USB mass storage for the NRF7002DK development board using on board chip
Hello everyone,
As the title suggests, we're trying to get the on board flash (mx25r64 as far as I can tell) of the nrf7002dk devboard working as a USB mass storage device (should be visible when connecting to Windows and MacOS).
Doing a bit of googling, I've found that a good starting point is the sample from:
/opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/
I started from there and tried various bits and pieces from different posts in the Nordic DevZone to try and get it working. Sadly it doesn't wanna yield and the most common error is either the partition manager not recognising the label put in the overlay or something else related to the partition manager not accepting/ initialising the disk.
Latest build log:
root@Tudors-MacBook mass # west build -b nrf7002dk/nrf5340/cpuapp/ns --pristine
-- west build: making build dir /opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/build pristine
Loading Zephyr module(s) (Zephyr base): sysbuild_default
-- Found Python3: /opt/homebrew/opt/[email protected]/bin/python3.13 (found suitable version "3.13.3", minimum required is "3.10") found components: Interpreter
-- Cache files will be written to: /Users/tudor/Library/Caches/zephyr
-- Found west (found suitable version "1.3.0", minimum required is "0.14.0")
-- Board: nrf7002dk, qualifiers: nrf5340/cpuapp/ns
Parsing /opt/nordic/ncs/v3.0.0/zephyr/share/sysbuild/Kconfig
Loaded configuration '/opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/build/_sysbuild/empty.conf'
Merged configuration '/opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/sysbuild.conf'
Configuration saved to '/opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/build/zephyr/.config'
Kconfig header saved to '/opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/build/_sysbuild/autoconf.h'
   * Running CMake for mass *
-- Application: /opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass
-- CMake version: 4.0.2
-- Found Python3: /opt/homebrew/bin/python3 (found suitable version "3.13.3", minimum required is "3.10") found components: Interpreter
-- Zephyr version: 4.0.99 (/opt/nordic/ncs/v3.0.0/zephyr)
-- ZEPHYR_TOOLCHAIN_VARIANT not set, trying to locate Zephyr SDK
-- Found host-tools: zephyr 0.17.0 (/Users/tudor/zephyr-sdk-0.17.0)
-- Found toolchain: zephyr 0.17.0 (/Users/tudor/zephyr-sdk-0.17.0)
-- Could NOT find Dtc (missing: DTC) (Required is at least version "1.4.6")
Hint: The project() command has not yet been called.  It sets up system-specific search paths.
-- Found BOARD.dts: /opt/nordic/ncs/v3.0.0/zephyr/boards/nordic/nrf7002dk/nrf7002dk_nrf5340_cpuapp_ns.dts
-- Found devicetree overlay: /opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/boards/nrf7002dk_nrf5340_cpuapp_ns.overlay
-- Generated zephyr.dts: /opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/build/mass/zephyr/zephyr.dts
-- Generated pickled edt: /opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/build/mass/zephyr/edt.pickle
-- Generated devicetree_generated.h: /opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/build/mass/zephyr/include/generated/zephyr/devicetree_generated.h
-- Including generated dts.cmake file: /opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/build/mass/zephyr/dts.cmake
warning: DISK_DRIVER_SDMMC (defined at
boards/shields/adafruit_2_8_tft_touch_v2/Kconfig.defconfig:37, drivers/disk/Kconfig.sdmmc:7) was
assigned the value 'y' but got the value 'n'. Check these unsatisfied dependencies: ((DISK_DRIVERS
&& (SHIELD_ADAFRUIT_2_8_TFT_TOUCH_V2 || SHIELD_ADAFRUIT_2_8_TFT_TOUCH_V2_NANO)) ||
((DT_HAS_ZEPHYR_SDMMC_DISK_ENABLED || DT_HAS_ST_STM32_SDMMC_ENABLED) && DISK_DRIVERS)) (=n). See
http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_DISK_DRIVER_SDMMC and/or look up
DISK_DRIVER_SDMMC in the menuconfig/guiconfig interface. The Application Development Primer, Setting
Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be helpful
too.
warning: NORDIC_QSPI_NOR (defined at /opt/nordic/ncs/v3.0.0/nrf/Kconfig.nrf:95,
drivers/flash/Kconfig.nordic_qspi_nor:4) was assigned the value 'y' but got the value 'n'. See
http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_NORDIC_QSPI_NOR and/or look up
NORDIC_QSPI_NOR in the menuconfig/guiconfig interface. The Application Development Primer, Setting
too.
warning: SDMMC_STM32_HWFC (defined at drivers/disk/Kconfig.sdmmc:47) was assigned the value 'y' but
got the value 'n'. Check these unsatisfied dependencies: SDMMC_STM32 (=n), (SOC_SERIES_STM32H5X ||
SOC_SERIES_STM32H7X || SOC_SERIES_STM32F7X || SOC_SERIES_STM32L4X || SOC_SERIES_STM32L5X) (=n),
DISK_DRIVER_SDMMC (=n). See
http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_SDMMC_STM32_HWFC and/or look up
SDMMC_STM32_HWFC in the menuconfig/guiconfig interface. The Application Development Primer, Setting
too.
