I tried to build the coprocessor using NCS 2.9.0, but it doesn’t seem to work.
Below is my project configuration,are there any additional parameters I need to set?
According to the manual(Version: v2.11+fall2024)
a. Create the docker network by executing the following commands
sudo docker network create --ipv6 --subnet fd11:db8:1::/64 -o com.docker.network.bridge.name=otbr0 otbr sudo sysctl net.ipv6.conf.otbr0.accept_ra_rt_info_max_plen=128 sudo sysctl net.ipv6.conf.otbr0.accept_ra=2
Run the dependency
sudo modprobe ip6table_filter
Run the docker
sudo docker run -it --rm --privileged --network otbr -p 8080:80 --sysctl "net.ipv6.conf.all.disable_ipv6=0 net.ipv6.conf.all.forwarding=1" --name otbr -e NAT64=0 --volume /dev/ttyACM0:/dev/ttyACM0 nrfconnect/otbr:9185bda --radio-url spinel+hdlc+uart:///dev/ttyACM0
Hi
It's the error log
Status: Downloaded newer image for nrfconnect/otbr:fbde28a
RADIO_URL: spinel+hdlc+uart:///dev/ttyACM0
TREL_URL:
TUN_INTERFACE_NAME: wpan0
BACKBONE_INTERFACE: eth0
NAT64_PREFIX: 64:ff9b::/96
DEBUG_LEVEL: 7
+++ dirname /app/script/server
++ cd /app/script/..
++ HAVE_SYSTEMCTL=0
++ have systemctl
++ command -v systemctl
++ HAVE_SERVICE=0
++ have service
++ command -v service
++ HAVE_SERVICE=1
++ [[ ! -n x ]]
++ echo 'Current platform is ubuntu'
++ with BORDER_ROUTING
++ local value
+++ printenv BORDER_ROUTING
++ value=1
++ [[ -z 1 ]]
++ [[ 1 == 1 ]]
++ with DHCPV6_PD
++ local value
+++ printenv DHCPV6_PD
++ value=
++ [[ -z '' ]]
++ [[ -f examples/platforms/ubuntu/default ]]
++ [[ '' == 1 ]]
++ local value
++ value=1
++ [[ -z 1 ]]
++ [[ 1 == 1 ]]
++ with NETWORK_MANAGER
++ local value
+++ printenv NETWORK_MANAGER
++ value=
++ [[ -z '' ]]
++ [[ '' == 1 ]]
++ STAGE_DIR=/app/stage
++ BUILD_DIR=/app/build
++ [[ -d /app/stage ]]
++ mkdir -v -p /app/stage
mkdir: created directory '/app/stage'
++ [[ -d /app/build ]]
++ mkdir -v -p /app/build
mkdir: created directory '/app/build'
++ export PATH=/app/stage/usr/bin:/app/stage/usr/sbin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
++ PATH=/app/stage/usr/bin:/app/stage/usr/sbin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
+++ basename /app/script/server
++ TASKNAME=server
++ BEFORE_HOOK=examples/platforms/ubuntu/before_server
++ AFTER_HOOK=examples/platforms/ubuntu/after_server
++ [[ ! -f examples/platforms/ubuntu/before_server ]]
++ BEFORE_HOOK=/dev/null
++ [[ ! -f examples/platforms/ubuntu/after_server ]]
++ AFTER_HOOK=/dev/null
+ . script/_nat64
++ NAT64_SERVICE=openthread
++ TAYGA_DEFAULT=/etc/default/tayga
++ TAYGA_CONF=/etc/tayga.conf
++ TAYGA_IPV4_ADDR=192.168.255.1
++ TAYGA_IPV6_ADDR=fdaa:bb:1::1
++ TAYGA_TUN_V6_ADDR=fdaa:bb:1::2
++ NAT64_PREFIX=64:ff9b::/96
++ DYNAMIC_POOL=192.168.255.0/24
++ NAT44_SERVICE=/etc/init.d/otbr-nat44
++ WLAN_IFNAMES=eth0
++ THREAD_IF=wpan0
+ . script/_dns64
++ BIND_CONF_OPTIONS=/etc/bind/named.conf.options
++ DNS64_NAMESERVER_ADDR=127.0.0.1
+++ echo 64:ff9b::/96
+++ tr '"/"' '"/"'
++ DNS64_CONF='dns64 64:ff9b::/96 { clients { thread; }; recursive-only yes; };'
++ without NAT64
++ with NAT64
++ local value
+++ printenv NAT64
++ value=0
++ [[ -z 0 ]]
++ [[ 0 == 1 ]]
++ '[' ubuntu = raspbian ']'
++ '[' ubuntu = beagleboneblack ']'
++ '[' ubuntu = ubuntu ']'
++ RESOLV_CONF_HEAD=/etc/resolvconf/resolv.conf.d/head
+ . script/_firewall
++ FIREWALL_SERVICE=/etc/init.d/otbr-firewall
++ sudo modprobe ip6table_filter
sudo: modprobe: command not found
++ true
++ FIREWALL=1
+ OTBR_MDNS=mDNSResponder
+ OT_BACKBONE_CI=0
+ REFERENCE_DEVICE=0
+ main
+ [[ '' == \s\h\u\t\d\o\w\n ]]
+ startup
+ . /dev/null
+ sudo sysctl --system
* Applying /etc/sysctl.d/10-console-messages.conf ...
