01:16.684,539] <dbg> wpa_supp: wpa_printf_impl: EAPOL: SUPP_PAE entering state CONNECTING
    [00:01:16.695,617] <dbg> wpa_supp: wpa_printf_impl: EAPOL: enable timer tick
    [00:01:16.705,261] <dbg> wpa_supp: wpa_printf_impl: EAPOL: SUPP_BE entering state IDLE
    [00:01:16.715,728] <dbg> wpa_supp: wpa_printf_impl: EAP: EAP entering state INITIALIZE
    [00:01:16.726,196] <dbg> wpa_supp: wpa_printf_impl: EAP: EAP entering state IDLE
    [00:01:16.736,236] <dbg> wpa_supp: wpa_printf_impl: wlan0: Setting authentication timeout: 10 sec 0 usec
    [00:01:16.748,291] <dbg> wpa_supp: wpa_printf_impl: wlan0: Cancelling scan request
    [00:01:16.758,453] <inf> wpa_supp: wlan0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
    [00:01:16.768,798] <dbg> wpa_supp: wpa_printf_impl: wlan0: RX EAPOL from b8:37:b2:09:1c:11
    [00:01:16.779,693] <dbg> wpa_supp: wpa_printf_impl: RX EAPOL - hexdump(len=9): 01 00 00 05 01 01 00 05 01
    [00:01:16.791,839] <dbg> wpa_supp: wpa_printf_impl: wlan0: Setting authentication timeout: 70 sec 0 usec
    [00:01:16.803,894] <dbg> wpa_supp: wpa_printf_impl: EAPOL: Received EAP-Packet frame
    [00:01:16.814,178] <dbg> wpa_supp: wpa_printf_impl: EAPOL: SUPP_PAE entering state RESTART
    [00:01:16.825,012] <dbg> wpa_supp: wpa_printf_impl: EAP: EAP entering state INITIALIZE
    [00:01:16.835,479] <dbg> wpa_supp: wpa_printf_impl: EAP: EAP entering state IDLE
    [00:01:16.845,458] <dbg> wpa_supp: wpa_printf_impl: EAPOL: SUPP_PAE entering state AUTHENTICATING
    [00:01:16.856,872] <dbg> wpa_supp: wpa_printf_impl: EAPOL: SUPP_BE entering state REQUEST
    [00:01:16.867,584] <dbg> wpa_supp: wpa_printf_impl: EAPOL: getSuppRsp
    [00:01:16.876,617] <dbg> wpa_supp: wpa_printf_impl: EAP: EAP entering state RECEIVED
    [00:01:16.887,084] <dbg> wpa_supp: wpa_printf_impl: EAP: Received EAP-Request id=1 method=1 vendor=0 vendorMethod=0
    [00:01:16.900,024] <dbg> wpa_supp: wpa_printf_impl: EAP: EAP entering state IDENTITY
    [00:01:16.910,400] <inf> wpa_supp: wlan0: CTRL-EVENT-EAP-STARTED EAP authentication started
    [00:01:16.921,325] <dbg> wpa_supp: wpa_printf_impl: EAP: Status notification: started (param=)
    [00:01:16.932,556] <dbg> wpa_supp: wpa_printf_impl: EAP: EAP-Request Identity data - hexdump_ascii(len=0):
    [00:01:16.944,732] <dbg> wpa_supp: _wpa_hexdump_ascii:
    [00:01:16.952,545] <dbg> wpa_supp: wpa_printf_impl: EAP: using anonymous identity - hexdump_ascii(len=4):
    [00:01:16.964,660] <dbg> wpa_supp: _wpa_hexdump_ascii:
                                       61 6e 6f 6e                                      |anon
    [00:01:16.981,475] <dbg> wpa_supp: wpa_printf_impl: EAP: EAP entering state SEND_RESPONSE
    [00:01:16.992,218] <dbg> wpa_supp: wpa_printf_impl: EAP: EAP entering state IDLE
    [00:01:17.002,166] <dbg> wpa_supp: wpa_printf_impl: EAPOL: SUPP_BE entering state RESPONSE
