nRF SDK v2.9.1 GPIO interrupt not working after wake up from long sleep
Hi everyone,
I'm working on a project using nrf52832 with SDK v2.9.1. I build my application on top of the nrf Desktop framework (https://docs.nordicsemi.com/bundle/ncs-latest/page/nrf/applications/nrf_desktop/README.html).
The GPIO interrupt stopped working after wake up from a long (few hours) sleep. The application stopped response to GPIO events. I can see the GPIO LATCH register is not cleared (therefore may not be a hardware issue). The GPIO configuration registers have expected value as well. The device still can connect to the host using bluetooth.
Logging didn't show any explicit error. The application is still running and connected to bluetooth. Most likely the irq_handler (nrfx_gpiote.c) is not called anymore. If I attach the debugger, the device will be restarted and the issue is gone. Even the debugger is attached, setting a breakpoint to the isr usually crashes the application.
Any suggestion how can I further debug this issue?
Thank you
    After deep sleep (System OFF), GPIO pin configuration can be lost, especially if the device is in debug interface mode. There is common errata [81] GPIO: PIN_CNF is not retained when in debug interface mode about pin_cnf is not retained in debug mode after reset. Have you tried without RTT or debugger attached to check if the error occurs?
    After waking up from sleep it is recommended to reconfigure GPIO and interrupt which necessary because configuration maybe lost after a long sleep. You can add the following code after entering sleep mode in the main() function.
    configure_button_interrupt();
    If you see the LATCH register is set but your handler is not called, it means the hardware event occurred, but the software did not respond—often due to missed or misconfigured interrupts or not clearing the LATCH/event after handling.
    We need to clear the LATCH register because, once a pin's SENSE condition is met, the corresponding bit in the LATCH register is set to 1 and remains set until it is explicitly cleared by the CPU. If the LATCH bit is not cleared, it will continue to indicate that the event has occurred, even if the pin no longer meets the SENSE condition. This can prevent new events from being detected and may block further interrupts or event handling for that pin.
    So, we need to clear the LATCH bit in your handler to allow new events to be detected. So in the main function, the following should be present.
    Check LATCH register (if using nrf_gpio directly)
            if (NRF_P0->LATCH & (1 << BUTTON_PIN)) {
                LOG_INF("LATCH set: event occurred but interrupt may not have fired");
                // Clear LATCH
                NRF_P0->LATCH = (1 << BUTTON_PIN);
  • Thank you Kazi for the reply.
    After more debugging, I think the issue happens after I enable the motion sensor. I use a PAW3222 optical motion sensor.
    The nrf desktop application example uses a PAW3212 sensor. The sensor driver for my PAW3222 is basically a copy of the PAW3212 (v2.9.1\nrf\drivers\sensor\paw3212\paw3212.c) with register address updates.
    Therefore, I think it is probably reproducible using the reference design. i.e. the nrf52dmouse_nrf52832 design. I don't have a PAW3212 at the moment, so, I cannot verify it by myself very soon.
    Here are the steps how can I reproduce the issue with a PAW3222:
     1. Connect the device to a computer using bluetooth. (without any debugger connected)
     2. Put the computer to sleep after 20min. Meanwhile, the device should already be in sleep mode after 20min.
     3. Wait for a few hours. I usually left the computer and device for a night of 8hrs. Shorter sleep time may not be able to trigger the issue.
     4. Wake up the device by moving the PAW3222 sensor. The device should be able to be waked up. The device should be able to connect to the host computer. Then pushing any button won't work anymore.
    To your previous suggestion,
    1. this issue can be reproduced without connected debugger, so, it may not be directly related to the issue in the errata.
    2. I tried to clear the LATCH register after wake up by writing 0 to it. However, the LATCH register cannot be cleared. I still need to do more experiments to see whether I made a mistake somewhere.
    The following is my PAW3222 driver, it is basically the same with the PAW3212 driver.
