I tried to build the coprocessor using NCS 2.9.0, but it doesn’t seem to work.
Below is my project configuration,are there any additional parameters I need to set?
I have used the file you provided, but I still get an error
ubuntu@ubuntu:~$ sudo docker network prune
WARNING! This will remove all custom networks not used by at least one container.
Are you sure you want to continue? [y/N] y
Deleted Networks:
otbr
ubuntu@ubuntu:~$ sudo docker network create --ipv6 --subnet fd11:db8:1::/64 -o com.docker.network.bridge.name=otbr0 otbr
e731fd46bee75b1c31afc2aa3fd0bf82138e9a0e75b725b5b1b9d5b36220e900
ubuntu@ubuntu:~$ sudo sysctl net.ipv6.conf.otbr0.accept_ra_rt_info_max_plen=128
net.ipv6.conf.otbr0.accept_ra_rt_info_max_plen = 128
ubuntu@ubuntu:~$ sudo sysctl net.ipv6.conf.otbr0.accept_ra=2
net.ipv6.conf.otbr0.accept_ra = 2
ubuntu@ubuntu:~$ sudo modprobe ip6table_filter
ubuntu@ubuntu:~$ sudo docker run -it --rm --privileged --name otbr --network otbr -p 8080:80 \
--sysctl "net.ipv6.conf.all.disable_ipv6=0 net.ipv4.conf.all.forwarding=1 net.ipv6.conf.all.forwarding=1" \
--volume /dev/ttyACM0:/dev/radio nrfconnect/otbr:fbde28a --radio-url spinel+hdlc+uart:///dev/radio?uart-baudrate=1000000
RADIO_URL: spinel+hdlc+uart:///dev/radio?uart-baudrate=1000000
TREL_URL:
TUN_INTERFACE_NAME: wpan0
BACKBONE_INTERFACE: eth0
NAT64_PREFIX: 64:ff9b::/96
DEBUG_LEVEL: 7
+++ dirname /app/script/server
++ cd /app/script/..
++ HAVE_SYSTEMCTL=0
++ have systemctl
++ command -v systemctl
++ HAVE_SERVICE=0
++ have service
++ command -v service
++ HAVE_SERVICE=1
++ [[ ! -n x ]]
++ echo 'Current platform is ubuntu'
++ with BORDER_ROUTING
++ local value
+++ printenv BORDER_ROUTING
++ value=1
++ [[ -z 1 ]]
++ [[ 1 == 1 ]]
++ with DHCPV6_PD
++ local value
+++ printenv DHCPV6_PD
++ value=
++ [[ -z '' ]]
++ [[ -f examples/platforms/ubuntu/default ]]
++ [[ '' == 1 ]]
++ local value
++ value=1
++ [[ -z 1 ]]
++ [[ 1 == 1 ]]
++ with NETWORK_MANAGER
++ local value
+++ printenv NETWORK_MANAGER
++ value=
++ [[ -z '' ]]
++ [[ '' == 1 ]]
++ STAGE_DIR=/app/stage
++ BUILD_DIR=/app/build
++ [[ -d /app/stage ]]
++ mkdir -v -p /app/stage
mkdir: created directory '/app/stage'
++ [[ -d /app/build ]]
++ mkdir -v -p /app/build
mkdir: created directory '/app/build'
++ export PATH=/app/stage/usr/bin:/app/stage/usr/sbin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
++ PATH=/app/stage/usr/bin:/app/stage/usr/sbin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
+++ basename /app/script/server
++ TASKNAME=server
++ BEFORE_HOOK=examples/platforms/ubuntu/before_server
++ AFTER_HOOK=examples/platforms/ubuntu/after_server
++ [[ ! -f examples/platforms/ubuntu/before_server ]]
++ BEFORE_HOOK=/dev/null
++ [[ ! -f examples/platforms/ubuntu/after_server ]]
++ AFTER_HOOK=/dev/null
+ . script/_nat64
++ NAT64_SERVICE=openthread
++ TAYGA_DEFAULT=/etc/default/tayga
++ TAYGA_CONF=/etc/tayga.conf
++ TAYGA_IPV4_ADDR=192.168.255.1
++ TAYGA_IPV6_ADDR=fdaa:bb:1::1
++ TAYGA_TUN_V6_ADDR=fdaa:bb:1::2
++ NAT64_PREFIX=64:ff9b::/96
++ DYNAMIC_POOL=192.168.255.0/24
++ NAT44_SERVICE=/etc/init.d/otbr-nat44
++ WLAN_IFNAMES=eth0
++ THREAD_IF=wpan0
+ . script/_dns64
++ BIND_CONF_OPTIONS=/etc/bind/named.conf.options
++ DNS64_NAMESERVER_ADDR=127.0.0.1
+++ echo 64:ff9b::/96
+++ tr '"/"' '"/"'
++ DNS64_CONF='dns64 64:ff9b::/96 { clients { thread; }; recursive-only yes; };'
++ without NAT64
++ with NAT64
++ local value
+++ printenv NAT64
++ value=1
++ [[ -z 1 ]]
++ [[ 1 == 1 ]]
++ without DNS64
++ with DNS64
++ local value
+++ printenv DNS64
++ value=0
++ [[ -z 0 ]]
++ [[ 0 == 1 ]]
++ '[' ubuntu = raspbian ']'
++ '[' ubuntu = beagleboneblack ']'
++ '[' ubuntu = ubuntu ']'
++ RESOLV_CONF_HEAD=/etc/resolvconf/resolv.conf.d/head
+ . script/_firewall
++ FIREWALL_SERVICE=/etc/init.d/otbr-firewall
++ sudo modprobe ip6table_filter
sudo: modprobe: command not found
++ true
++ FIREWALL=1
+ OTBR_MDNS=mDNSResponder
+ OT_BACKBONE_CI=0
+ REFERENCE_DEVICE=0
+ main
+ [[ '' == \s\h\u\t\d\o\w\n ]]
+ startup
+ . /dev/null
+ sudo sysctl --system
* Applying /etc/sysctl.d/10-console-messages.conf ...