    [00:01:17.013,000] <dbg> wpa_supp: wpa_printf_impl: EAPOL: txSuppRsp
    [00:01:17.021,942] <dbg> wpa_supp: wpa_printf_impl: TX EAPOL: dst=b8:37:b2:09:1c:11
    [00:01:17.032,226] <dbg> wpa_supp: wpa_printf_impl: TX EAPOL - hexdump(len=13): 01 00 00 09 02 01 00 09 01 61 6e 6f 6e
    [00:01:17.045,776] <dbg> wpa_supp: wpa_printf_impl: EAPOL: SUPP_BE entering state RECEIVE
    [00:01:17.057,006] <dbg> wpa_supp: wpa_printf_impl: Received len: 33, msg_len:33 - Associated with b8:37:b2:09:1c:11->END
    [00:01:17.071,014] <dbg> wpa_supp: wpa_printf_impl: Received len: 40, msg_len:40 - CTRL-EVENT-SUBNET-STATUS-UPDATE status=0->END
    [00:01:17.085,144] <dbg> wpa_supp: wpa_printf_impl: Event not supported: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
    [00:01:17.097,991] <dbg> wpa_supp: wpa_printf_impl: Received len: 49, msg_len:49 - CTRL-EVENT-EAP-STARTED EAP authentication started->END
    [00:01:17.112,915] <dbg> wpa_supp: wpa_printf_impl: Event not supported: CTRL-EVENT-EAP-STARTED EAP authentication started
    [00:01:17.126,556] <dbg> wpa_supp: wpa_printf_impl: Received len: 51, msg_len:51 - CTRL-EVENT-EAP-STATUS status='started' parameter=''->END
    [00:01:17.141,662] <dbg> wpa_supp: wpa_printf_impl: Event not supported: CTRL-EVENT-EAP-STATUS status='started' parameter=''
    [00:01:17.157,348] <dbg> wpa_supp: wpa_printf_impl: wlan0: RX EAPOL from b8:37:b2:09:1c:11
    [00:01:17.168,243] <dbg> wpa_supp: wpa_printf_impl: RX EAPOL - hexdump(len=10): 01 00 00 06 01 02 00 06 19 20
    [00:01:17.180,725] <dbg> wpa_supp: wpa_printf_impl: EAPOL: Received EAP-Packet frame
    [00:01:17.191,009] <dbg> wpa_supp: wpa_printf_impl: EAPOL: SUPP_BE entering state REQUEST
    [00:01:17.201,721] <dbg> wpa_supp: wpa_printf_impl: EAPOL: getSuppRsp
    [00:01:17.210,754] <dbg> wpa_supp: wpa_printf_impl: EAP: EAP entering state RECEIVED
    [00:01:17.221,191] <dbg> wpa_supp: wpa_printf_impl: EAP: Received EAP-Request id=2 method=25 vendor=0 vendorMethod=0
    [00:01:17.234,252] <dbg> wpa_supp: wpa_printf_impl: EAP: EAP entering state GET_METHOD
    [00:01:17.244,750] <dbg> wpa_supp: wpa_printf_impl: EAP: configuration does not allow: vendor 0 method 25
    [00:01:17.256,835] <dbg> wpa_supp: wpa_printf_impl: EAP: vendor 0 method 25 not allowed
    [00:01:17.267,456] <inf> wpa_supp: wlan0: CTRL-EVENT-EAP-PROPOSED-METHOD vendor=0 method=25 -> NAK
    [00:01:17.278,991] <dbg> wpa_supp: wpa_printf_impl: EAP: Status notification: refuse proposed method (param=PEAP)
    [00:01:17.291,900] <dbg> wpa_supp: wpa_printf_impl: EAP: Building EAP-Nak (requested type 25 vendor=0 method=0 not allowed)
    [00:01:17.305,572] <dbg> wpa_supp: wpa_printf_impl: EAP: allowed methods - hexdump(len=1): 0d
    [00:01:17.316,650] <dbg> wpa_supp: wpa_printf_impl: EAP: EAP entering state SEND_RESPONSE
