Problems building an example (matter light bulb) on a "custom board" that is identically configured as the dev kit nRF54L15DK
Hi everyone,
I'm using the nRF Connect SDK 3.0.2 and the nRF Connect Toolchain 3.0.1 with the matter ‘light_bulb’ example.
I just want to do the following:
1) Get exactly the same binary file merged.hex, but created with my own custom board files, e.g. board ‘myDK’.
2) As a second step, disable the use of the external flash memory mx25r64, creating a new partition table (just 2 smaller partitions inside the internal flash)
Sounds simple, but I'm having problems with it.
My first steps with the SDK were really promising. The examples work right away, but every change led to errors.
I've tried a lot:
Create my own board files (with VSCode-Wizzard) – within the project, outside in a separate directory. Change/create overlays and pm_static* but in the end all failed with errors regarding the mcuboot partition settings, missing arguments für --size and --offset, missing FLASH_DEVICE_ID etc.
I was working in bare metal projects for years now and wanted to see how a "state-of-the-art" SDK feel like, but it's very frustrating ...
What is the easiest way to accomplish this? Is shouldn't be that much of actions necessary!? The first part took only 2 minutes, but it does not build.
Thank you for your help!
/NoRG
  • Hi Marte,
    Thanks for your reply!
    I also managed to create the binary file.
    I used exactly your two ZIP files and added 1) a build configuration with the original DK and 2) a build configuration for the custom DK (both with proj.conf):
    -rw-r--r--@ 1 xxx  yyy  2461956  7 Jun 09:23 NordicDK/merged.hex
    -rw-r--r--@ 1 xxx  yyy  2461340  7 Jun 10:04 Custom/merged.hex
    Unfortunately, the second one does not work. The LEDs on the board remain off (LED2 does not flash and there is no UART output). I have no idea where to look next.
    Which files do you need from me to investigate the problem further?
    By the way, when I changed the original DK configuration, I even managed to change the pins and get my own board working without an external flash (using my own partition table that fits completely in the internal flash). But I really want to run both boards just by changing the board configuration and share the sources in one place.
    Best regards
    /NoRG
    This could be related to this:
    Marte Myrvold said:
    Please note that I have not enabled serial, console, or GPIO in custom_nrf54l15dk_nrf54l15_cpuapp_defconfig. If you plan to use these, I recommend adding them as in custom_nrf54l15dk_nrf54l15_cpuapp_defconfig.
    Please try adding this to custom_nrf54l15dk_nrf54l15_cpuapp_defconfig:
    # Enable UART driver
    CONFIG_SERIAL=y
    # Enable console
    CONFIG_CONSOLE=y
    CONFIG_UART_CONSOLE=y
    # Enable GPIO
    CONFIG_GPIO=y
    Marte
    I overlooked that you also mentioned the activation of the GPIOs. The serial is not necessary for the test, but without any GPIO it makes no sense at all :-)
    Unfortunately it does not work even WITH these changes.
    To try further I added more lines:
    # SPI
    CONFIG_SPI=y
    CONFIG_SPI_NOR=y
    CONFIG_SPI_NOR_SFDP_DEVICETREE=y
    CONFIG_SPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
    # required by SPI driver
    CONFIG_MULTITHREADING=y
    ... but it doesn't work either. I used to try everything possible, but it hasn't worked.
    And here is the problem: there is no inheritance of a given board configuration or a way to copy at least all configuration from an existing board. Is it possible for you to check out if the binary runs on the nRF54L15DK? In my case there is no sign of life: no flashing leds, no uart etc.
    You can also send me your binary - so I can check it out quickly!
    /NoRG
    I had to add the following:
    CONFIG_CHIP_SPI_NOR=y
    With this, the application started up. I added it in light_bulb/boards/custom_nrf54l15dk_nrf54l15_cpuapp.conf.
    Marte
  • Hi Marte,
    I really appreciate your time. I tried to repeat all your steps - but without success. Can you send me the two directories (board and light_bulb) including the binaries?
    Here are mine:
    -rw-r--r--@ 1 xxx  yyy  2461648 16 Jun 16:35 light_bulb_cust/Custom/merged.hex
    -rw-r--r--@ 1 xxx  yyy  2461956  7 Jun 09:23 light_bulb_cust/NordicDK/merged.hex
    Regards
    /NoRG
