Why project config is not finding relative path of these files but absolute path works fine:
Let me check with out Matter team.
Edvin
Hi Edvin
Any update on this?
Sorry for the late reply.
Our Matter team said:
If they are using our factory-data solution the base path is set to the ncs\modules\lib\matter\config\nrfconnect\chip-module, because it uses the origin of the CMake script. So if they provide "certs/Chip-DAC-Cert.der", it will point to ncs\modules\lib\matter\config\nrfconnect\chip-module\certs\Chip-DAC-Cert.der, which doesn't exist. Providing the absolute path is highly recommended in this case, instead of using relative paths.
By the way, to use custom certificates, they must set CONFIG_CHIP_FACTORY_DATA_CERT_SOURCE_USER=y as well.
Edvin
We have already set this config for custom certificates but I think there should be a way to use relative paths.
Thank you for your input! I will forward this to our developers, but as of now, it is not possible.
Edvin