Parsing /opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/Kconfig
Loaded configuration '/opt/nordic/ncs/v3.0.0/zephyr/boards/nordic/nrf7002dk/nrf7002dk_nrf5340_cpuapp_ns_defconfig'
Merged configuration '/opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/prj.conf'
Merged configuration '/opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/boards/nrf7002dk_nrf5340_cpuapp_ns.conf'
Merged configuration '/opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/build/mass/zephyr/.config.sysbuild'
Configuration saved to '/opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/build/mass/zephyr/.config'
Kconfig header saved to '/opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/build/mass/zephyr/include/generated/zephyr/autoconf.h'
-- Found GnuLd: /Users/tudor/zephyr-sdk-0.17.0/arm-zephyr-eabi/arm-zephyr-eabi/bin/ld.bfd (found version "2.38")
-- Found assembler: /Users/tudor/zephyr-sdk-0.17.0/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc
CMake Warning at /opt/nordic/ncs/v3.0.0/zephyr/subsys/usb/device/CMakeLists.txt:22 (message):
  CONFIG_USB_DEVICE_VID has default value 0x2FE3.
  This value is only for testing and MUST be configured for USB products.
=========== Generating psa_crypto_config ===============
Backup: CONFIG_MBEDTLS_PSA_CRYPTO_SPM: False
Backup: CONFIG_MBEDTLS_PSA_CRYPTO_C: False
Backup: CONFIG_MBEDTLS_PSA_CRYPTO_KEY_ID_ENCODES_OWNER: False
Backup: CONFIG_MBEDTLS_PLATFORM_SETUP_TEARDOWN_ALT: False
Backup: CONFIG_MBEDTLS_THREADING: False
Backup: CONFIG_MBEDTLS_THREADING_ALT: False
=========== Checkpoint: backup ===============
Restore: CONFIG_MBEDTLS_PSA_CRYPTO_SPM: False
Restore: CONFIG_MBEDTLS_PSA_CRYPTO_C: False
Restore: CONFIG_MBEDTLS_PSA_CRYPTO_KEY_ID_ENCODES_OWNER: False
Restore: CONFIG_MBEDTLS_PLATFORM_SETUP_TEARDOWN_ALT: False
Restore: CONFIG_MBEDTLS_THREADING: False
Restore: CONFIG_MBEDTLS_THREADING_ALT: False
=========== End psa_crypto_config ===============
=========== Generating psa_crypto_library_config ===============
Backup: CONFIG_MBEDTLS_USE_PSA_CRYPTO: True
Backup: CONFIG_MBEDTLS_PLATFORM_PRINTF_ALT: False
Restore: CONFIG_MBEDTLS_USE_PSA_CRYPTO: True
Restore: CONFIG_MBEDTLS_PLATFORM_PRINTF_ALT: False
=========== End psa_crypto_library_config ===============
-- Using ccache: /opt/homebrew/bin/ccache
-- Configuring done (5.7s)
-- Generating done (0.4s)
-- Build files have been written to: /opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/build/mass
-- Found partition manager static configuration : /opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/pm_static.yml
-- Configuring done (9.1s)
-- Generating done (0.0s)
[5/10] Performing build step for 'mass'
[1/278] Preparing syscall dependency handling
[6/278] Generating include/generated/zephyr/version.h
-- Zephyr version: 4.0.99 (/opt/nordic/ncs/v3.0.0/zephyr), build: v4.0.99-ncs1
[8/278] Generating ../../tfm/CMakeCache.txt
-- Found Git: /usr/bin/git (found version "2.39.5 (Apple Git-154)")
-- Found Python3: /opt/homebrew/bin/python3 (found version "3.13.3") found components: Interpreter
CMake Warning (dev) at /opt/nordic/ncs/v3.0.0/nrf/modules/trusted-firmware-m/tfm_boards/nrf5340_cpuapp/CMakeLists.txt:21 (install):
  Policy CMP0177 is not set: install() DESTINATION paths are normalized.  Run
  "cmake --help-policy CMP0177" for policy details.  Use the cmake_policy
  command to set the policy and suppress this warning.
This warning is for project developers.  Use -Wno-dev to suppress it.
-- Configuring done (0.9s)
-- Generating done (0.1s)
-- Build files have been written to: /opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/build/mass/tfm
[17/278] Performing build step for 'tfm'
[135/139] Linking C executable bin/tfm_s.axf
           FLASH:       32100 B        32 KB     97.96%
             RAM:       10404 B        32 KB     31.75%
[139/139] Linking C static library secure_fw/libtfm_s_veneers.a
[19/278] Performing install step for 'tfm'
-- Install configuration: "MinSizeRel"
----- Installing platform NS -----
[89/278] Building C object CMakeFiles/app.dir/src/main.c.obj
In file included from /opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/src/main.c:29:
/opt/nordic/ncs/v3.0.0/nrf/include/flash_map_pm.h:37:17: warning: 'littlefs_storage' defined but not used [-Wunused-variable]
   37 | #define storage littlefs_storage
/opt/nordic/ncs/v3.0.0/zephyr/include/zephyr/fs/littlefs.h:91:35: note: in definition of macro 'FS_LITTLEFS_DECLARE_CUSTOM_CONFIG'
   91 |         static struct fs_littlefs name = {                                                \
/opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/src/main.c:30:1: note: in expansion of macro 'FS_LITTLEFS_DECLARE_DEFAULT_CONFIG'
   30 | FS_LITTLEFS_DECLARE_DEFAULT_CONFIG(storage);
/opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/src/main.c:30:36: note: in expansion of macro 'storage'
[159/278] Building C object zephyr/drivers/disk/CMakeFiles/drivers__disk.dir/flashdisk.c.obj
FAILED: zephyr/drivers/disk/CMakeFiles/drivers__disk.dir/flashdisk.c.obj
ccache /Users/tudor/zephyr-sdk-0.17.0/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc -DKERNEL -DK_HEAP_MEM_POOL_SIZE=0 -DMBEDTLS_CONFIG_FILE=\"nrf-config.h\" -DMBEDTLS_PSA_CRYPTO_CONFIG_FILE=\"nrf-psa-crypto-config.h\" -DNRF5340_XXAA_APPLICATION -DNRF_SKIP_FICR_NS_COPY_TO_RAM -DNRF_TRUSTZONE_NONSECURE -DPICOLIBC_LONG_LONG_PRINTF_SCANF -DUSE_PARTITION_MANAGER=1 -D__LINUX_ERRNO_EXTENSIONS__ -D__PROGRAM_START -D__ZEPHYR_SUPERVISOR__ -D__ZEPHYR__=1 -I/opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/build/mass/zephyr/include/generated/zephyr -I/opt/nordic/ncs/v3.0.0/zephyr/include -I/opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/build/mass/zephyr/include/generated -I/opt/nordic/ncs/v3.0.0/zephyr/soc/nordic -I/opt/nordic/ncs/v3.0.0/zephyr/soc/nordic/nrf53/. -I/opt/nordic/ncs/v3.0.0/zephyr/soc/nordic/common/. -I/opt/nordic/ncs/v3.0.0/zephyr/subsys/usb/device -I/opt/nordic/ncs/v3.0.0/zephyr/drivers/usb/common/nrf_usbd_common/. -I/opt/nordic/ncs/v3.0.0/nrf/include -I/opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/build/mass/tfm/api_ns/interface/include -I/opt/nordic/ncs/v3.0.0/nrf/modules/trusted-firmware-m/. -I/opt/nordic/ncs/v3.0.0/nrf/include/tfm -I/opt/nordic/ncs/v3.0.0/nrf/tests/include -I/opt/nordic/ncs/v3.0.0/modules/hal/cmsis/CMSIS/Core/Include -I/opt/nordic/ncs/v3.0.0/zephyr/modules/cmsis/. -I/opt/nordic/ncs/v3.0.0/nrf/modules/hal_nordic/. -I/opt/nordic/ncs/v3.0.0/modules/hal/nordic/nrfx -I/opt/nordic/ncs/v3.0.0/modules/hal/nordic/nrfx/drivers/include -I/opt/nordic/ncs/v3.0.0/modules/hal/nordic/nrfx/mdk -I/opt/nordic/ncs/v3.0.0/zephyr/modules/hal_nordic/nrfx/. -I/opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/build/mass/generated/interface_nrf_security_psa -I/opt/nordic/ncs/v3.0.0/nrf/subsys/nrf_security/include -I/opt/nordic/ncs/v3.0.0/modules/crypto/oberon-psa-crypto/include -I/opt/nordic/ncs/v3.0.0/nrf/subsys/nrf_security/src/utils -I/opt/nordic/ncs/v3.0.0/modules/crypto/oberon-psa-crypto/library -I/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library -I/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/include -I/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/include/library -I/opt/nordic/ncs/v3.0.0/nrfxlib/crypto/nrf_oberon/include -I/opt/nordic/ncs/v3.0.0/nrfxlib/crypto/nrf_oberon/include/mbedtls -isystem /opt/nordic/ncs/v3.0.0/zephyr/lib/libc/common/include -Wshadow -fno-strict-aliasing -Os -imacros /opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/build/mass/zephyr/include/generated/zephyr/autoconf.h -fno-printf-return-value -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m33 -mthumb -mabi=aapcs -mfp16-format=ieee -mtp=soft --sysroot=/Users/tudor/zephyr-sdk-0.17.0/arm-zephyr-eabi/arm-zephyr-eabi -imacros /opt/nordic/ncs/v3.0.0/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wdouble-promotion -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-pic -fno-pie -fno-asynchronous-unwind-tables -ftls-model=local-exec -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=/opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass=CMAKE_SOURCE_DIR -fmacro-prefix-map=/opt/nordic/ncs/v3.0.0/zephyr=ZEPHYR_BASE -fmacro-prefix-map=/opt/nordic/ncs/v3.0.0=WEST_TOPDIR -ffunction-sections -fdata-sections -specs=picolibc.specs -std=c99 -MD -MT zephyr/drivers/disk/CMakeFiles/drivers__disk.dir/flashdisk.c.obj -MF zephyr/drivers/disk/CMakeFiles/drivers__disk.dir/flashdisk.c.obj.d -o zephyr/drivers/disk/CMakeFiles/drivers__disk.dir/flashdisk.c.obj -c /opt/nordic/ncs/v3.0.0/zephyr/drivers/disk/flashdisk.c
/opt/nordic/ncs/v3.0.0/zephyr/drivers/disk/flashdisk.c:533:1: error: return type defaults to 'int' [-Werror=implicit-int]
  533 | PM_FOREACH_AFFILIATED_TO_disk(DEFINE_FLASHDISKS_CACHE)
/opt/nordic/ncs/v3.0.0/zephyr/drivers/disk/flashdisk.c: In function 'PM_FOREACH_AFFILIATED_TO_disk':
/opt/nordic/ncs/v3.0.0/zephyr/drivers/disk/flashdisk.c:572:30: error: storage class specified for parameter 'flash_disks'
  572 | static struct flashdisk_data flash_disks[] = {
/opt/nordic/ncs/v3.0.0/zephyr/drivers/disk/flashdisk.c:572:15: error: parameter 'flash_disks' is initialized
/opt/nordic/ncs/v3.0.0/zephyr/drivers/disk/flashdisk.c:573:39: error: 'DEFINE_FLASHDISKS_DEVICE' undeclared (first use in this function)
  573 |         PM_FOREACH_AFFILIATED_TO_disk(DEFINE_FLASHDISKS_DEVICE)
/opt/nordic/ncs/v3.0.0/zephyr/drivers/disk/flashdisk.c:573:39: note: each undeclared identifier is reported only once for each function it appears in