    #define DT_DRV_COMPAT pixart_paw3222
    #include <zephyr/kernel.h>
    #include <zephyr/drivers/sensor.h>
    #include <zephyr/device.h>
    #include <zephyr/drivers/spi.h>
    #include <zephyr/sys/byteorder.h>
    #include <sensor/paw3222.h>
    LOG_MODULE_REGISTER(paw3222, CONFIG_PAW3222_LOG_LEVEL);
    /* Timings defined by spec */
    #define T_NCS_SCLK	1			/* 1 us */
    #define T_SRX		(20 - T_NCS_SCLK)	/* 20 us */
    #define T_SCLK_NCS_WR	(35 - T_NCS_SCLK)	/* 35 us */
    #define T_SWX		(180 - T_SCLK_NCS_WR)	/* 180 us */
    #define T_SRAD		160			/* 160 us */
    /* Sensor registers */
    #define PAW3222_REG_PRODUCT_ID		0x00
    #define PAW3222_REG_REVISION_ID		0x01
    #define PAW3222_REG_MOTION		    0x02
    #define PAW3222_REG_DELTA_X_LOW		0x03
    #define PAW3222_REG_DELTA_Y_LOW		0x04
    #define PAW3222_REG_OPERATION_MODE	0x05
    #define PAW3222_REG_CONFIGURATION	0x06
    #define PAW3222_REG_WRITE_PROTECT	0x09
    #define PAW3222_REG_DELTA_XY_HIGH	0x12
    #define PAW3222_REG_MOUSE_OPTION	0x19
    #define PAW3222_REG_SLEEP1		0x0A
    #define PAW3222_REG_SLEEP2		0x0B
    #define PAW3222_REG_SLEEP3		0x0C
    #define PAW3222_REG_CPI_X		0x0D
    #define PAW3222_REG_CPI_Y		0x0E
    /* CPI */
    #define PAW3222_CPI_STEP		30u
    #define PAW3222_CPI_MIN			(0x10 * PAW3222_CPI_STEP)
    #define PAW3222_CPI_MAX			(0x86 * PAW3222_CPI_STEP)
    /* Sleep */
    #define PAW3222_SLP_ENH_POS		4u
    #define PAW3222_SLP2_ENH_POS	3u
    #define PAW3222_SLP3_ENH_POS	5u
    #define PAW3222_ETM_POS			0u
    #define PAW3222_ETM_SIZE		4u
    #define PAW3222_FREQ_POS		(PAW3222_ETM_POS + PAW3222_ETM_SIZE)
    #define PAW3222_FREQ_SIZE		4u
    #define PAW3222_ETM_MIN			0u
    #define PAW3222_ETM_MAX			BIT_MASK(PAW3222_ETM_SIZE)
    #define PAW3222_ETM_MASK		(PAW3222_ETM_MAX << PAW3222_ETM_POS)
    #define PAW3222_FREQ_MIN		0u
    #define PAW3222_FREQ_MAX		BIT_MASK(PAW3222_FREQ_SIZE)
    #define PAW3222_FREQ_MASK		(PAW3222_FREQ_MAX << PAW3222_FREQ_POS)
    /* Motion status bits */
    #define PAW3222_MOTION_STATUS_MOTION	BIT(7)
    #define PAW3222_MOTION_STATUS_DYOVF	BIT(4)
    #define PAW3222_MOTION_STATUS_DXOVF	BIT(3)
    /* Configuration bits */
    #define PAW3222_CONFIG_CHIP_RESET	BIT(7)
    /* Mouse option bits */
    #define PAW3222_MOUSE_OPT_XY_SWAP	BIT(5)
    #define PAW3222_MOUSE_OPT_Y_INV		BIT(4)
    #define PAW3222_MOUSE_OPT_X_INV		BIT(3)
    #define PAW3222_MOUSE_OPT_12BITMODE	BIT(2)
    /* Convert deltas to x and y */
    #define PAW3222_DELTA_X(xy_high, x_low)	expand_s12((((xy_high) & 0xF0) << 4) | (x_low))
