Can't get WPA2 Enterprise (EAP-TLS) to connect to wifi AP using nrf5340/nrf7002/NCS2.9.0
I am trying to get the wifi stack to connect to a wifi AP using WAP2 Enterprise (initially just with identity and eap_password, later with full ca_certificate check and client certificate).
We have a custom PCB with nrf5340, nrf7002, and an application built with NCS2.9.0.
The code will connect ok when using WPA2-PSK and WPA3-SAE, but doesn't manage to connect using WPA2-EAP-TLS?
To try to determine why, I have enabled WPA2-Enterprise connection in the wifi-sta sample but this doesn't connect either.
wifi-sta prj.conf file:
4300.prj.conf
The connection setup code is like this:
static int __wifi_params_wpa2eap(struct wifi_connect_req_params *params)
    params->timeout =  CONFIG_STA_CONN_TIMEOUT_SEC * MSEC_PER_SEC;
    if (params->timeout == 0) {
        params->timeout = SYS_FOREVER_MS;
    /* Defaults */
    params->band = WIFI_FREQ_BAND_UNKNOWN;
    params->channel = WIFI_CHANNEL_ANY;
    params->security = WIFI_SECURITY_TYPE_NONE;
    params->mfp = WIFI_MFP_OPTIONAL;
    /* SSID */
    params->ssid =STA_SSID;
    params->ssid_length = strlen(params->ssid);
    params->security = WIFI_SECURITY_TYPE_EAP_TLS;
    params->eap_identity = STA_IDENTITY;        //"cc2-004a";
    params->eap_id_length = strlen(params->eap_identity);
    params->eap_password = STA_PASSWORD;
    params->eap_passwd_length = strlen(params->eap_password);
    return 0;
Is this correct to set up a WPA2 EAP-TLS connection?
btw my wifi AP is a HP 505H using an internal database for EAP user lookup.
The debug output from wpa_supplient during the connection attempt:
[00:00:00.470,855] <inf> sta: Starting cc2v1 with CPU frequency: 64 MHz
[00:00:00.471,038] <dbg> wpa_supp: wpa_printf_impl: wpa_supplicant v2.11-devel
[00:00:00.471,252] <inf> wifi_supplicant: wpa_supplicant initialized
[00:00:00.471,618] <dbg> wifi_supplicant: add_interface: Adding interface wlan0 [1] (0x200019b8)
[00:00:00.471,710] <dbg> wpa_supp: wpa_printf_impl: Calling wpa_cli: interface_add, argc: 5
[00:00:00.471,771] <dbg> wpa_supp: wpa_printf_impl: argv[0]: interface_add
[00:00:00.471,832] <dbg> wpa_supp: wpa_printf_impl: argv[1]: wlan0
[00:00:00.471,862] <dbg> wpa_supp: wpa_printf_impl: argv[2]: zephyr
[00:00:00.471,893] <dbg> wpa_supp: wpa_printf_impl: argv[3]: zephyr
[00:00:00.471,954] <dbg> wpa_supp: wpa_printf_impl: argv[4]: zephyr
[00:00:00.472,320] <dbg> wpa_supp: wpa_printf_impl: RX global ctrl_iface - hexdump_ascii(len=71):
[00:00:00.472,351] <dbg> wpa_supp: _wpa_hexdump_ascii:
49 4e 54 45 52 46 41 43 45 5f 41 44 44 20 77 6c |INTERFAC E_ADD wl
61 6e 30 09 7a 65 70 68 79 72 09 7a 65 70 68 79 |an0.zeph yr.zephy
72 09 7a 65 70 68 79 72 09 09 09 09 20 77 6c 61 |r.zephyr .... wla
6e 30 20 7a 65 70 68 79 72 20 7a 65 70 68 79 72 |n0 zephy r zephyr
20 7a 65 70 68 79 72 | zephyr
[00:00:00.472,412] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE GLOBAL INTERFACE_ADD 'wlan0 zephyr zephyr zephyr wlan0 zephyr zephyr zephyr'
[00:00:00.472,534] <dbg> wpa_supp: wpa_printf_impl: Initializing interface 'wlan0' conf 'zephyr' driver 'zephyr' ctrl_interface 'zephyr' bridge 'N/A'
[00:00:00.474,517] <dbg> wpa_supp: wpa_printf_impl: Add interface wlan0 to a new radio N/A
[00:00:00.477,966] <dbg> wpa_supp: wpa_printf_impl: wpa_supp: Added 802.11b mode based on 802.11g information
[00:00:00.478,179] <dbg> wpa_supp: wpa_printf_impl: l2_packet_init: iface wlan0 ifindex 1
[00:00:00.478,332] <dbg> wpa_supp: wpa_printf_impl: wlan0: Own MAC address: f0:ce:37:00:00:4a
[00:00:00.478,485] <dbg> wpa_supp: wpa_printf_impl: _wpa_drv_zep_set_key: priv:0x2000a450 alg 0 addr 0x0 key_idx 0 set_tx 0 seq 0x0 seq_len 0 key 0x0 key_len 0 key_flag 10
[00:00:00.482,025] <dbg> wpa_supp: wpa_printf_impl: _wpa_drv_zep_set_key: priv:0x2000a450 alg 0 addr 0x0 key_idx 1 set_tx 0 seq 0x0 seq_len 0 key 0x0 key_len 0 key_flag 10
[00:00:00.484,344] <dbg> wpa_supp: wpa_printf_impl: _wpa_drv_zep_set_key: priv:0x2000a450 alg 0 addr 0x0 key_idx 2 set_tx 0 seq 0x0 seq_len 0 key 0x0 key_len 0 key_flag 10
[00:00:00.486,663] <dbg> wpa_supp: wpa_printf_impl: _wpa_drv_zep_set_key: priv:0x2000a450 alg 0 addr 0x0 key_idx 3 set_tx 0 seq 0x0 seq_len 0 key 0x0 key_len 0 key_flag 10
[00:00:00.488,983] <dbg> wpa_supp: wpa_printf_impl: _wpa_drv_zep_set_key: priv:0x2000a450 alg 0 addr 0x0 key_idx 4 set_tx 0 seq 0x0 seq_len 0 key 0x0 key_len 0 key_flag 10
[00:00:00.492,675] <dbg> wpa_supp: wpa_printf_impl: _wpa_drv_zep_set_key: priv:0x2000a450 alg 0 addr 0x0 key_idx 5 set_tx 0 seq 0x0 seq_len 0 key 0x0 key_len 0 key_flag 10