    [00:01:17.327,392] <dbg> wpa_supp: wpa_printf_impl: EAP: EAP entering state IDLE
    [00:01:17.337,341] <dbg> wpa_supp: wpa_printf_impl: EAPOL: SUPP_BE entering state RESPONSE
    [00:01:17.348,144] <dbg> wpa_supp: wpa_printf_impl: EAPOL: txSuppRsp
    [00:01:17.357,086] <dbg> wpa_supp: wpa_printf_impl: TX EAPOL: dst=b8:37:b2:09:1c:11
    [00:01:17.367,370] <dbg> wpa_supp: wpa_printf_impl: TX EAPOL - hexdump(len=10): 01 00 00 06 02 02 00 06 03 0d
    [00:01:17.380,096] <dbg> wpa_supp: wpa_printf_impl: EAPOL: SUPP_BE entering state RECEIVE
    [00:01:17.391,479] <dbg> wpa_supp: wpa_printf_impl: Received len: 56, msg_len:56 - CTRL-EVENT-EAP-PROPOSED-METHOD vendor=0 method=25 -> NAK->END
    [00:01:17.407,409] <dbg> wpa_supp: wpa_printf_impl: Event not supported: CTRL-EVENT-EAP-PROPOSED-METHOD vendor=0 method=25 -> NAK
    [00:01:17.421,844] <dbg> wpa_supp: wpa_printf_impl: Received len: 70, msg_len:70 - CTRL-EVENT-EAP-STATUS status='refuse proposed method' parameter='PEAP'->END
    [00:01:17.438,598] <dbg> wpa_supp: wpa_printf_impl: Event not supported: CTRL-EVENT-EAP-STATUS status='refuse proposed method' parameter='PEAP'
    [00:01:17.455,902] <dbg> wpa_supp: wpa_printf_impl: wlan0: RX EAPOL from b8:37:b2:09:1c:11
    [00:01:17.466,796] <dbg> wpa_supp: wpa_printf_impl: RX EAPOL - hexdump(len=10): 01 00 00 06 01 03 00 06 0d 20
    [00:01:17.479,278] <dbg> wpa_supp: wpa_printf_impl: EAPOL: Received EAP-Packet frame
    [00:01:17.489,562] <dbg> wpa_supp: wpa_printf_impl: EAPOL: SUPP_BE entering state REQUEST
    [00:01:17.500,274] <dbg> wpa_supp: wpa_printf_impl: EAPOL: getSuppRsp
    [00:01:17.509,307] <dbg> wpa_supp: wpa_printf_impl: EAP: EAP entering state RECEIVED
    [00:01:17.519,744] <dbg> wpa_supp: wpa_printf_impl: EAP: Received EAP-Request id=3 method=13 vendor=0 vendorMethod=0
    [00:01:17.532,806] <dbg> wpa_supp: wpa_printf_impl: EAP: EAP entering state GET_METHOD
    [00:01:17.543,334] <inf> wpa_supp: wlan0: CTRL-EVENT-EAP-PROPOSED-METHOD vendor=0 method=13
    [00:01:17.664,215] <dbg> wpa_supp: wpa_printf_impl: EAP: allowed methods - hexdump(len=0):
    [00:01:17.675,018] <dbg> wpa_supp: wpa_printf_impl: EAP: EAP entering state SEND_RESPONSE
    [00:01:17.685,760] <dbg> wpa_supp: wpa_printf_impl: EAP: EAP entering state IDLE
    [00:01:17.695,709] <dbg> wpa_supp: wpa_printf_impl: EAPOL: SUPP_BE entering state RESPONSE
    [00:01:17.706,542] <dbg> wpa_supp: wpa_printf_impl: EAPOL: txSuppRsp
    [00:01:17.715,484] <dbg> wpa_supp: wpa_printf_impl: TX EAPOL: dst=b8:37:b2:09:1c:11
    [00:01:17.725,769] <dbg> wpa_supp: wpa_printf_impl: TX EAPOL - hexdump(len=10): 01 00 00 06 02 03 00 06 03 00
    [00:01:17.738,555] <dbg> wpa_supp: wpa_printf_impl: EAPOL: SUPP_BE entering state RECEIVE