/opt/nordic/ncs/v3.0.0/zephyr/drivers/disk/flashdisk.c:582:1: error: expected declaration specifiers before 'PM_FOREACH_AFFILIATED_TO_disk'
  582 | PM_FOREACH_AFFILIATED_TO_disk(VERIFY_CACHE_SIZE_IS_NOT_ZERO_IF_NOT_READ_ONLY)
In file included from /opt/nordic/ncs/v3.0.0/zephyr/include/zephyr/toolchain/gcc.h:98,
                 from /opt/nordic/ncs/v3.0.0/zephyr/include/zephyr/toolchain.h:50,
                 from /opt/nordic/ncs/v3.0.0/zephyr/include/zephyr/sys/__assert.h:11,
                 from /opt/nordic/ncs/v3.0.0/zephyr/drivers/disk/flashdisk.c:10:
/opt/nordic/ncs/v3.0.0/zephyr/include/zephyr/init.h:141:44: error: storage class specified for parameter '__init_disk_flash_init'
  141 | #define Z_INIT_ENTRY_NAME(init_id) _CONCAT(__init_, init_id)
/opt/nordic/ncs/v3.0.0/zephyr/include/zephyr/toolchain/common.h:137:26: note: in definition of macro '_DO_CONCAT'
  137 | #define _DO_CONCAT(x, y) x ## y
/opt/nordic/ncs/v3.0.0/zephyr/include/zephyr/init.h:141:36: note: in expansion of macro '_CONCAT'
/opt/nordic/ncs/v3.0.0/zephyr/include/zephyr/init.h:241:17: note: in expansion of macro 'Z_INIT_ENTRY_NAME'
  241 |                 Z_INIT_ENTRY_NAME(name) = {.init_fn = {.sys = (init_fn_)},                \
/opt/nordic/ncs/v3.0.0/zephyr/include/zephyr/init.h:223:9: note: in expansion of macro 'SYS_INIT_NAMED'
  223 |         SYS_INIT_NAMED(init_fn, init_fn, level, prio)
/opt/nordic/ncs/v3.0.0/zephyr/drivers/disk/flashdisk.c:612:1: note: in expansion of macro 'SYS_INIT'
  612 | SYS_INIT(disk_flash_init, POST_KERNEL, CONFIG_KERNEL_INIT_PRIORITY_DEFAULT);
/opt/nordic/ncs/v3.0.0/zephyr/include/zephyr/init.h:239:42: error: parameter '__init_disk_flash_init' is initialized
  239 |         static const Z_DECL_ALIGN(struct init_entry)                                      \
/opt/nordic/ncs/v3.0.0/zephyr/include/zephyr/toolchain/common.h:195:55: note: in definition of macro 'Z_DECL_ALIGN'
  195 | #define Z_DECL_ALIGN(type) __aligned(__alignof(type)) type
/opt/nordic/ncs/v3.0.0/zephyr/include/zephyr/init.h:141:44: error: section attribute not allowed for '__init_disk_flash_init'
/opt/nordic/ncs/v3.0.0/zephyr/include/zephyr/init.h:239:42: warning: 'used' attribute ignored [-Wattributes]
/opt/nordic/ncs/v3.0.0/zephyr/include/zephyr/init.h:141:44: error: alignment may not be specified for '__init_disk_flash_init'
In file included from /opt/nordic/ncs/v3.0.0/zephyr/include/zephyr/device.h:13,
                 from /opt/nordic/ncs/v3.0.0/zephyr/include/zephyr/sw_isr_table.h:18,
                 from /opt/nordic/ncs/v3.0.0/zephyr/include/zephyr/arch/arm/irq.h:19,
                 from /opt/nordic/ncs/v3.0.0/zephyr/include/zephyr/arch/arm/arch.h:24,
                 from /opt/nordic/ncs/v3.0.0/zephyr/include/zephyr/arch/cpu.h:19,
                 from /opt/nordic/ncs/v3.0.0/zephyr/include/zephyr/kernel_includes.h:36,
                 from /opt/nordic/ncs/v3.0.0/zephyr/include/zephyr/kernel.h:17,
                 from /opt/nordic/ncs/v3.0.0/zephyr/include/zephyr/drivers/disk.h:30,
                 from /opt/nordic/ncs/v3.0.0/zephyr/drivers/disk/flashdisk.c:12:
/opt/nordic/ncs/v3.0.0/zephyr/drivers/disk/flashdisk.c:612:10: error: 'disk_flash_init' undeclared (first use in this function)
/opt/nordic/ncs/v3.0.0/zephyr/include/zephyr/init.h:241:64: note: in definition of macro 'SYS_INIT_NAMED'
/opt/nordic/ncs/v3.0.0/zephyr/drivers/disk/flashdisk.c:533:1: error: type of 'DEFINE_FLASHDISKS_CACHE' defaults to 'int' [-Werror=implicit-int]
/opt/nordic/ncs/v3.0.0/zephyr/include/zephyr/init.h:141:44: error: declaration for parameter '__init_disk_flash_init' but no such parameter
/opt/nordic/ncs/v3.0.0/zephyr/drivers/disk/flashdisk.c:572:30: error: declaration for parameter 'flash_disks' but no such parameter
/opt/nordic/ncs/v3.0.0/zephyr/drivers/disk/flashdisk.c:613: error: expected '{' at end of input
/opt/nordic/ncs/v3.0.0/zephyr/drivers/disk/flashdisk.c:613: warning: control reaches end of non-void function [-Wreturn-type]
/opt/nordic/ncs/v3.0.0/zephyr/drivers/disk/flashdisk.c: At top level:
/opt/nordic/ncs/v3.0.0/zephyr/drivers/disk/flashdisk.c:464:37: warning: 'flash_disk_ops' defined but not used [-Wunused-const-variable=]
  464 | static const struct disk_operations flash_disk_ops = {
cc1: some warnings being treated as errors
[168/278] Building C object zephyr/drivers/usb/device/CMakeFiles/drivers__usb__device.dir/usb_dc_nrfx.c.obj
FAILED: _sysbuild/sysbuild/images/mass-prefix/src/mass-stamp/mass-build /opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/build/_sysbuild/sysbuild/images/mass-prefix/src/mass-stamp/mass-build
cd /opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/build/mass && /opt/homebrew/bin/cmake --build .
