Matter + OpenThread + PSA (Oberon): Crypto/Memory Optimization + mbedTLS Logging
currently i am configuring the networking stack on my project.
The goal is to use Matter's built-in Thread connection, to establish a Secure CoAP connection.
I am trying to use PSA + Oberon to have access to hardware accelerated crypto modules.
My current configuration is compiling, but it seems so redundant to me. CHIP/Matter and OpenThread are relying on legacy MBEDTLS functions, so i have to enable legacy support in my config:
### CHIP Configurations
# Enable CHIP
CONFIG_CHIP=y
CONFIG_CHIP_PROJECT_CONFIG="include/chip_project_config.h"
# 32768 == 0x8000 (example Product ID, should be changed with proper PID)
CONFIG_CHIP_DEVICE_PRODUCT_ID=32774
### General Settings
CONFIG_STD_CPP17=y
CONFIG_NEWLIB_LIBC=y
# Enable Matter pairing automatically on application start
CONFIG_CHIP_ENABLE_PAIRING_AUTOSTART=y
# Enable Matter extended announcement and increase duration to 1 hour
CONFIG_CHIP_BLE_EXT_ADVERTISING=y
CONFIG_CHIP_BLE_ADVERTISING_DURATION=60
# Add support for LEDs and buttons on Nordic development kits
CONFIG_DK_LIBRARY=y
# Bluetooth Low Energy configuration
CONFIG_BT_DEVICE_NAME="MatterTemplate"