kernel.printk = 4 4 1 7
* Applying /etc/sysctl.d/10-ipv6-privacy.conf ...
net.ipv6.conf.all.use_tempaddr = 2
net.ipv6.conf.default.use_tempaddr = 2
* Applying /etc/sysctl.d/10-kernel-hardening.conf ...
kernel.kptr_restrict = 1
* Applying /etc/sysctl.d/10-link-restrictions.conf ...
fs.protected_hardlinks = 1
fs.protected_symlinks = 1
* Applying /etc/sysctl.d/10-magic-sysrq.conf ...
kernel.sysrq = 176
* Applying /etc/sysctl.d/10-network-security.conf ...
net.ipv4.conf.default.rp_filter = 1
net.ipv4.conf.all.rp_filter = 1
net.ipv4.tcp_syncookies = 1
* Applying /etc/sysctl.d/10-ptrace.conf ...
kernel.yama.ptrace_scope = 1
* Applying /etc/sysctl.d/10-zeropage.conf ...
vm.mmap_min_addr = 32768
* Applying /etc/sysctl.d/60-otbr-accept-ra.conf ...
net.ipv6.conf.eth0.accept_ra = 2
net.ipv6.conf.eth0.accept_ra_rt_info_max_plen = 64
* Applying /etc/sysctl.d/60-otbr-ip-forward.conf ...
net.ipv6.conf.all.forwarding = 1
net.ipv4.ip_forward = 1
* Applying /etc/sysctl.conf ...
+ nat64_start
+ with NAT64
+ local value
++ printenv NAT64
+ value=1
+ [[ -z 1 ]]
+ [[ 1 == 1 ]]
+ '[' openthread = tayga ']'
+ nat44_start
+ with DOCKER
+ local value
++ printenv DOCKER
+ value=1
+ [[ -z 1 ]]
+ [[ 1 == 1 ]]
+ service otbr-nat44 start
+ dns64_start
+ with NAT64
+ local value
++ printenv NAT64
+ value=1
+ [[ -z 1 ]]
+ [[ 1 == 1 ]]
+ with DNS64
+ local value
++ printenv DNS64
+ value=0
+ [[ -z 0 ]]
+ [[ 0 == 1 ]]
+ return 0
+ firewall_start
+ with FIREWALL
+ local value
++ printenv FIREWALL
+ value=1
+ [[ -z 1 ]]
+ [[ 1 == 1 ]]
+ with DOCKER
+ local value
++ printenv DOCKER
+ value=1
+ [[ -z 1 ]]
+ [[ 1 == 1 ]]
+ service otbr-firewall start
+ case "$1" in
+ firewall_start
+ firewall_stop
+ ip6tables -C FORWARD -o wpan0 -j OTBR_FORWARD_INGRESS
ip6tables v1.6.1: Couldn't load target `OTBR_FORWARD_INGRESS':No such file or directory
Try `ip6tables -h' or 'ip6tables --help' for more information.
+ ip6tables -L OTBR_FORWARD_INGRESS
ip6tables: No chain/target/match by that name.