[00:00:00.494,964] <dbg> wpa_supp: wpa_printf_impl: wlan0: RSN: flushing PMKID list in the driver
[00:00:00.495,086] <dbg> wpa_supp: wpa_printf_impl: wlan0: State: DISCONNECTED -> INACTIVE
[00:00:00.557,220] <dbg> wpa_supp: wpa_printf_impl: EAPOL: SUPP_PAE entering state DISCONNECTED
[00:00:00.557,281] <dbg> wpa_supp: wpa_printf_impl: EAPOL: Supplicant port status: Unauthorized
[00:00:00.567,687] <dbg> wpa_supp: wpa_printf_impl: EAPOL: KEY_RX entering state NO_KEY_RECEIVE
[00:00:00.567,749] <dbg> wpa_supp: wpa_printf_impl: EAPOL: SUPP_BE entering state INITIALIZE
[00:00:00.567,779] <dbg> wpa_supp: wpa_printf_impl: EAP: EAP entering state DISABLED
[00:00:00.568,145] <dbg> wpa_supp: wpa_printf_impl: wlan0: Added interface wlan0
[00:00:00.568,267] <dbg> wpa_supp: wpa_printf_impl: wlan0: State: INACTIVE -> DISCONNECTED
[00:00:01.471,008] <dbg> wpa_supp: wpa_printf_impl: Calling wpa_cli: remove_network, argc: 2
[00:00:01.471,069] <dbg> wpa_supp: wpa_printf_impl: argv[0]: remove_network
[00:00:01.471,099] <dbg> wpa_supp: wpa_printf_impl: argv[1]: all
[00:00:01.471,466] <dbg> wpa_supp: wpa_printf_impl: wlan0: Control interface command 'REMOVE_NETWORK all'
[00:00:01.471,557] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: REMOVE_NETWORK all
[00:00:01.472,076] <dbg> wpa_supp: wpa_printf_impl: wlan0: Control interface command 'ADD_NETWORK'
[00:00:01.472,167] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: ADD_NETWORK
[00:00:01.472,656] <dbg> wpa_supp: wpa_printf_impl: Received len: 26, msg_len:26 - CTRL-EVENT-NETWORK-ADDED 0->END
[00:00:01.473,022] <dbg> wpa_supp: wpa_printf_impl: NET added: 0
[00:00:01.473,114] <dbg> wpa_supp: wpa_printf_impl: Calling wpa_cli: set_network, argc: 4
[00:00:01.473,175] <dbg> wpa_supp: wpa_printf_impl: argv[0]: set_network
[00:00:01.473,205] <dbg> wpa_supp: wpa_printf_impl: argv[1]: 0
[00:00:01.473,266] <dbg> wpa_supp: wpa_printf_impl: argv[2]: ssid
[00:00:01.473,297] <dbg> wpa_supp: wpa_printf_impl: argv[3]: "kiosk_wpa2_ent"
[00:00:01.473,693] <dbg> wpa_supp: wpa_printf_impl: wlan0: Control interface command 'SET_NETWORK [REMOVED]'
[00:00:01.473,815] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: SET_NETWORK id=0 name='ssid'
[00:00:01.473,876] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: value - hexdump_ascii(len=16): [REMOVED]
[00:00:01.473,968] <dbg> wpa_supp: wpa_printf_impl: ssid - hexdump_ascii(len=14):
[00:00:01.473,999] <dbg> wpa_supp: _wpa_hexdump_ascii:
6b 69 6f 73 6b 5f 77 70 61 32 5f 65 6e 74 |kiosk_wp a2_ent
[00:00:01.474,273] <dbg> wpa_supp: wpa_printf_impl: Calling wpa_cli: set_network, argc: 4
[00:00:01.474,304] <dbg> wpa_supp: wpa_printf_impl: argv[0]: set_network
[00:00:01.474,365] <dbg> wpa_supp: wpa_printf_impl: argv[1]: 0
[00:00:01.474,395] <dbg> wpa_supp: wpa_printf_impl: argv[2]: scan_ssid
[00:00:01.474,456] <dbg> wpa_supp: wpa_printf_impl: argv[3]: 1
[00:00:01.474,822] <dbg> wpa_supp: wpa_printf_impl: wlan0: Control interface command 'SET_NETWORK [REMOVED]'
[00:00:01.474,975] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: SET_NETWORK id=0 name='scan_ssid'
[00:00:01.475,036] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: value - hexdump_ascii(len=1): [REMOVED]
[00:00:01.475,097] <dbg> wpa_supp: wpa_printf_impl: scan_ssid=1 (0x1)
[00:00:01.475,372] <dbg> wpa_supp: wpa_printf_impl: Calling wpa_cli: set_network, argc: 4
[00:00:01.475,402] <dbg> wpa_supp: wpa_printf_impl: argv[0]: set_network
[00:00:01.475,463] <dbg> wpa_supp: wpa_printf_impl: argv[1]: 0
[00:00:01.475,494] <dbg> wpa_supp: wpa_printf_impl: argv[2]: key_mgmt
[00:00:01.475,524] <dbg> wpa_supp: wpa_printf_impl: argv[3]: NONE
[00:00:01.475,921] <dbg> wpa_supp: wpa_printf_impl: wlan0: Control interface command 'SET_NETWORK [REMOVED]'
[00:00:01.476,043] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: SET_NETWORK id=0 name='key_mgmt'
[00:00:01.476,104] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: value - hexdump_ascii(len=4): [REMOVED]
[00:00:01.476,196] <dbg> wpa_supp: wpa_printf_impl: key_mgmt: 0x4
[00:00:01.476,501] <dbg> wpa_supp: wpa_printf_impl: Calling wpa_cli: set_network, argc: 4
[00:00:01.476,531] <dbg> wpa_supp: wpa_printf_impl: argv[0]: set_network
[00:00:01.476,593] <dbg> wpa_supp: wpa_printf_impl: argv[1]: 0
[00:00:01.476,623] <dbg> wpa_supp: wpa_printf_impl: argv[2]: ieee80211w
[00:00:01.476,654] <dbg> wpa_supp: wpa_printf_impl: argv[3]: 0
[00:00:01.477,050] <dbg> wpa_supp: wpa_printf_impl: wlan0: Control interface command 'SET_NETWORK [REMOVED]'
