NRF52840dk to custom board debugging
  • I’ve designed and fabricated two custom boards around the nRF52840 SoC.
  • I use an nRF52840 DK as an SWD debugger to communicate with each board.
  • Using nrfjprog, I can read from and write to on-chip registers—including REG0 for VTG—via commands like:
    nrfjprog --memwr 0x10001304 --val 0x01 # set REG0 = 1.8 V
    nrfjprog --memwr 0x10001304 --val 0x05 # set REG0 = 5.0 V
  • Before flashing any firmware, a memory read at 0x10001304 returns all 1s (0xFFFFFFFF), showing the erased default state.
  • After flashing my Blinky example, the same address returns values like 0x034F or 0x0874, confirming the code image was written.
  • In nRF Connect for Desktop’s Programmer app, I see the “Program” operation complete successfully and can verify the flash contents.
  • I’ve assigned ten different GPIO pins in my Blinky code and wired LEDs (with series resistors and correct orientation) to each, but none of them blink.
  • I’ve meticulously checked every hardware detail—power rails, decoupling caps, pin-mapping, LED wiring, ground returns—and everything is correct.
  • Despite successful flashing and verified hardware, the firmware never drives the LEDs.
  • I suspect there may be an issue in my pin configuration, initialization sequence in code, or a subtle board-layout/design oversight.
  • I’m looking for insights on what I might be missing so that my GPIO outputs will toggle and the LEDs will blink as intended