kernel.printk = 4 4 1 7
* Applying /etc/sysctl.d/10-ipv6-privacy.conf ...
net.ipv6.conf.all.use_tempaddr = 2
net.ipv6.conf.default.use_tempaddr = 2
* Applying /etc/sysctl.d/10-kernel-hardening.conf ...
kernel.kptr_restrict = 1
* Applying /etc/sysctl.d/10-link-restrictions.conf ...
fs.protected_hardlinks = 1
fs.protected_symlinks = 1
* Applying /etc/sysctl.d/10-magic-sysrq.conf ...
kernel.sysrq = 176
* Applying /etc/sysctl.d/10-network-security.conf ...
net.ipv4.conf.default.rp_filter = 1
net.ipv4.conf.all.rp_filter = 1
net.ipv4.tcp_syncookies = 1
* Applying /etc/sysctl.d/10-ptrace.conf ...
kernel.yama.ptrace_scope = 1
* Applying /etc/sysctl.d/10-zeropage.conf ...
vm.mmap_min_addr = 32768
* Applying /etc/sysctl.d/60-otbr-accept-ra.conf ...
net.ipv6.conf.eth0.accept_ra = 2
net.ipv6.conf.eth0.accept_ra_rt_info_max_plen = 64
* Applying /etc/sysctl.d/60-otbr-ip-forward.conf ...
net.ipv6.conf.all.forwarding = 1
net.ipv4.ip_forward = 1
* Applying /etc/sysctl.conf ...
+ nat64_start
+ with NAT64
+ local value
++ printenv NAT64
+ value=0
+ [[ -z 0 ]]
+ [[ 0 == 1 ]]
+ return 0
+ dns64_start
+ with NAT64
+ local value
++ printenv NAT64
+ value=0
+ [[ -z 0 ]]
+ [[ 0 == 1 ]]
+ return 0
+ firewall_start
+ with FIREWALL
+ local value
++ printenv FIREWALL
+ value=1
+ [[ -z 1 ]]
+ [[ 1 == 1 ]]
+ with DOCKER
+ local value
++ printenv DOCKER
+ value=1
+ [[ -z 1 ]]
+ [[ 1 == 1 ]]
+ service otbr-firewall start
+ case "$1" in
+ firewall_start
+ firewall_stop
+ ip6tables -C FORWARD -o wpan0 -j OTBR_FORWARD_INGRESS
ip6tables v1.6.1: Couldn't load target `OTBR_FORWARD_INGRESS':No such file or directory
Try `ip6tables -h' or 'ip6tables --help' for more information.
+ ip6tables -L OTBR_FORWARD_INGRESS
ip6tables: No chain/target/match by that name.