[00:00:01.477,172] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: SET_NETWORK id=0 name='ieee80211w'
[00:00:01.477,233] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: value - hexdump_ascii(len=1): [REMOVED]
[00:00:01.477,386] <dbg> wpa_supp: wpa_printf_impl: ieee80211w=0 (0x0)
[00:00:01.477,661] <dbg> wpa_supp: wpa_printf_impl: Calling wpa_cli: set_network, argc: 4
[00:00:01.477,722] <dbg> wpa_supp: wpa_printf_impl: argv[0]: set_network
[00:00:01.477,752] <dbg> wpa_supp: wpa_printf_impl: argv[1]: 0
[00:00:01.477,813] <dbg> wpa_supp: wpa_printf_impl: argv[2]: proto
[00:00:01.477,844] <dbg> wpa_supp: wpa_printf_impl: argv[3]: RSN
[00:00:01.478,210] <dbg> wpa_supp: wpa_printf_impl: wlan0: Control interface command 'SET_NETWORK [REMOVED]'
[00:00:01.478,363] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: SET_NETWORK id=0 name='proto'
[00:00:01.478,424] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: value - hexdump_ascii(len=3): [REMOVED]
[00:00:01.478,485] <dbg> wpa_supp: wpa_printf_impl: proto: 0x2
[00:00:01.478,790] <dbg> wpa_supp: wpa_printf_impl: Calling wpa_cli: set_network, argc: 4
[00:00:01.478,820] <dbg> wpa_supp: wpa_printf_impl: argv[0]: set_network
[00:00:01.478,881] <dbg> wpa_supp: wpa_printf_impl: argv[1]: 0
[00:00:01.478,912] <dbg> wpa_supp: wpa_printf_impl: argv[2]: key_mgmt
[00:00:01.478,973] <dbg> wpa_supp: wpa_printf_impl: argv[3]: WPA-EAP
[00:00:01.479,339] <dbg> wpa_supp: wpa_printf_impl: wlan0: Control interface command 'SET_NETWORK [REMOVED]'
[00:00:01.479,492] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: SET_NETWORK id=0 name='key_mgmt'
[00:00:01.479,553] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: value - hexdump_ascii(len=7): [REMOVED]
[00:00:01.479,644] <dbg> wpa_supp: wpa_printf_impl: key_mgmt: 0x1
[00:00:01.479,919] <dbg> wpa_supp: wpa_printf_impl: Calling wpa_cli: set, argc: 3
[00:00:01.479,949] <dbg> wpa_supp: wpa_printf_impl: argv[0]: set
[00:00:01.480,010] <dbg> wpa_supp: wpa_printf_impl: argv[1]: openssl_ciphers
[00:00:01.480,041] <dbg> wpa_supp: wpa_printf_impl: argv[2]: "DEFAULT:!EXP:!LOW"
[00:00:01.480,438] <dbg> wpa_supp: wpa_printf_impl: wlan0: Control interface command 'SET openssl_ciphers "DEFAULT:!EXP:!LOW"'
[00:00:01.480,529] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE SET 'openssl_ciphers'='"DEFAULT:!EXP:!LOW"'
[00:00:01.480,651] <dbg> wpa_supp: wpa_printf_impl: openssl_ciphers='"DEFAULT:!EXP:!LOW"'
[00:00:01.480,926] <dbg> wpa_supp: wpa_printf_impl: Calling wpa_cli: set_network, argc: 4
[00:00:01.480,987] <dbg> wpa_supp: wpa_printf_impl: argv[0]: set_network
[00:00:01.481,018] <dbg> wpa_supp: wpa_printf_impl: argv[1]: 0
[00:00:01.481,048] <dbg> wpa_supp: wpa_printf_impl: argv[2]: group
[00:00:01.481,109] <dbg> wpa_supp: wpa_printf_impl: argv[3]: CCMP
[00:00:01.481,475] <dbg> wpa_supp: wpa_printf_impl: wlan0: Control interface command 'SET_NETWORK [REMOVED]'
[00:00:01.481,628] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: SET_NETWORK id=0 name='group'
[00:00:01.481,689] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: value - hexdump_ascii(len=4): [REMOVED]
[00:00:01.481,781] <dbg> wpa_supp: wpa_printf_impl: group: 0x10
[00:00:01.482,055] <dbg> wpa_supp: wpa_printf_impl: Calling wpa_cli: set_network, argc: 4
[00:00:01.482,116] <dbg> wpa_supp: wpa_printf_impl: argv[0]: set_network
[00:00:01.482,147] <dbg> wpa_supp: wpa_printf_impl: argv[1]: 0
[00:00:01.482,177] <dbg> wpa_supp: wpa_printf_impl: argv[2]: pairwise
[00:00:01.482,238] <dbg> wpa_supp: wpa_printf_impl: argv[3]: CCMP
[00:00:01.482,604] <dbg> wpa_supp: wpa_printf_impl: wlan0: Control interface command 'SET_NETWORK [REMOVED]'
[00:00:01.482,757] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: SET_NETWORK id=0 name='pairwise'
[00:00:01.482,818] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: value - hexdump_ascii(len=4): [REMOVED]
[00:00:01.482,910] <dbg> wpa_supp: wpa_printf_impl: pairwise: 0x10
[00:00:01.483,184] <dbg> wpa_supp: wpa_printf_impl: Calling wpa_cli: set_network, argc: 4
[00:00:01.483,245] <dbg> wpa_supp: wpa_printf_impl: argv[0]: set_network
[00:00:01.483,276] <dbg> wpa_supp: wpa_printf_impl: argv[1]: 0
[00:00:01.483,306] <dbg> wpa_supp: wpa_printf_impl: argv[2]: group_mgmt
[00:00:01.483,367] <dbg> wpa_supp: wpa_printf_impl: argv[3]: AES-128-CMAC
[00:00:01.483,734] <dbg> wpa_supp: wpa_printf_impl: wlan0: Control interface command 'SET_NETWORK [REMOVED]'
[00:00:01.483,917] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: SET_NETWORK id=0 name='group_mgmt'