+ ipset_destroy_if_exist otbr-ingress-deny-src
+ ipset list otbr-ingress-deny-src
ipset v6.34: Kernel support protocol versions 6-7 while userspace supports protocol versions 6-6
The set with the given name does not exist
+ ipset_destroy_if_exist otbr-ingress-deny-src-swap
+ ipset list otbr-ingress-deny-src-swap
+ ipset_destroy_if_exist otbr-ingress-allow-dst
+ ipset list otbr-ingress-allow-dst
+ ipset_destroy_if_exist otbr-ingress-allow-dst-swap
+ ipset list otbr-ingress-allow-dst-swap
+ ipset create -exist otbr-ingress-deny-src hash:net family inet6
+ ipset create -exist otbr-ingress-deny-src-swap hash:net family inet6
+ ipset create -exist otbr-ingress-allow-dst hash:net family inet6
+ ipset create -exist otbr-ingress-allow-dst-swap hash:net family inet6
+ ip6tables -N OTBR_FORWARD_INGRESS
+ ip6tables -I FORWARD 1 -o wpan0 -j OTBR_FORWARD_INGRESS
+ ip6tables -A OTBR_FORWARD_INGRESS -m pkttype --pkt-type unicast -i wpan0 -j DROP
+ ip6tables -A OTBR_FORWARD_INGRESS -m set --match-set otbr-ingress-deny-src src -j DROP
+ ip6tables -A OTBR_FORWARD_INGRESS -m set --match-set otbr-ingress-allow-dst dst -j ACCEPT
+ ip6tables -A OTBR_FORWARD_INGRESS -m pkttype --pkt-type unicast -j DROP
+ ip6tables -A OTBR_FORWARD_INGRESS -j ACCEPT
+ start_service rsyslog
+ local service_name=rsyslog
+ [[ 0 == 1 ]]
+ [[ 1 == 1 ]]
+ sudo service rsyslog status
* rsyslogd is not running
+ sudo service rsyslog start
* Starting enhanced syslogd rsyslogd [ OK ]
+ start_service dbus
+ local service_name=dbus
+ [[ 0 == 1 ]]
+ [[ 1 == 1 ]]
+ sudo service dbus status
* dbus is not running
+ sudo service dbus start
* Starting system message bus dbus [ OK ]
+ [[ mDNSResponder == \a\v\a\h\i ]]
+ [[ 0 == 1 ]]
+ [[ 0 == 1 ]]
+ have service
+ sudo service mdns status
Usage: /etc/init.d/mDNS {start|stop|reload|restart}
+ sudo service mdns start
Starting Apple Darwin Multicast DNS / DNS Service Discovery daemon: mdnsd.
+ without WEB_GUI
+ with WEB_GUI
+ local value
++ printenv WEB_GUI
+ value=1
+ [[ -z 1 ]]
+ [[ 1 == 1 ]]
+ start_service otbr-web
+ local service_name=otbr-web
+ [[ 0 == 1 ]]
+ [[ 1 == 1 ]]
+ sudo service otbr-web status
* otbr-web is not running
+ sudo service otbr-web start
* Starting thread web interface otbr-web [ OK ]
+ start_service otbr-agent
+ local service_name=otbr-agent
+ [[ 0 == 1 ]]
+ [[ 1 == 1 ]]
+ sudo service otbr-agent status
* otbr-agent is not running
+ sudo service otbr-agent start
* Starting thread border agent otbr-agent [ OK ]
+ . /dev/null
Jun 23 07:10:04 eb3f40287101 mDNSResponder: Default: mDNSResponder (Engineering Build) (Oct 21 2024 08:52:04) starting
Jun 23 07:10:05 eb3f40287101 rsyslogd: rsyslogd's groupid changed to 101
Jun 23 07:10:05 eb3f40287101 rsyslogd: rsyslogd's userid changed to 101
Jun 23 07:10:05 eb3f40287101 rsyslogd: [origin software="rsyslogd" swVersion="8.32.0" x-pid="98" x-info="http://www.rsyslog.com"] start
Jun 23 07:10:06 eb3f40287101 otbr-web[172]: [INFO]-WEB-----: Running 0.3.0-thread-reference-20230710-394-gfbde28a0596-dirty
Jun 23 07:10:06 eb3f40287101 otbr-web[172]: [INFO]-WEB-----: Border router web started on wpan0
Jun 23 07:10:06 eb3f40287101 otbr-web[172]: [ERR ]-WEB-----: OpenThread daemon is not running.
