Unable to Mount LittleFS File System On External Flash On NRF54L15-DK
Hi everyone,
I'm new to both nRF Connect SDK and Zephyr RTOS, and I’m trying to modify the official LittleFS FileSystem Sample to mount an external SPI flash as the storage backend.
So far, I haven't been successful in getting it to work.
I've attached the relevant files:
  • .overlay file with external flash node
  • prj.conf with the necessary config options
  • boards/<board_name>.yaml if needed
I'd really appreciate any advice, corrections, or working examples from anyone who has managed to get LittleFS working on external flash (especially using nordic,pm-ext-flash or similar).
Thanks in advance for your help!
Khalil
pm_static.yaml
nrf54l15dk_nrf54l15_cpuapp.conf2860.nrf54l15dk_nrf54l15_cpuapp.overlay
  • Hello Khalil,
    Could you please follow these steps:
    1. Remove your pm_static.yml from the project
    2. Build pristine once
    3. Verify that features in this build work. Stop here if this step failed.
    4. Copy the partitions.yml from that build directory as a new pm_static.yml
    5. Reconfigure the littlefs partition to external flash, remember to add some properties under the partitions as followed:
      affiliation:
        -disk
      extra_params: {
          disk_name: "littlefs",
          disk_cache_size: 4096,
          disk_sector_size: 512,
          disk_read_only: 0
      Here is an example:
      littlefs_storage:
        address: 0xe7600
        end_address: 0x800000
        region: external_flash
        device: mx25r6435f
        affiliation:
          -disk
        extra_params: {
            disk_read_only: 0
    Hieu
  • Thank you, Hieu, for your prompt response.
    I tried implementing your suggestion, but unfortunately, the modified LittleFS sample still throws the following runtime error:
    Sample program to r/w files on littlefs
    E: FAIL: unable to find flash area 1: -2
    I: littlefs partition at /lfs1
    I: LittleFS version 2.9, disk version 2.1
    E: can't open flash area 1
    E: fs mount error (-19)
    E: Automount /lfs1 failed: -19
    Below is the compiled partitions.yaml output after applying your changes:
    app:
    address: 0x0
    end_address: 0x165000
    region: flash_primary
    bootconf:
    address: 0xffd080
    end_address: 0xffd084
    region: bootconf
    external_flash:
    address: 0x6000
    littlefs_storage:
    address: 0x0
    device: DT_CHOSEN(nordic_pm_ext_flash)
    end_address: 0x6000
    placement:
    before:
    - tfm_storage
    - end
    otp:
    address: 0xffd500
    end_address: 0xffd9fc
    region: otp
    sram_primary:
    address: 0x20000000
    end_address: 0x2002f000
    region: sram_primary
    And here's the pm_static.yaml content I'm using:
    littlefs_storage:
    address: 0xe7600
    device: mx25r6435f
    affiliation:
    -disk
    extra_params: {
    disk_read_only: 0
    It’s worth noting that the generated partitions.yaml looks exactly the same even when I used a simplified pm_static.yaml like this:
    littlefs_ext_storage:
    address: 0x00000000
    placement:
    before: end
    I’m still stuck and wondering if you or anyone else could share a working sample project targeting the nRF54L15-DK that successfully mounts LittleFS on external SPI flash. That would be incredibly helpful for learning and troubleshooting.
    Thanks again for your support!
    Khalil
  • Hello Khalil,
    That was not all the steps I recommended. Could you follow them closely please?
    Hieu
  • Hi Hieu,
    Thank you for the clarification.
    I’ve carefully gone through your recommended five steps again. Below is a detailed breakdown of what I did:
    1. I removed the pm_static.yml file from the project, along with the previously added app.conf and app.overlay files, otherwise the project wouldn't buld/compile. The project is now the original LittleFS Sample project.
    2. I did a pristine build. No build errors observed
    3. I programmed the NRF54L15DK board. I could see from the consol output the internal flash is mounted correctly and the filesystem operated as expected..
    4. I copied the partitions.yml from the build directory as a new pm_static.yml into the project directory.
    5. In pm_static.yml file, I reconfigured the littlefs partition to external flash.
      app:
        address: 0x0
        end_address: 0x15f000
      bootconf:
        address: 0xffd080
        region: bootconf
      littlefs_storage:
        address: 0x00000000
        end_address: 0x00400000
        device: mx25r6435f
        affiliation:
          -disk
        extra_params: {
            disk_read_only: 0
      otp:
        address: 0xffd500
        region: otp
      sram_primary:
        address: 0x20000000
    6. The project fail to compile at this point, so I added back the app.conf and app.ovrelay files back into the project. It now compiles with the following warning :
         warning: ISO C99 requires whitespace after the macro name
         58 | #define PM_FOREACH_AFFILIATED_TO_-disk(fn)  fn(LITTLEFS_STORAGE)
    7. After flashing the console output is as follows:
      *** Booting nRF Connect SDK v3.0.1-9eb5615da66b ***
      *** Using Zephyr OS v4.0.99-77f865b8f8d0 ***
    For your reference, here's the content of the relevant files:
    app.conf:
    CONFIG_SPI=y
    CONFIG_SPI_NOR=y
    CONFIG_SPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
    CONFIG_PM_PARTITION_REGION_LITTLEFS_EXTERNAL=y
    app.overlay:
    /delete-node/ &storage_partition;
        chosen {
            nordic,pm-ext-flash = &mx25r64;
    	fstab {
    		compatible = "zephyr,fstab";
    		lfs1: lfs1 {
    			compatible = "zephyr,fstab,littlefs";
    			mount-point = "/lfs1";
    			partition = <&lfs1_partition>;
    			automount;
    			read-size = <16>;
    			prog-size = <16>;
    			cache-size = <64>;
    			lookahead-size = <32>;
    			block-cycles = <512>;
    &mx25r64 {
    	partitions {
    		#address-cells = <1>;
    		#size-cells = <1>;
    		lfs1_partition: partition@0 {
    			label = "lfs1_partition";
    			reg = <0x00000000 0x00800000>;
    Could you please advise which step or file configuration might be incorrect or incomplete?
    I'd apprecate your help in resolving this issue.
    Best Regards,
    Khalil
    P.S.:  I removed /delete-node/ &storage_partition; line from app.overlay and tried again. but still filesystem failes to mount.
  • Hello Khalil,
    My apology. It seems there was some syntax change. and the affiliation line should no longer be written the way I sent you. Could you please replace
      affiliation:
        -disk
    with
      affiliation: disk
    Please make that replacement and retry from the pm_static.yml step.
    As you are using the Partition Manager, the partitioning in the DeviceTree isn't in effect. Ref: Partition Manager.
    Hieu