[00:00:01.483,978] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: value - hexdump_ascii(len=12): [REMOVED]
[00:00:01.484,069] <dbg> wpa_supp: wpa_printf_impl: group_mgmt: 0x20
[00:00:01.484,375] <dbg> wpa_supp: wpa_printf_impl: Calling wpa_cli: set_network, argc: 4
[00:00:01.484,405] <dbg> wpa_supp: wpa_printf_impl: argv[0]: set_network
[00:00:01.484,466] <dbg> wpa_supp: wpa_printf_impl: argv[1]: 0
[00:00:01.484,497] <dbg> wpa_supp: wpa_printf_impl: argv[2]: proto
[00:00:01.484,527] <dbg> wpa_supp: wpa_printf_impl: argv[3]: RSN
[00:00:01.484,924] <dbg> wpa_supp: wpa_printf_impl: wlan0: Control interface command 'SET_NETWORK [REMOVED]'
[00:00:01.485,076] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: SET_NETWORK id=0 name='proto'
[00:00:01.485,137] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: value - hexdump_ascii(len=3): [REMOVED]
[00:00:01.485,443] <dbg> wpa_supp: wpa_printf_impl: Calling wpa_cli: set_network, argc: 4
[00:00:01.485,504] <dbg> wpa_supp: wpa_printf_impl: argv[0]: set_network
[00:00:01.485,534] <dbg> wpa_supp: wpa_printf_impl: argv[1]: 0
[00:00:01.485,565] <dbg> wpa_supp: wpa_printf_impl: argv[2]: eap
[00:00:01.485,626] <dbg> wpa_supp: wpa_printf_impl: argv[3]: TLS
[00:00:01.486,022] <dbg> wpa_supp: wpa_printf_impl: wlan0: Control interface command 'SET_NETWORK [REMOVED]'
[00:00:01.486,145] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: SET_NETWORK id=0 name='eap'
[00:00:01.486,206] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: value - hexdump_ascii(len=3): [REMOVED]
[00:00:01.486,511] <dbg> wpa_supp: wpa_printf_impl: eap methods - hexdump(len=16): 00 00 00 00 0d 00 00 00 00 00 00 00 00 00 00 00
[00:00:01.486,846] <dbg> wpa_supp: wpa_printf_impl: Calling wpa_cli: set_network, argc: 4
[00:00:01.486,877] <dbg> wpa_supp: wpa_printf_impl: argv[0]: set_network
[00:00:01.486,938] <dbg> wpa_supp: wpa_printf_impl: argv[1]: 0
[00:00:01.486,968] <dbg> wpa_supp: wpa_printf_impl: argv[2]: identity
[00:00:01.486,999] <dbg> wpa_supp: wpa_printf_impl: argv[3]: "cc2-004a"
[00:00:01.487,396] <dbg> wpa_supp: wpa_printf_impl: wlan0: Control interface command 'SET_NETWORK [REMOVED]'
[00:00:01.487,548] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: SET_NETWORK id=0 name='identity'
[00:00:01.487,609] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: value - hexdump_ascii(len=10): [REMOVED]
[00:00:01.487,701] <dbg> wpa_supp: wpa_printf_impl: identity - hexdump_ascii(len=8):
[00:00:01.487,731] <dbg> wpa_supp: _wpa_hexdump_ascii:
63 63 32 2d 30 30 34 61 |cc2-004a
[00:00:01.488,037] <dbg> wpa_supp: wpa_printf_impl: Calling wpa_cli: set_network, argc: 4
[00:00:01.488,067] <dbg> wpa_supp: wpa_printf_impl: argv[0]: set_network
[00:00:01.488,128] <dbg> wpa_supp: wpa_printf_impl: argv[1]: 0
[00:00:01.488,159] <dbg> wpa_supp: wpa_printf_impl: argv[2]: password
[00:00:01.488,220] <dbg> wpa_supp: wpa_printf_impl: argv[3]: "infrafon-2022"
[00:00:01.488,616] <dbg> wpa_supp: wpa_printf_impl: wlan0: Control interface command 'SET_NETWORK [REMOVED]'
[00:00:01.488,739] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: SET_NETWORK id=0 name='password'
[00:00:01.488,800] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: value - hexdump_ascii(len=15): [REMOVED]
[00:00:01.488,922] <dbg> wpa_supp: wpa_printf_impl: password - hexdump_ascii(len=13): [REMOVED]
[00:00:01.489,227] <dbg> wpa_supp: wpa_printf_impl: Calling wpa_cli: set_network, argc: 4
[00:00:01.489,257] <dbg> wpa_supp: wpa_printf_impl: argv[0]: set_network
[00:00:01.489,318] <dbg> wpa_supp: wpa_printf_impl: argv[1]: 0
[00:00:01.489,349] <dbg> wpa_supp: wpa_printf_impl: argv[2]: anonymous_identity
[00:00:01.489,410] <dbg> wpa_supp: wpa_printf_impl: argv[3]: "(null)"
[00:00:01.489,776] <dbg> wpa_supp: wpa_printf_impl: wlan0: Control interface command 'SET_NETWORK [REMOVED]'
[00:00:01.489,929] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: SET_NETWORK id=0 name='anonymous_identity'
[00:00:01.489,990] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE: value - hexdump_ascii(len=8): [REMOVED]
[00:00:01.490,081] <dbg> wpa_supp: wpa_printf_impl: anonymous_identity - hexdump_ascii(len=6):
[00:00:01.490,112] <dbg> wpa_supp: _wpa_hexdump_ascii:
28 6e 75 6c 6c 29 |(null)
[00:00:01.490,356] <inf> sta: Connection requested
[00:00:01.490,417] <inf> sta: ==================
[00:00:01.490,447] <inf> sta: State: DISCONNECTED
[00:00:01.568,054] <dbg> wpa_supp: wpa_printf_impl: EAPOL: disable timer tick
[00:00:01.790,557] <inf> sta: ==================
What else should my code do to get this to work?
