The URL below does not have the DNs number for v2.9.2, but is it the same as for v2.9.0 and v2.9.1?
Since Bluetooth SIG lists it as v2.9.x, we believe they are the same thing.
Hiroki
Hiroki
This will be an additional check.
Is it correct to understand that the Matter sample code uses the SoftDevice Controller subsystem?
Hiroki
Regarding the DN, I am checking this internally and will get back to you.
H-ogawa said:Is it correct to understand that the Matter sample code uses the SoftDevice Controller subsystem?
You can see from our documentation, that the nRF Connect SDK has the Softdevice Controller as the default BLE controller and also if you check any Matter sample, you can see that the BLE stack is enabled for commissioning. So in short, yes, it should use the SoftDevice controller subsystem.
-Priyanka
Hi,Priyanka
Thank you for your reply.
I checked the documentation.
I understood that it is set to SoftDevice Controller by default and that there is no production support for the Zephyr Bluetooth LE Controller.
I look forward to hearing from you, about DN.
Hiroki
H-ogawa said:I look forward to hearing from you, about DN.
Yes, it's the same as for v2.9.0 and v2.9.1
Thank you for pointing this out. We'll include this.
-Priyanka
Hi,Priyanka
Sorry for the additional confirmation, but is the Thread CID the same?
There is no mention of v2.9.2 here either.
Hiroki
