Hi Team,
We are developing on a custom board with an nRF54L15 (Raytac Module with NRF54L15_xxAA_ENGB) and are unable to provision a pre-generated secp256r1 private key into a non-reserved KMU slot.
The nrfutil tool fails with the error: Failed to provision keys on "1050XXXXXX", Device error: Keys [123] failed provisioning.
We have followed the KMU Provisioning documentation and have reviewed similar DevZone tickets, but have not been able to resolve the issue.
Hardware & Software Environment
- SoC: nRF54L15_xxAA_ENGB module (on a custom board)
- Debugger: nRF52840 DK (PCA10056)
- J-Link Version: V8.18
- nrfutil Version: 8.0.0
- nrfutil device Versions Tested: 2.7.2 through 2.12.1
- NCS SDK Versions Tested: v3.0.1, v2.8
Steps to Reproduce
1. Generate Key Attributes JSON
We use the generate_psa_key_attributes.py script to create the provisioning file (we have also tried an older version of the script, same issue). Our intent is to provision a 256-bit secp256r1 private key, we are currently using the following parameters:
python3 generate_psa_key_attributes.py \
--usage ENCRYPT_DECRYPT_EXPORT_COPY \
--id 123 \
--type RAW_DATA \
--size 256 \
--algorithm NONE \
--location LOCATION_CRACEN_KMU \
--lifetime PERSISTENCE_READ_ONLY \
--cracen_usage ENCRYPTED \
--key {key_data_hex} \
--file kmu_provisioning_data.json
2. Sample Generated JSON
This creates the following kmu_provisioning_data.json file:
"version": 0,
"keyslots": [
"metadata": "0x01100001034B4E800303000000000000000000007B20FF7F00000000",
"value": "0xfed92de4023d69b9b9d58badebda646889bfb48784408464093a0fdd69b491b1"
3. Run Provisioning Command
We then execute the provisioning command:
nrfutil device x-provision-keys --serial-number 1050XXXXXX --key-file kmu_provisioning_data.json
Expected vs. Actual Results
- Expected: The key is successfully provisioned into KMU slot 123.
- Actual: The command fails with the error message:
Troubleshooting Steps Taken
- Device State: We perform
nrfutil device erase --allandnrfutil device --recoverbetween attempts to ensure the MCU is in a clean state for provisioning. - Hardware Connectivity: Our custom board programs successfully with standard applications, and we can observe UART output, confirming the debugger connection and basic board functionality are correct.
- Tool Versions: We have tested a wide range of
nrfutil deviceversions.- Versions up to
2.10.2failed withERROR: Could not read from flash. - Versions from
2.10.3to2.12.1consistently produce thefailed provisioningerror.
- Versions up to
- DevZone Research: We reviewed the ticket "RE: nRF54L15 - unable to provision key", but it focuses on provisioning via
west, whereas our issue is withnrfutil. - We managed to capture a log from the nrfutil device command, it is attached.log.json
