MISO line mimics the MOSI line in SPIM configuration sdk 17.1.0
When I looked at the SPI lines using the oscilloscope, I saw that the MISO line had the same signal as the MOSI line. As you can see from the image, basically SPI configuration works properly. Before message transfer CS pin goes low, and after that, the MOSI line works. I can read message that I sent using the oscilloscope.
What can be the problem with the MISO line signal reflecting the MOSI line signal? The SPI config stage CPOL = 0, CPAH = 1, I am using a 2 MHz clock signal. Thanks for your help.
  • Well, .. it is not very clear how you are powering the board. Maybe you could measure AVDD and AVSS & AGND which I think you are assuming are 3V and 0V.
    JP2 VDD supplied from the 3rd pin That is 2.5V (or 5V) which requires an external 5V (Vcc_5V). Did you mean to supply 3V to JP2 middle (2nd) pin to provide 3V on AVDD?
    JP20 1-2 (GND) Does that mean an external wire to pin 2? AVSS must also be connected to AGND (or 2.5V which doesn't exist if there is no 5V) which looks like pin 2 to pin 3 not 1-2 (the schematic doesn't exactly make pin numbers clear)
    J3 connections? Why are these not all detailed
    JP21 1-2 means SPI_CS is on J3 pin 1
    JP22 2-3 means SPI_START is on J3 pin 14
  • Hi   thanks for your answer.  Yes, when I measure the voltage between AVSS, AVDD I see 3V.
    I didn't have a 5V external power supply and yes, I connect my 3V power supply to the VCC_5V side, not to the 2nd leg.
    JP20 1-2 means they are shorted. In the image I shared before, when I connected pins 1-2 together, AVSS was connected to GND. I did not share J3 part because there is no challenging part in there, I connected them directly to the microcontroller side defined pins.
  • The symmetric voltage supply on the EK board can accept anything from ~3V to 5V DC and provide stable symmetric 2.5V to the chip (as long as the source can supply roughly 50mA). Adjust your jumpers to use the outputs from the LDOs, your description does not sound correct to me.
    It may be a good idea to draw your own schematic that includes the connections to the STM/NRF board(s).
    The ADS1299 absolutely refuses to work when the analog voltages or the pin config is not 100% correct.
  • Thank you for your help  and  . I haven't made any progress in this section so far. I think this is because I have problems feeding the ADS1299, and therefore, I can't communicate. While working on the coding, I also designed a PCB with the ADS1299 chip and the nRF52840 module as suggested by TI, and it arrived.
    I made the connections on the ADS1299 chip as follows:
    ADS1299 ------------------------- nRF52
    AVDD                                     VDD
    DVDD                                     VDD
    AVSS                                      GND
    CLKSEL                                  VDD
    DAISYIN                                 GND
    DRDY                                     P0.12
    SCK                                        P0.13
    MISO                                      P0.14
    MOSI                                      P0.15
    CS                                          P0.16
    START                                    P0.17
    RESET                                   P0.19
    PWDN                                    P0.20
    I measured the VCAP1 voltage, and it is above 1.1V, but I still cannot establish communication. ADS1299 returns 0x00 as a result. This is the latest library code that I created.
