I am experiencing an issue with my nRF915DK board. When I connect the board to my PC via USB, the debugger LED blinks continuously.
I have the same issue with a nrf52840DK.
I'm using a JLink_V7.94i driver.
I had try to use different USB cable
Note, the serial number (i.e 1051288714) is displayed in vs code
Thanks in advance , Philippe
Are those boards both new?
Have you flashed any sample on them previously?
Could you try setting the device in Bootloader mode?
Priyanka
These have been already used, and flash with some sample.
Here is the log I had when I open the DK9151 with tthe Nrf Programmer
2025-06-06T11:59:02.492Z INFO Using the bundled core version for nrfutil device: 8.0.0
2025-06-06T11:59:03.166Z INFO Using nrfutil-device version: 2.6.4
2025-06-06T11:59:03.166Z INFO Using nrf-device-lib version: 0.17.35
2025-06-06T11:59:03.166Z INFO Using nrfjprog DLL version: 10.24.2
2025-06-06T11:59:03.166Z INFO Using JLink version: JLink_V7.94i
2025-06-06T11:59:03.542Z INFO Getting serial port options from the persistent store for 001051288714.pc-nrfconnect-programmer
2025-06-06T11:59:03.543Z INFO Getting serial port options from the persistent store for FTC9QOG6.pc-nrfconnect-programmer
2025-06-06T11:59:06.182Z INFO Selecting device with the serial number 001051288714
2025-06-06T11:59:07.799Z INFO Selected device with the serial number 001051288714
2025-06-06T11:59:07.799Z INFO Using nrfutil device to communicate with target via JLink
2025-06-06T11:59:09.298Z INFO Reading readback protection status for Application core
2025-06-06T11:59:09.299Z ERROR Failed "reading readback protection status for application core". Error: code: 1, description: Generic, message: Batch task protection-get failed, [Probe] Emulator error: No emulator with connection info 'Usb(JLinkSerialNumber(1051288714))' was found
2025-06-06T11:59:09.619Z ERROR Error: Failed with exit code 1.
One or more batch tasks failed:
- [Probe] Emulator error: No emulator with connection info 'Usb(JLinkSerialNumber(1051288714))' was found, code: Generic.
Message: Batch task protection-get failed, [Probe] Emulator error: No emulator with connection info 'Usb(JLinkSerialNumber(1051288714))' was found.
2025-06-06T11:59:18.113Z INFO Getting serial port options from the persistent store for 001051288714.pc-nrfconnect-programmer
The issue has been resolved by removing all Windows registry entries related to a specific USB device (by serial number), using the following method:
001051288714).Regards, Philippe