Thanks!
  • The project is exactly the code in NCS3.0.0 in nrf/samples/wifi/shell, which I copied to my directory wifi_shell_30.
    I updated the prj.conf to add I2C support when building for my board (one of the nrf70 control IOs is on a ioexpander).
    # Copyright (c) 2022 Nordic Semiconductor ASA
    #BW add I2C driver to allow ioexpander to work
    CONFIG_I2C=y
    CONFIG_WIFI=y
    CONFIG_WIFI_NRF70=y
    # WPA supplicant
    CONFIG_WIFI_NM_WPA_SUPPLICANT=y
    CONFIG_NET_L2_WIFI_SHELL=y
    # Networking
    CONFIG_NETWORKING=y
    CONFIG_NET_SOCKETS=y
    CONFIG_NET_LOG=y
    CONFIG_NET_IPV6=y
    CONFIG_NET_IPV4=y
    CONFIG_NET_UDP=y
    CONFIG_NET_TCP=y
    CONFIG_NET_DHCPV4=y
    CONFIG_DNS_RESOLVER=y
    CONFIG_NET_STATISTICS=y
    CONFIG_NET_STATISTICS_WIFI=y
    CONFIG_NET_STATISTICS_USER_API=y
    CONFIG_NET_PKT_RX_COUNT=8
    CONFIG_NET_PKT_TX_COUNT=8
    # Below section is the primary contributor to SRAM and is currently
    # tuned for performance, but this will be revisited in the future.
    CONFIG_NET_BUF_RX_COUNT=16
    CONFIG_NET_BUF_TX_COUNT=16
    CONFIG_NRF70_RX_NUM_BUFS=16
    CONFIG_NRF70_MAX_TX_AGGREGATION=4
    CONFIG_NET_TC_TX_COUNT=1
    CONFIG_NET_IF_UNICAST_IPV6_ADDR_COUNT=4
    CONFIG_NET_IF_MCAST_IPV6_ADDR_COUNT=5
    CONFIG_NET_MAX_CONTEXTS=5
    CONFIG_NET_CONTEXT_SYNC_RECV=y
    CONFIG_INIT_STACKS=y
    CONFIG_NET_L2_ETHERNET=y
    CONFIG_NET_SHELL=y
    # Memories
    CONFIG_MAIN_STACK_SIZE=5200
    CONFIG_SHELL_STACK_SIZE=5400
    CONFIG_NET_TX_STACK_SIZE=4096
    CONFIG_NET_RX_STACK_SIZE=4096
    # Debugging
    CONFIG_STACK_SENTINEL=y
    CONFIG_DEBUG_COREDUMP=y
    CONFIG_DEBUG_COREDUMP_BACKEND_LOGGING=y
    CONFIG_DEBUG_COREDUMP_MEMORY_DUMP_MIN=y
    CONFIG_SHELL_CMDS_RESIZE=n
    #CONFIG_DEBUG=y
    CONFIG_WIFI_NM_WPA_SUPPLICANT_LOG_LEVEL_INF=y
    # Kernel options
    CONFIG_ENTROPY_GENERATOR=y
    CONFIG_REBOOT=y
    # Logging
    CONFIG_LOG=y
    CONFIG_PRINTK=y
    CONFIG_SHELL=y
    CONFIG_SHELL_GETOPT=y
    CONFIG_DEVICE_SHELL=y
    CONFIG_POSIX_CLOCK=y
    CONFIG_DATE_SHELL=y
    CONFIG_NET_CONFIG_AUTO_INIT=n
    CONFIG_POSIX_API=y
    CONFIG_WIFI_CREDENTIALS=y
    CONFIG_FLASH=y
    CONFIG_FLASH_PAGE_LAYOUT=y
    CONFIG_FLASH_MAP=y
    CONFIG_NVS=y
    CONFIG_SETTINGS=y
    CONFIG_SETTINGS_NVS=y
    # printing of scan results puts pressure on queues in new locking
    # design in net_mgmt. So, use a higher timeout for a crowded
    # environment.
    CONFIG_NET_MGMT_EVENT_QUEUE_TIMEOUT=5000
    CONFIG_NET_SOCKETS_POLL_MAX=12
    CONFIG_NET_MGMT_EVENT_QUEUE_SIZE=16
    Updated the zephyr tree with my certifs:
    ca.pem, client.pem, client_key.pem into zephyr/samples/net/wifi/test_cert
    and built as
    west build --build-dir wifi_shell_30/build wifi_shell_30 -S wifi-enterprise --board <board reference> --pristine   -DCONFIG_WIFI_NM_WPA_SUPPLICANT_LOG_LEVEL_DBG=y -DCONFIG_LOG_MODE_IMMEDIATE=y
    I should have clarified. I meant the app code, so I can compare it with the shell sample to see why it tries to connect while your application does not.
    Marte
  • Ah ok.