    #include "ADS1299_nRF.h"
    #include <nrf.h>
    #include <nrf_log.h>
    #include <nrf_log_ctrl.h>
    #include <nrf_log_default_backends.h>
    #include <nrf_gpio.h>
    #include <nrf_delay.h>
    #include "ads1299_delay.h"
    #include "nrfx_spim.h"
    // Enable polling mode for DRDY
    #define POLL_DREADY
    #define SPIM2 NRF_SPIM2
    #define ADS_POWER_RAMP_TIME_MSECS 30 // Delay for regulator to stabilize
    bool new_data_available = false;
    uint8_t rx_buffer[27], tx_buffer[8];
    uint8_t sample_number = 0;
    static uint8_t regData[24]; // Mirror of ADS1299 registers
    /** @brief SPI interface initialization. Accurate timing use HFCLK clock */
    void spi_init(void) {
        // Start HFCLK source for accurate timing
        while (NRF_CLOCK->EVENTS_HFCLKSTARTED == 0);
        // Disable SPIM to configure it
        SPIM2->ENABLE = (SPIM_ENABLE_ENABLE_Disabled << SPIM_ENABLE_ENABLE_Pos);
        // Configure SPIM2 pins
        SPIM2->PSEL.SCK = ((PIN_SCK << SPIM_PSEL_SCK_PIN_Pos) |
                            (0 << SPIM_PSEL_SCK_PORT_Pos) |
                            (SPIM_PSEL_SCK_CONNECT_Connected << SPIM_PSEL_SCK_CONNECT_Pos));
        SPIM2->PSEL.MOSI = ((PIN_MOSI << SPIM_PSEL_MOSI_PIN_Pos) |
                            (0 << SPIM_PSEL_MOSI_PORT_Pos) |
                            (SPIM_PSEL_MOSI_CONNECT_Connected << SPIM_PSEL_MOSI_CONNECT_Pos));
        SPIM2->PSEL.MISO = ((PIN_MISO << SPIM_PSEL_MISO_PIN_Pos) |
                            (0 << SPIM_PSEL_MISO_PORT_Pos) |
                            (SPIM_PSEL_MISO_CONNECT_Connected << SPIM_PSEL_MISO_CONNECT_Pos));
        SPIM2->FREQUENCY = SPIM_FREQUENCY_FREQUENCY_M4; // 2 MHz (t_CLK = 500 ns)
        SPIM2->ORC = 0xFF;
        // ADS1299 set Data mode: clock polarity = 0, clock phase = 1
        SPIM2->CONFIG = (SPIM_CONFIG_CPOL_ActiveHigh << SPIM_CONFIG_CPOL_Pos) |  // CPOL = 0
                        (SPIM_CONFIG_CPHA_Trailing << SPIM_CONFIG_CPHA_Pos) |     // CPHA = 1
                        (SPIM_CONFIG_ORDER_MsbFirst << SPIM_CONFIG_ORDER_Pos);
        SPIM2->EVENTS_END = 0;
        SPIM2->EVENTS_ENDTX = 0;
        SPIM2->EVENTS_ENDRX = 0;
        SPIM2->INTENCLR = 0xFFFFFFFFUL;
        SPIM2->INTENSET = 0x040;
        SPIM2->ENABLE = (SPIM_ENABLE_ENABLE_Enabled << SPIM_ENABLE_ENABLE_Pos);
    void gpio_init(void)
        //NRF_P0->PIN_CNF[CS_PIN]   = 0x301;  // output, high drive high and low H0H1
        //NRF_P0->PIN_CNF[PIN_SCK]  = 0x301;  // output, high drive high and low H0H1
        //NRF_P0->PIN_CNF[PIN_MOSI] = 0x301;      // output, standard drive S0S1
        //nrf_gpio_cfg(PIN_MISO, NRF_GPIO_PIN_DIR_INPUT, NRF_GPIO_PIN_INPUT_DISCONNECT, NRF_GPIO_PIN_NOPULL, NRF_GPIO_PIN_H0H1, NRF_GPIO_PIN_NOSENSE);
        nrf_gpio_cfg(PWDN_PIN, NRF_GPIO_PIN_DIR_OUTPUT, NRF_GPIO_PIN_INPUT_DISCONNECT, NRF_GPIO_PIN_NOPULL, NRF_GPIO_PIN_H0H1, NRF_GPIO_PIN_NOSENSE);
        nrf_gpio_cfg(RESET_PIN, NRF_GPIO_PIN_DIR_OUTPUT, NRF_GPIO_PIN_INPUT_DISCONNECT, NRF_GPIO_PIN_NOPULL, NRF_GPIO_PIN_H0H1, NRF_GPIO_PIN_NOSENSE);
        nrf_gpio_cfg_input(PIN_DRDY, GPIO_PIN_CNF_PULL_Pullup);
        nrf_gpio_pin_clear(CS_PIN);
        nrf_delay_ms(50);
        nrf_gpio_pin_set(CS_PIN);
        nrf_delay_ms(10);
    static void spi_uninit(void) {
        nrf_gpio_cfg_input(PIN_SCK, NRF_GPIO_PIN_NOPULL);
        nrf_gpio_cfg_input(PIN_MOSI, NRF_GPIO_PIN_NOPULL);
        nrf_gpio_cfg_input(PIN_MISO, NRF_GPIO_PIN_NOPULL);
    bool spi_transfer_byte(uint8_t *tx, uint8_t *rx, size_t len) {
        if (!(SPIM2->ENABLE & SPIM_ENABLE_ENABLE_Msk)) {
        SPIM2->TXD.PTR = (uint32_t)tx;