    [00:01:17.749,908] <dbg> wpa_supp: wpa_printf_impl: Received len: 49, msg_len:49 - CTRL-EVENT-EAP-PROPOSED-METHOD vendor=0 method=13->END
    [00:01:17.764,831] <dbg> wpa_supp: wpa_printf_impl: Event not supported: CTRL-EVENT-EAP-PROPOSED-METHOD vendor=0 method=13
    [00:01:17.778,472] <dbg> wpa_supp: wpa_printf_impl: Received len: 69, msg_len:69 - CTRL-EVENT-EAP-STATUS status='accept proposed method' parameter='TLS'->END
    [00:01:17.795,135] <dbg> wpa_supp: wpa_printf_impl: Event not supported: CTRL-EVENT-EAP-STATUS status='accept proposed method' parameter='TLS'
    [00:01:17.810,516] <dbg> wpa_supp: wpa_printf_impl: Received len: 62, msg_len:62 - EAP: Failed to initialize EAP method: vendor 0 method 13 (TLS)->END
    [00:01:18.749,908] <dbg> wpa_supp: wpa_printf_impl: EAPOL: startWhen --> 0
    [00:01:18.765,716] <dbg> wpa_supp: wpa_printf_impl: wlan0: RX EAPOL from b8:37:b2:09:1c:11
    [00:01:18.776,641] <dbg> wpa_supp: wpa_printf_impl: RX EAPOL - hexdump(len=8): 01 00 00 04 04 03 00 04
    [00:01:18.788,513] <dbg> wpa_supp: wpa_printf_impl: EAPOL: Received EAP-Packet frame
    [00:01:18.798,797] <dbg> wpa_supp: wpa_printf_impl: EAPOL: SUPP_BE entering state REQUEST
    [00:01:18.809,509] <dbg> wpa_supp: wpa_printf_impl: EAPOL: getSuppRsp
    [00:01:18.818,511] <dbg> wpa_supp: wpa_printf_impl: EAP: EAP entering state RECEIVED
    [00:01:18.828,979] <dbg> wpa_supp: wpa_printf_impl: EAP: Received EAP-Failure
    [00:01:18.838,653] <dbg> wpa_supp: wpa_printf_impl: EAP: Status notification: completion (param=failure)
    [00:01:18.850,769] <dbg> wpa_supp: wpa_printf_impl: EAP: EAP entering state FAILURE
    [00:01:18.860,992] <inf> wpa_supp: wlan0: CTRL-EVENT-EAP-FAILURE EAP authentication failed
    [00:01:18.871,826] <dbg> wpa_supp: wpa_printf_impl: EAPOL: SUPP_PAE entering state HELD
    [00:01:18.882,385] <dbg> wpa_supp: wpa_printf_impl: EAPOL: Supplicant port status: Unauthorized
    [00:01:18.900,543] <dbg> wpa_supp: wpa_printf_impl: EAPOL: SUPP_BE entering state RECEIVE
    [00:01:18.911,437] <dbg> wpa_supp: wpa_printf_impl: EAPOL: SUPP_BE entering state FAIL
    [00:01:18.921,905] <dbg> wpa_supp: wpa_printf_impl: EAPOL: SUPP_BE entering state IDLE
    [00:01:18.932,403] <dbg> wpa_supp: wpa_printf_impl: EAPOL authentication completed - result=FAILURE
    [00:01:18.944,061] <dbg> wpa_supp: wpa_printf_impl: wlan0: Setting authentication timeout: 2 sec 0 usec
    [00:01:18.956,054] <dbg> wifi_supplicant: event_socket_handler: Passing message 11 to wpa_supplicant
    [00:01:18.967,742] <dbg> wpa_supp: wpa_printf_impl: wlan0: Event DEAUTH (11) received
    [00:01:18.978,179] <dbg> wpa_supp: wpa_printf_impl: wlan0: Deauthentication notification
    [00:01:18.988,830] <dbg> wpa_supp: wpa_printf_impl: wlan0:  * reason 1 (UNSPECIFIED)
    [00:01:18.999,206] <dbg> wpa_supp: wpa_printf_impl: wlan0:  * address b8:37:b2:09:1c:11