    Full application code is a bit large (I will try again with the wifi 'sta' sample next week), but heres the connect function:
    // Here we support only EAP-TLS
    static bool _connect_wpa2_eap(struct _netwifi_ctx* ctx, char* ssid, char* client_private_key_pass, char* client_identity, char* eap_pass) {
    	if (_isConnected(ctx)) {
    		// already connected
    		log_warn("netwifi: Connection request WPA2-EAP to AP[%s] but already connected!", ssid);
    		return true;
    	// MUST provide client private key, identity and eap_pass or no go
    	if (client_private_key_pass==NULL || client_identity==NULL || eap_pass==NULL) {
    		log_warn("netwifi: Connection request WPA2-EAP to AP[%s] but missing private key or identity or eap password!", ssid);
    		return false;
    	int ret = 0;
    	ctx->connect_requested = true;
    	ctx->ip_ok=false;		// No IP yet
    	memset(&(ctx->cnx_params), 0, sizeof(struct wifi_connect_req_params));
    	ctx->cnx_params.security = WIFI_SECURITY_TYPE_EAP_TLS;	// ==WIFI_SECURITY_TYPE_EAP ie WPA2-Enterprise with EAP_TLS authentication
    	// Note : this timeout does not seem to have any effect, the connect timeout in the WPA is always 10s (but we have a connect timer to shorten it if required)
    	// But don't set it less than the 10s as the wpa_supp doesn't like being disconnected while its still trying...
    	ctx->cnx_params.timeout = wvmgr_get_item_as_int("devcfg.wifi.connect_timeout_seconds", 30)* 1000;		//SYS_FOREVER_MS;
    	/* Defaults */
    	ctx->cnx_params.band = WIFI_FREQ_BAND_2_4_GHZ;		// WIFI_FREQ_BAND_UNKNOWN;
    	ctx->cnx_params.channel = WIFI_CHANNEL_ANY;
    	ctx->cnx_params.mfp = WIFI_MFP_OPTIONAL;
    	/* SSID */
    	ctx->cnx_params.ssid = ssid;
    	ctx->cnx_params.ssid_length = strlen(ctx->cnx_params.ssid);
    	/** Private key passwd for enterprise mode */
    	ctx->cnx_params.key_passwd = client_private_key_pass;
    	/** Private key passwd length, max 128 */
    	ctx->cnx_params.key_passwd_length = strlen(ctx->cnx_params.key_passwd);
    	// client identity is default device id
    	ctx->cnx_params.eap_identity = client_identity;	// "[email protected]",
    	/** eap identity length, max 64 */
    	ctx->cnx_params.eap_id_length = strlen(ctx->cnx_params.eap_identity);
    	/** Password string for EAP. */
    	ctx->cnx_params.eap_password = eap_pass;		// "password",
    	/** eap passwd length, max 128 */
    	ctx->cnx_params.eap_passwd_length = strlen(ctx->cnx_params.eap_password);
    	ctx->eap_conf.type = WIFI_EAP_TYPE_TLS;
    	ctx->eap_conf.eap_type_phase1 = WIFI_EAP_TYPE_TLS;
    	ctx->eap_conf.eap_type_phase2 = WIFI_EAP_TYPE_TLS; // No inner method needed for TLS
    	if ((ret=net_mgmt(NET_REQUEST_WIFI_CONNECT, ctx->iface,
    		     &ctx->cnx_params, sizeof(struct wifi_connect_req_params)))!=0) {
    		log_warn("netwifi: Connection request WPA2-EAP failed (%d) to AP[%s] for [%s]; reset wifi", ret, ctx->cnx_params.ssid, ctx->cnx_params.eap_identity);
    		ctx->connect_requested = false;
    		_wifi_reset(ctx);
    		return false;
    	netmgr_net_event(ctx->name, NET_EVT_CONNECT_START);
    	log_cpdbg("netwifi: Connection requested WPA2-EAP to AP[%s] for [%s]", ctx->cnx_params.ssid, ctx->cnx_params.eap_identity);
    	// Start the connection timer. This only stops when we get a DHCP IP address...
    	wsched_timer_start(ctx->connect_timer, wvmgr_get_item_as_int("devcfg.wifi.connect_timeout_seconds", 5)*1000, 1000, _connect_timeout_cb, ctx);
    	return true;
    It sets up the certificates like this:
    static uint8_t* _load_pem(char* name, uint32_t* buf_szp) {
    	char* file_id = Util_sprintf("certs/wifi/%s", name);
    	int fsize = usb_fs_get_file_size(file_id);
    	if (fsize>0) {
    		uint8_t* buf = Util_amalloc(fsize+4);
    		if (buf!=NULL) {
    			file_handle_t fh = usb_fs_open_file(file_id, true);
    			if (fh!=NULL) {
    				uint32_t blen = usb_fs_read_file(fh, buf, fsize);
