Channel Forcing and Configuring Channel Selection Algorithm
Hello Nordic Support Team,
I have three queries to make.
  • Is it possible to force the channel in which the data transmission is happening using nRF52840 DK.
To explain more, I am implementing a UART Communication with nRF DK and connected to a mobile phone and capturing the data using a Dongle. I am seeing this regular channel hopping(FHSS) mechanism of BLE. Instead of that, I'd like to force the data to be transmitted in one channel even if there is interference.
  • The next is I would like to configure the Channel Selection Algorithm, I guess we have the feasibility to do so.
  • Finally, I want to know whether it is possible to configure the channel hopping sequence or is there any relation with CSA to it?
Thanks in advance!
    No, it is not possible to set a BLE device to use only one single channel. It is against the Bluetooth Specification. I don't have the number from the top of my head, but I believe that you need to use 15 channels in your channel map.
    So you will not be able to do this using our SoftDevice Controller (Bluetooth stack). Zephyr's bluetooth stack is open source, so in theory you can do anything there, but in the end, a peripheral (which is the usual role for the nRF) can only request channel map updates. They are then accepted or declined by the central (the phone, typically).
    If you were the central in the connection, however, and the phone the peripheral, the central could in theory send a channel map update with only one channel, but I doubt that a phone (or any serious/certified BLE device) would accept this, and it would probably disconnect immediately.
    May I ask why you want to only use one channel?
    Edvin
  • Thanks for explaining the situation Edvin.
    Regarding the question you asked, we are testing out to create interference in some particular spectrum in 2.4GHz. So that is why we need channel to be forced in a narrowband.
    So, I guess we can configure the nrf52840 DK as central and configre a particular channel map in it. then if I use another DK as a peripheral maybe i could do it?
  • Not possible with Bluetooth Low Energy.
    Are you doing this to perform some test case? Or are you going to use the nRF52DK as a noise source on a specific channel?
    BR,
    Edvin
  • Yes Exactly,
    I wanted to use it as a noise source and want to test interference in 2.4GHz Spectrum.
  • I understand. No, you can not use Bluetooth for this. It will not allow you to use only one channel. I suggest you look into using a proprietary radio protocol.
    I don't know what SDK type you are using. But perhaps you can look into the ESB (Enhanced ShockBurst) sample, which is a proprietary radio protocol. If you are using this, you have more control of the radio directly. When you are using the SoftDevice controller, the radio is unavailable from the application.
    Edvin