Jun 23 07:10:07 eb3f40287101 otbr-agent: [NOTE]-AGENT---: Backbone interface: eth0
Jun 23 07:10:07 eb3f40287101 otbr-agent[199]: [NOTE]-AGENT---: Running 0.3.0-thread-reference-20230710-394-gfbde28a0596-dirty
Jun 23 07:10:07 eb3f40287101 otbr-agent[199]: [NOTE]-AGENT---: Thread version: 1.4.0
Jun 23 07:10:07 eb3f40287101 otbr-agent[199]: [NOTE]-AGENT---: Thread interface: wpan0
Jun 23 07:10:07 eb3f40287101 otbr-agent[199]: [NOTE]-AGENT---: Radio URL: spinel+hdlc+uart:///dev/radio?uart-baudrate=1000000
Jun 23 07:10:07 eb3f40287101 otbr-agent[199]: [NOTE]-ILS-----: Infra link selected: eth0
Jun 23 07:10:07 eb3f40287101 otbr-agent[199]: [INFO]-RCP_HOS-: OpenThread log level changed to 5
Jun 23 07:10:07 eb3f40287101 otbr-agent[199]: 49d.17:05:34.646 [C] P-HdlcIntface-: Radio file '/dev/radio' not supported
Jun 23 07:10:07 eb3f40287101 otbr-agent[199]: 49d.17:05:34.649 [C] P-HdlcIntface-: Radio file '/dev/radio' not supported
Jun 23 07:10:07 eb3f40287101 otbr-agent[199]: 49d.17:05:34.649 [C] Platform------: Init() at spinel_driver.cpp:70: Failure
Jun 23 07:10:37 eb3f40287101 otbr-web[172]: [ERR ]-WEB-----: OpenThread daemon is not running.
Jun 23 07:10:37 eb3f40287101 otbr-web[172]: [ERR ]-WEB-----: Wpan service error: 13
If I build coprocessor using 2.4.1...
Last login: Tue Jun 24 00:04:21 2025 from 192.168.50.12
WARNING! This will remove all custom networks not used by at least one container .
Deleted Networks:
otbr
ubuntu@ubuntu:~$ sudo docker network create --ipv6 --subnet fd11:db8:1::/64 -o c om.docker.network.bridge.name=otbr0 otbr
b79e9ec801bd121b58d9b7e8fde20f82c69b8e3e561c1c969e9a9eb6934bf1c1
ubuntu@ubuntu:~$ sudo docker run -it --rm --privileged --name otbr --network otbr -p 8080:80 --sysctl "net.ipv6.conf.all.disable_ipv6=0 net.ipv6.conf.all.forwarding=1" -e NAT64=0 --volume /dev/ttyACM0:/dev/ttyACM0 nrfconnect/otbr:9185bda --radio-url spinel+hdlc+uart:///dev/ttyACM0
RADIO_URL: spinel+hdlc+uart:///dev/ttyACM0
TREL_URL:
++ [[ ! -n x ]]
++ local value
++ value=1
++ [[ -z 1 ]]
++ [[ 1 == 1 ]]
++ with DHCPV6_PD
++ local value
++ value=
++ [[ -z '' ]]
++ [[ '' == 1 ]]
++ local value
++ value=1
++ [[ -z 1 ]]
++ [[ 1 == 1 ]]
++ local value
++ value=
++ [[ -z '' ]]
++ [[ '' == 1 ]]
++ TASKNAME=server
+ . script/_nat64
+ . script/_dns64
+++ tr '"/"' '"/"'
++ without NAT64
++ with NAT64
++ local value
+++ printenv NAT64
++ value=0
++ [[ -z 0 ]]
++ [[ 0 == 1 ]]
++ true
+ main
+ startup
+ . /dev/null
kernel.sysrq = 176
+ nat64_start
+ with NAT64
+ local value
++ printenv NAT64
+ value=0
+ [[ -z 0 ]]
+ [[ 0 == 1 ]]
+ return 0
+ dns64_start
+ with NAT64
+ local value
++ printenv NAT64
+ value=0
+ [[ -z 0 ]]
+ [[ 0 == 1 ]]
+ return 0
+ firewall_start
+ with DOCKER
+ local value
++ printenv DOCKER
+ value=1
+ [[ -z 1 ]]
+ [[ 1 == 1 ]]
+ case "$1" in
+ firewall_start
+ firewall_stop
+ have systemctl
+ have service
+ sudo service avahi-daemon status
Avahi mDNS/DNS-SD Daemon is not running
+ sudo service avahi-daemon start
* Starting Avahi mDNS/DNS-SD Daemon avahi-daemon [ OK ]
+ without WEB_GUI
+ with WEB_GUI
+ local value
++ printenv WEB_GUI
+ value=1
+ [[ -z 1 ]]
+ [[ 1 == 1 ]]
+ . /dev/null
Jun 24 00:10:20 23fdc2e10cad avahi-daemon[151]: Joining mDNS multicast group on interface lo.IPv4 with address 127.0.0.1.
Jun 24 00:10:20 23fdc2e10cad avahi-daemon[151]: New relevant interface lo.IPv4 for mDNS.
Jun 24 00:10:20 23fdc2e10cad avahi-daemon[151]: Network interface enumeration completed.
Jun 24 00:10:20 23fdc2e10cad avahi-daemon[151]: Registering new address record for fd11:db8:1::2 on eth0.*.
