NRF52840
S140
App based on ble_app_multilink_central.
I have tried to build a bridge between BLE peripheral and PC.
I have spend so many time on PC side app.
The problem is the COM port will close in the middle if there are many packets to send.I didn't think of MCU side problem,after many failure I thought of checking NRF52840,it did trigger the error in the title and reset. That close the com connection,and the com port gets ready soon before I can notice it.
I have browsered the devzone,and found many post mang years ago.
This is the solution:
//From
if (err_code == NRF_ERROR_BUSY) // Softdevice is processing another GATT request.
NRF_LOG_DEBUG("SD is currently busy. The GATT request procedure will be attempted \
again later.");
//to
if (err_code == NRF_ERROR_BUSY) || (err_code == NRF_ERROR_RESOURCES) // Softdevice is processing another GATT request.
again later.");
I don't want to change the SD code, it is not easy to maintain.Can I check first and then try to write? or Just not to reset system, ignore the data?
Thank you