FATAL ERROR: command exited with status 1: /opt/homebrew/bin/cmake --build /opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/build
The whole sample project folder:
8686.mass.zip
Any and all help is gladly welcome! :)
  • Slight update:
    After a myriad of trial and errors, I got to a state that seems to be WAAAY closer to the desired one:
    4452.mass.zip
    (above is the whole sample project with the added modifications)
    Build command and output:
    west build -b nrf7002dk/nrf5340/cpuapp/ns --pristine -- -DCONFIG_APP_MSC_STORAGE_FLASH_LITTLEFS=y ; west flash
    Merged configuration '/opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/build/_sysbuild/empty.conf'
    -- CMake version: 4.0.3
    warning: DISK_DRIVER_FLASH (defined at drivers/disk/Kconfig.flash:4) was assigned the value 'y' but
    got the value 'n'. Check these unsatisfied dependencies: DT_HAS_ZEPHYR_FLASH_DISK_ENABLED (=n). See
    http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_DISK_DRIVER_FLASH and/or look up
    DISK_DRIVER_FLASH in the menuconfig/guiconfig interface. The Application Development Primer, Setting
    too.
    Merged configuration '/opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/build/mass/zephyr/misc/generated/extra_kconfig_options.conf'
    CMake Warning at /opt/nordic/ncs/v3.0.0/zephyr/CMakeLists.txt:1002 (message):
      No SOURCES given to Zephyr library: drivers__disk
      Excluding target from build.
    -- Configuring done (4.2s)
    -- Generating done (0.2s)
    -- Configuring done (6.7s)
    [1/290] Preparing syscall dependency handling
    [6/290] Generating include/generated/zephyr/version.h
    [7/290] Generating ../../tfm/CMakeCache.txt
    -- Configuring done (0.6s)
    [12/290] Performing build step for 'tfm'
    [19/290] Performing install step for 'tfm'
    [95/290] Building C object CMakeFiles/app.dir/src/main.c.obj
    /opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/src/main.c:33:1: warning: multi-line comment [-Wcomment]
       33 | // #if !defined(CONFIG_DISK_DRIVER_FLASH) && \
    [290/290] Linking C executable zephyr/zephyr.elf
               FLASH:       83992 B       944 KB      8.69%
                 RAM:       17312 B       416 KB      4.06%
            IDT_LIST:          0 GB        32 KB      0.00%
    Generating files from /opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/build/mass/zephyr/zephyr.elf for board: nrf7002dk
    [10/10] Generating ../merged.hex
    -- west flash: rebuilding
    [0/5] Performing build step for 'mass'
    [0/14] Performing build step for 'tfm'
    ninja: no work to do.
    [2/3] Performing install step for 'tfm'
    [3/3] Completed 'tfm'
    [4/5] cd /opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/build/_sysbuild && /opt/homebrew/bin/cmake -E true
    -- west flash: using runner nrfutil
    -- runners.nrfutil: reset after flashing requested
    Using board 001050707950
    -- runners.nrfutil: Flashing file: /opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/build/merged.hex
    -- runners.nrfutil: Erasing address ranges touched by firmware
    -- runners.nrfutil: Programming image
    -- runners.nrfutil: Verifying image
    -- runners.nrfutil: Reset
    -- runners.nrfutil: Board with serial number 1050707950 flashed successfully.
    Board startup log:
    [00:00:00.420,959] <inf> spi_nor: mx25r6435f@0: 8 MiBy flash
    [00:00:00.422,149] <inf> littlefs: littlefs partition at /lfs0
    [00:00:00.422,180] <inf> littlefs: LittleFS version 2.9, disk version 2.1
    [00:00:00.422,363] <inf> littlefs: FS at flash-controller@39000:0xf4000 is 6 0x1000-byte blocks with 512 cycle
    [00:00:00.422,363] <inf> littlefs: partition sizes: rd 16 ; pr 16 ; ca 64 ; la 32
    [00:00:00.422,576] <inf> littlefs: Automount /lfs0 succeeded
    *** Booting nRF Connect SDK v3.0.0-3bfc46578e42 ***
    *** Using Zephyr OS v4.0.99-a0e545cb437a ***
    [00:00:00.422,698] <err> usb_msc: Storage init ERROR !!!! - Aborting USB init
    [00:00:00.422,729] <inf> littlefs: LittleFS version 2.9, disk version 2.1
    [00:00:00.424,194] <inf> littlefs: FS at mx25r6435f@0:0x0 is 2048 0x1000-byte blocks with 512 cycle
    [00:00:00.424,194] <inf> littlefs: partition sizes: rd 16 ; pr 16 ; ca 64 ; la 32
    Mount /lfs: 0
    /lfs: bsize = 16 ; frsize = 4096 ; blocks = 2048 ; bfree = 2046
    /lfs opendir: 0
    End of files
    [00:00:00.477,325] <inf> main: The device is put in USB mass storage mode.