Jun 24 00:10:20 23fdc2e10cad avahi-daemon[151]: Registering new address record for 172.20.0.2 on eth0.IPv4.
Jun 24 00:10:20 23fdc2e10cad avahi-daemon[151]: Registering new address record for ::1 on lo.*.
Jun 24 00:10:20 23fdc2e10cad avahi-daemon[151]: Registering new address record for 127.0.0.1 on lo.IPv4.
Jun 24 00:10:20 23fdc2e10cad rsyslogd: rsyslogd's groupid changed to 101
Jun 24 00:10:20 23fdc2e10cad rsyslogd: rsyslogd's userid changed to 101
Jun 24 00:10:20 23fdc2e10cad rsyslogd: [origin software="rsyslogd" swVersion="8.32.0" x-pid="84" x-info="http://www.rsyslog.com"] start
Jun 24 00:10:21 23fdc2e10cad avahi-daemon[151]: Server startup complete. Host name is 23fdc2e10cad.local. Local service cookie is 1309939092.
Jun 24 00:10:22 23fdc2e10cad otbr-agent: [NOTE]-AGENT---: Backbone interface: eth0
Jun 24 00:10:22 23fdc2e10cad otbr-agent[179]: [NOTE]-AGENT---: Running 0.3.0-9185bdaaf4-dirty
Jun 24 00:10:22 23fdc2e10cad otbr-agent[179]: [NOTE]-AGENT---: Thread version: 1.3.0
Jun 24 00:10:22 23fdc2e10cad otbr-agent[179]: [NOTE]-AGENT---: Thread interface: wpan0
Jun 24 00:10:22 23fdc2e10cad otbr-agent[179]: [NOTE]-AGENT---: Radio URL: spinel+hdlc+uart:///dev/ttyACM0
Jun 24 00:10:22 23fdc2e10cad otbr-agent[179]: [NOTE]-ILS-----: Infra link selected: eth0
Jun 24 00:10:22 23fdc2e10cad otbr-agent[179]: [INFO]-NCP-----: OpenThread log level changed to 5
Jun 24 00:10:22 23fdc2e10cad otbr-web[207]: [INFO]-WEB-----: Running 0.3.0-9185bdaaf4-dirty
Jun 24 00:10:22 23fdc2e10cad otbr-web[207]: [INFO]-WEB-----: Border router web started on wpan0
Jun 24 00:10:22 23fdc2e10cad otbr-web[207]: [ERR ]-WEB-----: OpenThread daemon is not running.
Jun 24 00:10:22 23fdc2e10cad otbr-agent[179]: 49d.17:06:33.677 [I] Platform------: RCP reset: RESET_POWER_ON
Jun 24 00:10:22 23fdc2e10cad otbr-agent[179]: 49d.17:06:33.684 [I] Platform------: Software reset RCP successfully
Jun 24 00:10:22 23fdc2e10cad otbr-agent[179]: 49d.17:06:33.684 [I] Platform------: RCP reset: RESET_POWER_ON
Jun 24 00:10:22 23fdc2e10cad otbr-agent[179]: 49d.17:06:33.689 [I] Platform------: Backbone interface is configured to eth0 (2)
Jun 24 00:10:22 23fdc2e10cad kernel: [ 226.418612] tun: Universal TUN/TAP device driver, 1.6
Jun 24 00:10:22 23fdc2e10cad otbr-agent[179]: 49d.17:06:33.713 [I] Platform------: [netif] Sent request#1 to set addr_gen_mode to 1
Jun 24 00:10:22 23fdc2e10cad otbr-agent[179]: 00:00:00.021 [I] ChildSupervsn-: Timeout: 0 -> 190
Jun 24 00:10:22 23fdc2e10cad otbr-agent[179]: 00:00:00.029 [I] InfraIf-------: Init infra netif 2
Jun 24 00:10:22 23fdc2e10cad otbr-agent[179]: 00:00:00.030 [N] BorderRouter--: No valid /48 BR ULA prefix found in settings, generating new one
Jun 24 00:10:22 23fdc2e10cad otbr-agent[179]: 00:00:00.037 [I] Settings------: Saved BrUlaPrefix fd88:d3b2:12d1::/48
Jun 24 00:10:22 23fdc2e10cad otbr-agent[179]: 00:00:00.038 [N] BorderRouter--: BR ULA prefix: fd88:d3b2:12d1::/48 (generated)
Jun 24 00:10:22 23fdc2e10cad otbr-agent[179]: 00:00:00.038 [I] BorderRouter--: Generated local OMR prefix: fd88:d3b2:12d1:1::/64
Jun 24 00:10:22 23fdc2e10cad otbr-agent[179]: 00:00:00.038 [I] BorderRouter--: Generated local NAT64 prefix: fd88:d3b2:12d1:2:0:0::/96
Jun 24 00:10:22 23fdc2e10cad otbr-agent[179]: 00:00:00.038 [N] BorderRouter--: Local on-link prefix: fdde:ad00:beef:cafe::/64
Jun 24 00:10:22 23fdc2e10cad otbr-agent[179]: 00:00:00.038 [I] InfraIf-------: State changed: NOT RUNNING -> RUNNING
Jun 24 00:10:22 23fdc2e10cad otbr-agent[179]: 00:00:00.039 [I] Platform------: Got nameserver #0: 127.0.0.11
Jun 24 00:10:22 23fdc2e10cad otbr-agent[179]: [INFO]-UTILS---: Set state callback: OK
Jun 24 00:10:22 23fdc2e10cad otbr-agent[179]: 00:00:00.040 [I] Nat64---------: NAT64 translator is now NotRunning
Jun 24 00:10:22 23fdc2e10cad otbr-agent[179]: [INFO]-BA------: Publish meshcop service OpenThread BorderRouter #3EEB._meshcop._udp.local.
