Change Installation Path of Power Profiler
I´m trying to change the installation path of the Nordic Power Profiler as I´m running out of space.
I have about 9GB left, but when trying to open a captured file, Power Proflier says that the file does not fit in the available disk space.
I´ve already change the temp directory but it seems like the Software still relies on space on my C drive.
Is there a way to install the Software on another disk?
Thank you
  • Hi, Thank you for the questions.
    The ppk2 file is 684KB.
    I´ve installed Power Profiler on C-Drive. There´s about 8.3GB space available.
    I´ve chosen my D-Drive as a temporary directory, there´s about 167GB available.
    As soon as I try to load the ppk2 file, an error occurs (see screenshot).
    Here´s the log dump:
    2025-07-26T12:31:47.674Z INFO Initialising the bundled nrfutil device
    2025-07-26T12:31:47.991Z DEBUG Application data folder: C:\Users\Jonas\AppData\Roaming\nrfconnect\pc-nrfconnect-ppk
    2025-07-26T12:31:48.282Z DEBUG Sending event "ppk: running nrfutil device"
    2025-07-26T12:31:48.290Z DEBUG App pc-nrfconnect-ppk v4.2.2 (official)
    2025-07-26T12:31:48.290Z DEBUG App path: C:\Users\Jonas\.nrfconnect-apps\node_modules\pc-nrfconnect-ppk
    2025-07-26T12:31:48.290Z DEBUG nRFConnect 5.2.0, required by the app is (>=5.2.0)
    2025-07-26T12:31:48.290Z DEBUG nRFConnect path: C:\Users\Jonas\AppData\Local\Programs\nrfconnect\resources\app.asar
    2025-07-26T12:31:48.291Z DEBUG HomeDir: C:\Users\Jonas
    2025-07-26T12:31:48.291Z DEBUG TmpDir: C:\Users\Jonas\AppData\Local\Temp
    2025-07-26T12:31:50.178Z DEBUG Sending event "ppk: running nrfutil device"
    2025-07-26T12:31:51.301Z DEBUG Sending event "ppk: running nrfutil device"
    2025-07-26T12:31:51.302Z DEBUG Sending event "ppk: running nrfutil device"
    2025-07-26T12:31:51.311Z DEBUG Sending event "ppk: running nrfutil device"
    2025-07-26T12:31:51.473Z INFO Using the bundled core version for nrfutil device: 8.0.0
    2025-07-26T12:31:51.530Z INFO Using nrfutil-device version: 2.10.2
    2025-07-26T12:31:51.531Z INFO Using nrf-device-lib version: 0.17.71
    2025-07-26T12:31:51.531Z INFO Using nrf-probe version: 0.38.0
    2025-07-26T12:31:51.531Z INFO Using JLink version: JLink_V8.18
    2025-07-26T12:32:02.914Z INFO Restoring state from C:\Users\Jonas\Documents\Studium\MSD\Semester_2\Forschung\Bericht\PPK2_Messungen\aps1604_test.ppk2
  • Hello JonasD27,
    Thank you for the details.
    To confirm, is this the .ppk2 file you are trying to open?
    Could you please also share what is the Disk full trigger set to at the moment/when the issue occurs?
  • Yes, that is the file I´m trying to open.
    Disk Full Trigger was set to the maximum of 10240 MB.
    I´ve discovered the following: As soon as I set the Disk Full Trigger to a smaller value (e.g. 3000 MB), I can open the file without a problem. Is this behavior intended?
    It is a bug. The Disk Full Trigger is checked against a different drive. That will get fixed soon.
    Thank you for the report and helping us getting to the bottom of it.