    				usb_fs_close_file(fh);
    				if (blen==fsize) {
    					*buf_szp = fsize;
    					return buf;
    			Util_afree(buf);
    	return NULL;
    // Need to have all 3 elements or no go
    static bool _setup_ent_creds(struct _netwifi_ctx* ctx, char* ca_cert_name, char* client_cert_name, char* client_key_name) {
    #ifdef CONFIG_WIFI_NM_WPA_SUPPLICANT_CRYPTO_ENTERPRISE
    	if (ca_cert_name==NULL || client_cert_name==NULL || client_key_name==NULL) {
    		log_warn("netwifi: Wi-Fi enterprise but missing certs config!");
    		return false;
    	// Free old ones
    	if (ctx->enterprise_creds_params.ca_cert!=NULL) {
    		Util_afree(ctx->enterprise_creds_params.ca_cert);
    	if (ctx->enterprise_creds_params.client_cert!=NULL) {
    		Util_afree(ctx->enterprise_creds_params.client_cert);
    	if (ctx->enterprise_creds_params.client_key!=NULL) {
    		Util_afree(ctx->enterprise_creds_params.client_key);
    	// Ensure all null and 0 len
    	memset(&ctx->enterprise_creds_params, 0, sizeof(struct wifi_enterprise_creds_params));
    	// Load creds from /certs/wifi/<filename in config>
    	if ((ctx->enterprise_creds_params.ca_cert = _load_pem(ca_cert_name, &ctx->enterprise_creds_params.ca_cert_len))==NULL) {
    		log_warn("netwifi: no CA cert found @[%s]", ca_cert_name);
    		return false;
    	if ((ctx->enterprise_creds_params.client_cert = _load_pem(client_cert_name, &ctx->enterprise_creds_params.client_cert_len))==NULL) {
    		log_warn("netwifi: no client cert found @[%s]", client_cert_name);
    		return false;
    	if ((ctx->enterprise_creds_params.client_key = _load_pem(client_key_name, &ctx->enterprise_creds_params.client_key_len))==NULL) {
    		log_warn("netwifi: no client key found @[%s]", client_key_name);
    		return false;
    	int retreq = net_mgmt(NET_REQUEST_WIFI_ENTERPRISE_CREDS, ctx->iface, &ctx->enterprise_creds_params, sizeof(struct wifi_enterprise_creds_params));
    	if (retreq!=0) {
    		log_warn("netwifi: Failed to set Wi-Fi enterprise credentials: %d", retreq);
    		return false;
    	log_cpdbg("netwifi: set Wi-Fi enterprise credentials: %d", retreq);
    	return true;
    #else
    	log_warn("netwifi: Wi-Fi enterprise but not built with code!");
    	return false;
    The certificates seem to be maybe the issue for the shell (0x3d00 error)
    the root CA (ca.pem)
    -----BEGIN CERTIFICATE-----
    MIIDdzCCAl+gAwIBAgIUSPHDcjKwnzJwpPNKqqJ9CZ6z8y0wDQYJKoZIhvcNAQEL
    BQAwSzELMAkGA1UEBhMCRlIxEjAQBgNVBAgMCUZpbmlzdGVyZTERMA8GA1UECgwI
    SW5mcmFmb24xFTATBgNVBAMMDGluZnJhZm9uLmNvbTAeFw0yNTA2MDMwODU5MzRa
    Fw0yNTA3MDMwODU5MzRaMEsxCzAJBgNVBAYTAkZSMRIwEAYDVQQIDAlGaW5pc3Rl
    cmUxETAPBgNVBAoMCEluZnJhZm9uMRUwEwYDVQQDDAxpbmZyYWZvbi5jb20wggEi
    MA0GCSqGSIb3DQEBAQUAA4IBDwAwggEKAoIBAQDIsfqHWTOvEbipYL/ReZGcuYZ/
    QTtzdqZvOUE10121QDM9yCIEN1xzcq16Dlfs+HmrXSFmHSZhMK2xrnd59DzuyDq5
    snQg2BPfEJUqxDJg+ON055j57GXp8dUKZrCY9VSZa17jtJHYThYZpUoxqDjFlWvO
    Shqcw/9rkf3z+/6nCF1uNV7vwife4mo1okY4SNUuxPBiEhZBZOg6d5Ydb0fxsxYj
    qMN+vu3ELHPnHzzcEMzY/iA5qahPigACbm4NwXRrfdvTFfcqgJ43WWZr9FLlj3TO
    5BX1HHYRerI+MhPIK/PJmQbbJy4VC91Z414XJElXAya5myMmwd8qDFc9NQqRAgMB
    AAGjUzBRMB0GA1UdDgQWBBSNNMZnwGIr73sGUr5ZcccVGkD3LTAfBgNVHSMEGDAW
    gBSNNMZnwGIr73sGUr5ZcccVGkD3LTAPBgNVHRMBAf8EBTADAQH/MA0GCSqGSIb3
    DQEBCwUAA4IBAQBOyrJ2iQpkycm0gsL+Z/Ueu3BA1sUGUC3cbIeluuPybzmsjTrA
    dqnaymJJbcRz+Ge39VpZpeVrQO5IwVLAWrzg2Vyyyv5uOdf2VjakfUlneAF0U+zK
    nZaaaLdwjj93wV14U+8JGF1Lb6Q41+fjQ5eIF/1OtV4gI8G9qQ46TwTsR+DSkKol
    Z/5AOWkg4TarfKzghS7O6llwV+mfwXKQtsQbGQVhscXKRsAVPE/OaqkYCSXgLRTf
    5pcYCeRky/fhUJV6BKy4VLac40u5luKOGSjNV4Ycnqr0o4vIexuPCKw21cCpGqnk
    11Y85cQqpF2DzU7gFW/ovVGl2ygcjjjeVg3V
    -----END CERTIFICATE-----
    The client key (client_key.pem)
    -----BEGIN RSA PRIVATE KEY-----
    Proc-Type: 4,ENCRYPTED
    DEK-Info: DES-EDE3-CBC,5BD79331E8C31EE0
    dBjnzKTP9Ww1RSJYxgExTmMvPKb2iWPjNw6tYbzXS+LrvecHZ7rhb9zUq3Giouwq
    PJ0Hv2XC8gzWqHvcaXHNytOYlvPzVMJqeoK3HRgTJi5v4ywBj73/Q9uKXPOQ1sFY