Jun 24 00:10:22 23fdc2e10cad otbr-agent[179]: 00:00:00.047 [I] Settings------: Saved BorderAgentId {id:6d4aebb211aeed8645edb4ec520f593c}
Jun 24 00:10:22 23fdc2e10cad otbr-agent[179]: [INFO]-MDNS----: Registering new service OpenThread BorderRouter #3EEB._meshcop._udp.local, serviceRef = (nil)
Jun 24 00:10:22 23fdc2e10cad otbr-agent[179]: [INFO]-ADPROXY-: Publish all hosts and services
Jun 24 00:10:22 23fdc2e10cad otbr-agent[179]: [INFO]-ADPROXY-: Started
Jun 24 00:10:22 23fdc2e10cad otbr-agent[179]: [INFO]-DPROXY--: Started
Jun 24 00:10:22 23fdc2e10cad otbr-agent[179]: [INFO]-BA------: Start Thread Border Agent: OK
Jun 24 00:10:22 23fdc2e10cad otbr-agent[179]: 00:00:00.049 [I] BbrLocal------: Add Domain Prefix: ::/0, NotFound
Jun 24 00:10:22 23fdc2e10cad otbr-agent[179]: 00:00:00.049 [I] BbrLocal------: Add BBR Service: seqno (80), delay (5s), timeout (3600s), InvalidState
Jun 24 00:10:22 23fdc2e10cad otbr-agent[179]: [INFO]-APP-----: Thread Border Router started on AIL eth0.
Jun 24 00:10:22 23fdc2e10cad otbr-agent[179]: 00:00:00.052 [I] Notifier------: StateChanged (0x42038200) [NetData PanId NetName ExtPanId BbrState (unknown)]
Jun 24 00:10:22 23fdc2e10cad otbr-agent[179]: 00:00:00.052 [I] Bbr-----------: Start listening on port 61631
Jun 24 00:10:22 23fdc2e10cad otbr-agent[179]: 00:00:00.053 [I] Bbr-----------: Backbone TMF subscribes ff32:40:fdde:ad00:beef:0:0:3: OK
Jun 24 00:10:22 23fdc2e10cad otbr-agent[179]: 00:00:00.053 [I] BbrManager----: Start Backbone TMF agent: OK
Jun 24 00:10:22 23fdc2e10cad otbr-agent[179]: 00:00:00.065 [I] Platform------: Execute command `ipset flush otbr-ingress-allow-dst-swap` = 0
Jun 24 00:10:22 23fdc2e10cad otbr-agent[179]: 00:00:00.078 [I] Platform------: Execute command `ipset flush otbr-ingress-deny-src-swap` = 0
Jun 24 00:10:22 23fdc2e10cad otbr-agent[179]: 00:00:00.091 [I] Platform------: Execute command `ipset add otbr-ingress-deny-src-swap fdde:ad00:beef:0::/64 -exist` = 0
Jun 24 00:10:22 23fdc2e10cad otbr-agent[179]: 00:00:00.104 [I] Platform------: Execute command `ipset swap otbr-ingress-deny-src-swap otbr-ingress-deny-src` = 0
Jun 24 00:10:22 23fdc2e10cad otbr-agent[179]: 00:00:00.117 [I] Platform------: Execute command `ipset swap otbr-ingress-allow-dst-swap otbr-ingress-allow-dst` = 0
Jun 24 00:10:22 23fdc2e10cad otbr-agent[179]: 00:00:00.117 [I] Platform------: MulticastRoutingManager: Disable: OK
Jun 24 00:10:22 23fdc2e10cad otbr-agent[179]: [DEBG]-BBA-----: BackboneAgent: HandleBackboneRouterState: state=1, mBackboneRouterState=0
Jun 24 00:10:22 23fdc2e10cad otbr-agent[179]: 00:00:00.117 [I] RouterTable---: Route table
Jun 24 00:10:22 23fdc2e10cad otbr-agent[179]: 00:00:00.119 [I] Platform------: [netif] Host netif is down
Jun 24 00:10:22 23fdc2e10cad otbr-agent[179]: 00:00:00.120 [I] Platform------: [netif] Succeeded to process request#1
Jun 24 00:10:23 23fdc2e10cad otbr-agent[179]: [INFO]-MDNS----: Received reply for service OpenThread BorderRouter #3EEB._meshcop._udp., serviceRef = 0xaaab1614aa70
Jun 24 00:10:23 23fdc2e10cad otbr-agent[179]: [INFO]-MDNS----: Successfully registered service OpenThread BorderRouter #3EEB._meshcop._udp.
