Non-simultaneous multi-image DFU OTA over WiFi? Rollback capabilities?
I'm looking for answers and some explanation for two main questions - is it possible to perform non-simultaneous multi-image FOTA over WiFi? Is it possible to support update rollback for both cores on the nRF5340?
For context, I'm currently working with a custom board that features the nRF5340 (running custom application on application core, HCI IPC sample on network core), nRF7002, and external SPI-NOR flash (where all new images are being stored and swapped). The company I work for maintains a private server from which images are downloaded via HTTPS, and we're looking to support rollback functionality for at least the application core, but ideally for the network core, as well.
I've seen some threads, such as this one, that suggest that this capability is not supported at all due to the reason mentioned in the documentation for simultaneous multi-image updates. Additionally, in taking the complete DevAcademy NCS Intermediate course (being sure to read through the DFU lessons multiple times), I saw it mentioned why non-simultaneous updates are discouraged for the nRF5340.
So, if simultaneous multi-image updates prevent rollback capability, and the usage of BLE for DFU prevents non-simultaneous updates from being feasible for the nRF5340, I feel the resultant predicament begs the question, wouldn't a non-simultaneous multi-image update work fine in my use case? Since the network core is only running the HCI IPC sample and DFU is taking place over WiFi via the nRF7002, in the event that the interface between the cores changes, the host MCU would still be able to download and apply the network core's update despite not being able to communicate with it, right? Or are there other interactions between the cores that are necessary for the host's operation and would prevent it from updating the network core?
I'm not seeing much more documentation on the topic of non-simultaneous multi-image updates other than them not being recommended for FOTA, so I can't tell if this is a lost cause, but if they are feasible, then wouldn't update rollbacks for either core also be feasible?
Thank you!
  • Hi Abhijith,
    Thank you for getting back to me! I appreciate the heads up regarding possible delays, that's very good to know!
    I believe you can follow an update sequence like this
    Something like this is just what I was looking for! I was having some trouble wrapping my head around what sequence would work but what you've outlined makes sense to me. I'll keep an eye out for confirmation!
    And thank you for your explanation regarding how the application core utilizes the PCD area in RAM during the DFU process, however my question lies less in how it works and more in why it works that way.
    However, during this rollback, MCUboot may also attempt to "restore" the network core image
    What exactly do you mean when you say MCUboot "may" attempt to restore the image? Is it indeterminate behavior? Or would it attempt to do so as a means of following suit with a simultaneous update (i.e. if images are updated simultaneously, they should also be rolled back simultaneously)? In the case you've presented, would the triggered DFU process be a simultaneous update or would it be sequential like what was discussed earlier?
    Hopefully my questions make sense within this context, though please let me know if they don't and I can try to rephrase for clarity!
    Thank you again!
  • Hello Amira,
    Sorry for the confusion. I was trying to explain the process mentioned in the note (linked in one of my responses). I was describing a case of a simultaneous DFU process, specifically, how a rollback during a simultaneous update affects the network core, or simply what that note is trying to convey.
    Although the note falls under the topic of simultaneous updates on the nRF5340, it actually highlights a deeper technical detail, the network core does not support rollback. Unlike the application core, the network core doesn’t have a separate flash area to store a backup of its firmware. This means that if you update it and something goes wrong, there’s no way to automatically revert to the previous version.
    If both cores are updated together, they should be rolled back together. In your case, since you're performing a sequential update, a rollback of the application core should be possible, but a rollback of the network core is not supported.
    Kind Regards,
    Abhijith
  • Hi Abhijith,
    I really appreciate you taking the time to answer my questions!
    I think I see now what you mean by rollback not being supported by the network core.
    Would maintaining a partition in external flash be sufficient for rollback use when performing non-simultaneous updates? Or would the backup image need to be stored in the network core's internal flash?
    For example, if two separate partitions are maintained in external flash (one for the application core's secondary image and one for the network core's secondary image), and an update for just the network core gets triggered, would the network core's old firmware be swapped into external flash? Or would it be discarded?
    I only ask because in rereading the DevAcademy lesson on DFU for the nRF5340, I was under the impression that the old image for the network core could remain available via the swap mechanism shown in this photo for non-simultaneous updates:
    and this photo for simultaneous updates:
    But with the information you've provided, I'm assuming these photos are simply to illustrate the swap mechanism for firmware upgrades, and the same mechanism doesn't apply for downgrades/rollbacks?
    Also, would there be anything preventing a "manual" rollback wherein downgraded firmware is loaded into the network core's secondary image slot (not via swap) and is then treated as an "update"?
    Thank you again!
    The application core writes directly to the netcore's flash using IPC or shared memory (PCD RAM). So, when you update only the netcore, the old firmware gets overwritten and is no longer available.
    This is the default behavior, and currently, netcore rollback is not officially supported. You can check the old DevZone thread I shared earlier for more details.
    Also, take a look at this repository,  the examples are a bit outdated, but they show how shared SRAM is used. The images you mentioned show the swap mechanism in action.
    I think this is how a netcore rollback might be possible, but it hasn’t been officially tested or supported by Nordic. So I can't say for sure if it will work, and I won’t be able to provide much support, as I haven’t tried it myself.
    Abhijith
  • Hi Abhijith,
    I see now! Thank you so much for your help with my questions, this is the exact information I was looking for!
