nRF54L15 - Fail to provision keys in to the KMU (nrfutil)
Hi Team,
We are developing on a custom board with an nRF54L15 (Raytac Module with NRF54L15_xxAA_ENGB) and are unable to provision a pre-generated secp256r1 private key into a non-reserved KMU slot.
The nrfutil tool fails with the error: Failed to provision keys on "1050XXXXXX", Device error: Keys [123] failed provisioning.
We have followed the KMU Provisioning documentation and have reviewed similar DevZone tickets, but have not been able to resolve the issue.
Hardware & Software Environment
  • SoC: nRF54L15_xxAA_ENGB module (on a custom board)
  • Debugger: nRF52840 DK (PCA10056)
  • J-Link Version: V8.18
  • nrfutil Version: 8.0.0
  • nrfutil device Versions Tested: 2.7.2 through 2.12.1
  • NCS SDK Versions Tested: v3.0.1, v2.8
Steps to Reproduce
1. Generate Key Attributes JSON
We use the generate_psa_key_attributes.py script to create the provisioning file (we have also tried an older version of the script, same issue). Our intent is to provision a 256-bit secp256r1 private key, we are currently using the following parameters:
python3 generate_psa_key_attributes.py \
  --usage ENCRYPT_DECRYPT_EXPORT_COPY \
  --id 123 \
  --type RAW_DATA \
  --size 256 \
  --algorithm NONE \
  --location LOCATION_CRACEN_KMU \
  --lifetime PERSISTENCE_READ_ONLY \
  --cracen_usage ENCRYPTED \
  --key {key_data_hex} \
  --file kmu_provisioning_data.json
2. Sample Generated JSON
This creates the following kmu_provisioning_data.json file:
    "version": 0,
    "keyslots": [
            "metadata": "0x01100001034B4E800303000000000000000000007B20FF7F00000000",
            "value": "0xfed92de4023d69b9b9d58badebda646889bfb48784408464093a0fdd69b491b1"
3. Run Provisioning Command
We then execute the provisioning command:
nrfutil device x-provision-keys --serial-number 1050XXXXXX --key-file kmu_provisioning_data.json
Expected vs. Actual Results
  • Expected: The key is successfully provisioned into KMU slot 123.
  • Actual: The command fails with the error message:
Troubleshooting Steps Taken
  1. Device State: We perform nrfutil device erase --all and nrfutil device --recover between attempts to ensure the MCU is in a clean state for provisioning.
  2. Hardware Connectivity: Our custom board programs successfully with standard applications, and we can observe UART output, confirming the debugger connection and basic board functionality are correct.
  3. Tool Versions: We have tested a wide range of nrfutil device versions.
    • Versions up to 2.10.2 failed with ERROR: Could not read from flash.
    • Versions from 2.10.3 to 2.12.1 consistently produce the failed provisioning error.
  4. DevZone Research: We reviewed the ticket "RE: nRF54L15 - unable to provision key", but it focuses on provisioning via west, whereas our issue is with nrfutil.
  5. We managed to capture a log from the nrfutil device command, it is attached.log.json
  • Hi DanN,
    Could you please try again with the argument --log-level trace?
    It will produce a log file in the .nrfutils/log folder, which is located in the home directory on Linux, or the user root directory on Windows. Please share that file with us.
    Hieu
  • Hi Hieu,
    There are two files in the logs folder, I redacted some file path names and left only the logs regarding the most recent command execution.