    #define PAW3222_DELTA_Y(xy_high, y_low)	expand_s12((((xy_high) & 0x0F) << 8) | (y_low))
    /* Sensor identification values */
    #define PAW3222_PRODUCT_ID		0x30
    /* Write protect magic */
    #define PAW3222_WPMAGIC			0x5A
    #define SPI_WRITE_BIT			BIT(7)
    /* Helper macros used to convert sensor values. */
    #define PAW3222_SVALUE_TO_CPI(svalue)   ((uint32_t)(svalue).val1)
    #define PAW3222_SVALUE_TO_TIME(svalue)  ((uint32_t)(svalue).val1)
    #define PAW3222_SVALUE_TO_BOOL(svalue)  ((svalue).val1 != 0)
    enum async_init_step {
    	ASYNC_INIT_STEP_POWER_UP,
    	ASYNC_INIT_STEP_VERIFY_ID,
    	ASYNC_INIT_STEP_CONFIGURE,
    	ASYNC_INIT_STEP_COUNT
    struct paw3222_data {
    	const struct device          *dev;
    	struct gpio_callback         irq_gpio_cb;
    	struct k_spinlock            lock;
    	int16_t                      x;
    	int16_t                      y;
    	sensor_trigger_handler_t     data_ready_handler;
    	struct k_work                trigger_handler_work;
    	struct k_work_delayable      init_work;
    	enum async_init_step         async_init_step;
    	int                          err;
    	bool                         ready;
    struct paw3222_config {
    	struct gpio_dt_spec irq_gpio;
    	struct spi_dt_spec bus;
    	struct gpio_dt_spec cs_gpio;
    static const int32_t async_init_delay[ASYNC_INIT_STEP_COUNT] = {
    	[ASYNC_INIT_STEP_POWER_UP]  = 1,
    	[ASYNC_INIT_STEP_VERIFY_ID] = 0,
    	[ASYNC_INIT_STEP_CONFIGURE] = 0,
    static int paw3222_async_init_power_up(const struct device *dev);
    static int paw3222_async_init_verify_id(const struct device *dev);
    static int paw3222_async_init_configure(const struct device *dev);
    static int (* const async_init_fn[ASYNC_INIT_STEP_COUNT])(const struct device *dev) = {
    	[ASYNC_INIT_STEP_POWER_UP]  = paw3222_async_init_power_up,
    	[ASYNC_INIT_STEP_VERIFY_ID] = paw3222_async_init_verify_id,
    	[ASYNC_INIT_STEP_CONFIGURE] = paw3222_async_init_configure,
    static int16_t expand_s12(int16_t x)
    	/* Left shifting of negative values is undefined behavior, so we cannot
    	 * depend on automatic integer promotion (it will convert int16_t to int).
    	 * To expand sign we cast s16 to unsigned int and left shift it then
    	 * cast it to signed integer and do the right shift. Since type is
    	 * signed compiler will perform arithmetic shift. This last operation
    	 * is implementation defined in C but defined in the compiler's
    	 * documentation and common for modern compilers and CPUs.
