bt_gatt_notify intermittently not received by phone application
  1. Device Overview
We have developed a smart wearable that sends notifications to our mobile application over BLE. Under normal conditions, the device alternates sensor + battery data and IMU data every second and status updates is sent on event.
  1. GATT Profile
2.1 Services and Characteristics
Battery Service
  • Battery Level characteristic
Debug Service
  • Debug characteristic
Data Service
  • Sensor Data characteristic (20 bytes)
  • Status Data characteristic (2 bytes)
  • IMU Data characteristic (12 bytes)
SMP Service
(Secure Management Protocol for OTA updates)
2.2 MTU
Default MTU size is used: 23 bytes
  1. Notification Schedule
  • Sensor Data and IMU Data notifications alternate once every second
  • Status Data is sent only when an event occurs (not on a timer)
  • Battery Level notifications are sent on demand
  1. Observed Issue
In most cases, all notifications arrive correctly.
Intermittently, Sensor Data, IMU Data and Battery Level notifications fail to arrive, while Status Data continues to be received reliably.
This behavior is seen in the user field; we’re unable to reproduce it in the lab, which makes debugging complex.
One user downloaded nRF Connect and the problem still occurs, so it does not appear related to our app.
  1. Expected Behavior
All characteristics configured for notification should deliver updates without loss, according to the schedule above.
We are really struggling to find the root cause of the issue or just a reproducer, thank you for any pointers or insights!
27317.prj.conf
    Bluetooth ensures delivery of notifications and other GATT data. Retransmission will be attempted until successfull, or the link is disconnected due to supervision timeout. That leads to a few questions:
    1. Is there a disconnect seen when you loose data, or not? If yes, we need to follow that path. If not, there are other considerations:
    2. Do you know that the notifications are acually "sent" from the application, by Bluetooth API calls?  Or could it be that the calls are not made for some reason (due to application logic, for instance)?
    3. Do the API calls where you sent the notifications (that typically end up in bt_gatt_notify()) succeed or are errors returned?
    I understand this is tricky as you are not reproducing in your lab, but perhaps you can add some more logging to get information about this in the field? If not, I suspect there is a need to find a way to reproduce this on your end to debug further.
  • Hi Einar,
    Thanks for the prompt reply.
    1. No disconnection is seen (status notification still works, these are based on user event)
    2. The call to bt_gatt_notify is conditionned to :
    • phone being connected (seems to be ok cause same check for status)
    • Notify_enable flag (set and unset with ccc callback) (it seems this flag is unecessary, we are going to remove it in the next version.
    But, the difference from the status notify is that all the other call are launched by a timer in another work queue, so that might come from here.
    k_work_queue_init(&sensor_timer_work_q);
    k_work_queue_start(&sensor_timer_work_q,
                       sensor_timer_stack,
                       K_THREAD_STACK_SIZEOF(sensor_timer_stack), 5,
                       NULL);
    k_timer_init(&adc_timer, sensor_timer_event, NULL);
    k_timer_start(&adc_timer, K_NO_WAIT, K_MSEC(SAMPLING_ROUND_INTERVAL_MSEC));
    void sensor_timer_event(struct k_timer *timer_id)
        ARG_UNUSED(timer_id);
        k_work_submit_to_queue(&sensor_timer_work_q, &on_imu_and_send_gsr_work);
    void on_imu_and_send_gsr_handler()
        call to bt_gatt_notify()
    K_WORK_DEFINE(on_imu_and_send_gsr_work, on_imu_and_send_gsr_handler);
    3. I have no idea if the call succeed or not unfortunately.
    I'm working to find a reproducer, feel free to share if you have any idea.
    I see. As you do not see a disconnect, it seems likely that the notification is not successfully queued. I do not have any specific reason to belive that is the problem, but I see you do not check the return value when submitting to the queue. If the queue is full for some resion, this would then fail silently. Perhaps theer are similar cases in the application as well, where return values are not checked and errors might go unnoticed and unhandled?
  • Hi Einar,
    Thank you for your suggestions. I’ve since managed to reproduce the issue in the lab. It turned out that I was starting sensor_timer very early in the initialization sequence.
    Later, when initializing another timer, timer_beta, a rare timing condition caused me to call k_timer_start(&timer_beta, K_MSEC(5000), K_MSEC(5000)); before I had actually initialized it. As a result, sensor_timer never fired again.
    I couldn’t isolate a minimal repro though I did see that if you invoke a timer’s start function before calling its init function, it will run after init completes (I would have expected for the timer to wait a new start function called after init).
    Rémi
  • Hi Remi,
    I am trying to assist in this thread while Einar is away for his summer vacation. The behavior you see is normal when due to some race condition you happen to use the timer before it is initialized. I hope that you manage to make a minimal repro and share the project here so that I can assist you with the timing race condition you are seeing with the call of timer start before initialization.