+ ipset_destroy_if_exist otbr-ingress-deny-src
+ ipset list otbr-ingress-deny-src
ipset v6.34: Kernel support protocol versions 6-7 while userspace supports protocol versions 6-6
The set with the given name does not exist
+ ipset_destroy_if_exist otbr-ingress-deny-src-swap
+ ipset list otbr-ingress-deny-src-swap
+ ipset_destroy_if_exist otbr-ingress-allow-dst
+ ipset list otbr-ingress-allow-dst
+ ipset_destroy_if_exist otbr-ingress-allow-dst-swap
+ ipset list otbr-ingress-allow-dst-swap
+ ipset create -exist otbr-ingress-deny-src hash:net family inet6
+ ipset create -exist otbr-ingress-deny-src-swap hash:net family inet6
+ ipset create -exist otbr-ingress-allow-dst hash:net family inet6
+ ipset create -exist otbr-ingress-allow-dst-swap hash:net family inet6
+ ip6tables -N OTBR_FORWARD_INGRESS
+ ip6tables -I FORWARD 1 -o wpan0 -j OTBR_FORWARD_INGRESS
+ ip6tables -A OTBR_FORWARD_INGRESS -m pkttype --pkt-type unicast -i wpan0 -j DROP
+ ip6tables -A OTBR_FORWARD_INGRESS -m set --match-set otbr-ingress-deny-src src -j DROP
+ ip6tables -A OTBR_FORWARD_INGRESS -m set --match-set otbr-ingress-allow-dst dst -j ACCEPT
+ ip6tables -A OTBR_FORWARD_INGRESS -m pkttype --pkt-type unicast -j DROP
+ ip6tables -A OTBR_FORWARD_INGRESS -j ACCEPT
+ start_service rsyslog
+ local service_name=rsyslog
+ [[ 0 == 1 ]]
+ [[ 1 == 1 ]]
+ sudo service rsyslog status
* rsyslogd is not running
+ sudo service rsyslog start
* Starting enhanced syslogd rsyslogd [ OK ]
+ start_service dbus
+ local service_name=dbus
+ [[ 0 == 1 ]]
+ [[ 1 == 1 ]]
+ sudo service dbus status
* dbus is not running
+ sudo service dbus start
* Starting system message bus dbus [ OK ]
+ [[ mDNSResponder == \a\v\a\h\i ]]
+ [[ 0 == 1 ]]
+ [[ 0 == 1 ]]
+ have service
+ sudo service mdns status
Usage: /etc/init.d/mDNS {start|stop|reload|restart}
+ sudo service mdns start
Starting Apple Darwin Multicast DNS / DNS Service Discovery daemon: mdnsd.
+ without WEB_GUI
+ with WEB_GUI
+ local value
++ printenv WEB_GUI
+ value=1
+ [[ -z 1 ]]
+ [[ 1 == 1 ]]
+ start_service otbr-web
+ local service_name=otbr-web
+ [[ 0 == 1 ]]
+ [[ 1 == 1 ]]
+ sudo service otbr-web status
* otbr-web is not running
+ sudo service otbr-web start
* Starting thread web interface otbr-web [ OK ]
+ start_service otbr-agent
+ local service_name=otbr-agent
+ [[ 0 == 1 ]]
+ [[ 1 == 1 ]]
+ sudo service otbr-agent status
* otbr-agent is not running
+ sudo service otbr-agent start
* Starting thread border agent otbr-agent [ OK ]
+ . /dev/null
Jun 19 06:41:38 795f97665693 mDNSResponder: Default: mDNSResponder (Engineering Build) (Oct 21 2024 08:52:04) starting
Jun 19 06:41:39 795f97665693 rsyslogd: rsyslogd's groupid changed to 101
Jun 19 06:41:39 795f97665693 rsyslogd: rsyslogd's userid changed to 101
Jun 19 06:41:39 795f97665693 rsyslogd: [origin software="rsyslogd" swVersion="8.32.0" x-pid="85" x-info="http://www.rsyslog.com"] start
Jun 19 06:41:40 795f97665693 otbr-web[159]: [INFO]-WEB-----: Running 0.3.0-thread-reference-20230710-394-gfbde28a0596-dirty
Jun 19 06:41:40 795f97665693 otbr-web[159]: [INFO]-WEB-----: Border router web started on wpan0
Jun 19 06:41:40 795f97665693 otbr-web[159]: [ERR ]-WEB-----: OpenThread daemon is not running.
Jun 19 06:41:41 795f97665693 otbr-agent: [NOTE]-AGENT---: Backbone interface: eth0
Jun 19 06:41:41 795f97665693 otbr-agent[186]: [NOTE]-AGENT---: Running 0.3.0-thread-reference-20230710-394-gfbde28a0596-dirty
Jun 19 06:41:41 795f97665693 otbr-agent[186]: [NOTE]-AGENT---: Thread version: 1.4.0
Jun 19 06:41:41 795f97665693 otbr-agent[186]: [NOTE]-AGENT---: Thread interface: wpan0
Jun 19 06:41:41 795f97665693 otbr-agent[186]: [NOTE]-AGENT---: Radio URL: spinel+hdlc+uart:///dev/ttyACM0
Jun 19 06:41:41 795f97665693 otbr-agent[186]: [NOTE]-ILS-----: Infra link selected: eth0
Jun 19 06:41:41 795f97665693 otbr-agent[186]: [INFO]-RCP_HOS-: OpenThread log level changed to 5
Jun 19 06:41:41 795f97665693 otbr-agent[186]: 49d.17:50:14.431 [C] P-HdlcIntface-: Radio file '/dev/ttyACM0' not supported
Jun 19 06:41:41 795f97665693 otbr-agent[186]: 49d.17:50:14.431 [C] Platform------: Init() at spinel_driver.cpp:70: Failure
Jun 19 06:45:35 795f97665693 otbr-web[159]: [ERR ]-WEB-----: OpenThread daemon is not running.