    This makes things more favourable since we have the littlefs filesystem enabled in the main controller and the mx25r6435f configured to have its own filesystem referenced. Ideally, we'd have both the FS and the disk on the mx25r6435f in two partitions (let's say 1MB for the FS and 7MB for the disk), but that's the final step.
    Currently the biggest issue is that the mx25r6435f isn't exposed as a mass storage disk.
    How MacOS sees the board when plugged in:
    tudor@Mac littlefs-fuse % log show --predicate 'eventMessage contains "USB"' --last 10m | grep -i Zephyr
    2025-07-03 09:16:11.852763+0100 0x268a     Default     0x0                  1198   0    icdd: [com.apple.imagecapture:icdd]            [Removed] | [USB][          Zephyr MSC ] ( 0, 0, 0) @ 0x140000 |
    2025-07-03 09:16:11.852805+0100 0x268a     Default     0x0                  1198   0    icdd: [com.apple.imagecapture:icdd]            [Removed] | [USB][          Zephyr MSC ] ( 8, 6,50) @ 0x140000 |
    2025-07-03 09:16:12.659585+0100 0x268a     Default     0x0                  1198   0    icdd: [com.apple.imagecapture:icdd]                Added | 0x100004e4 - [USB][          Zephyr MSC ] ( 0, 0, 0) @ 0x140000 |
    2025-07-03 09:16:12.659799+0100 0x268a     Default     0x0                  1198   0    icdd: [com.apple.imagecapture:icdd]             Inferior | 0x100004e5 - [USB][          Zephyr MSC ] ( 8, 6,50) @ 0x140000 |
    (log with USB connection events)
    tudor@Mac littlefs-fuse % system_profiler SPUSBDataType
    USB:
        USB 3.1 Bus:
          Host Controller Driver: AppleT8132USBXHCI
            USB3.1 Hub:
              Product ID: 0x0626
              Vendor ID: 0x05e3  (Genesys Logic, Inc.)
              Version: 6.63
              Speed: Up to 5 Gb/s
              Manufacturer: GenesysLogic
              Location ID: 0x00200000 / 1
              Current Available (mA): 900
              Current Required (mA): 0
              Extra Operating Current (mA): 0
                AX88179B:
                  Product ID: 0x1790
                  Vendor ID: 0x0b95  (ASIX Electronics Corporation)
                  Version: 2.00
                  Serial Number: 006C1FF71CDB4E
                  Speed: Up to 5 Gb/s
                  Manufacturer: ASIX
                  Location ID: 0x00230000 / 3
                  Current Required (mA): 184
            USB2.1 Hub:
              Product ID: 0x0610
              Version: 6.63
              Speed: Up to 480 Mb/s
              Location ID: 0x00100000 / 2
              Current Available (mA): 500
              Current Required (mA): 100
                Zephyr MSC:
                  Product ID: 0x0008
                  Vendor ID: 0x2fe3
                  Version: 4.00
                  Serial Number: 21DE3ED9722C5446
                  Speed: Up to 12 Mb/s
                  Manufacturer: ZEPHYR
                  Location ID: 0x00140000 / 5
                J-Link:
                  Product ID: 0x1061
                  Vendor ID: 0x1366
                  Version: 1.00
                  Serial Number: 001050707950
                  Manufacturer: SEGGER
                  Location ID: 0x00110000 / 4
                  Current Required (mA): 500
                  Media:
                    MSD Volume:
                      Capacity: 11.2 MB (11,176,448 bytes)
                      Removable Media: Yes
                      BSD Name: disk5
                      Logical Unit: 0
                      Partition Map Type: Unknown
                      S.M.A.R.T. status: Verified
                      USB Interface: 5
        USB 3.1 Bus:
    (detailed information about connected USB peripherals)
    But in the high level OS, we see nothing:
    Trying it on Windows, presents the volume, but it has no size (0 bytes used, 0 bytes free).