    [00:01:19.009,765] <dbg> wpa_supp: wpa_printf_impl: Deauthentication frame IE(s) - hexdump(len=0): [NULL]
    [00:01:19.021,942] <inf> wpa_supp: wlan0: CTRL-EVENT-DISCONNECTED bssid=b8:37:b2:09:1c:11 reason=1
    Connection request failed (1)
    [00:01:19.039,306] <inf> wpa_supp: wlan0: CTRL-EVENT-SSID-TEMP-DISABLED id=0 ssid="kiosk_wpa2_ent" auth_failures=1 duration=10 reason=AUTH_FAILED
    [00:01:19.054,962] <dbg> wpa_supp: wpa_printf_impl: wlan0: Auto connect enabled: try to reconnect (wps=0/0 wpa_state=6)
    [00:01:19.068,359] <dbg> wpa_supp: wpa_printf_impl: wlan0: Setting scan request: 0.100000 sec
    [00:01:19.079,528] <dbg> wpa_supp: wpa_printf_impl: wlan0: Radio work 'sme-connect'@0x2005cd00 done in 3.611786 seconds
    [00:01:19.092,926] <dbg> wpa_supp: wpa_printf_impl: wlan0: radio_work_free('sme-connect'@0x2005cd00): num_active_works --> 0
    [00:01:19.106,842] <inf> wpa_supp: wlan0: Added BSSID b8:37:b2:09:1c:11 into ignore list, ignoring for 10 seconds
    [00:01:19.119,720] <dbg> wpa_supp: wpa_printf_impl: wlan0: Another BSS in this ESS has been seen; try it next
    [00:01:19.132,324] <inf> wpa_supp: wlan0: BSSID b8:37:b2:09:1c:11 ignore list count incremented to 2, ignoring for 10 seconds
    [00:01:19.146,270] <dbg> wpa_supp: wpa_printf_impl: wlan0: Consecutive connection failures: 1 --> request scan in 100 ms
    [00:01:19.159,790] <dbg> wpa_supp: wpa_printf_impl: wlan0: Ignore new scan request for 0.100000 sec since an earlier request is scheduled to trigger sooner
    [00:01:19.176,239] <dbg> wpa_supp: wpa_printf_impl: wlan0: WPA: Clear old PMK and PTK
    [00:01:19.186,950] <dbg> wpa_supp: wpa_printf_impl: wlan0: Disconnect event - remove keys
    [00:01:19.197,723] <dbg> wpa_supp: wpa_printf_impl: wlan0: State: ASSOCIATED -> DISCONNECTED
    [00:01:19.208,740] <dbg> wpa_supp: wpa_printf_impl: EAPOL: External notification - portEnabled=0
    [00:01:19.220,031] <dbg> wpa_supp: wpa_printf_impl: EAPOL: SUPP_PAE entering state DISCONNECTED
    [00:01:19.231,292] <dbg> wpa_supp: wpa_printf_impl: EAPOL: Supplicant port status: Unauthorized
    [00:01:19.251,708] <dbg> wpa_supp: wpa_printf_impl: EAPOL: SUPP_BE entering state INITIALIZE
    [00:01:19.262,847] <dbg> wpa_supp: wpa_printf_impl: EAP: EAP entering state DISABLED
    [00:01:19.273,162] <dbg> wpa_supp: wpa_printf_impl: EAPOL: External notification - portValid=0
    [00:01:19.284,423] <dbg> wpa_supp: wpa_printf_impl: Received len: 61, msg_len:61 - CTRL-EVENT-EAP-STATUS status='completion' parameter='failure'->END
    [00:01:19.300,384] <dbg> wpa_supp: wpa_printf_impl: Event not supported: CTRL-EVENT-EAP-STATUS status='completion' parameter='failure'
    [00:01:19.315,063] <dbg> wpa_supp: wpa_printf_impl: Received len: 48, msg_len:48 - CTRL-EVENT-EAP-FAILURE EAP authentication failed->END