Jun 19 06:45:35 795f97665693 otbr-web[159]: [ERR ]-WEB-----: Wpan service error: 13
Can you download the OTBR docker image that is compatible with the nRF Connect SDK v2.9.0? You should do this before starting the docker, but you can do it after doing the other steps:
docker pull nrfconnect/otbr:fbde28a
Please also try using this command to start the OTBR docker:
sudo modprobe ip6table_filter sudo docker run -it --rm --privileged --name otbr --network otbr -p 8080:80 \ --sysctl "net.ipv6.conf.all.disable_ipv6=0 net.ipv4.conf.all.forwarding=1 net.ipv6.conf.all.forwarding=1" \ --volume /dev/ttyACM0:/dev/radio nrfconnect/otbr:fbde28a --radio-url spinel+hdlc+uart:///dev/radio?uart-baudrate=1000000
It uses version fbde28a of the OTBR docker, which is downloaded in the previous command, instead of the version you are using. It also sets the baud rate to 1000000, which is the same as what is used in the co-processor sample.
Marte
It still doesn't work, the error message is as follows:
ubuntu@ubuntu:~$ sudo docker network create --ipv6 --subnet fd11:db8:1::/64 -o com.docker.network.bridge.name=otbr0 otbr
552ad397e32cceabbf5030c1d05d9ebf653ec1dfa0b799a86b5b707291347f9b
ubuntu@ubuntu:~$ sudo sysctl net.ipv6.conf.otbr0.accept_ra_rt_info_max_plen=128
net.ipv6.conf.otbr0.accept_ra_rt_info_max_plen = 128
ubuntu@ubuntu:~$ sudo sysctl net.ipv6.conf.otbr0.accept_ra=2
net.ipv6.conf.otbr0.accept_ra = 2
ubuntu@ubuntu:~$ sudo modprobe ip6table_filter
ubuntu@ubuntu:~$ sudo docker run -it --rm --privileged --name otbr --network otbr -p 8080:80 \
RADIO_URL: spinel+hdlc+uart:///dev/radio?uart-baudrate=1000000
TREL_URL:
DEBUG_LEVEL: 7
++ HAVE_SYSTEMCTL=0
++ have systemctl
++ HAVE_SERVICE=0
++ have service
++ HAVE_SERVICE=1
++ [[ ! -n x ]]
++ local value
++ value=1
++ [[ -z 1 ]]
++ [[ 1 == 1 ]]
++ with DHCPV6_PD
++ local value
++ value=
++ [[ -z '' ]]
++ [[ '' == 1 ]]
++ local value
++ value=1
++ [[ -z 1 ]]
++ [[ 1 == 1 ]]
++ local value
++ value=
++ [[ -z '' ]]
++ [[ '' == 1 ]]
++ TASKNAME=server
+ . script/_nat64
++ THREAD_IF=wpan0
+ . script/_dns64
+++ tr '"/"' '"/"'
++ without NAT64
++ with NAT64
++ local value
+++ printenv NAT64
++ value=1
++ [[ -z 1 ]]
++ [[ 1 == 1 ]]
++ without DNS64
++ with DNS64
++ local value
+++ printenv DNS64
++ value=0
++ [[ -z 0 ]]
++ [[ 0 == 1 ]]
++ true
++ FIREWALL=1
+ OT_BACKBONE_CI=0
+ main
+ startup
+ . /dev/null
kernel.sysrq = 176
+ nat64_start
+ with NAT64
+ local value
++ printenv NAT64
+ value=1
+ [[ -z 1 ]]
+ [[ 1 == 1 ]]
+ '[' openthread = tayga ']'
+ nat44_start
+ with DOCKER
+ local value
++ printenv DOCKER
+ value=1
+ [[ -z 1 ]]
+ [[ 1 == 1 ]]
+ service otbr-nat44 start
+ dns64_start
+ with NAT64
+ local value
++ printenv NAT64
+ value=1
+ [[ -z 1 ]]
+ [[ 1 == 1 ]]
+ with DNS64
+ local value