    Edit:
    I know that I need to enable this chunk of code:
    // &msc_disk0 {
    //     compatible = "zephyr,flash-disk";
    //     partition = <&storage_partition>;
    //     disk-name = "STORAGE";
    //     cache-size = <4096>;
    //     // sector-size = <512>;
    But the moment I do that, the build breaks:
    tudor@Mac mass % west build -b nrf7002dk/nrf5340/cpuapp/ns --pristine -- -DCONFIG_APP_MSC_STORAGE_FLASH_LITTLEFS=y
    -- Configuring done (4.1s)
    -- Generating done (0.3s)
    -- Configuring done (6.3s)
    [1/294] Preparing syscall dependency handling
    [8/294] Generating include/generated/zephyr/version.h
    [9/294] Generating ../../tfm/CMakeCache.txt
    [14/294] Performing build step for 'tfm'
    [21/294] Performing install step for 'tfm'
    [119/294] Building C object CMakeFiles/app.dir/src/main.c.obj
    /opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/src/main.c:34:1: warning: multi-line comment [-Wcomment]
       34 | // #if !defined(CONFIG_DISK_DRIVER_FLASH) && \
    [181/294] Building C object zephyr/drivers/disk/CMakeFiles/drivers__disk.dir/flashdisk.c.obj
    ccache /Users/tudor/zephyr-sdk-0.17.0/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc -DKERNEL -DK_HEAP_MEM_POOL_SIZE=0 -DMBEDTLS_CONFIG_FILE=\"nrf-config.h\" -DMBEDTLS_PSA_CRYPTO_CONFIG_FILE=\"nrf-psa-crypto-config.h\" -DNRF5340_XXAA_APPLICATION -DNRF_SKIP_FICR_NS_COPY_TO_RAM -DNRF_TRUSTZONE_NONSECURE -DPICOLIBC_LONG_LONG_PRINTF_SCANF -DUSE_PARTITION_MANAGER=1 -D__LINUX_ERRNO_EXTENSIONS__ -D__PROGRAM_START -D__ZEPHYR_SUPERVISOR__ -D__ZEPHYR__=1 -I/opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/build/mass/zephyr/include/generated/zephyr -I/opt/nordic/ncs/v3.0.0/zephyr/include -I/opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/build/mass/zephyr/include/generated -I/opt/nordic/ncs/v3.0.0/zephyr/soc/nordic -I/opt/nordic/ncs/v3.0.0/zephyr/soc/nordic/nrf53/. -I/opt/nordic/ncs/v3.0.0/zephyr/soc/nordic/common/. -I/opt/nordic/ncs/v3.0.0/zephyr/subsys/usb/device -I/opt/nordic/ncs/v3.0.0/zephyr/subsys/settings/include -I/opt/nordic/ncs/v3.0.0/zephyr/drivers/usb/common/nrf_usbd_common/. -I/opt/nordic/ncs/v3.0.0/nrf/include -I/opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/build/mass/tfm/api_ns/interface/include -I/opt/nordic/ncs/v3.0.0/nrf/subsys/settings/include -I/opt/nordic/ncs/v3.0.0/nrf/modules/trusted-firmware-m/. -I/opt/nordic/ncs/v3.0.0/nrf/include/tfm -I/opt/nordic/ncs/v3.0.0/nrf/tests/include -I/opt/nordic/ncs/v3.0.0/modules/hal/cmsis/CMSIS/Core/Include -I/opt/nordic/ncs/v3.0.0/zephyr/modules/cmsis/. -I/opt/nordic/ncs/v3.0.0/nrf/modules/hal_nordic/. -I/opt/nordic/ncs/v3.0.0/modules/hal/nordic/nrfx -I/opt/nordic/ncs/v3.0.0/modules/hal/nordic/nrfx/drivers/include -I/opt/nordic/ncs/v3.0.0/modules/hal/nordic/nrfx/mdk -I/opt/nordic/ncs/v3.0.0/zephyr/modules/hal_nordic/nrfx/. -I/opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/build/mass/input_files -I/opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/build/mass -I/opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/build/mass/generated/interface_nrf_security_psa -I/opt/nordic/ncs/v3.0.0/nrf/subsys/nrf_security/include -I/opt/nordic/ncs/v3.0.0/modules/crypto/oberon-psa-crypto/include -I/opt/nordic/ncs/v3.0.0/nrf/subsys/nrf_security/src/utils -I/opt/nordic/ncs/v3.0.0/modules/crypto/oberon-psa-crypto/library -I/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library -I/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/include -I/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/include/library -I/opt/nordic/ncs/v3.0.0/nrfxlib/crypto/nrf_oberon/include -I/opt/nordic/ncs/v3.0.0/nrfxlib/crypto/nrf_oberon/include/mbedtls -isystem /opt/nordic/ncs/v3.0.0/zephyr/lib/libc/common/include -Wshadow -fno-strict-aliasing -Os -imacros /opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass/build/mass/zephyr/include/generated/zephyr/autoconf.h -fno-printf-return-value -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m33 -mthumb -mabi=aapcs -mfp16-format=ieee -mtp=soft --sysroot=/Users/tudor/zephyr-sdk-0.17.0/arm-zephyr-eabi/arm-zephyr-eabi -imacros /opt/nordic/ncs/v3.0.0/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wdouble-promotion -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-pic -fno-pie -fno-asynchronous-unwind-tables -ftls-model=local-exec -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=/opt/nordic/ncs/v3.0.0/zephyr/samples/subsys/usb/mass=CMAKE_SOURCE_DIR -fmacro-prefix-map=/opt/nordic/ncs/v3.0.0/zephyr=ZEPHYR_BASE -fmacro-prefix-map=/opt/nordic/ncs/v3.0.0=WEST_TOPDIR -ffunction-sections -fdata-sections -specs=picolibc.specs -std=c99 -MD -MT zephyr/drivers/disk/CMakeFiles/drivers__disk.dir/flashdisk.c.obj -MF zephyr/drivers/disk/CMakeFiles/drivers__disk.dir/flashdisk.c.obj.d -o zephyr/drivers/disk/CMakeFiles/drivers__disk.dir/flashdisk.c.obj -c /opt/nordic/ncs/v3.0.0/zephyr/drivers/disk/flashdisk.c
    /opt/nordic/ncs/v3.0.0/zephyr/drivers/disk/flashdisk.c:613:1: note: in expansion of macro 'SYS_INIT'
      613 | SYS_INIT(disk_flash_init, POST_KERNEL, CONFIG_KERNEL_INIT_PRIORITY_DEFAULT);
    /opt/nordic/ncs/v3.0.0/zephyr/drivers/disk/flashdisk.c:613:10: error: 'disk_flash_init' undeclared (first use in this function)
    /opt/nordic/ncs/v3.0.0/zephyr/drivers/disk/flashdisk.c:614: error: expected '{' at end of input
    /opt/nordic/ncs/v3.0.0/zephyr/drivers/disk/flashdisk.c:614: warning: control reaches end of non-void function [-Wreturn-type]
    [192/294] Building C object zephyr/drivers/usb/device/CMakeFiles/drivers__usb__device.dir/usb_dc_nrfx.c.obj
  • I got it partially working:
    So the storage is presented as an USB Mass Storage device and has ~ the correct size: 8.4MB.