        SPIM2->TXD.MAXCNT = len;
        SPIM2->RXD.PTR = (uint32_t)rx;
        SPIM2->RXD.MAXCNT = len;
        SPIM2->TASKS_START = 1;
        while (!SPIM2->EVENTS_END);
        SPIM2->TASKS_STOP = 1;
        while (!SPIM2->EVENTS_STOPPED);
        NRF_LOG_INFO("SPI TX: 0x%02x, RX: 0x%02x", tx[0], rx ? rx[0] : 0);
        return true;
    bool spi_transfer_bytes(const uint8_t *tx, uint8_t *rx, size_t len) {
        static uint8_t dummy_tx = 0xFF;
        static uint8_t dummy_rx;
        SPIM2->TXD.PTR = (uint32_t)(tx ? tx : &dummy_tx);
        SPIM2->RXD.PTR = (uint32_t)(rx ? rx : &dummy_rx);
        SPIM2->ENABLE = SPIM_ENABLE_ENABLE_Disabled; // Disable SPIM to allow pull-up to take effect
        return true;
    void ADS1299_pwr_up_seq(void) {
        nrf_gpio_pin_set(PWDN_PIN); // Power on
        nrf_gpio_pin_set(RESET_PIN); // Reset low
        nrf_delay_ms(150);          // Wait for tPOR
        nrf_gpio_pin_clear(RESET_PIN); // Reset low
        nrf_delay_us(2);             // ≥2 clock cycles
        nrf_gpio_pin_set(RESET_PIN);  // Reset high
        nrf_delay_ms(10);              // Stabilization
    void Reset_ADS(void)
    	nrf_delay_us(100000);
    	nrf_gpio_pin_clear(PWDN_PIN);
    bool ADS1299_init(void) {
        // Recommended power-up sequence for ADS1299
        NRF_LOG_INFO("Initializing ADS1299");
        //Reset_ADS();
        ADS1299_pwr_up_seq();
        NRF_LOG_INFO("SPI init success");
    #ifdef POLL_DREADY
        NRF_LOG_INFO("DRDY polling enabled");
    #else
        NRF_LOG_INFO("DRDY interrupt not implemented");
        return true;
    void poll_dready(void) {
    #ifdef POLL_DREADY
        NRF_LOG_INFO("Polling DRDY, state: %d", nrf_gpio_pin_read(PIN_DRDY));
        if (nrf_gpio_pin_read(PIN_DRDY) == 0) {
            NRF_LOG_INFO("DRDY low, receiving data");
            ADS1299_receive_data();
            send_new_available_data();
    bool ADS1299_write_register(uint8_t address, uint8_t value) {
        uint8_t cmd[] = {
            (uint8_t)(address | COMMAND_WREG),
            0x00, // Write 1 register
            value
        nrf_delay_us(2); // t_CSSC: Delay from CS low to first SCLK (min 6 ns, use 50 ns for safety)
        spi_transfer_byte(cmd, NULL, 3);
        nrf_delay_us(2); // t_CSH: Delay from last SCLK to CS high (min 1 µs)
        nrf_delay_us(1); // t_CSH hold time after CS high
        regData[address] = value;
        return true;
    uint8_t ADS1299_read_reg(uint8_t address) {
        uint8_t tx_data = 0x20 | address;  // RREG command (0x20) + address
        uint8_t dummy = 0x00;
        uint8_t rx_data = 0;
        // Pull CS low to start transaction
        // Send RREG command + address (transmit only)
        spi_transfer_byte(&tx_data, NULL, 1);
        nrf_delay_us(2);
        // Send dummy byte and receive register data
        spi_transfer_byte(&dummy, &rx_data, 1);
        nrf_delay_us(2);
        // Pull CS high to end transaction
        // Store in global array if you're using it
        regData[address] = rx_data;
        return rx_data;  // Return the register value directly
    bool ADS1299_send_command(uint8_t command) {
        uint8_t dummy;
        spi_transfer_byte(&command, NULL, 1);
        nrf_delay_us(2);
        nrf_delay_us(2); // t_CSH hold time after CS high
        return true;
    bool ADS1299_send_start(void) {
        bool result = ADS1299_send_command(COMMAND_START);
        return result;
    bool ADS1299_send_read_continuous(void) {
        bool result = ADS1299_send_command(COMMAND_RDATAC);
        nrf_delay_us(3); // Allow RDATAC to settle
