I have a zephyr zbus project running on the nrf52840DK that’s working well. We want to port the project to the nrf54H20DK, but I’m having trouble seeing the log messages. I’m not sure if it’s even executing. So, I went ahead and built the sample Hello_World zbus example just to get something working and still don’t see any log activity. I then went ahead and built this same sample for the nrf54L15DK and that is working well. For some reason, I can’t get anything to run on the nrf54H20DK. Unfortunately, J-Link doesn’t support this part yet so I’m unable to debug the project along with the RTT viewer and ozone being unavailable. I’m wondering if the board is not working properly or if there is something missing that is preventing the device from outputting log messages. We only have one of these boards. I’ve attached the source code and the prj.conf file.
CONFIG_LOG_MODE_MINIMAL=y CONFIG_BOOT_BANNER=n CONFIG_MAIN_THREAD_PRIORITY=5 CONFIG_ZBUS=y CONFIG_ZBUS_LOG_LEVEL_INF=y CONFIG_ZBUS_CHANNEL_NAME=y CONFIG_ZBUS_OBSERVER_NAME=y CONFIG_ZBUS_RUNTIME_OBSERVERS=y CONFIG_PRINTK=y # Disable RTT CONFIG_USE_SEGGER_RTT=n CONFIG_RTT_CONSOLE=n # Enable UART console CONFIG_CONSOLE=y CONFIG_UART_CONSOLE=y # Enable logging over UART CONFIG_LOG=y CONFIG_LOG_BACKEND_UART=y CONFIG_LOG_BACKEND_RTT=n CONFIG_LOG_DEFAULT_LEVEL=4 CONFIG_LOG_MODE_IMMEDIATE=y # Serial/UART settings CONFIG_SERIAL=y CONFIG_UART_INTERRUPT_DRIVEN=y # Optional: Enable shell over UART CONFIG_SHELL=y CONFIG_SHELL_BACKENDS=y CONFIG_SHELL_BACKEND_SERIAL=y CONFIG_SHELL_BACKEND_RTT=n
/* * Copyright (c) 2022 Rodrigo Peixoto <[email protected]> * SPDX-License-Identifier: Apache-2.0 */ #include <stdint.h> #include <zephyr/kernel.h> #include <zephyr/sys/printk.h> #include <zephyr/logging/log.h> #include <zephyr/zbus/zbus.h> // LOG_MODULE_DECLARE(zbus, CONFIG_ZBUS_LOG_LEVEL); LOG_MODULE_REGISTER(main, LOG_LEVEL_INF); struct version_msg { uint8_t major; uint8_t minor; uint16_t build; }; struct acc_msg { int x; int y; int z; }; ZBUS_CHAN_DEFINE(version_chan, /* Name */ struct version_msg, /* Message type */ NULL, /* Validator */ NULL, /* User data */ ZBUS_OBSERVERS_EMPTY, /* observers */ ZBUS_MSG_INIT(.major = 0, .minor = 1, .build = 2) /* Initial value major 0, minor 1, build 2 */ ); ZBUS_CHAN_DEFINE(acc_data_chan, /* Name */ struct acc_msg, /* Message type */ NULL, /* Validator */ NULL, /* User data */ ZBUS_OBSERVERS(foo_lis, bar_sub), /* observers */ ZBUS_MSG_INIT(.x = 0, .y = 0, .z = 0) /* Initial value */ ); static bool simple_chan_validator(const void *msg, size_t msg_size) { ARG_UNUSED(msg_size); const int *simple = msg; if ((*simple >= 0) && (*simple < 10)) { return true; } return false; } ZBUS_CHAN_DEFINE(simple_chan, /* Name */ int, /* Message type */ simple_chan_validator, /* Validator */ NULL, /* User data */ ZBUS_OBSERVERS_EMPTY, /* observers */ 0 /* Initial value is 0 */ ); static void listener_callback_example(const struct zbus_channel *chan) { const struct acc_msg *acc = zbus_chan_const_msg(chan); LOG_INF("From listener -> Acc x=%d, y=%d, z=%d", acc->x, acc->y, acc->z); } ZBUS_LISTENER_DEFINE(foo_lis, listener_callback_example); ZBUS_SUBSCRIBER_DEFINE(bar_sub, 4); static void subscriber_task(void) { const struct zbus_channel *chan; while (!zbus_sub_wait(&bar_sub, &chan, K_FOREVER)) { struct acc_msg acc; if (&acc_data_chan == chan) { zbus_chan_read(&acc_data_chan, &acc, K_MSEC(500)); LOG_INF("From subscriber -> Acc x=%d, y=%d, z=%d", acc.x, acc.y, acc.z); } } } K_THREAD_DEFINE(subscriber_task_id, CONFIG_MAIN_STACK_SIZE, subscriber_task, NULL, NULL, NULL, 3, 0, 0); static bool print_channel_data_iterator(const struct zbus_channel *chan, void *user_data) { int *count = user_data; LOG_INF("%d - Channel %s:", *count, zbus_chan_name(chan)); LOG_INF(" Message size: %d", zbus_chan_msg_size(chan)); LOG_INF(" Observers:"); ++(*count); struct zbus_channel_observation *observation; for (int16_t i = chan->data->observers_start_idx, limit = chan->data->observers_end_idx; i < limit; ++i) { STRUCT_SECTION_GET(zbus_channel_observation, i, &observation); __ASSERT(observation != NULL, "observation must be not NULL"); LOG_INF(" - %s", observation->obs->name); } struct zbus_observer_node *obs_nd, *tmp; SYS_SLIST_FOR_EACH_CONTAINER_SAFE(&chan->data->observers, obs_nd, tmp, node) { LOG_INF(" - %s", obs_nd->obs->name); } return true; } static bool print_observer_data_iterator(const struct zbus_observer *obs, void *user_data) { int *count = user_data; LOG_INF("%d - %s %s", *count, obs->type == ZBUS_OBSERVER_LISTENER_TYPE ? "Listener" : "Subscriber", zbus_obs_name(obs)); ++(*count); return true; } int main(void) { int err, value; struct acc_msg acc1 = {.x = 1, .y = 1, .z = 1}; const struct version_msg *v = zbus_chan_const_msg(&version_chan); printk("Hello from nRF54H20\n"); LOG_INF("Sensor sample started raw reading, version %u.%u-%u!", v->major, v->minor, v->build); int count = 0; LOG_INF("Channel list:"); zbus_iterate_over_channels_with_user_data(print_channel_data_iterator, &count); count = 0; LOG_INF("Observers list:"); zbus_iterate_over_observers_with_user_data(print_observer_data_iterator, &count); zbus_chan_pub(&acc_data_chan, &acc1, K_SECONDS(1)); k_msleep(1000); acc1.x = 2; acc1.y = 2; acc1.z = 2; zbus_chan_pub(&acc_data_chan, &(acc1), K_SECONDS(1)); value = 5; err = zbus_chan_pub(&simple_chan, &value, K_MSEC(200)); if (err == 0) { LOG_INF("Pub a valid value to a channel with validator successfully."); } value = 15; err = zbus_chan_pub(&simple_chan, &value, K_MSEC(200)); if (err == -ENOMSG) { LOG_INF("Pub an invalid value to a channel with validator successfully."); } return 0; }