Jun 24 00:10:23 23fdc2e10cad otbr-agent[179]: [INFO]-BA------: Result of publish meshcop service OpenThread BorderRouter #3EEB._meshcop._udp.local: OK
Jun 24 00:10:25 23fdc2e10cad avahi-daemon[151]: Withdrawing address record for fd11:db8:1::2 on eth0.
Jun 24 00:10:25 23fdc2e10cad avahi-daemon[151]: Withdrawing address record for 172.20.0.2 on eth0.
Jun 24 00:10:25 23fdc2e10cad avahi-daemon[151]: Withdrawing address record for 127.0.0.1 on lo.
Jun 24 00:10:25 23fdc2e10cad avahi-daemon[151]: Host name conflict, retrying with 23fdc2e10cad-2
Jun 24 00:10:25 23fdc2e10cad avahi-daemon[151]: Registering new address record for fd11:db8:1::2 on eth0.*.
Jun 24 00:10:25 23fdc2e10cad avahi-daemon[151]: Registering new address record for 172.20.0.2 on eth0.IPv4.
Jun 24 00:10:25 23fdc2e10cad avahi-daemon[151]: Registering new address record for ::1 on lo.*.
Jun 24 00:10:25 23fdc2e10cad avahi-daemon[151]: Registering new address record for 127.0.0.1 on lo.IPv4.
Jun 24 00:10:25 23fdc2e10cad avahi-daemon[151]: Withdrawing address record for ::1 on lo.
Jun 24 00:10:25 23fdc2e10cad avahi-daemon[151]: Host name conflict, retrying with 23fdc2e10cad-3
Jun 24 00:10:27 23fdc2e10cad avahi-daemon[151]: Withdrawing address record for fd11:db8:1::2 on eth0.
Jun 24 00:10:27 23fdc2e10cad avahi-daemon[151]: Withdrawing address record for ::1 on lo.
Jun 24 00:10:27 23fdc2e10cad avahi-daemon[151]: Withdrawing address record for 127.0.0.1 on lo.
Jun 24 00:10:27 23fdc2e10cad avahi-daemon[151]: Host name conflict, retrying with 23fdc2e10cad-4
Jun 24 00:10:27 23fdc2e10cad avahi-daemon[151]: Registering new address record for fd11:db8:1::2 on eth0.*.
Jun 24 00:10:27 23fdc2e10cad avahi-daemon[151]: Registering new address record for 172.20.0.2 on eth0.IPv4.
Jun 24 00:10:27 23fdc2e10cad avahi-daemon[151]: Registering new address record for ::1 on lo.*.
Jun 24 00:10:27 23fdc2e10cad avahi-daemon[151]: Registering new address record for 127.0.0.1 on lo.IPv4.
Jun 24 00:10:28 23fdc2e10cad avahi-daemon[151]: Withdrawing address record for fd11:db8:1::2 on eth0.
Jun 24 00:10:28 23fdc2e10cad avahi-daemon[151]: Withdrawing address record for ::1 on lo.
Jun 24 00:10:28 23fdc2e10cad avahi-daemon[151]: Withdrawing address record for 127.0.0.1 on lo.
Jun 24 00:10:28 23fdc2e10cad avahi-daemon[151]: Host name conflict, retrying with 23fdc2e10cad-5
Jun 24 00:10:28 23fdc2e10cad avahi-daemon[151]: Registering new address record for fd11:db8:1::2 on eth0.*.
Jun 24 00:10:28 23fdc2e10cad avahi-daemon[151]: Registering new address record for 172.20.0.2 on eth0.IPv4.
Jun 24 00:10:28 23fdc2e10cad avahi-daemon[151]: Registering new address record for ::1 on lo.*.
Jun 24 00:10:28 23fdc2e10cad avahi-daemon[151]: Registering new address record for 127.0.0.1 on lo.IPv4.
