Bricked PCA10056 nrf52840 DK
I have recently bought two nrf52840dk, version 3.0.0, unboxed and plugged into usb. One would show up with a usb storage on the side and in vscode a J-link window prompted for a device update on the interface nrf5340 chip on the dk, but the other one doesn't have either. How can I factory reset the non working one? Here are some logs to show.
lsusb:
Working one:
Bus 003 Device 045: ID 1366:1061 SEGGER J-Link
Non working one:
Bus 003 Device 056: ID 1366:0101 SEGGER J-Link PLUS
dmesg messages:
Working one:
usb 3-1: new full-speed USB device number 21 using xhci_hcd
usb 3-1: New USB device found, idVendor=1366, idProduct=1051, bcdDevice= 1.00
usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
usb 3-1: Product: J-Link
usb 3-1: Manufacturer: SEGGER
usb 3-1: SerialNumber: 001050220349
cdc_acm 3-1:1.0: ttyACM0: USB ACM device
cdc_acm 3-1:1.2: ttyACM1: USB ACM device
usb-storage 3-1:1.5: USB Mass Storage device detected
scsi host0: usb-storage 3-1:1.5
scsi 0:0:0:0: Direct-Access SEGGER MSD Volume 1.00 PQ: 0 ANSI: 4
sd 0:0:0:0: Attached scsi generic sg0 type 0
sd 0:0:0:0: [sda] 21829 512-byte logical blocks: (11.2 MB/10.7 MiB)
sd 0:0:0:0: [sda] Write Protect is off
sd 0:0:0:0: [sda] Mode Sense: 0b 00 00 08
sd 0:0:0:0: [sda] No Caching mode page found
sd 0:0:0:0: [sda] Assuming drive cache: write through
sda:
sd 0:0:0:0: [sda] Attached SCSI removable disk
usb 3-1: USB disconnect, device number 21
umount: attempt to access beyond end of device
sda: rw=0, sector=0, nr_sectors = 1 limit=0
FAT-fs (sda): unable to read boot sector to mark fs as dirty
Non working one:
usb 3-1: new full-speed USB device number 23 using xhci_hcd
usb 3-1: New USB device found, idVendor=1366, idProduct=0101, bcdDevice= 1.00
usb 3-1: SerialNumber: 001050261048
usb 3-1: USB disconnect, device number 23
VSCode nrf connect extension
Working one:
Non-working one:
  • I installed linux version of https://www.nordicsemi.com/Products/Development-tools/nRF-Command-Line-Tools/Download but am having trouble getting nrfjprog command to work. I'll try the rest a few days later. Thank you.
  • I finally have time to come back to try fixing. So I have nRF Connect for desktop installed and ran Quick Start 1.3.
    Interesting to see that it can still be recognised as a nrf52840 DK but it will not go anywhere.
    Does the log ring any bell?
    2025-07-09T06:36:42.644Z INFO Initialising the bundled nrfutil device
    2025-07-09T06:36:42.658Z DEBUG Started watching devices
    2025-07-09T06:36:48.980Z INFO Using the bundled core version for nrfutil device: 8.0.0
    2025-07-09T06:36:49.054Z DEBUG Selected device: nRF52840 DK
    2025-07-09T06:36:49.094Z DEBUG Changed step: Info
    2025-07-09T06:36:49.095Z INFO Using nrfutil-device version: 2.10.2
    2025-07-09T06:36:49.096Z INFO Using nrf-device-lib version: 0.17.71
    2025-07-09T06:36:49.096Z INFO Using nrf-probe version: 0.38.0
    2025-07-09T06:36:49.096Z INFO Using JLink version: JLink_V8.18
    2025-07-09T06:37:59.285Z DEBUG Changed step: Rename
    2025-07-09T06:38:01.593Z DEBUG Changed step: Info
    2025-07-09T06:38:04.841Z DEBUG Changed step: Rename
    2025-07-09T06:38:06.285Z DEBUG Changed step: Program
    2025-07-09T06:38:18.973Z ERROR [ProbeLib] [2025-07-09 06:38:18.955244Z] Failed to initialize worker: Timed out waiting for response from worker.
    2025-07-09T06:38:23.142Z ERROR [ProbeLib] [2025-07-09 06:38:23.141505Z] Trace channel disconnected unexpectedly.
    2025-07-09T06:38:23.143Z ERROR [ProbeLib] [2025-07-09 06:38:23.142954Z] Worker terminated by signal 9.
    2025-07-09T06:38:23.143Z ERROR [ProbeLib] [2025-07-09 06:38:23.143028Z] Error output of terminated worker:
  • Fresh eyes always works!
    I got inspiration from the jlink homepage (https://www.segger.com/products/debug-probes/j-link/tools/j-link-commander/) and ran
    ./opt/SEGGER/JLink/JLinkExe
    It immediately brought up a prompt and told me its firmware needs refreshing. After that it works like the other DK.
    Cheston
    cheston@cheston:/opt/SEGGER/JLink$ ls
    DDConditionerExe        JLinkRegistration       JScopeExe
    DevProExe               JLinkRegistrationExe    JTAGLoadExe
    Doc                     JLinkRemoteServer       libjlinkarm.so
    ETC                     JLinkRemoteServerCLExe  libjlinkarm.so.8Ran
    Firmwares               JLinkRemoteServerExe    libjlinkarm.so.8.18.0
    GDBServer               JLinkRTTClient          libjlinkarm_x86.so
    JFlashExe               JLinkRTTClientExe       libjlinkarm_x86.so.8
    JFlashLiteExe           JLinkRTTLogger          libjlinkarm_x86.so.8.18.0
    JFlashSPI_CL            JLinkRTTLoggerExe       libQtCore.so
    JFlashSPICLExe          JLinkRTTViewerExe       libQtCore.so.4
    JFlashSPIExe            JLinkSTM32              libQtCore.so.4.8
    JLinkConfigExe          JLinkSTM32Exe           libQtCore.so.4.8.7
    JLinkExe                JLinkSWOViewer          libQtGui.so
    JLinkGDBServer          JLinkSWOViewerCLExe     libQtGui.so.4
    JLinkGDBServerCLExe     JLinkSWOViewerExe       libQtGui.so.4.8
    JLinkGDBServerExe       JLinkUSBWebServerExe    libQtGui.so.4.8.7
    JLinkGUIServerExe       JLinkXVCDServerExe      Samples
    JLinkLicenseManager     JMemExe                 Script
    JLinkLicenseManagerExe  JRunExe                 x86
    cheston@cheston:/opt/SEGGER/JLink$ ./JLinkExe
    SEGGER J-Link Commander V8.18 (Compiled Mar  5 2025 14:47:32)
    DLL version V8.18, compiled Mar  5 2025 14:46:29
    Connecting to J-Link via USB...Updating firmware:  J-Link OB-nRF5340-NordicSemi compiled Feb 11 2025 17:15:35
    Replacing firmware: J-Link OB-nRF5340-NordicSemi compiled May 18 2021 BTL
    Waiting for new firmware to boot
    New firmware booted successfully
    O.K.
    Firmware: J-Link OB-nRF5340-NordicSemi compiled Feb 11 2025 17:15:35
    Hardware version: V1.00
    J-Link uptime (since boot): 0d 00h 00m 00s
    S/N: 1050261048
    License(s): RDI, FlashBP, FlashDL, JFlash, GDB
    USB speed mode: Full speed (12 MBit/s)
    VTref=3.300V
    Type "connect" to establish a target connection, '?' for help
    J-Link>