    Current state of project here:
    5582.mass.zip
    The key changes that enabled things:
    I added a "pm_static.yml" file to the root folder of the sample (in the "mass") directory. Contents of pm_static.yml:
    storage_partition:
      address: 0x0
      end_address: 0x800000
      region: external_flash
      affiliation: disk
      extra_params:
        disk_name: "ZEPHYR"
        disk_cache_size: 4096
        disk_sector_size: 512
        disk_read_only: 0
      placement:
        before:
          - end
    Note: it's EXTREMELY important to name the file EXACTLY "pm_static.yml". I've spent around a day wondering why the Partition Manager wasn't detecting my file. The reason was that I copied a file named "partitions.yaml" from the /build directory and started editing it and somehow when I changed its name, it was "pm_static.yml " (an extra space at the end).
    Other notable changes were:
    - the overlay exposes the same disk name as pm_static.yml:
    	msc_disk0 {
    		disk-name = "ZEPHYR";
    - I'm not sure if this truly matters or not, but the board's *.conf file also has the same name:
    CONFIG_MASS_STORAGE_DISK_NAME="ZEPHYR"
    Edit: forgot to add: things aren't completely solved since this volume is not formattable or usable in any way. The board's boot logs show that the file system is now somehow linked back to internal flash:
    [00:00:00.269,561] <inf> spi_nor: mx25r6435f@0: 8 MiBy flash
    [00:00:00.271,942] <inf> flashdisk: Initialize device ZEPHYR
    [00:00:00.271,942] <inf> flashdisk: offset 0, sector size 512, page size 4096, volume size 8388608
    Area 8 at 0xfc000 on flash-controller@39000 for 8192 bytes
    [00:00:00.275,573] <inf> littlefs: LittleFS version 2.9, disk version 2.1
    [00:00:00.275,756] <inf> littlefs: FS at flash-controller@39000:0xfc000 is 2 0x1000-byte blocks with 512 cycle
    [00:00:00.275,756] <inf> littlefs: partition sizes: rd 16 ; pr 16 ; ca 64 ; la 32
    Mount /lfs: 0
    /lfs: bsize = 16 ; frsize = 4096 ; blocks = 2 ; bfree = 0
    Files before write:
    /lfs opendir: 0
      F 9 test.txt
    End of files
    Read from file: 'hello1234'
    [00:00:00.329,681] <inf> main: The device is put in USB mass storage mode.
    Also, based on my understanding, LittleFS can run both a FS and the USB Mass Storage simultaneously, right? If that's so, would they coexist on the same partition or do they require separate partitions? Thinking
  • Hello Elfving,
    Are you still on the case? You haven't said anything in 14 days...
  • Hi Tudor, and I am deeply sorry about the delay on this case.
    First of all, in order to build the mass sample for the nRF7002DK you have to make some changes to the dts. This can be done by adding eg. this to an nrf7002dk_nrf5340_cpuapp.overlay file.
    /delete-node/ &storage_partition;
    &mx25r64 {
    	partitions {
    		#address-cells = <1>;
    		#size-cells = <1>;
    		storage_partition: partition@0 {
    			label = "storage";
    			reg = <0x00000000 0x00020000>;
    	msc_disk0 {
    		disk-name = "NAND";
    And remember not to build with sysbuild, which I believe is the default option with NCS>=3 (ie. implied when you select default instead of sysbuild), as this zephyr sample wasn't made with multi-core in mind.
    Tudor B. said:
    Finished trying it; didn't work.
    I believe that was what you were lacking in your first comment here, though I'm not sure.
    Tudor B. said:
    I found the "LittleFS Example" section and that is exactly what we want since we'd like the LittleFS file system also. Although I don't have an nrf52840dk on hand, I decided to build for it since it had an *.overlay already set up in the sample folder, so it should work.
    I got the impression that littleFS wouldn't be recognized by Windows and Mac, and that is the end goal right? So I guess FATfs is better. I guess that is what you've figured out here, though I am surprised to see that you did get it to work with. I would rather recommend FATfs, and there is configs for that here. Though if you've gotten littleFS working I guess that is fine.
    I am not sure, though do you have a use-case for you needing both here?
    Elfving
  • Currently our architect and CEO are pushing for LittleFS for both File System and USB Mass Storage since it's more reliable and has error correction (theoretically). There's something called LittleFS FUSE that helps OSes recognise disks that have the LittleFS File System. I've played with it a bit but at this point I'm not sure if LFS FUSE ain't working correctly or if my config of the sample project is erroneous so LFS FUSE won't read the disk correctly.
    That aside, if you have a proposal that combats LFS for both FS and USB Mass Storage, then I can present your argument to my superiors and maybe we can switch to something that's much easier to set up and just as good. WinkGrin