    [00:01:19.329,895] <dbg> wpa_supp: wpa_printf_impl: Event not supported: CTRL-EVENT-EAP-FAILURE EAP authentication failed
    [00:01:19.343,475] <dbg> wpa_supp: wpa_printf_impl: Received len: 56, msg_len:56 - CTRL-EVENT-DISCONNECTED bssid=b8:37:b2:09:1c:11 reason=1->END
    [00:01:19.359,069] <dbg> wpa_supp: wpa_printf_impl: Received len: 103, msg_len:103 - CTRL-EVENT-SSID-TEMP-DISABLED id=0 ssid="kiosk_wpa2_ent" auth_failures=1 duration=10 reason=AUTH_FAILED->END
    [00:01:19.378,936] <dbg> wpa_supp: wpa_printf_impl: Received len: 71, msg_len:71 - Added BSSID b8:37:b2:09:1c:11 into ignore list, ignoring for 10 seconds->END
    [00:01:19.395,782] <dbg> wpa_supp: wpa_printf_impl: Received len: 83, msg_len:83 - BSSID b8:37:b2:09:1c:11 ignore list count incremented to 2, ignoring for 10 seconds->END
    [00:01:19.413,726] <dbg> wpa_supp: wpa_printf_impl: wlan0: State: DISCONNECTED -> SCANNING
    [00:01:19.424,621] <dbg> wpa_supp: wpa_printf_impl: wlan0: Starting AP scan for wildcard SSID
    [00:01:19.435,791] <dbg> wpa_supp: wpa_printf_impl: wlan0: Optimize scan based on previously generated frequency list
    [00:01:19.449,066] <dbg> wpa_supp: wpa_printf_impl: wlan0: Add radio work 'scan'@0x2005d068
    [00:01:19.460,021] <dbg> wpa_supp: wpa_printf_impl: wlan0: First radio work item in the queue - schedule start immediately
    [00:01:19.473,815] <dbg> wpa_supp: wpa_printf_impl: wlan0: Starting radio work 'scan'@0x2005d068 after 0.013763 second wait
    [00:01:19.496,093] <dbg> wpa_supp: wpa_printf_impl: wpa_drv_zep_scan2: Scan requested - scan timeout 35 seconds
    [00:01:19.509,826] <dbg> wifi_supplicant: event_socket_handler: Passing message 47 to wpa_supplicant
    [00:01:19.521,514] <dbg> wpa_supp: wpa_printf_impl: wlan0: Event SCAN_STARTED (47) received
    [00:01:19.532,501] <dbg> wpa_supp: wpa_printf_impl: wlan0: Own scan request started a scan in 0.022796 seconds
    [00:01:19.545,227] <dbg> wpa_supp: wpa_printf_impl: Received len: 24, msg_len:24 - CTRL-EVENT-SCAN-STARTED ->END
    [00:01:19.558,624] <dbg> wifi_supplicant: event_socket_handler: Passing message 3 to wpa_supplicant
    [00:01:19.570,251] <dbg> wpa_supp: wpa_printf_impl: wlan0: Event SCAN_RESULTS (3) received
    [00:01:19.581,115] <dbg> wpa_supp: wpa_printf_impl: wlan0: Scan completed in 0.048615 seconds
    [00:01:19.595,214] <dbg> wpa_supp: wpa_printf_impl: Sorted scan results
    [00:01:19.604,461] <dbg> wpa_supp: wpa_printf_impl: b8:37:b2:09:1c:01 ssid=kiosk_wpa2_ent freq=2412 qual=0 noise=-89~ level=-71 snr=18 flags=0xb age=58 est=52000
    [00:01:19.623,107] <dbg> wpa_supp: wpa_printf_impl: IEs - hexdump(len=243): 00 0e 6b 69 6f 73 6b 5f 77 70 61 32 5f 65 6e 74 01 08 82 84 0b 16 24 30 48 6c 03 01 01 05 04 00 01 00 00 2a 01 00 32 04 0c 12 18 60 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00 00 0f ac 01 28 00 0b 05 00 00 30 dd 6d 2d 1a ad 09