# Other settings
CONFIG_THREAD_NAME=y
CONFIG_MPU_STACK_GUARD=y
CONFIG_RESET_ON_FATAL_ERROR=n
CONFIG_CHIP_LIB_SHELL=n
CONFIG_NCS_SAMPLE_MATTER_TEST_SHELL=n
# Disable NFC commissioning
CONFIG_CHIP_NFC_COMMISSIONING=n
# Reduce application size
CONFIG_USE_SEGGER_RTT=n
# Enable Factory Data feature
CONFIG_CHIP_FACTORY_DATA=y
CONFIG_CHIP_FACTORY_DATA_BUILD=y
# Enable assertions
CONFIG_ASSERT=y
# Enable Bootloader
CONFIG_BOOTLOADER_MCUBOOT=y
### Security Configurations
CONFIG_NRF_SECURITY=y
### Crypto Configurations
CONFIG_CHIP_CRYPTO_PSA=y
CONFIG_MBEDTLS_SSL_PROTO_DTLS=y
CONFIG_MBEDTLS_KEY_EXCHANGE_ECDHE_ECDSA_ENABLED=y
CONFIG_OPENTHREAD_CRYPTO_PSA=y
# PSA configurations for algorithms
CONFIG_PSA_WANT_ALG_GCM=y
CONFIG_PSA_WANT_ALG_JPAKE=y
CONFIG_PSA_WANT_ALG_ECDSA=y
CONFIG_PSA_WANT_KEY_TYPE_ECC_PUBLIC_KEY=y
CONFIG_PSA_WANT_ECC_SECP_R1_256=y
CONFIG_PSA_CRYPTO_DRIVER_OBERON=y
# Enable mbedTLS integration with PSA
CONFIG_MBEDTLS_LEGACY_CRYPTO_C=y
CONFIG_MBEDTLS_PSA_CRYPTO_C=y
CONFIG_MBEDTLS_ECP_C=y
CONFIG_MBEDTLS_PK_C=n
CONFIG_MBEDTLS_TLS_LIBRARY=n
CONFIG_MBEDTLS_X509_LIBRARY=n
# Enable mbedTLS support for public key cryptography (PK)
CONFIG_MBEDTLS_RSA_C=y
CONFIG_MBEDTLS_ECDSA_C=y
# Increase MBEDTLS heap size to enable dtls handling
CONFIG_MBEDTLS_HEAP_SIZE=16384
### CoAP Configurations
CONFIG_COAP=y
CONFIG_COAP_UTILS=y
### Connectivity Configurations
# OpenThread configurations
CONFIG_OPENTHREAD_COAPS=y
CONFIG_OPENTHREAD_COAP=y
CONFIG_OPENTHREAD_SOURCES=y
### NFC Configurations
CONFIG_NFC_PLATFORM=n
### OpenThread Shell Configurations
CONFIG_OPENTHREAD_SHELL=n
# CONFIG_OPENTHREAD_MBEDTLS=n
CONFIG_OPENTHREAD_NRF_SECURITY_PSA_CHOICE=y
CONFIG_NRF_OBERON=y
# enable monitor debug mode
CONFIG_CORTEX_M_DEBUG_MONITOR_HOOK=y
CONFIG_SEGGER_DEBUGMON=y
CONFIG_DEBUG_THREAD_INFO=y
CONFIG_MBEDTLS_DEBUG_C=y
CONFIG_MBEDTLS_DEBUG_LEVEL=4
CONFIG_OPENTHREAD_MBEDTLS_DEBUG=y
# Attempt to use RTT logging. Currently not feasible.
# CONFIG_USE_SEGGER_RTT=y
# CONFIG_RTT_CONSOLE=y
# CONFIG_UART_CONSOLE=n
# CONFIG_LOG_MODE_MINIMAL=n
# CONFIG_LOG_BACKEND_RTT=y
Is there another way of configuring the project to use PSA and not legacy MBEDTLS? This configuration uses 99% of my flash. Additionally i am not sure if PSA is used after all when enabling legacy mbedtls?
Also i have one more question regarding logging:
I see CHIP logs and my user LOG_INF in the serial console, but i cant get MBEDTLS logging to work. I want to debug my DTLS CoAP handshake on the Openthread network stack. Is there more needed than configuring:
Thanks for your help!
Best Jonas
  • Could i get an answer on this please? Slight smile I am unsure about this configuration using MBEDTLS and PSA in tandem...
    Essentially through CONFIG_CHIP_CRYTO_PSA=y (which should be default as i understood?) Matter should always use PSA instead of MBEDTLS. Still my Code wont compile without CONFIG_MBEDTLS_LEGACY_CRYPTO_C=y
    ../../../../../modules/lib/matter/src/crypto/CHIPCryptoPALmbedTLSCert.cpp: In function 'CHIP_ERROR chip::Crypto::VerifyCertificateSigningRequest(const uint8_t*, size_t, P256PublicKey&)':
    ../../../../../modules/lib/matter/src/crypto/CHIPCryptoPALmbedTLSCert.cpp:69:15: error: 'mbedtls_pk_ec' was not declared in this scope; did you mean 'mbedtls_pk_free'?
       69 |     keypair = mbedtls_pk_ec(csr.CHIP_CRYPTO_PAL_PRIVATE_X509(pk));
          |               mbedtls_pk_free
    ../../../../../modules/lib/matter/src/crypto/CHIPCryptoPALmbedTLSCert.cpp: In function 'CHIP_ERROR chip::Crypto::ExtractPubkeyFromX509Cert(const chip::ByteSpan&, P256PublicKey&)':
    ../../../../../modules/lib/matter/src/crypto/CHIPCryptoPALmbedTLSCert.cpp:521:15: error: 'mbedtls_pk_ec' was not declared in this scope; did you mean 'mbedtls_pk_free'?
      521 |     keypair = mbedtls_pk_ec(mbed_cert.CHIP_CRYPTO_PAL_PRIVATE_X509(pk));
          |               mbedtls_pk_free
  • Hi, so I checked with the developers:
    no it is not supported while using PSA API. This file should not be compiled while compiling firmware for a device; this part is dedicated to a Matter controller. If a customer wants to compile this file, they need to switch to MbedTLS (but in this case, they cannot inherit the Thread certificate from us).
    Jonathan
  • Thanks for the answer.
    I dont want this file to be compiled then. But why is it being compiled anyway?
    I think i have a missing link understanding the matter build in the nrf sdk.
    In build/modules/connectedhomeip/args.gn the crypto system is set to PSA:
    chip_crypto = "psa"
    Why is mbedtls being used?
    In the build files e.g.  build/modules/connectedhomeip/gen/include/crypto/CryptoBuildConfig.h mbedtls is explicitly disabled:
    #define CHIP_CRYPTO_MBEDTLS 0
    #define CHIP_CRYPTO_PSA 1
    #define CHIP_CRYPTO_PSA_SPAKE2P 1
    #define CHIP_CRYPTO_OPENSSL 0
    #define CHIP_CRYPTO_BORINGSSL 0
    #define CHIP_CRYPTO_PLATFORM 0
    still modules/lib/matter/src/crypto/CHIPCryptoPALmbedTLSCert.cpp is being compiled during matter build.
    in modules/lib/matter/cryptoBUILD.gn this block implies the file is also being used in PSA configuration:
    } else if (chip_crypto == "psa") {
      import("//build_overrides/mbedtls.gni")
      source_set("cryptopal_psa") {
        sources = [
          "CHIPCryptoPALPSA.cpp",
          "CHIPCryptoPALPSA.h",
          "CHIPCryptoPALmbedTLS.h",
          "CHIPCryptoPALmbedTLSCert.cpp",
        public_deps = [ ":public_headers" ]
        if (!chip_external_mbedtls) {
          public_deps += [ "${mbedtls_root}:mbedtls" ]
    So it seems to be correct that it is being used. Looks like matter still relies on some mbedtls functionality?
    Thanks for your time, Best Jonas
