It flashes with sucess
C:\Users\vasco>openocd -f interface/stlink.cfg -f target/nrf52.cfg -c "program \"C:/Users/vasco/OneDrive/Ambiente de Trabalho/zephyr.hex\" verify reset exit"
Open On-Chip Debugger 0.12.0
Licensed under GNU GPL v2
For bug reports, read
openocd.org/.../bugs.html
Info : auto-selecting first available session transport "hla_swd". To override use 'transport select <transport>'.
Info : The selected transport took over low-level target control. The results might differ compared to plain JTAG/SWD
nRF52 device has a CTRL-AP dedicated to recover the device from AP lock.
A high level adapter (like a ST-Link) you are currently using cannot access
the CTRL-AP so 'nrf52_recover' command will not work.
Do not enable UICR APPROTECT.
Info : clock speed 1000 kHz
Info : STLINK V2J29S7 (API v2) VID:PID 0483:3748
Info : Target voltage: 3.155354
Info : [nrf52.cpu] Cortex-M4 r0p1 processor detected
Info : [nrf52.cpu] target has 6 breakpoints, 4 watchpoints
Info : starting gdb server for nrf52.cpu on 3333
Info : Listening on port 3333 for gdb connections
[nrf52.cpu] halted due to debug-request, current mode: Thread
xPSR: 0x01000000 pc: 0x0000ea50 msp: 0x20003b80
** Programming Started **
Info : nRF52805-xxAA(build code: A0) 192kB Flash, 24kB RAM
Info : Padding image section 0 at 0x0001a264 with 12 bytes
Warn : Adding extra erase range, 0x0001b4dc .. 0x0001bfff
** Programming Finished **
** Verify Started **
** Verified OK **
** Resetting Target **
shutdown command invoked
but my pcb board dosent do nothing,
I have this code
