Project is not compile with SB_CONFIG_MCUBOOT_SIGNATURE_USING_KMU
We are building project with this config parameters:
SB_CONFIG_BOOTLOADER_MCUBOOT=y
SB_CONFIG_MCUBOOT_SIGNATURE_USING_KMU=y
SB_CONFIG_BOOT_SIGNATURE_TYPE_ED25519=y
SB_CONFIG_BOOT_ENCRYPTION=y
But we get this error messages while compile:
c:/ncs/toolchains/b620d30767/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd.exe: app/libapp.a(encrypted_psa.c.obj): in function `bootutil_aes_ctr_init':
C:/ncs/v2.9.1/bootloader/mcuboot/boot/bootutil/src/encrypted_psa.c:103: undefined reference to `log_const_mcuboot_psa_enc'
c:/ncs/toolchains/b620d30767/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd.exe: app/libapp.a(encrypted_psa.c.obj): in function `boot_decrypt_key':
C:/ncs/v2.9.1/bootloader/mcuboot/boot/bootutil/src/encrypted_psa.c:268: undefined reference to `log_const_mcuboot_psa_enc'
c:/ncs/toolchains/b620d30767/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd.exe: C:/ncs/v2.9.1/bootloader/mcuboot/boot/bootutil/src/encrypted_psa.c:289: undefined reference to `log_const_mcuboot_psa_enc'
c:/ncs/toolchains/b620d30767/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd.exe: app/libapp.a(encrypted_psa.c.obj): in function `bootutil_aes_ctr_encrypt':
C:/ncs/v2.9.1/bootloader/mcuboot/boot/bootutil/src/encrypted_psa.c:354: undefined reference to `log_const_mcuboot_psa_enc'
c:/ncs/toolchains/b620d30767/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd.exe: app/libapp.a(encrypted_psa.c.obj): in function `bootutil_aes_ctr_decrypt':
C:/ncs/v2.9.1/bootloader/mcuboot/boot/bootutil/src/encrypted_psa.c:434: undefined reference to `log_const_mcuboot_psa_enc'
If we use CONFIG_LOG=n for mcuboot, then project compiles normally. Also we get this warnings:
C:/ncs/v2.9.1/bootloader/mcuboot/boot/bootutil/include/bootutil/crypto/aes_ctr.h: In function 'bootutil_aes_ctr_drop':
C:/ncs/v2.9.1/bootloader/mcuboot/boot/bootutil/include/bootutil/crypto/aes_ctr.h:65:26: warning: argument to 'sizeof' in 'memset' call is the same expression as the destination; did you mean to dereference it? [-Wsizeof-pointer-memaccess]
   65 |     memset(ctx, 0, sizeof(ctx));
Is there any way to fix that?
    I am unable to reproduce this compilation error, with my minimal configuration in hello_world:
    hello_world_sysbuild_mcuboot.zip
    Could you check what I'm missing?
    That second warning is something I will report back to the team. That looks incorrect, as the sizeof() should be sizeof(*ctx) to get the type.
    Håkon
    Thank you so much for sharing.
    The issue is that it is the incorrect define that was originally used for the log declaration.
    It shall be declared with BOOT_LOG_MODULE_REGISTER, and not +BOOT_LOG_MODULE_DECLARE.
    Here's a patch for v2.9.x with the proposed fixes:
    diff --git a/boot/bootutil/include/bootutil/crypto/aes_ctr.h b/boot/bootutil/include/bootutil/crypto/aes_ctr.h
    index 44190361..92c8e2a7 100644
    --- a/boot/bootutil/include/bootutil/crypto/aes_ctr.h
    +++ b/boot/bootutil/include/bootutil/crypto/aes_ctr.h
    @@ -62,7 +62,7 @@ void bootutil_aes_ctr_init(bootutil_aes_ctr_context *ctx);
     static inline void bootutil_aes_ctr_drop(bootutil_aes_ctr_context *ctx)
    -    memset(ctx, 0, sizeof(ctx));
    +    memset(ctx, 0, sizeof(*ctx));
     static inline int bootutil_aes_ctr_set_key(bootutil_aes_ctr_context *ctx, const uint8_t *k)
    diff --git a/boot/bootutil/src/encrypted_psa.c b/boot/bootutil/src/encrypted_psa.c
    index c3f72884..38ed3c6e 100644
    --- a/boot/bootutil/src/encrypted_psa.c
    +++ b/boot/bootutil/src/encrypted_psa.c
    @@ -25,7 +25,7 @@
     #include "bootutil_priv.h"
     #include "bootutil/bootutil_log.h"
    -BOOT_LOG_MODULE_DECLARE(mcuboot_psa_enc);
    +BOOT_LOG_MODULE_REGISTER(mcuboot_psa_enc);
     #define EXPECTED_ENC_LEN    BOOT_ENC_TLV_SIZE
     #define EXPECTED_ENC_TLV    IMAGE_TLV_ENC_X25519
    I will ofcourse bring this up internally.
    Håkon
  • This fixes worked perfectly. Is there any information if this changes will be merged in the next SDK version (3.0.3 i guess)?
    This is great to hear!
    Unfortunately, I have not gotten a more detailed description on when this will be fixed, but I have notified our mcuboot team of this bug.
    Håkon