    	return ((signed int)((unsigned int)x << 20)) >> 20;
    static int spi_cs_ctrl(const struct device *dev, bool enable)
    	const struct paw3222_config *config = dev->config;
    	int err;
    	if (!enable) {
    		k_busy_wait(T_NCS_SCLK);
    	err = gpio_pin_set_dt(&config->cs_gpio, (int)enable);
    	if (err) {
    		LOG_ERR("SPI CS ctrl failed");
    	if (enable) {
    	return err;
    static int reg_read(const struct device *dev, uint8_t reg, uint8_t *buf)
    	int err;
    	__ASSERT_NO_MSG((reg & SPI_WRITE_BIT) == 0);
    	err = spi_cs_ctrl(dev, true);
    	if (err) {
    		return err;
    	/* Write register address. */
    	const struct spi_buf tx_buf = {
    		.buf = &reg,
    		.len = 1
    	const struct spi_buf_set tx = {
    		.buffers = &tx_buf,
    		.count = 1
    	err = spi_write_dt(&config->bus, &tx);
    	if (err) {
    		LOG_ERR("Reg read failed on SPI write");
    		return err;
    	k_busy_wait(T_SRAD);
    	/* Read register value. */
    	struct spi_buf rx_buf = {
    		.buf = buf,
    		.len = 1,
    	const struct spi_buf_set rx = {
    		.buffers = &rx_buf,
    		.count = 1,
    	err = spi_read_dt(&config->bus, &rx);
    	if (err) {
    		LOG_ERR("Reg read failed on SPI read");
    		return err;
    	err = spi_cs_ctrl(dev, false);
    	if (err) {
    		return err;
    	k_busy_wait(T_SRX);
    	return 0;
    static int reg_write(const struct device *dev, uint8_t reg, uint8_t val)
    	int err;
    	if (err) {
    		return err;
    	uint8_t buf[] = {
    		SPI_WRITE_BIT | reg,
    		val
    		.buf = buf,
    		.len = ARRAY_SIZE(buf)
    		.buffers = &tx_buf,
    		.count = 1
    	if (err) {
    		LOG_ERR("Reg write failed on SPI write");
    		return err;
    	k_busy_wait(T_SCLK_NCS_WR);
    	if (err) {
    		return err;
    	k_busy_wait(T_SWX);
    	return 0;
    static int update_cpi(const struct device *dev, uint32_t cpi)
    	int err;
    	if ((cpi > PAW3222_CPI_MAX) || (cpi < PAW3222_CPI_MIN)) {
    		LOG_ERR("CPI %" PRIu32 " out of range", cpi);
    		return -EINVAL;
    	uint8_t regval = cpi / PAW3222_CPI_STEP;
    	LOG_DBG("Set CPI: %u (requested: %u, reg:0x%" PRIx8 ")",
    		regval * PAW3222_CPI_STEP, cpi, regval);
    	err = reg_write(dev, PAW3222_REG_WRITE_PROTECT, PAW3222_WPMAGIC);
    	if (err) {
    		LOG_ERR("Cannot disable write protect");
    		return err;
    	err = reg_write(dev, PAW3222_REG_CPI_X, regval);
    	if (err) {
    		LOG_ERR("Failed to change x CPI");
    		return err;
    	err = reg_write(dev, PAW3222_REG_CPI_Y, regval);
    	if (err) {
    		LOG_ERR("Failed to change y CPI");
    		return err;
    	err = reg_write(dev, PAW3222_REG_WRITE_PROTECT, 0);
    	if (err) {
    		LOG_ERR("Cannot enable write protect");
    	return err;
    static int update_sleep_timeout(const struct device *dev, uint8_t reg_addr,
    				uint32_t timeout_ms)
    	uint32_t timeout_step_ms;
    	switch (reg_addr) {
    	case PAW3222_REG_SLEEP1:
    		timeout_step_ms = 32;
    	case PAW3222_REG_SLEEP2:
    	case PAW3222_REG_SLEEP3:
    		timeout_step_ms = 20480;
    		LOG_ERR("Not supported");
    		return -ENOTSUP;
    	uint32_t etm = timeout_ms / timeout_step_ms - 1;
    	if ((etm < PAW3222_ETM_MIN) || (etm > PAW3222_ETM_MAX)) {
