customize the Nina AoA C2909 Nina TAG
Dear Staff,
we have some Ublox C2909 TAG based on your nRF52833 chip.We need to program them for an RTLS project.
In particular we need to:
We have following doubts/information to ask :
  1. how can we download the demo code (link above) by SWD and not by USB(UART) ? Which are the step to follow in Visual studio by using an external programmer?
  2. do you have a demo app in which the nrf52833 or similar work like  an I2C slave in order to integrate it the demo app?
  3. Is it possible for massive production , use a raspberry PI and OpenOCD to flash the FW on the nrf52833 chips without an external debugger in between them ? I see this tutorial that seem to work (Overview | Programming Microcontrollers using OpenOCD on a Raspberry Pi | Adafruit Learning System) , can you confirm?
Hope you can help!
Thanks a lot.
  • how can we download the demo code (link above) by SWD and not by USB(UART) ? Which are the step to follow in Visual studio by using an external programmer?
    If there is more than one external programmer or DK attached when you flash from VS code, you will be prompted which you want to choose when flashing.
    Look for overlay files using compatible = "nordic,nrf-twis"; An example can be:
    \nrf\tests\benchmarks\i2c_endless\
    \zephyr\tests\boards\nrf\i2c\i2c_slave\
    Our nrfjprog and nrfutil command line tools are using SEGGER J-link, so I typically recommend to check out production programmers from SEGGER. Other vendors may also exists, but not directly supported by us.
    Kenneth
  • HI Kenneth ,
    thanks a lot for clearification.
    I will try the \zephyr\tests\boards\nrf\i2c\i2c_slave\
    Nicola
