Run Matter Certification case TC-DGGEN-2.1 can't auto commission success
I used Nordic52480 DK(bulb) as DUT to  run Matter Certification case TC-DGGEN-2.1 .
Steps:
1. setup OTBR on Pi4:./certification-tool/backend/test_collections/matter/scripts/OTBR/otbr_start.sh
2. Config on testharness like below:
"config": {
"test_parameters": null,
"network": {
"wifi": {
"ssid": "testharness",
"password": "wifi-password"
"thread": {
"operational_dataset_hex": "0e08000000000001000035060004001fffe00708fdefb6c1c9cf5b0d0410bcb0fc3d56ac8fbc88baa63ba2af4e760c0402a0f7f8000300000f0102123402081111111122222222030444454d4f051000112233445566778899aabbccddeeff"
"dut_config": {
"discriminator": "3840",
"setup_code": "20202021",
"pairing_mode": "ble-thread",
"chip_timeout": null,
"chip_use_paa_certs": false,
"trace_log": true
"pics": {
"clusters": {
"General Diagnostics Cluster Test Plan": {
"name": "General Diagnostics Cluster Test Plan",
"items": {
"DGGEN.S": {
"number": "DGGEN.S",
"enabled": true
"DGGEN.C": {
"number": "DGGEN.C",
"enabled": false
"DGGEN.S.A0000": {
"number": "DGGEN.S.A0000",
"enabled": true
"DGGEN.S.A0001": {
"number": "DGGEN.S.A0001",
"enabled": true
"DGGEN.S.A0002": {
"number": "DGGEN.S.A0002",
"enabled": false
"DGGEN.S.A0003": {
"number": "DGGEN.S.A0003",
"enabled": false
"DGGEN.S.A0004": {
"number": "DGGEN.S.A0004",
"enabled": false
"DGGEN.S.A0005": {
"number": "DGGEN.S.A0005",
"enabled": false
"DGGEN.S.A0006": {
"number": "DGGEN.S.A0006",
"enabled": false
"DGGEN.S.A0007": {
"number": "DGGEN.S.A0007",
"enabled": false
"DGGEN.S.A0008": {
"number": "DGGEN.S.A0008",
"enabled": true
"DGGEN.S.C00.Rsp": {
"number": "DGGEN.S.C00.Rsp",
"enabled": true
"DGGEN.S.E00": {
"number": "DGGEN.S.E00",
"enabled": false
"DGGEN.S.E01": {
"number": "DGGEN.S.E01",
"enabled": false
"DGGEN.S.E02": {
"number": "DGGEN.S.E02",
"enabled": false
"DGGEN.S.E03": {
"number": "DGGEN.S.E03",
"enabled": true
"DGGEN.S.C": {
"number": "DGGEN.S.C",
"enabled": false
"DGGEN.S.E": {
"number": "DGGEN.S.E",
"enabled": false
"DGGEN.S.A": {
"number": "DGGEN.S.A",
"enabled": false
"DGGEN.C.A0000": {
"number": "DGGEN.C.A0000",
"enabled": false
"DGGEN.C.A0001": {
"number": "DGGEN.C.A0001",
"enabled": false
"DGGEN.C.A0002": {
"number": "DGGEN.C.A0002",
"enabled": false
"DGGEN.C.A0003": {
"number": "DGGEN.C.A0003",
"enabled": false
"DGGEN.C.A0004": {
"number": "DGGEN.C.A0004",
"enabled": false
"DGGEN.C.A0005": {
"number": "DGGEN.C.A0005",
"enabled": false
"DGGEN.C.A0006": {
"number": "DGGEN.C.A0006",
"enabled": false
"DGGEN.C.A0007": {
"number": "DGGEN.C.A0007",
"enabled": false
"DGGEN.C.A0008": {
"number": "DGGEN.C.A0008",
"enabled": false
"DGGEN.C.C00.Tx": {
"number": "DGGEN.C.C00.Tx",
"enabled": false
3. run  TC-DGGEN-2.1, but auto commission fail. (nordic52840 factory reset before run case) , log refer to below file.
UI_Test_Run_2025_06_11_10_51_25.log
  • Hi chew_moon_cake,
    I just want to update you that Maria is out of office. I tried to resume her internal communication thread, but there hasn't been any feedback yet.
    Another of our engineer with more Matter experience is returning next week. I will try to loop her in and see if she can help better.
    Our apologies for the inconvenience. Thank you for your patience.
    Hieu
    Could you please provide more details?
    We need to have logs from border router to check what "not properly" started.
    If the Border Router (BR) is started by the Test harness, you can check if the srp server is running on the Border Router with:
    docker exec -ti <otbr_container> ot-ctl srp server state
    If the srp server is not running, you can enable it with:
    docker exec -ti <otbr_container> ot-ctl srp server enable
    If the Border Router is not started by the Test Harness, you can start it on your own.
    For example, you can start it with the script in certification-tool/backend/test_collections/matter/scripts/OTBR/.
    If the Border Router is on a separated device from the Test Harness, that also works.
    On the Border Router, you need to get the dataset hex with
    dataset active -x
    Then please set the dataset hex in the project config in the Test Harness at these locations:
    "test_parameters": {
        "thread-dataset-hex":  <output_of_dataset_active_x>
    and
    "thread": {
        "operational_dataset_hex": <output_of_dataset_active_x>
    Hieu