    		LOG_WRN("Sleep timeout %" PRIu32 " out of range", timeout_ms);
    		return -EINVAL;
    	LOG_DBG("Set sleep%d timeout: %u (requested: %u, reg:0x%" PRIx8 ")",
    		reg_addr - PAW3222_REG_SLEEP1 + 1,
    		(etm + 1) * timeout_step_ms,
    		timeout_ms,
    		etm);
    	int err;
    	if (err) {
    		return err;
    	uint8_t regval;
    	err = reg_read(dev, reg_addr, &regval);
    	if (err) {
    		LOG_ERR("Failed to read sleep register");
    		return err;
    	__ASSERT_NO_MSG((etm & PAW3222_ETM_MASK) == etm);
    	regval &= ~PAW3222_ETM_MASK;
    	regval |= (etm << PAW3222_ETM_POS);
    	err = reg_write(dev, reg_addr, regval);
    	if (err) {
    		LOG_ERR("Failed to change sleep time");
    		return err;
    	if (err) {
    	return err;
    static int update_sample_time(const struct device *dev, uint8_t reg_addr,
    			      uint32_t sample_time_ms)
    	uint32_t sample_time_step;
    	uint32_t sample_time_min;
    	uint32_t sample_time_max;
    	switch (reg_addr) {
    		sample_time_step = 4;
    		sample_time_min = 4;
    		sample_time_max = 64;
    		sample_time_step = 64;
    		sample_time_min = 64;
    		sample_time_max = 1024;
    		return -ENOTSUP;
    	if ((sample_time_ms > sample_time_max) ||
    	    (sample_time_ms < sample_time_min))	{
    		LOG_WRN("Sample time %" PRIu32 " out of range", sample_time_ms);
    		return -EINVAL;
    	uint8_t reg_freq = (sample_time_ms - sample_time_min) / sample_time_step;
    	LOG_DBG("Set sleep%d sample time: %u (requested: %u, reg:0x%" PRIx8 ")",
    		(reg_freq * sample_time_step) + sample_time_min,
    		sample_time_ms,
    		reg_freq);
    	__ASSERT_NO_MSG(reg_freq <= PAW3222_FREQ_MAX);
    	int err;
    	if (err) {
    		return err;
    	uint8_t regval;
    	if (err) {
    		return err;
    	regval &= ~PAW3222_FREQ_MASK;
    	regval |= (reg_freq << PAW3222_FREQ_POS);
    	if (err) {
    		LOG_ERR("Failed to change sample time");
    		return err;
    	if (err) {
    	return err;
    static int toggle_sleep_modes(const struct device *dev, uint8_t reg_addr1,
    			      uint8_t reg_addr2, bool enable)
    	int err = reg_write(dev, PAW3222_REG_WRITE_PROTECT,
    			    PAW3222_WPMAGIC);
    	if (err) {
    		return err;
    	uint8_t regval;
    	LOG_DBG("%sable sleep", (enable) ? ("En") : ("Dis"));
    	/* Sleep 1 and Sleep 2 */
    	err = reg_read(dev, reg_addr1, &regval);
    	if (err) {
    		LOG_ERR("Failed to read operation mode register");
    		return err;
    	uint8_t sleep_enable_mask = BIT(PAW3222_SLP_ENH_POS) |
    				 BIT(PAW3222_SLP2_ENH_POS);
    	if (enable) {
    		regval |= sleep_enable_mask;
    	} else {
    		regval &= ~sleep_enable_mask;
    	err = reg_write(dev, reg_addr1, regval);
    	if (err) {
    		LOG_ERR("Failed to %sable sleep", (enable) ? ("en") : ("dis"));
    		return err;
    	/* Sleep 3 */
    	err = reg_read(dev, reg_addr2, &regval);
    	if (err) {
    		LOG_ERR("Failed to read configuration register");
    		return err;
    	sleep_enable_mask = BIT(PAW3222_SLP3_ENH_POS);
    	if (enable) {
    	} else {
    	err = reg_write(dev, reg_addr2, regval);
    	if (err) {
    		return err;
    	if (err) {
    	return err;