    [2025-06-25T13:33:49.186Z] [30898] INFO - nrfutil (version = 8.0.0, platform = x86_64-unknown-linux-gnu) invoked with device --version
    [2025-06-25T13:34:27.901Z] [31007] INFO - nrfutil (version = 8.0.0, platform = x86_64-unknown-linux-gnu) invoked with device recover --serial-number 1050253845
    [2025-06-25T13:34:32.596Z] [31057] INFO - nrfutil (version = 8.0.0, platform = x86_64-unknown-linux-gnu) invoked with device recover --serial-number 1050250936
    [2025-06-25T13:35:12.602Z] [31248] INFO - nrfutil (version = 8.0.0, platform = x86_64-unknown-linux-gnu) invoked with --version
    [2025-06-25T13:35:12.825Z] [31260] INFO - nrfutil (version = 8.0.0, platform = x86_64-unknown-linux-gnu) invoked with device list --log-level=off --json
    [2025-06-25T13:35:27.029Z] [31380] INFO - nrfutil (version = 8.0.0, platform = x86_64-unknown-linux-gnu) invoked with device read --address 131072 --bytes 4 --serial-number 001050250936
    [2025-06-25T13:35:27.438Z] [31415] INFO - nrfutil (version = 8.0.0, platform = x86_64-unknown-linux-gnu) invoked with device read --address 16761612 --bytes 4 --serial-number 001050250936
    [2025-06-25T13:35:27.846Z] [31450] INFO - nrfutil (version = 8.0.0, platform = x86_64-unknown-linux-gnu) invoked with device read --address 16761616 --bytes 4 --serial-number 001050250936
    [2025-06-25T13:35:28.254Z] [31499] INFO - nrfutil (version = 8.0.0, platform = x86_64-unknown-linux-gnu) invoked with device read --address 16761620 --bytes 4 --serial-number 001050250936
    [2025-06-25T13:35:28.663Z] [31534] INFO - nrfutil (version = 8.0.0, platform = x86_64-unknown-linux-gnu) invoked with device read --address 16761624 --bytes 4 --serial-number 001050250936
    [2025-06-25T13:36:01.438Z] [31646] INFO - nrfutil (version = 8.0.0, platform = x86_64-unknown-linux-gnu) invoked with device erase --all --serial-number 001050250936
    [2025-06-25T13:36:01.947Z] [31684] INFO - nrfutil (version = 8.0.0, platform = x86_64-unknown-linux-gnu) invoked with device erase --all --serial-number 001050253845
    [2025-06-25T13:36:02.456Z] [31731] INFO - nrfutil (version = 8.0.0, platform = x86_64-unknown-linux-gnu) invoked with device program --firmware /home/internal_boot_partition_cs.hex --serial-number 001050250936
    [2025-06-25T13:36:02.964Z] [31783] INFO - nrfutil (version = 8.0.0, platform = x86_64-unknown-linux-gnu) invoked with device program --firmware /home/internal_boot_partition_cs.hex --serial-number 001050253845
    [2025-06-25T13:36:03.473Z] [31828] INFO - nrfutil (version = 8.0.0, platform = x86_64-unknown-linux-gnu) invoked with device x-provision-keys --serial-number 001050250936 --key-file /home/kmu_provisioning_data.json
    [2025-06-25T13:36:16.568Z] [31915] INFO - nrfutil (version = 8.0.0, platform = x86_64-unknown-linux-gnu) invoked with device recover --serial-number 1050253845
    [2025-06-25T13:36:19.961Z] [31956] INFO - nrfutil (version = 8.0.0, platform = x86_64-unknown-linux-gnu) invoked with device recover --serial-number 1050250936
    [2025-06-25T13:37:02.586Z] [32102] INFO - nrfutil (version = 8.0.0, platform = x86_64-unknown-linux-gnu) invoked with device x-provision-keys --serial-number 1050250936 --key-file /home/kmu_provisioning_data.json --log-level trace
    8015.nrfutil-device.log
    Thanks!
    Daniyal
  • Hi Daniyal,
    My apology for the late follow up. I have been out of office.
    The issue is that keys cannot be provisioned to KMU without an algorithm specified. If you specify an algorithm, things will work.
    Hieu
  • Hi Hieu,
    Thanks for the update, I assume you are talking about the "--algorithm" parameter passed onto the generate_psa_key_attributes.py script.
    I have just tried with both other two available options for the --algorithm input parameter, "CBC" and "EDDSA_PURE" I'm getting the same error.
    Daniyal
