psa_generate_key failed! (Error: -134)
I am using NCS 3.0.0 and I want to generate keys ...
But the method I am using to generate keys is giving me this error
Here is the code where it is returning error:
psa_set_key_usage_flags(&key_attributes, PSA_KEY_USAGE_SIGN_HASH | PSA_KEY_USAGE_DECRYPT | PSA_KEY_USAGE_EXPORT);
psa_set_key_lifetime(&key_attributes, PSA_KEY_PERSISTENCE_VOLATILE);
psa_set_key_algorithm(&key_attributes, PSA_ALG_RSA_PKCS1V15_SIGN(PSA_ALG_SHA_256));
psa_set_key_type(&key_attributes, PSA_KEY_TYPE_RSA_KEY_PAIR);
psa_set_key_bits(&key_attributes, (use_rsa_2048) ? KEY_SIZE : KEY_SIZE_1024);
status = psa_generate_key(&key_attributes, &m_initial_keypair_handle);
if (status != PSA_SUCCESS)
LOG_INF("psa_generate_key failed! (Error: %d)", status);
return APP_ERROR;
I need to Know How can I generate keys in NCS 3.0.0? Is there any example code for it?
    Which sample do you base this on?
    Which configurations have you added to prj.conf to support the features you need for this?
    Sigurd Hellesvik
  • The issue has been resolved. It was due to the heap size.
    By the this was the configuration I was using :
    # Enable nordic security backend and PSA APIs
    CONFIG_MBEDTLS_LIBRARY_NRF_SECURITY=y
    CONFIG_MBEDTLS_PSA_CRYPTO_C=y
    CONFIG_MBEDTLS_USE_PSA_CRYPTO=y
    # Mbedtls configuration
    CONFIG_MBEDTLS_RSA_C=y
    CONFIG_MBEDTLS_PK_C=y
    CONFIG_MBEDTLS_PK_PARSE_C=y
    CONFIG_MBEDTLS_PK_WRITE_C=y
    CONFIG_MBEDTLS_PKCS1_V15=y
    CONFIG_CRYPTO=y
    CONFIG_MBEDTLS=y
    CONFIG_NRF_SECURITY=y
    CONFIG_MBEDTLS_ENABLE_HEAP=y
    CONFIG_MBEDTLS_HEAP_SIZE=38912
    CONFIG_PSA_CRYPTO_DRIVER_CC3XX=y
    CONFIG_PSA_CRYPTO_DRIVER_OBERON=n
    CONFIG_MBEDTLS_LEGACY_CRYPTO_C=y
    CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR_IMPORT=y
    CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR_EXPORT=y
    CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR_GENERATE=y
    CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR_DERIVE=y
    # Key types
    CONFIG_PSA_WANT_KEY_TYPE_RSA_PUBLIC_KEY=y
    CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_SIGN=y
    CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_CRYPT=y
    # CONFIG_PSA_CRYPTO_DRIVER_ALG_CBC_NO_PADDING_CC3XX=n
    # Algorithms
    CONFIG_PSA_WANT_ALG_SHA_256=y
    # Define key size
    CONFIG_PSA_WANT_RSA_KEY_SIZE_2048=y