        return result;
    bool ADS1299_send_reset(void) {
        bool result = ADS1299_send_command(COMMAND_RESET);
        NRF_LOG_INFO("Reset command sent, result: %d", result);
        return result;
    bool ADS1299_send_sdatac(void) {
        bool result = ADS1299_send_command(COMMAND_SDATAC);
        NRF_LOG_INFO("Stop read continuously command sent, result: %d", result);
        return result;
    bool ADS1299_receive_data(void) {
        if (!spi_transfer_bytes(NULL, rx_buffer, 27)) {
            NRF_LOG_ERROR("Failed to receive data");
            return false;
        new_data_available = true;
        NRF_LOG_INFO("Data received, triggering send_new_available_data");
        return true;
    bool ADS1299_poll_new_data(ADS1299_data_t *data) {
        if (new_data_available) {
            *data = ADS1299_convert_data();
            return true;
        return false;
    static inline int32_t buffer_to_channel(uint8_t id) {
        int32_t value = (rx_buffer[3 + id * 3] << 16) | (rx_buffer[4 + id * 3] << 8) | rx_buffer[5 + id * 3];
        if (value & 0x00800000) {
            value |= 0xFF000000;
        } else {
            value &= 0x00FFFFFF;
        return value;
    ADS1299_data_t ADS1299_convert_data(void) {
        ADS1299_data_t data;
        data.lead_off_positive = rx_buffer[0] << 4;
        data.lead_off_positive |= (rx_buffer[1] & 0b11110000) >> 4;
        data.lead_off_negative = rx_buffer[1] << 4;
        data.lead_off_negative |= (rx_buffer[2] & 0b11110000) >> 4;
        data.gpio_0 = rx_buffer[2] & 0b00001000;
        data.gpio_1 = rx_buffer[2] & 0b00000100;
        data.gpio_2 = rx_buffer[2] & 0b00000010;
        data.gpio_3 = rx_buffer[2] & 0b00000001;
        data.channel_0 = buffer_to_channel(0);
        data.channel_1 = buffer_to_channel(1);
        data.channel_2 = buffer_to_channel(2);
        data.channel_3 = buffer_to_channel(3);
        data.channel_4 = buffer_to_channel(4);
        data.channel_5 = buffer_to_channel(5);
        data.channel_6 = buffer_to_channel(6);
        data.channel_7 = buffer_to_channel(7);
        return data;
    void send_new_available_data(void) {
            NRF_LOG_INFO("Sample: %d", sample_number++);
            for (uint8_t i = 0; i < 27; i++) {
                NRF_LOG_INFO("Byte %d: 0x%02x", i, rx_buffer[i]);
    This is the main part.
    #include <nrf.h>
    #include "nrf_delay.h"
    #include "nrf_gpio.h"
    extern bool new_data_available;
    int main(void) {
        NRF_LOG_INIT(NULL);
        NRF_LOG_INFO("Starting ADS1299 initialization");
        gpio_init();
        spi_init();
        if (!ADS1299_init())
            NRF_LOG_ERROR("ADS1299 init failed");
            while (1) {
                //nrf_gpio_pin_toggle(LED_PIN);
                NRF_LOG_FLUSH();
                nrf_delay_ms(200);
        ADS1299_send_reset();
        nrf_delay_ms(1);
        ADS1299_send_sdatac();
        uint8_t id = 0x00;
        id = ADS1299_read_reg(ID);
        if (id == 0x3E)
            NRF_LOG_INFO("ADS1299 communication success, ID: 0x%02x", id);
            NRF_LOG_INFO("ADS1299 communication fail, ID: 0x%02x", id);
    Thank you for your suggestions and help so far. It would be easier to reach the problem through a card that has been put together rather than trying to debug the problem through DK.
  • Re-read the ADS1299 datasheet. It clearly stated in chapter 7.3 that you need at least 4.75V between AVDD and AVSS.
    Unsurprisingly the chip won't work when your supply is significantly below that.
    Sounds like you need to redesign your board...