    static void irq_handler(const struct device *gpiob, struct gpio_callback *cb,
    			uint32_t pins)
    	int err;
    	struct paw3222_data *data = CONTAINER_OF(cb, struct paw3222_data,
    						 irq_gpio_cb);
    	const struct device *dev = data->dev;
    	err = gpio_pin_interrupt_configure_dt(&config->irq_gpio,
    					      GPIO_INT_DISABLE);
    	if (unlikely(err)) {
    		LOG_ERR("Cannot disable IRQ");
    		k_panic();
    	k_work_submit(&data->trigger_handler_work);
    static void trigger_handler(struct k_work *work)
    	sensor_trigger_handler_t handler;
    	int err = 0;
    	struct paw3222_data *data = CONTAINER_OF(work, struct paw3222_data,
    	k_spinlock_key_t key = k_spin_lock(&data->lock);
    	handler = data->data_ready_handler;
    	k_spin_unlock(&data->lock, key);
    	if (!handler) {
    		return;
    	struct sensor_trigger trig = {
    		.type = SENSOR_TRIG_DATA_READY,
    		.chan = SENSOR_CHAN_ALL,
    	handler(dev, &trig);
    	if (data->data_ready_handler) {
    						      GPIO_INT_LEVEL_ACTIVE);
    		LOG_ERR("Cannot re-enable IRQ");
    		k_panic();
    	return reg_write(dev, PAW3222_REG_CONFIGURATION,
    			 PAW3222_CONFIG_CHIP_RESET);
    	int err;
    	uint8_t product_id;
    	err = reg_read(dev, PAW3222_REG_PRODUCT_ID, &product_id);
    	if (err) {
    		LOG_ERR("Cannot obtain product ID");
    		return err;
    	LOG_DBG("Product ID: 0x%" PRIx8, product_id);
    	if (product_id != PAW3222_PRODUCT_ID) {
    		LOG_ERR("Invalid product ID (0x%" PRIx8")!", product_id);
    		return -EIO;
    	return err;
    	int err;
    	if (!err) {
    		uint8_t mouse_option = 0;
    		if (IS_ENABLED(CONFIG_PAW3222_ORIENTATION_90)) {
    			mouse_option |= PAW3222_MOUSE_OPT_XY_SWAP |
    					PAW3222_MOUSE_OPT_Y_INV;
    		} else if (IS_ENABLED(CONFIG_PAW3222_ORIENTATION_180)) {
    			mouse_option |= PAW3222_MOUSE_OPT_Y_INV |
    					PAW3222_MOUSE_OPT_X_INV;
    		} else if (IS_ENABLED(CONFIG_PAW3222_ORIENTATION_270)) {
    		if (IS_ENABLED(CONFIG_PAW3222_12_BIT_MODE)) {
    			mouse_option |= PAW3222_MOUSE_OPT_12BITMODE;
    		err = reg_write(dev, PAW3222_REG_MOUSE_OPTION,
    				mouse_option);
    	if (!err) {
    	return err;
    static void paw3222_async_init(struct k_work *work)
    						 init_work.work);
    	LOG_DBG("PAW3222 async init step %d", data->async_init_step);
    	data->err = async_init_fn[data->async_init_step](dev);
    	if (data->err) {
    		LOG_ERR("PAW3222 initialization failed");
    	} else {
    		data->async_init_step++;
    		if (data->async_init_step == ASYNC_INIT_STEP_COUNT) {
    			data->ready = true;
    			LOG_INF("PAW3222 initialized");
    		} else {
    			k_work_schedule(&data->init_work,
    					K_MSEC(async_init_delay[
    						data->async_init_step]));
    static int paw3222_init_irq(const struct device *dev)
    	int err;
    	struct paw3222_data *data = dev->data;
    	if (!device_is_ready(config->irq_gpio.port)) {
    		LOG_ERR("IRQ GPIO device not ready");
    		return -ENODEV;
    	err = gpio_pin_configure_dt(&config->irq_gpio, GPIO_INPUT);
    	if (err) {
    		LOG_ERR("Cannot configure IRQ GPIO");
    		return err;
    	gpio_init_callback(&data->irq_gpio_cb, irq_handler,
    			   BIT(config->irq_gpio.pin));
