Unable to build bluetooth hci_uart zephyr sample
 I am trying to build bluetooth hci_uart sample for esp32 board and haven't had much success so far. I am running this command to build:
`west build -p always -b nrf5340dk/nrf5340/cpuapp samples/bluetooth/hci_uart -d build`
warning: BT_CTLR_DTM_HCI (defined at subsys/bluetooth/controller/Kconfig.dtm:14) was assigned the value 'y' but got the value 'n'. Check these unsatisfied dependencies: BT_CTLR_DTM_HCI_SUPPORT (=n), HAS_BT_CTLR (=n). See docs.zephyrproject.org/.../kconfig.html and/or look up BT_CTLR_DTM_HCI in the menuconfig/guiconfig interface. The Application Development Primer, Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be helpful too. warning: BT_CTLR_ASSERT_HANDLER (defined at subsys/bluetooth/controller/Kconfig:1181) was assigned the value 'y' but got the value 'n'. Check these unsatisfied dependencies: HAS_BT_CTLR (=n). See docs.zephyrproject.org/.../kconfig.html and/or look up BT_CTLR_ASSERT_HANDLER in the menuconfig/guiconfig interface. The Application Development Primer, Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be helpful too. warning: HAS_NORDIC_DRIVERS (defined at modules/hal_nordic/Kconfig:7) has direct dependencies 0 with value n, but is currently being y-selected by the following symbols: - SOC_SERIES_NRF53X (defined at soc/nordic/Kconfig.soc:36, soc/nordic/nrf53/Kconfig.soc:6, soc/nordic/nrf53/Kconfig:6), with value y, direct dependencies y (value: y), and select condition SOC_FAMILY_NORDIC_NRF (value: y) warning: CMSIS_CORE_HAS_SYSTEM_CORE_CLOCK (defined at soc/nxp/imxrt/imxrt6xx/Kconfig.defconfig:8, modules/cmsis_6/Kconfig:23) has direct dependencies (SOC_SERIES_IMXRT6XX && SOC_FAMILY_NXP_IMXRT) || (HAS_CMSIS_CORE && 0) with value n, but is currently being y-selected by the following symbols: - SOC_FAMILY_NORDIC_NRF (defined at soc/nordic/Kconfig.soc:19, soc/nordic/Kconfig:9), with value y, direct dependencies y (value: y), and select condition ARM (value: y) warning: HAS_NRFX (defined at modules/hal_nordic/nrfx/Kconfig:4) has direct dependencies 0 with value n, but is currently being y-selected by the following symbols: - SOC_SERIES_NRF53X (defined at soc/nordic/Kconfig.soc:36, soc/nordic/nrf53/Kconfig.soc:6, soc/nordic/nrf53/Kconfig:6), with value y, direct dependencies y (value: y), and select condition SOC_FAMILY_NORDIC_NRF (value: y) warning: OPENAMP (defined at modules/Kconfig.open-amp:7) has direct dependencies ZEPHYR_OPEN_AMP_MODULE with value n, but is currently being y-selected by the following symbols: - IPC_SERVICE_BACKEND_RPMSG (defined at subsys/ipc/ipc_service/backends/Kconfig:10), with value y, direct dependencies MBOX && DT_HAS_ZEPHYR_IPC_OPENAMP_STATIC_VRINGS_ENABLED && IPC_SERVICE (value: y), and select condition MBOX && DT_HAS_ZEPHYR_IPC_OPENAMP_STATIC_VRINGS_ENABLED && IPC_SERVICE (value: y) warning: NRFX_CLOCK (defined at modules/hal_nordic/nrfx/Kconfig:16) has direct dependencies HAS_NRFX && 0 with value n, but is currently being y-selected by the following symbols: - CLOCK_CONTROL_NRF (defined at drivers/clock_control/Kconfig.nrf:13), with value y, direct dependencies DT_HAS_NORDIC_NRF_CLOCK_ENABLED && CLOCK_CONTROL (value: y), and select condition !CLOCK_CONTROL_NRF_FORCE_ALT && DT_HAS_NORDIC_NRF_CLOCK_ENABLED && CLOCK_CONTROL (value: y) warning: NRFX_GPPI (defined at modules/hal_nordic/nrfx/Kconfig:237) has direct dependencies HAS_NRFX && 0 with value n, but is currently being y-selected by the following symbols: - SOC_NRF53_RTC_PRETICK (defined at soc/nordic/nrf53/Kconfig:93), with value y, direct dependencies ((SYS_CLOCK_EXISTS && SOC_NRF5340_CPUNET) || SOC_NRF5340_CPUAPP) && SOC_SERIES_NRF53X && SOC_FAMILY_NORDIC_NRF (value: y), and select condition ((SYS_CLOCK_EXISTS && SOC_NRF5340_CPUNET) || SOC_NRF5340_CPUAPP) && SOC_SERIES_NRF53X && SOC_FAMILY_NORDIC_NRF (value: y) - UART_0_ENHANCED_POLL_OUT (defined at drivers/serial/Kconfig.nrfx_uart_instance:21), with value y, direct dependencies !n && HAS_HW_NRF_UARTE0 && (HAS_HW_NRF_PPI || HAS_HW_NRF_DPPIC) && (HAS_HW_NRF_UART0 || HAS_HW_NRF_UARTE0) && UART_NRFX && SERIAL (value: y), and select condition !n && HAS_HW_NRF_UARTE0 && (HAS_HW_NRF_PPI || HAS_HW_NRF_DPPIC) && (HAS_HW_NRF_UART0 || HAS_HW_NRF_UARTE0) && UART_NRFX && SERIAL (value: y) warning: NRFX_GPIOTE0 (defined at modules/hal_nordic/nrfx/Kconfig:199) has direct dependencies HAS_NRFX && 0 with value n, but is currently being y-selected by the following symbols: - GPIO_NRFX (defined at drivers/gpio/Kconfig.nrfx:4), with value y, direct dependencies DT_HAS_NORDIC_NRF_GPIO_ENABLED && GPIO (value: y), and select condition HAS_HW_NRF_GPIOTE0 && DT_HAS_NORDIC_NRF_GPIO_ENABLED && GPIO (value: y) warning: NRFX_IPC (defined at modules/hal_nordic/nrfx/Kconfig:260) has direct dependencies HAS_NRFX && 0 with value n, but is currently being y-selected by the following symbols: - MBOX_NRFX_IPC (defined at drivers/mbox/Kconfig.nrfx:4), with value y, direct dependencies DT_HAS_NORDIC_MBOX_NRF_IPC_ENABLED && MBOX (value: y), and select condition DT_HAS_NORDIC_MBOX_NRF_IPC_ENABLED && MBOX (value: y) warning: NRFX_CLOCK_LFXO_TWO_STAGE_ENABLED (defined at modules/hal_nordic/nrfx/Kconfig:22) has direct dependencies NRFX_CLOCK && HAS_NRFX && 0 with value n, but is currently being y-selected by the following symbols: - CLOCK_CONTROL_NRF_K32SRC_XTAL (defined at drivers/clock_control/Kconfig.nrf:41), with value y, direct dependencies <choice CLOCK_CONTROL_NRF_SOURCE> (value: y), and select condition !SOC_SERIES_BSIM_NRFXX && !CLOCK_CONTROL_NRF_FORCE_ALT && <choice CLOCK_CONTROL_NRF_SOURCE> (value: y) warning: NRFX_CLOCK_LF_SRC_XTAL (defined at modules/hal_nordic/nrfx/Kconfig:31) has direct dependencies NRFX_CLOCK && HAS_NRFX && 0 with value n, but is currently being y-selected by the following symbols: - CLOCK_CONTROL_NRF_K32SRC_XTAL (defined at drivers/clock_control/Kconfig.nrf:41), with value y, direct dependencies <choice CLOCK_CONTROL_NRF_SOURCE> (value: y), and select condition !CLOCK_CONTROL_NRF_FORCE_ALT && <choice CLOCK_CONTROL_NRF_SOURCE> (value: y) Parsing /Kconfig Loaded configuration '/boards/nordic/nrf5340dk/nrf5340dk_nrf5340_cpuapp_defconfig' Merged configuration '/samples/bluetooth/hci_uart/prj.conf' Merged configuration '/samples/bluetooth/hci_uart/boards/nrf5340dk_nrf5340_cpuapp.conf' error: Aborting due to Kconfig warnings CMake Error at /cmake/modules/kconfig.cmake:373 (message): command failed with return code: 1 Call Stack (most recent call first): /cmake/modules/zephyr_default.cmake:131 (include) /share/zephyr-package/cmake/ZephyrConfig.cmake:66 (include) /share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate) CMakeLists.txt:5 (find_package) -- Configuring incomplete, errors occurred!
    Did you mean the nRF5340 board? Just want to make sure there is no misunderstanding, since the rest of your question seems pretty nRF5340 oriented.
    What NCS version are you using? In some versions, we had some issues that the network core for the nRF5340 is not configured correctly in the Zephyr samples (such as zephyr\samples\bluetooth\hci_uart).
    To fix this, try pulling some files from one of the nrf samples, such as nrf\samples\bluetooth\peripheral_uart.
    I have not been able to reproduce the exact same build error that you posted, but I don't know what NCS version you are using.
    Try copying these files from peripheral_uart, and paste them in hci_uart (replace them if it exists, create it if not):
    Kconfig.sysbuild
    sysbuild\ipc_radio\prj.conf
    Let me know what NCS you are using if it doesn't solve the issue.
    Edvin