++ printenv DNS64
+ value=0
+ [[ -z 0 ]]
+ [[ 0 == 1 ]]
+ return 0
+ firewall_start
+ with FIREWALL
+ local value
+ value=1
+ [[ -z 1 ]]
+ [[ 1 == 1 ]]
+ with DOCKER
+ local value
++ printenv DOCKER
+ value=1
+ [[ -z 1 ]]
+ [[ 1 == 1 ]]
+ case "$1" in
+ firewall_start
+ firewall_stop
+ [[ 0 == 1 ]]
+ [[ 1 == 1 ]]
+ [[ 0 == 1 ]]
+ [[ 1 == 1 ]]
+ [[ 0 == 1 ]]
+ [[ 0 == 1 ]]
+ have service
+ without WEB_GUI
+ with WEB_GUI
+ local value
++ printenv WEB_GUI
+ value=1
+ [[ -z 1 ]]
+ [[ 1 == 1 ]]
+ [[ 0 == 1 ]]
+ [[ 1 == 1 ]]
+ [[ 0 == 1 ]]
+ [[ 1 == 1 ]]
+ . /dev/null
Jun 20 01:17:36 44aa05106354 mDNSResponder: Default: mDNSResponder (Engineering Build) (Oct 21 2024 08:52:04) starting
Jun 20 01:17:37 44aa05106354 rsyslogd: rsyslogd's groupid changed to 101
Jun 20 01:17:37 44aa05106354 rsyslogd: rsyslogd's userid changed to 101
Jun 20 01:17:37 44aa05106354 rsyslogd: [origin software="rsyslogd" swVersion="8.32.0" x-pid="97" x-info="http://www.rsyslog.com"] start
Jun 20 01:17:38 44aa05106354 otbr-web[171]: [INFO]-WEB-----: Running 0.3.0-thread-reference-20230710-394-gfbde28a0596-dirty
Jun 20 01:17:38 44aa05106354 otbr-web[171]: [INFO]-WEB-----: Border router web started on wpan0
Jun 20 01:17:38 44aa05106354 otbr-web[171]: [ERR ]-WEB-----: OpenThread daemon is not running.
Jun 20 01:17:39 44aa05106354 otbr-agent: [NOTE]-AGENT---: Backbone interface: eth0
Jun 20 01:17:39 44aa05106354 otbr-agent[198]: [NOTE]-AGENT---: Running 0.3.0-thread-reference-20230710-394-gfbde28a0596-dirty
Jun 20 01:17:39 44aa05106354 otbr-agent[198]: [NOTE]-AGENT---: Thread version: 1.4.0
Jun 20 01:17:39 44aa05106354 otbr-agent[198]: [NOTE]-AGENT---: Thread interface: wpan0
Jun 20 01:17:39 44aa05106354 otbr-agent[198]: [NOTE]-AGENT---: Radio URL: spinel+hdlc+uart:///dev/radio?uart-baudrate=1000000
Jun 20 01:17:39 44aa05106354 otbr-agent[198]: [NOTE]-ILS-----: Infra link selected: eth0
Jun 20 01:17:39 44aa05106354 otbr-agent[198]: [INFO]-RCP_HOS-: OpenThread log level changed to 5
Jun 20 01:17:39 44aa05106354 otbr-agent[198]: 49d.17:13:38.002 [C] P-HdlcIntface-: Radio file '/dev/radio' not supported
Jun 20 01:17:39 44aa05106354 otbr-agent[198]: 49d.17:13:38.004 [C] P-HdlcIntface-: Radio file '/dev/radio' not supported
Jun 20 01:17:39 44aa05106354 otbr-agent[198]: 49d.17:13:38.004 [C] Platform------: Init() at spinel_driver.cpp:70: Failure
Jun 20 01:17:39 44aa05106354 otbr-agent[198]: 49d.17:13:38.005 [C] P-HdlcIntface-: Radio file '/dev/radio' not supported
Jun 20 01:18:09 44aa05106354 otbr-web[171]: [ERR ]-WEB-----: OpenThread daemon is not running.
Jun 20 01:18:09 44aa05106354 otbr-web[171]: [ERR ]-WEB-----: Wpan service error: 13
To verify, are you using the nRF52840 DK as your RCP? If so, can you try flashing it with this hex file and see if it works?
Marte