    [00:01:19.654,418] <dbg> wpa_supp: wpa_printf_impl: Beacon IEs - hexdump(len=243): 00 0e 6b 69 6f 73 6b 5f 77 70 61 32 5f 65 6e 74 01 08 82 84 0b 16 24 30 48 6c 03 01 01 05 04 00 01 00 00 2a 01 00 32 04 0c 12 18 60 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00 00 0f ac 01 28 00 0b 05 00 00 30 dd 6d 2d 1a
    [00:01:19.684,112] <dbg> wpa_supp: wpa_printf_impl: wlan0: BSS: Start scan result update 2
    [00:01:19.695,190] <dbg> wpa_supp: wpa_printf_impl: BSS: last_scan_res_used=1/32
    [00:01:19.705,169] <dbg> wpa_supp: wpa_printf_impl: wlan0: New scan results available (own=1 ext=0)
    [00:01:19.716,949] <dbg> wpa_supp: wpa_printf_impl: wlan0: Radio work 'scan'@0x2005d068 done in 0.243134 seconds
    [00:01:19.729,736] <dbg> wpa_supp: wpa_printf_impl: wlan0: radio_work_free('scan'@0x2005d068): num_active_works --> 0
    [00:01:19.742,980] <dbg> wpa_supp: wpa_printf_impl: wlan0: Postpone network selection by 10 seconds since all networks are disabled
    [00:01:19.757,507] <dbg> wpa_supp: wpa_printf_impl: Received len: 24, msg_len:24 - CTRL-EVENT-SCAN-RESULTS ->END
    [00:01:19.770,324] <dbg> wpa_supp: wpa_printf_impl: EAPOL: disable timer tick
    [00:01:29.757,476] <dbg> wpa_supp: wpa_printf_impl: wlan0: Try to associate due to network getting re-enabled
    [00:01:29.769,927] <dbg> wpa_supp: wpa_printf_impl: Fast associate: Old scan results
    [00:01:29.780,273] <dbg> wpa_supp: wpa_printf_impl: wlan0: Setting scan request: 0.000000 sec
    [00:01:29.791,442] <dbg> wpa_supp: wpa_printf_impl: Scan SSID - hexdump_ascii(len=14):
    [00:01:29.801,879] <dbg> wpa_supp: _wpa_hexdump_ascii:
                                       6b 69 6f 73 6b 5f 77 70  61 32 5f 65 6e 74       |kiosk_wp a2_ent
    [00:01:29.818,725] <dbg> wpa_supp: wpa_printf_impl: wlan0: Include wildcard SSID in the scan request
    [00:01:29.830,535] <dbg> wpa_supp: wpa_printf_impl: wlan0: Add radio work 'scan'@0x2005cea8
    [00:01:29.841,491] <dbg> wpa_supp: wpa_printf_impl: wlan0: First radio work item in the queue - schedule start immediately
    [00:01:29.855,255] <dbg> wpa_supp: wpa_printf_impl: wlan0: Starting radio work 'scan'@0x2005cea8 after 0.013702 second wait
    [00:01:29.877,075] <dbg> wpa_supp: wpa_printf_impl: wpa_drv_zep_scan2: Scan requested - scan timeout 35 seconds
    [00:01:29.890,716] <dbg> wifi_supplicant: event_socket_handler: Passing message 47 to wpa_supplicant
    [00:01:29.902,404] <dbg> wpa_supp: wpa_printf_impl: wlan0: Event SCAN_STARTED (47) received
    [00:01:29.913,360] <dbg> wpa_supp: wpa_printf_impl: wlan0: Own scan request started a scan in 0.022767 seconds
    [00:01:29.926,086] <dbg> wpa_supp: wpa_printf_impl: Received len: 24, msg_len:24 - CTRL-EVENT-SCAN-STARTED ->END
    Can you share your current application code so I can check it on my side?
    Marte