    N81ZJjIBDuGk0xMtlP4UJ6qGXrgEUzo/HgXN0mtdqDt8OFiVq9J1PztiYBCn0vpj
    VYBnwPCkBF/nngxMPKjsbWhFRXnANkwWluRI+R2fH+JjrYEars2LVThidWjCx3ej
    9Y9Ih9yE217/+ONWBDCgjs8Dh+rgMnvMsA13siwLfyXRfZvoC0Lymt17dvsDiaAc
    FTDB9gNtUh7ZnNoQ/7outlgcn9cRTAHVjq2dG5qO5KBwFCmU5RYBGK1uu43lpuL/
    08pGvCwJ7u4UCoLjk7Q68kAcBqCmqPX3Y9Qk4zgVMeXOeiA969t4VbNaUNq2ri2q
    fxH0Lbl34b3FGt/F9j9bCYdYak0V0846bC8jCOT5dMwz05bBvG1+5Erw2NCk9k2L
    B9ovTQeLdchFoJNrl9nPkh0ipxvtlyzyJLvKjJ0RGJJytkAbI173+OM7cQgsq1uz
    iOrY/f/cKEzyltpISZfARPmpzh/HflIGiiqpsv//0ITIl2X40RyNBXU7iTVKoMob
    4yuNDVQCoOXjyosJ6rir9Ou39BWY0qiY5njyXHrannMmjCeN9xcIztEN1TF1m6+Z
    znqhkc8e+fQlPIVNM15wH+WEw5egZSUWMDU3g8AsxiLxiRe/zdTnpXe+0hbAH4s+
    7iYes1/yD2p0rOTAh3Sg0htBXnUUK6M/OXTtcantG1SmwvENSV13rPXsTTnPhgIl
    GdGg/jGjW23iU6ztEkKEO/2v5+5wFNmFFrDAY5Pl3jElnoFwEnnA/n8ndCfboB+r
    wQJYrrU8WP1BsaEFrdU/yZuHqfO9Z3fFG/BqPUTe9MGksJF921ID3fDTdeo8RGY3
    leuDjiXRISgEc8a7BE0NYnkNnMMkKNkfa0zbgRJMg9NfJjNh+MsvesDUexwEgUOK
    2eRvVuXcyhFZ+SyN3ijY7EmGAGgCMI9FEQ+HbOZa+nQeUw1Rks8vZPYHPdHPYfac
    Hn+DyGZ4tpeMFEIzdjennEwEQj7uW7kB5eZvWp7kTpXbxZMI785ZGnS2Pfe1V9v5
    y6+PGvuBvkSdIKwtQDXyAd8WdnjVmBpfb/kFbpWqC8PytPr1bsMd6YPyaNo6pP/8
    fLmZ103gO5PFYathFRCV2/W/xsjunvLC1jt+og6iSzxzboFDhpO6Y2M6RsTjhk4c
    ybKfNt0UbLH5LW1+XYdqdLGSecefe6NBq/OWxkhXs9Om79Sv1+1qPoajVe+oIB2B
    MxcR78V8eE3OoymAT7mWAqiGokukFtMEaHbtkZtjBOEkLvVdiSG6y4uS2c6yE/e0
    chLwuCNgIa+uoHVh5Osc70RlRbhfkxzR3rkZxDeniIxCokO6iIi12l357mja2TM0
    uE8D2QMc16nvg9IsFy7bMc5Ehf6TSEmAfDhHTGDmpEEK/lEqIUSH0QeGVXh8w6ge
    Viy3qzpFg9ddjGIXl2TJt8nrWMqdMFvZMrHGKXRKujXLsctEB5FbeQ==
    -----END RSA PRIVATE KEY-----
    and the client signed certificate (client.pem)
    MIIDKDCCAhACFA36ysYJv6exm5n1jADbn3MLNCyrMA0GCSqGSIb3DQEBCwUAMEsx
    CzAJBgNVBAYTAkZSMRIwEAYDVQQIDAlGaW5pc3RlcmUxETAPBgNVBAoMCEluZnJh
    Zm9uMRUwEwYDVQQDDAxpbmZyYWZvbi5jb20wHhcNMjUwNjAzMDkxMDA5WhcNMjUw
    NzAzMDkxMDA5WjBWMQswCQYDVQQGEwJGUjESMBAGA1UECAwJRmluaXN0ZXJlMREw
    DwYDVQQKDAhJbmZyYWZvbjENMAsGA1UECwwEVGVzdDERMA8GA1UEAwwIY2MyLTAw
    NGEwggEiMA0GCSqGSIb3DQEBAQUAA4IBDwAwggEKAoIBAQC7bN5Jy8kx7z3LU/qH
    IO1+QR/hjtx3sHQKp4ni6m+Mqv/PElxWEaxx8D3NThMmftGvDEbkDaV1G10KZODL
    maY0ExsUnaTewgk+nBs0rMfsJnbhxMBiaFstHYKPsqAF4JtvdKfTN05BkHDDHULI
    5N5DXP2Orty2Lh5866JfNywmDbcamDrbp1TcpJL7atc7ukrkPwZZU0tA9YAnkeYj
    sd9R/TUNA7UEo7wb4a+r+xiv+ECrzK5KJz+icYgQPbF52PFVrJX8rG/PrSqZGsr9
    XhWoZF7MzlmYRmqZijbB0khVHFn0x5lsXYyQL+5AXeoF/SbPFC65/qLdWTZSXWrr
    5RFdAgMBAAEwDQYJKoZIhvcNAQELBQADggEBAIai4nNCWtX+94jeX00a36qUffPW
    +neYi3aVZU9xestlvLhjhSf9bU5MO7w8JnRQaIzd2jh3NV+Ab4Yizrn7Zmr3bARY
    VPs1Uswf2HHoS5YIJqF/us6Px1wljNWi7hspyPpwFKPIWMXvMfAO4ZT+5mQ7ksYR
    aS3MuervINOwa166Sb64JgwQ9bWabKX14Wj03/VrVIkxzVzQjVsFFEH9abepao7w
    WQhxl3Sl+dFHH0IuGMC2cABhW69EynsF7LxvKZwFhgksVblHubOg6Ekq2KI79Mj8
    Su1KG4PXt8UX0scIn2Z8amxIHj+t2jz5+IYw0MDPHYtBMm9MPZkOBqmG1bk=
    I don't see any issue with these but maybe something isn't dealt with by the mbedtls parser?
    thanks!
    Marte is currently out, I think it's best she looks into this when she is back. I expect in a few days.
    Kenneth
    Can you try adding this to _connect_wpa2_eap()?
    params->eap_ver = 1;
    I also see that you used anon-id in your shell command, but not in _connect_wpa2_eap(). Do you see any difference if you add this as well?
    ctx->cnx_params.anon_id = anon_id;
    ctx->cnx_params.aid_length = strlen(ctx->cnx_params.anon_id);
    Make sure to fill anon_id with something like you did in the shell command.
    If you decide to use v3.0.0, you can try to providing the certificates during runtime using the script in Run time certificates. Then connect to the network by calling _connect_wpa2_eap(). This will let you check if providing the certificates or the connection is the issue.
    Do you have a computer with Linux? If so, can you try to get a sniffer log? If you need instructions for how to do this, let me know.
    Marte
