Devacademy L4_e2. mqtt_connect error -12 when connecting to HiveMq serverless cluster.
I'm half way through the Cellular course on the dev academy and although I am able to connect to the Nordic and Hivemq publich brokers, when I attempt to connect to my serverless Hivemq cluster, I receive the mqtt_connect error 12.
My client_init is as below (username and password removed).
int client_init(struct mqtt_client* client)
int err;
/* Initializes the client instance. */
mqtt_client_init(client);
/* Resolves the configured hostname and initializes the MQTT broker structure */
err = broker_init();
if (err) {
LOG_ERR("Failed to initialise broker connection");
return err;
char password[] = "xxxxxxxxx";
char username[] = "xxxxxxxxxx";
struct mqtt_utf8 pass = {
.utf8 = (uint8_t*)password,
.size = strlen(password)
struct mqtt_utf8 uname = {
.utf8 = (uint8_t*)username,
.size = strlen(username)
/* MQTT client configuration */
client->broker = &broker;
client->evt_cb = mqtt_evt_handler;
client->client_id.utf8 = client_id_get();
client->client_id.size = strlen(client->client_id.utf8);
client->password = &pass;
client->user_name = &uname;
client->protocol_version = MQTT_VERSION_3_1_1;
/* MQTT buffers configuration */
client->rx_buf = rx_buffer;
client->rx_buf_size = sizeof(rx_buffer);
client->tx_buf = tx_buffer;
client->tx_buf_size = sizeof(tx_buffer);
/* STEP 5 - Modify the client client_init() function to use Secure TCP transport instead of non-secure TCP transport. */
client->transport.type = MQTT_TRANSPORT_SECURE;
struct mqtt_sec_config* tls_cfg = &(client->transport).tls.config;
static sec_tag_t sec_tag_list[] = { CONFIG_MQTT_TLS_SEC_TAG };
LOG_INF("TLS enabled");
tls_cfg->peer_verify = CONFIG_MQTT_TLS_PEER_VERIFY;
tls_cfg->cipher_list = NULL;
tls_cfg->cipher_count = 0;
tls_cfg->sec_tag_count = ARRAY_SIZE(sec_tag_list);
tls_cfg->sec_tag_list = sec_tag_list;
tls_cfg->hostname = CONFIG_MQTT_BROKER_HOSTNAME;
tls_cfg->session_cache = IS_ENABLED(CONFIG_MQTT_TLS_SESSION_CACHING) ? TLS_SESSION_CACHE_ENABLED : TLS_SESSION_CACHE_DISABLED;
return err;
Project conf is:
# C++
CONFIG_CPP=y
CONFIG_STD_CPP20=y
CONFIG_REQUIRES_FULL_LIBCPP=y
# Logging
CONFIG_LOG=y
# Button and LED support
CONFIG_DK_LIBRARY=y
# Newlib
CONFIG_NEWLIB_LIBC=y
# Networking
CONFIG_NETWORKING=y
CONFIG_NET_NATIVE=n
CONFIG_NET_SOCKETS=y
CONFIG_NET_SOCKETS_OFFLOAD=y
CONFIG_POSIX_API=y
# Memory
CONFIG_MAIN_STACK_SIZE=4096
CONFIG_HEAP_MEM_POOL_SIZE=4096
# Modem library
CONFIG_NRF_MODEM_LIB=y
CONFIG_MODEM_KEY_MGMT=y
# LTE link control
CONFIG_LTE_LINK_CONTROL=y
CONFIG_LTE_NETWORK_MODE_LTE_M_NBIOT=y
# MQTT
CONFIG_MQTT_LIB=y
CONFIG_MQTT_CLEAN_SESSION=y
CONFIG_MQTT_LIB_TLS=y
# Application
CONFIG_MQTT_PUB_TOPIC="alcsystems/publish/topic"
CONFIG_MQTT_SUB_TOPIC="alcsystems/subscribe/topic"
CONFIG_BUTTON_EVENT_PUBLISH_MSG="Hi from nRF91 Series device"
# CONFIG_MQTT_BROKER_HOSTNAME="mqtt.nordicsemi.academy"
CONFIG_MQTT_BROKER_HOSTNAME="033cdd1462f949a2b4812c18f4ca9d13.s1.eu.hivemq.cloud"
# STEP 2.2 - Change the MQTT broker port
CONFIG_MQTT_BROKER_PORT=8883
# CONFIG_MQTT_BROKER_PORT=1883
As you can see, I have increased the memory and also increased the buffer sizes to 512.
Any help would be gratefully received.
Andy
  • And finally, I have the answer.  I eventually found this link : https://github.com/zephyrproject-rtos/zephyr/issues/73089 with this comment revealing the cause of the problem.
    There are multiple ways to assign the username and password and most will compile, but fail at runtime.  The final solution for me was to declare the mqtt_utf structs as static in main.c and then pass them as pointers to client_init.  It then took several attempts to find a working solution to assigning the values to the structs.  The final version looks like this:
    int client_init(struct mqtt_client* client, struct mqtt_utf8* uname, struct mqtt_utf8* pass)
    int err;
    if (err) {
    return err;
    uname->utf8 = (uint8_t*)"xxxxxxxxxx";
    uname->size = (uint32_t)strlen(uname->utf8);
    pass->utf8 = (uint8_t*)"xxxxxxxxxx";
    pass->size = (uint32_t)strlen(pass->utf8);
    client->password = pass;
    client->user_name = uname;
    This issue has cost me three production days and the fix is is incredibly flakey.  I would be grateful if a more elegant and robust method of implementing the username and password fields could be found in a future release.
    In the meantime, I hope this post helps someone struggling with the same problem.