Jun 24 00:10:29 23fdc2e10cad avahi-daemon[151]: Withdrawing address record for fd11:db8:1::2 on eth0.
Jun 24 00:10:29 23fdc2e10cad avahi-daemon[151]: Withdrawing address record for ::1 on lo.
Jun 24 00:10:29 23fdc2e10cad avahi-daemon[151]: Withdrawing address record for 127.0.0.1 on lo.
Jun 24 00:10:29 23fdc2e10cad avahi-daemon[151]: Host name conflict, retrying with 23fdc2e10cad-6
Jun 24 00:10:29 23fdc2e10cad avahi-daemon[151]: Registering new address record for fd11:db8:1::2 on eth0.*.
Jun 24 00:10:29 23fdc2e10cad avahi-daemon[151]: Registering new address record for 172.20.0.2 on eth0.IPv4.
Jun 24 00:10:29 23fdc2e10cad avahi-daemon[151]: Registering new address record for ::1 on lo.*.
Jun 24 00:10:29 23fdc2e10cad avahi-daemon[151]: Registering new address record for 127.0.0.1 on lo.IPv4.
Jun 24 00:10:30 23fdc2e10cad avahi-daemon[151]: Server startup complete. Host name is 23fdc2e10cad-6.local. Local service cookie is 1309939092.
Jun 24 00:10:30 23fdc2e10cad mDNSResponder: Default: mDNSCoreReceiveResponse: Received from 172.20.0.2:5353 22 2.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.1.0.0.0.8.b.d.0.1.1.d.f.ip6.arpa. PTR 23fdc2e10cad-6.local.
Jun 24 00:10:30 23fdc2e10cad mDNSResponder: Default: mDNSCoreReceiveResponse: Unexpected conflict discarding 20 2.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.1.0.0.0.8.B.D.0.1.1.D.F.ip6.arpa. PTR 23fdc2e10cad.local.
Jun 24 00:10:30 23fdc2e10cad mDNSResponder: Default: mDNSCoreReceiveResponse: Received from 172.20.0.2:5353 22 2.0.20.172.in-addr.arpa. PTR 23fdc2e10cad-6.local.
Jun 24 00:10:30 23fdc2e10cad mDNSResponder: Default: mDNSCoreReceiveResponse: Unexpected conflict discarding 20 2.0.20.172.in-addr.arpa. PTR 23fdc2e10cad.local.
Do you get it to work if you follow the guide in our documentation instead? You can find it here: Thread Border Router.
Marte
Sorry, I don't quite understand what you mean. Are you asking me to verify the co-processor or the Raspberry Pi?
In my case, it's very likely that the co-processor is not working properly. That's because I have another co-processor that works perfectly with the Raspberry Pi.
What I want to know is whether the co-processor from NCS 2.9.0 is incompatible with the environment provided by CSA.
Alternatively, based on the link you shared in your previous reply, could you provide the correct steps for setup? That would be a great help to me.
I was able to get it to work with an nRF52840 DK with the co-processor sample in nRF Connect SDK v2.9.0, so it should work. If you do not get this to work, try v3.0.2 instead.
Are you using a DK or a dongle?
If it is a DK, you must disable the mass storage feature first:
JLinkExe -device NRF52840_XXAA -if SWD -speed 4000 -autoconnect 1 -SelectEmuBySN SEGGER_ID J-Link>MSDDisable Probe configured successfully. J-Link>SetHWFC Force New configuration applies immediately. J-Link>exit
Here are the steps I used:
1. Disable mass storage feature as described above.
2. Build and flash the co-processor sample in v2.9.0:
west build -b nrf52840dk/nrf52840
west flash --recover
3. Install Docker daemon:
sudo apt update && sudo apt install docker.io
4. Start Docker daemon:
sudo systemctl start docker
5. Create the network for the OTBR:
6. Download the OTBR docker image for v2.9.0:
docker pull nrfconnect/otbr:fbde28a
7. Connected the co-processor and verified the device:
nrfjprog --com <snr> /dev/ttyACM0 VCOM0 <snr> /dev/ttyACM1 VCOM1
8. Start the OTBR container:
sudo modprobe ip6table_filter sudo docker run -it --rm --privileged --name otbr --network otbr -p 8080:80 \ --sysctl "net.ipv6.conf.all.disable_ipv6=0 net.ipv4.conf.all.forwarding=1 net.ipv6.conf.all.forwarding=1" \ --volume /dev/ttyACM0:/dev/radio nrfconnect/otbr:fbde28a --radio-url spinel+hdlc+uart:///dev/radio?uart-baudrate=1000000
After this, you can form the network using the instructions here: https://openthread.io/guides/border-router/form-network or opening http://localhost:8080/ in a web browser.
Marte
