NRF51822 to NRF24L01
I have a NRF24L01 board, which acts as a receiver. It listens on RF channel 2 using address pipe 0 address as follows 0xC47B4D0331. I am able to transmit to this NRF24L01 board using another NRF24L01 board which acts as the Tx. This has been tested to work.
I am trying to program a NRF51822 as a Tx to work in ESB mode so that I can communicate to the NRF24L01 board as Rx with address pipe 0 set to 0xC47B4D0331.
The code below doesn't work. Can some one comment whether this is the way to go.
#include "nrf_delay.h"
#include "nrf_gpio.h"
#include "nrf_esb.h"
#define PIPE_NUMBER 0 ///pipe 0
#define TX_PAYLOAD_LENGTH 10
static uint8_t my_tx_payload[]= {0,0,0,0,1,0,0,0,0,0};                ///< Payload to send to PRX.
static uint8_t my_rx_payload[10]; ///< Placeholder for received ACK payloads from PRX.
	// Setup port directions
	nrf_gpio_port_dir_set(2, NRF_GPIO_PORT_DIR_OUTPUT);
	// Initialise ESB
        nrf_esb_set_crc_length(	NRF_ESB_CRC_LENGTH_2_BYTE));
	nrf_esb_init(NRF_ESB_MODE_PTX);
	nrf_esb_set_base_address_length(NRF_ESB_BASE_ADDRESS_LENGTH_4B);
	nrf_esb_set_address_prefix_byte(0,0xC4);
	nrf_esb_set_base_address_0(0x7b4d0331);
	nrf_esb_set_channel(2);
	nrf_esb_enable();
	// Add packet into TX queue
	(void)nrf_esb_add_packet_to_tx_fifo(PIPE_NUMBER, my_tx_payload, 10, NRF_ESB_PACKET_USE_ACK);
	while(1)
// If an ACK was received, we send another packet.
void nrf_esb_tx_success(uint32_t tx_pipe, int32_t rssi){
	// Read buttons and load data payload into TX queue
	// my_tx_payload[0] = nrf_gpio_port_read(BUTTONS);
	(void)nrf_esb_add_packet_to_tx_fifo(PIPE_NUMBER, my_tx_payload, TX_PAYLOAD_LENGTH, NRF_ESB_PACKET_USE_ACK);
// If the transmission failed, send a new packet.
void nrf_esb_tx_failed(uint32_t tx_pipe){
	(void)nrf_esb_add_packet_to_tx_fifo(PIPE_NUMBER, my_tx_payload, TX_PAYLOAD_LENGTH, NRF_ESB_PACKET_USE_ACK);}
void nrf_esb_rx_data_ready(uint32_t rx_pipe, int32_t rssi){
	uint32_t my_rx_payload_length;
	// Pop packet and write first byte of the payload to the GPIO port.
	(void)nrf_esb_fetch_packet_from_rx_fifo(PIPE_NUMBER, my_rx_payload, &my_rx_payload_length);
	if (my_rx_payload_length > 0)
// light up LED on port 21 if ack received
		nrf_gpio_port_write(2,16);
void nrf_esb_disabled(void)
