Good afternoon!
As the NRF7002 takes about 400ms to start up from shutdown, we would like to use the very low power deep sleep function for quick startup.
Unfortunately, due to the archtitecture of the design, the main power rail will be shut off when the main microcontroller is in deep sleep. However, a deep sleep power supply of 3.0V @ 2mA will be avaiable.
Is there a specific pin out of all the power pins on the NRF7002 that is used for deep sleep? This way I could attach it to the deep sleep supply while the other power pins will be connected to the normal 3V3 voltage rail.
As the different power pins are not described in the datasheet, I'm a bit puzzled on what their purpose is.
Thank you in advance for helping us.
Kind regards
Simone
