I am working on the channel sounding feature on the 54l15 and I want to perform it sequentially between 3 reflectors and one initiator. I realized that after I make a disconnection with a reflector, unless it reboots, it's not able to connect back. I am really puzzled by this as this looks like a simple solution but I have not a clue. This is my code for it. I'm thinking that maybe it's because when I disconnect it I didn't clean up the resources properly? It would return E: Advertising failed to start (err -12). Maybe this is also something I need to address on the initiator code?
#include <zephyr/types.h>
#include <zephyr/kernel.h>
#include <zephyr/sys/reboot.h>
#include <zephyr/bluetooth/conn.h>
#include <zephyr/bluetooth/uuid.h>
#include <zephyr/bluetooth/cs.h>
#include <bluetooth/services/ras.h>
#include <dk_buttons_and_leds.h>
LOG_MODULE_REGISTER(app_main, LOG_LEVEL_INF);
#define CON_STATUS_LED DK_LED1
static K_SEM_DEFINE(sem_connected, 0, 1);
static struct bt_conn *connection;
static const struct bt_data ad[] = {
BT_DATA_BYTES(BT_DATA_FLAGS, (BT_LE_AD_GENERAL | BT_LE_AD_NO_BREDR)),
BT_DATA_BYTES(BT_DATA_UUID16_ALL, BT_UUID_16_ENCODE(BT_UUID_RANGING_SERVICE_VAL)),
BT_DATA(BT_DATA_NAME_COMPLETE, CONFIG_BT_DEVICE_NAME, sizeof(CONFIG_BT_DEVICE_NAME) - 1),
static void connected_cb(struct bt_conn *conn, uint8_t err)
(void)bt_addr_le_to_str(bt_conn_get_dst(conn), addr, sizeof(addr));
LOG_INF("Connected to %s (err 0x%02X)", addr, err);
if (err) {
bt_conn_unref(conn);
connection = NULL;
connection = bt_conn_ref(conn);
k_sem_give(&sem_connected);
dk_set_led_on(CON_STATUS_LED);
static void disconnected_cb(struct bt_conn *conn, uint8_t reason)
LOG_INF("Disconnected (reason 0x%02X)", reason);
connection = NULL;
dk_set_led_off(CON_STATUS_LED);
// sys_reboot(SYS_REBOOT_COLD);
int err;
err = bt_enable(NULL);
if (err) {
LOG_ERR("Bluetooth init failed (err %d)", err);
return 0;
err = bt_le_adv_start(BT_LE_ADV_CONN_FAST_2, ad, ARRAY_SIZE(ad), NULL, 0);
if (err) {
LOG_ERR("Advertising failed to start (err %d)", err);
return 0;
static void remote_capabilities_cb(struct bt_conn *conn,
uint8_t status,
struct bt_conn_le_cs_capabilities *params)
ARG_UNUSED(conn);
ARG_UNUSED(params);
if (status == BT_HCI_ERR_SUCCESS) {
LOG_INF("CS capability exchange completed.");
} else {
LOG_WRN("CS capability exchange failed. (HCI status 0x%02x)", status);
static void config_create_cb(struct bt_conn *conn,
uint8_t status,
struct bt_conn_le_cs_config *config)
ARG_UNUSED(conn);
LOG_INF("CS config creation complete. ID: %d", config->id);
} else {
LOG_WRN("CS config creation failed. (HCI status 0x%02x)", status);
static void security_enable_cb(struct bt_conn *conn, uint8_t status)
ARG_UNUSED(conn);
LOG_INF("CS security enabled.");
} else {
LOG_WRN("CS security enable failed. (HCI status 0x%02x)", status);
static void procedure_enable_cb(struct bt_conn *conn,
uint8_t status,
struct bt_conn_le_cs_procedure_enable_complete *params)
ARG_UNUSED(conn);
if (params->state == 1) {
LOG_INF("CS procedures enabled.");
} else {
LOG_INF("CS procedures disabled.");
} else {
LOG_WRN("CS procedures enable failed. (HCI status 0x%02x)", status);
BT_CONN_CB_DEFINE(conn_cb) = {
.connected = connected_cb,
.disconnected = disconnected_cb,
.le_cs_read_remote_capabilities_complete = remote_capabilities_cb,
.le_cs_config_complete = config_create_cb,
.le_cs_security_enable_complete = security_enable_cb,
.le_cs_procedure_enable_complete = procedure_enable_cb,
int err;
LOG_INF("Starting Channel Sounding Reflector Sample");
dk_leds_init();
if (err) {
return 0;
if (err) {
return 0;
while (true) {
k_sem_take(&sem_connected, K_FOREVER);
const struct bt_le_cs_set_default_settings_param default_settings = {
.enable_initiator_role = false,
.enable_reflector_role = true,
.cs_sync_antenna_selection = BT_LE_CS_ANTENNA_SELECTION_OPT_REPETITIVE,
.max_tx_power = BT_HCI_OP_LE_CS_MAX_MAX_TX_POWER,
err = bt_le_cs_set_default_settings(connection, &default_settings);
if (err) {
LOG_ERR("Failed to configure default CS settings (err %d)", err);
return 0;
I also tried a sequential model where I enable and disable channel sounding on each device instead of disconnecting, but I realized that the results are similar to those from concurrent models. They are all able to maintain connections but one one device actually receives data. Would this also be because the firmware was not optimized for this use case? Thank you in advance.
Sincerely,
Triston Tsui
