Does nPM2100 support CR123A 1S2P?
Hi Sir,
As we know the nPM2100 support AA/AAA batteries, LiMnO2 coin cells (e.g., CR2032),  Alkaline coin cells (e.g., LR44).
But could nPM2100 support CR123A 1S2P?
Thank you.
BRs, Han
  • Hi Han,
    Currently, the nPM2100 fuel gauge does not support the CR123A 1S2P configuration.
    I assume this request is related to a high-current application , could you share the expected peak and average currents?
    Anyway for experimental evaluation, the closest available model is the CR2032 (LiMnO2), as it shares similar voltage characteristics.
    Tharaka
  • Hi Tharaka,
    Thank you for the update.
    According your feedback, in other words, the nPM2100 doesn't support the high-current battery? e.g. CR123A (1550mAh), or E91 (2500mAh, Alkaline)
    For AA/AAA batteries, the Energizer E91 (2500mAh, Alkaline) and L91 (3500mAh, Ultimate Lithium) are also call AAA batteries.
    Do we support these AA/AAA batteries?
    Thank you.
    BRs, Han
  • Hi
    To clarify, the nPM2100 does support high-capacity batteries such as the CR123A (1550 mAh), E91 (2500 mAh Alkaline – AA), and L91 (3500 mAh Lithium – AA), as well as other AA variants. The battery capacity itself is not a limitation.
    From a PMIC perspective:
    • The boost regulator can deliver up to 150 mA total.
    • The LDO/load switch is supplied from the boost rail, so it shares this 150 mA current limit—not in addition to it.
    So yes, the nPM2100 can work with CR123A or high-capacity AA/AAA batteries, as long as the system load remains within the 150 mA budget.
    From a fuel gauge perspective:
    • The fuel gauge currently supports Alkaline AA/AAA cells like the E91.
    • For CR123A or similar Li/MnO₂ chemistry cells, the CR2032 model can be used as a reference for early evaluation.
    • However, a custom model may be required for accurate state-of-charge estimation. Knowing the expected peak and average currents would help in assessing this further.
    Hope this clarifies.
    Tharaka
  • Hi Tharaka,
    Thank you for the clarify.
    So, we do support CR123A, but doesn't support CR123A 1S2P.
    But if the battery capacity itself is not a limitation and battery voltage doesn't over 3V. Why don't we support 1S2P configuration? it seems doesn't violate the spec.
    The peak current is about 110~120mA, average current is about 10~15mA.
    Thank you.
    BRs, Han
  • Sorry if i misunderstood with the fuel gauge support
    '' Currently, the nPM2100 fuel gauge does not support the CR123A 1S2P configuration.''
    I meant it is just the fuel gauge SW  and the battery model which does not support this configuration.
    I can confirm you that nPM2100 PMIC support this CR123A 1S2P configuration as long as battery pack voltage is within the PMIC input voltage specification.
    Regards
    Tharaka
