Hello team,
We are using nrf54l15 platform using NCS 3.02 SDK.
When advertising the MAC address changes in two following conditions
1. After every reset
2. After connect - disconnect.
Kindly guide us on this.
Hello team,
Check CONFIG_BT_PRIVACY setting.
What sample are you testing that reproduces this behavior?
And note that the change of BLE address just means that you are using a random static address, that will change in scenarios that you describe. However, I seem to remember that they typically use the same address on every reset, but I may be wrong.
What sample are you testing on, and I can try to reproduce what you are seeing, and see if this sample uses any special setting that canges the address.
Edvin
Ok, so it is not one of our samples that I can easily run to test?
I guess you could try removing CONFIG_BT_PRIVACY=y
From NCS\zephyr\subsys\bluetooth\host\Kconfig:
config BT_PRIVACY bool "Device privacy" help Enable privacy for the local device. This makes the device use Resolvable Private Addresses (RPAs) by default. Note: Establishing connections as a directed advertiser, or to a directed advertiser is only possible if the controller also supports privacy.
So setting that to "n" instead of "y", or remove it from your prj.conf should make it use it's default address all the time, if that is what you want to have.
Edvin