    	err = gpio_add_callback(config->irq_gpio.port,
    				&data->irq_gpio_cb);
    	if (err) {
    		LOG_ERR("Cannot add IRQ GPIO callback");
    	return err;
    static int paw3222_init(const struct device *dev)
    	int err;
    	/* Assert that negative numbers are processed as expected */
    	__ASSERT_NO_MSG(-1 == expand_s12(0xFFF));
    	k_work_init(&data->trigger_handler_work, trigger_handler);
    	data->dev = dev;
    	if (!spi_is_ready_dt(&config->bus)) {
    		return -ENODEV;
    	if (!device_is_ready(config->cs_gpio.port)) {
    		LOG_ERR("SPI CS device not ready");
    		return -ENODEV;
    	err = gpio_pin_configure_dt(&config->cs_gpio, GPIO_OUTPUT_INACTIVE);
    	if (err) {
    		LOG_ERR("Cannot configure SPI CS GPIO");
    		return err;
    	err = paw3222_init_irq(dev);
    	if (err) {
    		return err;
    	k_work_init_delayable(&data->init_work, paw3222_async_init);
    			K_MSEC(async_init_delay[data->async_init_step]));
    	return err;
    static int paw3222_sample_fetch(const struct device *dev, enum sensor_channel chan)
    	uint8_t motion_status;
    	int err;
    	if (unlikely(chan != SENSOR_CHAN_ALL)) {
    		return -ENOTSUP;
    	if (unlikely(!data->ready)) {
    		LOG_INF("Device is not initialized yet");
    		return -EBUSY;
    	err = reg_read(dev, PAW3222_REG_MOTION, &motion_status);
    	if (err) {
    		LOG_ERR("Cannot read motion");
    		return err;
    	if ((motion_status & PAW3222_MOTION_STATUS_MOTION) != 0) {
    		uint8_t x_low;
    		uint8_t y_low;
    		if ((motion_status & PAW3222_MOTION_STATUS_DXOVF) != 0) {
    			LOG_WRN("X delta overflowed");
    		if ((motion_status & PAW3222_MOTION_STATUS_DYOVF) != 0) {
    			LOG_WRN("Y delta overflowed");
    		err = reg_read(dev, PAW3222_REG_DELTA_X_LOW, &x_low);
    		if (err) {
    			LOG_ERR("Cannot read X delta");
    			return err;
    		err = reg_read(dev, PAW3222_REG_DELTA_Y_LOW, &y_low);
    		if (err) {
    			LOG_ERR("Cannot read Y delta");
    			return err;
    			uint8_t xy_high;
    			err = reg_read(dev, PAW3222_REG_DELTA_XY_HIGH,
    				       &xy_high);
    			if (err) {
    				LOG_ERR("Cannot read XY delta high");
    				return err;
    			data->x = PAW3222_DELTA_X(xy_high, x_low);
    			data->y = PAW3222_DELTA_Y(xy_high, y_low);
    		} else {
    			data->x = (int8_t)x_low;
    			data->y = (int8_t)y_low;
    	} else {
    		data->x = 0;
    		data->y = 0;
    	return err;
    static int paw3222_channel_get(const struct device *dev, enum sensor_channel chan,
    			       struct sensor_value *val)
    		return -EBUSY;
    	switch (chan) {
    	case SENSOR_CHAN_POS_DX:
    		val->val1 = data->x;
    		val->val2 = 0;
    	case SENSOR_CHAN_POS_DY:
    		val->val1 = data->y;
    		val->val2 = 0;
    		return -ENOTSUP;
    	return 0;
    static int paw3222_trigger_set(const struct device *dev,
    			       const struct sensor_trigger *trig,
    			       sensor_trigger_handler_t handler)
    	int err;
    	if (unlikely(trig->type != SENSOR_TRIG_DATA_READY)) {
    		return -ENOTSUP;
    	if (unlikely(trig->chan != SENSOR_CHAN_ALL)) {
    		return -ENOTSUP;
    		return -EBUSY;
    	if (handler) {
    	} else {
    						      GPIO_INT_DISABLE);
    	if (!err) {
    		data->data_ready_handler = handler;
    	return err;
    static int paw3222_attr_set(const struct device *dev, enum sensor_channel chan,
    			    enum sensor_attribute attr,
    			    const struct sensor_value *val)
    	int err;
    		return -ENOTSUP;
    		return -EBUSY;
    	switch ((uint32_t)attr) {
    	case PAW3222_ATTR_CPI:
    		err = update_cpi(dev, PAW3222_SVALUE_TO_CPI(*val));
    	case PAW3222_ATTR_SLEEP_ENABLE:
    		err = toggle_sleep_modes(dev,
    					 PAW3222_REG_OPERATION_MODE,
    					 PAW3222_SVALUE_TO_BOOL(*val));
    	case PAW3222_ATTR_SLEEP1_TIMEOUT:
    		err = update_sleep_timeout(dev,
    					   PAW3222_REG_SLEEP1,
    					   PAW3222_SVALUE_TO_TIME(*val));
    	case PAW3222_ATTR_SLEEP2_TIMEOUT:
    					   PAW3222_REG_SLEEP2,
    	case PAW3222_ATTR_SLEEP3_TIMEOUT:
    					   PAW3222_REG_SLEEP3,
    	case PAW3222_ATTR_SLEEP1_SAMPLE_TIME:
    		err = update_sample_time(dev,
    					 PAW3222_REG_SLEEP1,
    	case PAW3222_ATTR_SLEEP2_SAMPLE_TIME:
    					 PAW3222_REG_SLEEP2,
    	case PAW3222_ATTR_SLEEP3_SAMPLE_TIME:
    					 PAW3222_REG_SLEEP3,
    		LOG_ERR("Unknown attribute");
    		return -ENOTSUP;
    	return err;
    static const struct sensor_driver_api paw3222_driver_api = {
    	.sample_fetch = paw3222_sample_fetch,
    	.channel_get  = paw3222_channel_get,
    	.trigger_set  = paw3222_trigger_set,
    	.attr_set     = paw3222_attr_set,
    #define PAW3222_DEFINE(n)						       \
    	static struct paw3222_data data##n;				       \
    	static const struct paw3222_config config##n = {		       \
    		.irq_gpio = GPIO_DT_SPEC_INST_GET(n, irq_gpios),	       \
    		.bus = {						       \
    			.bus = DEVICE_DT_GET(DT_INST_BUS(n)),		       \
    			.config = {					       \
    				.frequency = DT_INST_PROP(n,		       \
    							  spi_max_frequency),  \
    				.operation = SPI_WORD_SET(8) |		       \
    					     SPI_TRANSFER_MSB |		       \
    					     SPI_MODE_CPOL | SPI_MODE_CPHA,    \
    				.slave = DT_INST_REG_ADDR(n),		       \
    		.cs_gpio = SPI_CS_GPIOS_DT_SPEC_GET(DT_DRV_INST(n)),	       \
    	DEVICE_DT_INST_DEFINE(n, paw3222_init, NULL, &data##n, &config##n,     \
    			      POST_KERNEL, CONFIG_SENSOR_INIT_PRIORITY,	       \
    			      &paw3222_driver_api);
    DT_INST_FOREACH_STATUS_OKAY(PAW3222_DEFINE)
    Thank you!
  • For the LATCH register reset, I should write 1s to it instead of 0s.
  • Yes.
    If you are writing '1' to clear the LATCH register and still observe that it cannot be cleared, please ensure you are following the documented workaround for a known hardware anomaly: after writing to the LATCH register, you must wait at least 3 CPU cycles before reading it again
    After clearing, insert at least 3 dummy reads of the LATCH register before checking its state ([173] GPIO: Writes to LATCH register take several CPU cycles to take effect)
    // Clear the LATCH register for the desired pin
    NRF_GPIO->LATCH = (1UL << pin_number);
    // Perform 3 dummy reads to ensure the value is updated
    volatile uint32_t dummy;
    dummy = NRF_GPIO->LATCH;
    // Now it is safe to read or check the LATCH register
    uint32_t latch_state = NRF_GPIO->LATCH;
